libfci_cli commands description document for SDK BSP41 pfeng v1.7.0
hittzt
Senior Contributor I
Recently, I tested pfe feature based on SDK BSP41, and I found that the pfe driver updated its codes to v1.7.0 and the log_if is not used as previous, but I can not find the related fci commands description.
So would you please help to tell  where can get the files or documents?
Zhantao
Daniel-Aguirre
Can you let us know which S32G variant you are using?
Please, let us know.
hittzt
I used RDB3 v1.1 SOC for test, and I followed the doc: "PFE_S32G_A53_LNX_UserManual.pdf", which is from the previous pfe branch, like v1.4.0, but now these .pdf files are all removed from the v1.7.0 branch.
Zhantao
Daniel-Aguirre
Seems to be that this community thread and the following might contain the same information:
Re: pfe slave test steps based on BSP41 - NXP Community
Is there a problem if we continue in the above community thread? Or would you like for us to mirror the information to this thread?
