fsl_image_networking_full
yangjinzhuang
       what are the differences between follow images(auto/ network/networking_full):
           Targets specific to NXP:
fsl-image-mfgtool-initramfs
fsl-image-itb
fsl-image-blueboxdt
fsl-image-auto
fsl-image-bluebox
fsl-image-networking
fsl-image-dom0less
 fsl-image-flash
 fsl-image-blueboxsdfactory
fsl-image-base
 fsl-image-blueboxbootflash
 fsl-image-ubuntu-base
fsl-image-ubuntu-ros
fsl-image-fit
fsl-image-base-fit
 fsl-image-itbflash
fsl-image-networking-full
 fsl-image-ubuntu
fsl-image-sim
I want to build LINUX BSP myself with all Ethernet functions, GMAC and PFE include,  which type of image is right?
yangjinzhuang
Hello Chen,
         Thanks for your reply.
         Does the Auto target include PFE firmware? If I bitbake auto myself, do I need to manually download and load the PFE firmware? Is there a guide document on how to load the PFE firmware? I don't find it in the Linux_BSP UM.
         Thanks!
chenyin_h
Hello, @yangjinzhuang
Thanks for the reply, you may reference the replies from the other thread you created, it is detailed described.
Best Regards
Chenyin
chenyin_h
Thanks for the question.
From the BSP UM, the default target is fsl-image-auto, which is commonly used. Additionally, fsl-image-flash is the flashimage target; fsl-image-ubuntu, fsl-image-ubuntu-base and fsl-image-ubuntu-ros are the ubuntu target image, the ros one additionally includes the ROS packages, fsl-image-base is similar to the fsl-image-auto, but with few packages included.
You may not need to care about the others since they are not mentioned in the manual. For example, fsl-image-bluebox… is for bluebox, which is a special mixed board that is not similar to common reference boards like RDB2/RDB3.
For your requirments, fsl-image-auto could be correct for use.
Hope it helps.
Best Regards
Chenyin
yangjinzhuang
Hello Chen,
         Thanks!
%3CLINGO-SUB%20id%3D%22lingo-sub-1892730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efsl_image_networking_full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bwhat%20are%20the%20differences%20between%20follow%20images(auto%2F%20network%2Fnetworking_full)%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20Targets%20specific%20to%20NXP%3A%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-mfgtool-initramfs%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-itb%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-blueboxdt%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-auto%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-bluebox%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-networking%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-dom0less%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bfsl-image-flash%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bfsl-image-blueboxsdfactory%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-base%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bfsl-image-blueboxbootflash%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bfsl-image-ubuntu-base%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-ubuntu-ros%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-fit%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-base-fit%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bfsl-image-itbflash%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-networking-full%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3Bfsl-image-ubuntu%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3Efsl-image-sim%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20want%20to%20build%20LINUX%20BSP%20myself%20with%20all%20Ethernet%20functions%2C%20GMAC%20and%20PFE%20include%2C%26nbsp%3B%20which%20type%20of%20image%20is%20right%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20fsl_image_networking_full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210110%22%20target%3D%22_blank%22%3E%40yangjinzhuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20reply%2C%20you%20may%20reference%20the%20replies%20from%20the%20other%20thread%20you%20created%2C%20it%20is%20detailed%20described.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20fsl_image_networking_full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Chen%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BThanks%20for%20your%20reply.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BDoes%20the%20Auto%20target%20include%20PFE%20firmware%3F%20If%20I%20bitbake%20auto%20myself%2C%20do%20I%20need%20to%20manually%20download%20and%20load%20the%20PFE%20firmware%3F%20Is%20there%20a%20guide%20document%20on%20how%20to%20load%20the%20PFE%20firmware%3F%20I%20don't%20find%20it%20in%20the%20Linux_BSP%20UM.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BThanks!%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1893294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20fsl_image_networking_full%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1893294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F210110%22%20target%3D%22_blank%22%3E%40yangjinzhuang%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20question.%3C%2FP%3E%0A%3CP%3EFrom%20the%20BSP%20UM%2C%20the%20default%20target%20is%20fsl-image-auto%2C%20which%20is%20commonly%20used.%20Additionally%2C%20fsl-image-flash%20is%20the%20flashimage%20target%3B%20fsl-image-ubuntu%2C%20fsl-image-ubuntu-base%20and%20fsl-image-ubuntu-ros%20are%20the%20ubuntu%20target%20image%2C%20the%20ros%20one%20additionally%20includes%20the%20ROS%20packages%2C%20fsl-image-base%20is%20similar%20to%20the%20fsl-image-auto%2C%20but%20with%20few%20packages%20included.%3C%2FP%3E%0A%3CP%3EYou%20may%20not%20need%20to%20care%20about%20the%20others%20since%20they%20are%20not%20mentioned%20in%20the%20manual.%20For%20example%2C%20fsl-image-bluebox%E2%80%A6%20is%20for%20bluebox%2C%20which%20is%20a%20special%20mixed%20board%20that%20is%20not%20similar%20to%20common%20reference%20boards%20like%20RDB2%2FRDB3.%3C%2FP%3E%0A%3CP%3EFor%20your%20requirments%2C%20fsl-image-auto%20could%20be%20correct%20for%20use.%3C%2FP%3E%0A%3CP%3EHope%20it%20helps.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
