how to implementation AVB/TSN with goldBox3
1,546件の閲覧回数
ehxhflskfk
I'm currently trying to implement TSN and AVB with Gold-Box3 I'm still a beginner, so I don't know how to implement this. I'm curious about how to install hardware and software and connectors to use,  Thank you so much for giving me a solution from start to finish
what use program tool, use example, use cood.... etc...
we need solution ㅠㅠ
thank you!!!
1,485件の閲覧回数
Miguel04
Hi @ehxhflskfk
AVB/TSN both seems to be supported under the SJA1110 and AVB is also supported under S32G, unfortunately, there is not much information or examples available on our side, I recommend you to contact your DFAE or NXP representative, since a lot of the information regarding SJA1110 is available under NDA (For SJA1110), they might be able to provide you more documentation for your inquiry.
I apologize for the inconvenience.
Best Regards, Miguel.
