how to create sja1110_uc.bin and sja1110_switch.bin from S32DS?
2,878 次查看
Simon666
I want to use SPI to download sja1110 firmware with different config and code base,
how to create a new image for sja1110 not only use GOLDVIP image?
thanks
标记 (1)
2,842 次查看
Bio_TICFSL
Hello Simon666,
You need to download the SJA1110-EVM Configuration Tools from: https://www.nxp.com/products/interfaces/ethernet-/automotive-ethernet-switches/sja1110-evm-evaluatio...
Is not only for goldvip image you can apply to your desing
https://www.nxp.com/document/guide/get-started-with-the-sja1110-evm:GS-SJA1110-EVM
4 回复数
2,843 次查看
Bio_TICFSL
Hello Simon666,
2,840 次查看
Simon666
I already download the SJA1110-EVM patch, but only get flash.bin, no other bin files, where is uc.bin and switch.bin?
2,539 次查看
Ethan_L
hi @Simon666 ,
Do you know how to create sja1110_switch.bin and sja1110_uc.bin, I have the same problem about this.
Thanks, Ethan.
2,047 次查看
Gerry15
Hey,
take a look at the following git repository of nxp.
If you want use the Linux BSP of NXP, it is possible to add the "sja1110" layer similar to the "pfe" layer, which will download the mentioned files from the git repo. Take a look at building the Linux BSP!
Greetings
