emmc dump caused by CQHCI
7,338件の閲覧回数
yan4
Hi NXP Teams
Recently we face a problem casued by CQHCI feature.
kernel version: 6.1.68
platform: S32G3
emmc model: FEMDME008G-A8A39
We used sysbench to perform pressure test on emmc and emmc keeped outputting dump information.
dump messages are below:
[ 232.419161] mmc0: cqhci: timeout for tag 4, qcnt 25
[ 232.423677] mmc0: cqhci: ============ CQHCI REGISTER DUMP ===========
[ 232.430083] mmc0: cqhci: Caps: 0x0000310a | Version: 0x00000510
[ 232.436501] mmc0: cqhci: Config: 0x00001001 | Control: 0x00000000
[ 232.442924] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006
[ 232.449346] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000
[ 232.455799] mmc0: cqhci: TDL base: 0x823c3000 | TDL up32: 0x00000000
[ 232.462202] mmc0: cqhci: Doorbell: 0x81dfffff | TCN: 0x00000000
[ 232.468619] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00800000
[ 232.475067] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000
[ 232.481469] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000900
[ 232.487896] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000
[ 232.494330] mmc0: cqhci: Resp idx: 0x0000000d | Resp arg: 0x00000000
[ 232.500739] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 232.507158] mmc0: sdhci: Sys addr: 0x9ca3e000 | Version: 0x00000002
[ 232.513578] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000020
[ 232.520001] mmc0: sdhci: Argument: 0x00018000 | Trn mode: 0x00000023
[ 232.526424] mmc0: sdhci: Present: 0x01fd8008 | Host ctl: 0x00000030
[ 232.532847] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 232.539279] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x0000000f
[ 232.545694] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 232.552126] mmc0: sdhci: Int enab: 0x107f4000 | Sig enab: 0x107f4000
[ 232.558568] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 232.564973] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b407
[ 232.571391] mmc0: sdhci: Cmd: 0x00000d1a | Max curr: 0x00ffffff
[ 232.577837] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0xffffffff
[ 232.584242] mmc0: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d0ffff
[ 232.590660] mmc0: sdhci: Host ctl2: 0x00000008
[ 232.595104] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xad464408
[ 232.601514] mmc0: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 232.609066] mmc0: sdhci-esdhc-imx: cmd debug status: 0x2120
[ 232.614702] mmc0: sdhci-esdhc-imx: data debug status: 0x2200
[ 232.620431] mmc0: sdhci-esdhc-imx: trans debug status: 0x2300
[ 232.626246] mmc0: sdhci-esdhc-imx: dma debug status: 0x2400
[ 232.631888] mmc0: sdhci-esdhc-imx: adma debug status: 0x2510
[ 232.637616] mmc0: sdhci-esdhc-imx: fifo debug status: 0x2680
[ 232.643345] mmc0: sdhci-esdhc-imx: async fifo debug status: 0x2750
[ 232.649595] mmc0: sdhci: ============================================
[ 232.656073] mmc0: running CQE recovery
[ 289.818104] mmc0: running CQE recovery
[ 423.303076] mmc0: cqhci: timeout for tag 31, qcnt 27
[ 423.307677] mmc0: cqhci: ============ CQHCI REGISTER DUMP ===========
[ 423.314085] mmc0: cqhci: Caps: 0x0000310a | Version: 0x00000510
[ 423.320504] mmc0: cqhci: Config: 0x00001001 | Control: 0x00000000
[ 423.326927] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006
[ 423.333381] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000
[ 423.339786] mmc0: cqhci: TDL base: 0x823c3000 | TDL up32: 0x00000000
[ 423.346379] mmc0: cqhci: Doorbell: 0xff1fcfff | TCN: 0x00000000
[ 423.352628] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00000400
[ 423.359047] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000
[ 423.365465] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000900
[ 423.371888] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000
[ 423.378309] mmc0: cqhci: Resp idx: 0x0000000d | Resp arg: 0x00000000
[ 423.384736] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 423.391160] mmc0: sdhci: Sys addr: 0xa5b7b000 | Version: 0x00000002
[ 423.397583] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000020
[ 423.404005] mmc0: sdhci: Argument: 0x00018000 | Trn mode: 0x00000023
[ 423.410426] mmc0: sdhci: Present: 0x01fd8008 | Host ctl: 0x00000030
[ 423.416849] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 423.423280] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x0000000f
[ 423.429696] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 423.436119] mmc0: sdhci: Int enab: 0x107f4000 | Sig enab: 0x107f4000
[ 423.442568] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 423.449210] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b407
[ 423.455401] mmc0: sdhci: Cmd: 0x00000d1a | Max curr: 0x00ffffff
[ 423.461812] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0xffffffff
[ 423.468236] mmc0: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d0ffff
[ 423.474657] mmc0: sdhci: Host ctl2: 0x00000008
[ 423.479083] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xad467408
[ 423.485508] mmc0: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 423.493061] mmc0: sdhci-esdhc-imx: cmd debug status: 0x2120
[ 423.498701] mmc0: sdhci-esdhc-imx: data debug status: 0x2200
[ 423.504429] mmc0: sdhci-esdhc-imx: trans debug status: 0x2300
[ 423.510245] mmc0: sdhci-esdhc-imx: dma debug status: 0x2400
[ 423.515887] mmc0: sdhci-esdhc-imx: adma debug status: 0x2510
[ 423.521615] mmc0: sdhci-esdhc-imx: fifo debug status: 0x2680
[ 423.527344] mmc0: sdhci-esdhc-imx: async fifo debug status: 0x2750
[ 423.533593] mmc0: sdhci: ============================================
[ 423.540075] mmc0: running CQE recovery
[ 501.799092] mmc0: cqhci: timeout for tag 31, qcnt 24
[ 501.803698] mmc0: cqhci: ============ CQHCI REGISTER DUMP ===========
[ 501.810106] mmc0: cqhci: Caps: 0x0000310a | Version: 0x00000510
[ 501.816528] mmc0: cqhci: Config: 0x00001001 | Control: 0x00000000
[ 501.822948] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006
[ 501.829398] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000
[ 501.835801] mmc0: cqhci: TDL base: 0x823c3000 | TDL up32: 0x00000000
[ 501.842221] mmc0: cqhci: Doorbell: 0xe01fffff | TCN: 0x00000000
[ 501.848666] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00008000
[ 501.855070] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000
[ 501.861533] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000900
[ 501.867916] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000
[ 501.874333] mmc0: cqhci: Resp idx: 0x0000000d | Resp arg: 0x00000000
[ 501.880756] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 501.887180] mmc0: sdhci: Sys addr: 0xa5a15000 | Version: 0x00000002
[ 501.893600] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000020
[ 501.900029] mmc0: sdhci: Argument: 0x00018000 | Trn mode: 0x00000023
[ 501.906450] mmc0: sdhci: Present: 0x01fd8008 | Host ctl: 0x00000030
[ 501.912875] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 501.919301] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x0000000f
[ 501.925717] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 501.932139] mmc0: sdhci: Int enab: 0x107f4000 | Sig enab: 0x107f4000
[ 501.938564] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 501.944994] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b407
[ 501.951435] mmc0: sdhci: Cmd: 0x00000d1a | Max curr: 0x00ffffff
[ 501.957841] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0xffffffff
[ 501.964284] mmc0: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d0ffff
[ 501.970686] mmc0: sdhci: Host ctl2: 0x00000008
[ 501.975106] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xad463808
[ 501.981529] mmc0: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 501.989083] mmc0: sdhci-esdhc-imx: cmd debug status: 0x2120
[ 501.994728] mmc0: sdhci-esdhc-imx: data debug status: 0x2200
[ 502.000451] mmc0: sdhci-esdhc-imx: trans debug status: 0x2300
[ 502.006266] mmc0: sdhci-esdhc-imx: dma debug status: 0x2400
[ 502.011909] mmc0: sdhci-esdhc-imx: adma debug status: 0x2510
[ 502.017636] mmc0: sdhci-esdhc-imx: fifo debug status: 0x2680
[ 502.023365] mmc0: sdhci-esdhc-imx: async fifo debug status: 0x2750
[ 502.029650] mmc0: sdhci: ============================================
[ 502.036090] mmc0: running CQE recovery
[ 607.207068] mmc0: cqhci: timeout for tag 31, qcnt 21
[ 607.211666] mmc0: cqhci: ============ CQHCI REGISTER DUMP ===========
[ 607.218083] mmc0: cqhci: Caps: 0x0000310a | Version: 0x00000510
[ 607.224498] mmc0: cqhci: Config: 0x00001001 | Control: 0x00000000
[ 607.230915] mmc0: cqhci: Int stat: 0x00000000 | Int enab: 0x00000006
[ 607.237344] mmc0: cqhci: Int sig: 0x00000006 | Int Coal: 0x00000000
[ 607.243803] mmc0: cqhci: TDL base: 0x823c3000 | TDL up32: 0x00000000
[ 607.250194] mmc0: cqhci: Doorbell: 0x83ffc1fe | TCN: 0x00000000
[ 607.256635] mmc0: cqhci: Dev queue: 0x00000000 | Dev Pend: 0x00000001
[ 607.263039] mmc0: cqhci: Task clr: 0x00000000 | SSC1: 0x00011000
[ 607.269485] mmc0: cqhci: SSC2: 0x00000001 | DCMD rsp: 0x00000900
[ 607.275915] mmc0: cqhci: RED mask: 0xfdf9a080 | TERRI: 0x00000000
[ 607.282328] mmc0: cqhci: Resp idx: 0x0000000d | Resp arg: 0x00000000
[ 607.288731] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 607.295180] mmc0: sdhci: Sys addr: 0x9cefe000 | Version: 0x00000002
[ 607.301577] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000020
[ 607.308021] mmc0: sdhci: Argument: 0x00018000 | Trn mode: 0x00000023
[ 607.314425] mmc0: sdhci: Present: 0x01fd8008 | Host ctl: 0x00000030
[ 607.320843] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 607.327263] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x0000000f
[ 607.333725] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 607.340117] mmc0: sdhci: Int enab: 0x107f4000 | Sig enab: 0x107f4000
[ 607.346575] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 607.352962] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b407
[ 607.359405] mmc0: sdhci: Cmd: 0x00000d1a | Max curr: 0x00ffffff
[ 607.365818] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0xffffffff
[ 607.372254] mmc0: sdhci: Resp[2]: 0x329f5903 | Resp[3]: 0x00d0ffff
[ 607.378692] mmc0: sdhci: Host ctl2: 0x00000008
[ 607.383103] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xad463408
[ 607.389505] mmc0: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 607.397083] mmc0: sdhci-esdhc-imx: cmd debug status: 0x2120
[ 607.402704] mmc0: sdhci-esdhc-imx: data debug status: 0x2200
[ 607.408454] mmc0: sdhci-esdhc-imx: trans debug status: 0x2300
[ 607.414245] mmc0: sdhci-esdhc-imx: dma debug status: 0x2400
[ 607.419880] mmc0: sdhci-esdhc-imx: adma debug status: 0x2510
[ 607.425607] mmc0: sdhci-esdhc-imx: fifo debug status: 0x2680
[ 607.431335] mmc0: sdhci-esdhc-imx: async fifo debug status: 0x2750
[ 607.437586] mmc0: sdhci: ============================================
[ 607.444076] mmc0: running CQE recovery
We noticed that all dumps occurred when CMD13 was sent and then emmc responsed timeout. We tried to use debugfs to find out reason and we noticed that only on the occasion that we execute “cat /sys/kernel/debug/mmc0/mmc0\:0001/status” to send a CMD13 to emmc which takes about 10 seconds to return and display result while in other cases we excute other command such as "cat /sys/kernel/debug/mmc0/mmc0\:0001/state" which returns immediatly.
Afterall, we closed CQHCI and solved the problem. It seems that CQHCI doesn't work well on emmc produced by specific manufacture. We would like to see new progress on  this issue.
Yan
タグ(3)
7,078件の閲覧回数
jun13_chen
8 返答(返信)
7,062件の閲覧回数
chenyin_h
Hello, @yan4
I did not reproduce the issue on local RDB, but once met such issues on other NXP platforms. I suggest disabling the CQHCI temporally.
Thanks for @jun13_chen's inputs, may close the feature with the patch mentioned.
Chenyin
7,262件の閲覧回数
chenyin_h
Hello, @yan4
Thanks a lot for your valuable post, I could understand the status, and would check if it existed on refernece boards.
Chenyin
7,099件の閲覧回数
yan4
Hello,chenyin_h
Have you confirmed whether this problem exits on board  previously mentioned or not? If you need some extra information, I would be glad to provide.
Best Regards
Yan
7,309件の閲覧回数
chenyin_h
Hello, @yan4
Thanks for your post.
I noticed that the 6.1.68 kernel is used during your test, which seems not a formally supported version from BSP perspective.
May I know if you also met the issue while using the BSP(, for example, BSP41 with 5.15.x or 6.6.x kenel)?
Chenyin
7,274件の閲覧回数
yan4
Hello, chenyin
I need to explain that the kernel I use is customized so it doesn't match the formally supported version of BSP38 which is supposed to be V5.15. However, there is a similar problem in community, link:https://community.nxp.com/t5/i-MX-Processors/The-issues-on-quot-mmc0-cqhci-timeout-for-tag-0-quot/m-....
They encountered the same issue on the I.MX platform, and their BSP version and kernel version are officially supported. So I won't suppose that this issue is caused by a mismatched kernel version. By the way, I noticed that CQHCI seems to be an unstable feature , occasionally disabled and then enabled in linux main branch, but [email protected] enabled it in 2022. Perhaps we should reassess the necessity of introducing this feature or fix the bugs within it.
Best Regards
Yan
7,306件の閲覧回数
yan4
Yes, BSP38 with 6.1.168 kernel was used in my test.
7,079件の閲覧回数
jun13_chen
タグ(1)
7,054件の閲覧回数
yan4
Hello,jun13_chen
This patch can indeed solve the problem. Thanks a lot.
%3CLINGO-SUB%20id%3D%22lingo-sub-1961706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECQHCI%20%E3%81%AB%E3%82%88%E3%82%8B%20emmc%20%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFNXP%E3%83%81%E3%83%BC%E3%83%A0%3C%2FP%3E%3CP%3E%E6%9C%80%E8%BF%91%E3%80%81CQHCI%E6%A9%9F%E8%83%BD%E3%81%AB%E8%B5%B7%E5%9B%A0%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ekernel%20version%3A%206.1.68%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3AS32G3%3C%2FP%3E%3CP%3EeMMC%E3%83%A2%E3%83%87%E3%83%AB%3AFEMDME008G-A8A39%3C%2FP%3E%3CP%3Esysbench%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6emmc%E3%81%AE%E5%9C%A7%E5%8A%9B%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81emmc%E3%81%AF%E3%83%80%E3%83%B3%E3%83%97%E6%83%85%E5%A0%B1%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%80%E3%83%B3%E3%83%97%E3%83%BB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%5B%20232.419161%5D%20mmc0%3A%20CQHCI%3A%20%E3%82%BF%E3%82%B0%204%E3%80%81QCNT%2025%20%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3CBR%20%2F%3E%5B%20232.423677%5D%20MMC0%3A%20CQHCI%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20CQHCI%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20232.430083%5D%20mmc0%3A%20cqhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x0000310a%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000510%3CBR%20%2F%3E%5B%20232.436501%5D%20mmc0%3Acqhci%3A%E8%A8%AD%E5%AE%9A%3A0x00001001%20%7C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%3A0x00000000%3CBR%20%2F%3E%5B%20232.442924%5D%20mmc0%3A%20cqhci%3A%20Int%20%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E5%9B%BD%E9%9A%9B%20enab%3A%200x00000006%3CBR%20%2F%3E%5B%20232.449346%5D%20mmc0%3A%20cqhci%3A%20Int%20sig%3A%200x00000006%20%7CInt%20Coal%3A%200x00000000%3CBR%20%2F%3E%5B%20232.455799%5D%20mmc0%3A%20cqhci%3A%20TDL%20%E3%83%99%E3%83%BC%E3%82%B9%3A%200x823c3000%20%7CTDL%20up32%3A0x00000000%3CBR%20%2F%3E%5B%20232.462202%5D%20mmc0%3A%20cqhci%3A%20%E3%83%89%E3%82%A2%E3%83%99%E3%83%AB%3A%200x81dfffff%20%7CTCN%3A0x00000000%3CBR%20%2F%3E%5B%20232.468619%5D%20mmc0%3A%20cqhci%3A%20%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%A5%E3%83%BC%3A%200x00000000%20%7C%E9%96%8B%E7%99%BA%E3%83%9A%E3%83%B3%E3%83%89%3A0x00800000%3CBR%20%2F%3E%5B%20232.475067%5D%20mmc0%3A%20cqhci%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20clr%3A%200x00000000%20%7CSSC1%3A0x00011000%3CBR%20%2F%3E%5B%20232.481469%5D%20mmc0%3A%20cqhci%3A%20SSC2%3A%200x00000001%20%7CDCMD%20RSP%20%3A%200x00000900%3CBR%20%2F%3E%5B%20232.487896%5D%20mmc0%3Acqhci%3ARED%E3%83%9E%E3%82%B9%E3%82%AF%3A0xfdf9a080%20%7C%E3%83%86%E3%83%AA%E3%83%BC%3A0x00000000%3CBR%20%2F%3E%5B%20232.494330%5D%20mmc0%3A%20cqhci%3A%20Resp%20idx%3A%200x0000000d%20%7C%E5%BF%9C%E7%AD%94%E5%BC%95%E6%95%B0%3A%200x00000000%3CBR%20%2F%3E%5B%20232.500739%5D%20MMC0%3A%20SDHCI%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20232.507158%5D%20mmc0%3A%20sdhci%3A%20Sys%20addr%3A%200x9ca3e000%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000002%3CBR%20%2F%3E%5B%20232.513578%5D%20mmc0%3A%20sdhci%3A%20%E7%99%BD%E9%BB%92%E3%82%B5%E3%82%A4%E3%82%BA%3A%200x00000200%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AFCNT%3A0x00000020%3CBR%20%2F%3E%5B%20232.520001%5D%20mmc0%3A%20sdhci%3A%20%E5%BC%95%E6%95%B0%3A%200x00018000%20%7CTrn%E3%83%A2%E3%83%BC%E3%83%89%3A0x00000023%3CBR%20%2F%3E%5B%20232.526424%5D%20mmc0%3A%20sdhci%3A%20%E7%8F%BE%E5%9C%A8%3A%200x01fd8008%20%7C%E3%83%9B%E3%82%B9%E3%83%88ctl%3A0x00000030%3CBR%20%2F%3E%5B%20232.532847%5D%20mmc0%3A%20sdhci%3A%20%E9%9B%BB%E6%BA%90%3A%200x00000002%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3A0x00000080%3CBR%20%2F%3E%5B%20232.539279%5D%20mmc0%3A%20sdhci%3A%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%3A%200x00000008%20%7C%E6%99%82%E8%A8%88%3A0x0000000f%3CBR%20%2F%3E%5B%20232.545694%5D%20MMC0%3A%20SDHCI%3A%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3A%200x0000008f%20%7CInt%E7%B5%B1%E8%A8%88%3A0x00000000%3CBR%20%2F%3E%5B%20232.552126%5D%20mmc0%3A%20sdhci%3A%20Int%20enab%3A%200x107f4000%20%7C%E7%BD%B2%E5%90%8Denab%3A0x107f4000%3CBR%20%2F%3E%5B%20232.558568%5D%20mmc0%3A%20sdhci%3A%20ACmd%20%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88int%3A0x00000502%3CBR%20%2F%3E%5B%20232.564973%5D%20mmc0%3A%20sdhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x07eb0000%20%7CCaps_1%3A0x0000b407%3CBR%20%2F%3E%5B%20232.571391%5D%20mmc0%3A%20sdhci%3A%20Cmd%3A%200x00000d1a%20%7C%E6%9C%80%E5%A4%A7%E3%82%AB%E3%83%BC%3A0x00ffffff%3CBR%20%2F%3E%5B%20232.577837%5D%20mmc0%3A%20sdhci%3A%20Resp%5B0%5D%3A%200x00000000%20%7CResp%5B1%5D%3A0xffffffff%3CBR%20%2F%3E%5B%20232.584242%5D%20mmc0%3A%20sdhci%3A%20Resp%5B2%5D%3A%200x329f5903%20%7C%E5%BF%9C%E7%AD%94%5B3%5D%3A0x00d0ffff%3CBR%20%2F%3E%5B%20232.590660%5D%20mmc0%3A%20sdhci%3A%20%E3%83%9B%E3%82%B9%E3%83%88%20ctl2%3A%200x00000008%3CBR%20%2F%3E%5B%20232.595104%5D%20mmc0%3A%20sdhci%3A%20ADMA%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%200x00000000%20%7CADMA%E3%81%AEPtr%3A0xad464408%3CBR%20%2F%3E%5B%20232.601514%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%20ESDHC%20IMX%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20232.609066%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20CMD%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2120%3CBR%20%2F%3E%5B%20232.614702%5D%20MMC0%3A%20SDHCI-ESDHC-IMX%3A%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2200%3CBR%20%2F%3E%5B%20232.620431%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2300%3CBR%20%2F%3E%5B%20232.626246%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20DMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2400%3CBR%20%2F%3E%5B%20232.631888%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20ADMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2510%3CBR%20%2F%3E%5B%20232.637616%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2680%3CBR%20%2F%3E%5B%20232.643345%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20ASYNC%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2750%3CBR%20%2F%3E%5B%20232.649595%5D%20MMC0%3A%20SDHCI%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20232.656073%5D%20mmc0%3A%20CQE%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20289.818104%5D%20mmc0%3A%20CQE%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20423.303076%5D%20mmc0%3A%20CQHCI%3A%20%E3%82%BF%E3%82%B0%2031%E3%80%81QCNT%2027%20%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3CBR%20%2F%3E%5B%20423.307677%5D%20MMC0%3A%20CQHCI%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20423.314085%5D%20mmc0%3A%20cqhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x0000310a%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000510%3CBR%20%2F%3E%5B%20423.320504%5D%20mmc0%3A%20cqhci%3A%20%E8%A8%AD%E5%AE%9A%3A%200x00001001%20%7C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%3A0x00000000%3CBR%20%2F%3E%5B%20423.326927%5D%20mmc0%3A%20cqhci%3A%20%E5%9B%BD%E9%9A%9B%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E5%9B%BD%E9%9A%9B%20enab%3A%200x00000006%3CBR%20%2F%3E%5B%20423.333381%5D%20mmc0%3A%20cqhci%3A%20Int%20sig%3A%200x00000006%20%7CInt%20Coal%3A%200x00000000%3CBR%20%2F%3E%5B%20423.339786%5D%20mmc0%3A%20cqhci%3A%20TDL%20%E3%83%99%E3%83%BC%E3%82%B9%3A%200x823c3000%20%7CTDL%20up32%3A0x00000000%3CBR%20%2F%3E%5B%20423.346379%5D%20mmc0%3A%20cqhci%3A%20%E3%83%89%E3%82%A2%E3%83%99%E3%83%AB%3A%200xff1fcfff%20%7CTCN%3A0x00000000%3CBR%20%2F%3E%5B%20423.352628%5D%20mmc0%3A%20cqhci%3A%20%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%A5%E3%83%BC%3A%200x00000000%20%7C%E9%96%8B%E7%99%BA%E3%83%9A%E3%83%B3%E3%83%89%3A0x00000400%3CBR%20%2F%3E%5B%20423.359047%5D%20mmc0%3A%20cqhci%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20clr%3A%200x00000000%20%7CSSC1%3A0x00011000%3CBR%20%2F%3E%5B%20423.365465%5D%20mmc0%3A%20cqhci%3A%20SSC2%3A%200x00000001%20%7CDCMD%20RSP%20%3A%200x00000900%3CBR%20%2F%3E%5B%20423.371888%5D%20mmc0%3Acqhci%3ARED%E3%83%9E%E3%82%B9%E3%82%AF%3A0xfdf9a080%20%7C%E3%83%86%E3%83%AA%E3%83%BC%3A0x00000000%3CBR%20%2F%3E%5B%20423.378309%5D%20mmc0%3A%20cqhci%3A%20Resp%20idx%3A%200x0000000d%20%7C%E5%BF%9C%E7%AD%94%E5%BC%95%E6%95%B0%3A%200x00000000%3CBR%20%2F%3E%5B%20423.384736%5D%20MMC0%3A%20SDHCI%20%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SDHCI%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20423.391160%5D%20mmc0%3A%20sdhci%3A%20Sys%20addr%3A%200xa5b7b000%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000002%3CBR%20%2F%3E%5B%20423.397583%5D%20mmc0%3A%20sdhci%3A%20%E9%BB%92%E5%AD%97%E3%82%B5%E3%82%A4%E3%82%BA%3A%200x00000200%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AFCNT%3A0x00000020%3CBR%20%2F%3E%5B%20423.404005%5D%20mmc0%3A%20sdhci%3A%20%E5%BC%95%E6%95%B0%3A%200x00018000%20%7CTrn%E3%83%A2%E3%83%BC%E3%83%89%3A0x00000023%3CBR%20%2F%3E%5B%20423.410426%5D%20mmc0%3A%20sdhci%3A%20%E7%8F%BE%E5%9C%A8%3A%200x01fd8008%20%7C%E3%83%9B%E3%82%B9%E3%83%88ctl%3A0x00000030%3CBR%20%2F%3E%5B%20423.416849%5D%20mmc0%3A%20sdhci%3A%20%E9%9B%BB%E6%BA%90%3A%200x00000002%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3A0x00000080%3CBR%20%2F%3E%5B%20423.423280%5D%20mmc0%3A%20sdhci%3A%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%3A%200x00000008%20%7C%E6%99%82%E8%A8%88%3A0x0000000f%3CBR%20%2F%3E%5B%20423.429696%5D%20mmc0%3A%20sdhci%3A%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3A%200x0000008f%20%7CInt%E7%B5%B1%E8%A8%88%3A0x00000000%3CBR%20%2F%3E%5B%20423.436119%5D%20mmc0%3A%20sdhci%3A%20Int%20enab%3A%200x107f4000%20%7C%E7%BD%B2%E5%90%8Denab%3A0x107f4000%3CBR%20%2F%3E%5B%20423.442568%5D%20mmc0%3A%20sdhci%3A%20ACmd%20%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88int%3A0x00000502%3CBR%20%2F%3E%5B%20423.449210%5D%20mmc0%3A%20sdhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x07eb0000%20%7CCaps_1%3A0x0000b407%3CBR%20%2F%3E%5B%20423.455401%5D%20mmc0%3A%20sdhci%3A%20Cmd%3A%200x00000d1a%20%7C%E6%9C%80%E5%A4%A7%E3%82%AB%E3%83%BC%3A0x00ffffff%3CBR%20%2F%3E%5B%20423.461812%5D%20mmc0%3A%20sdhci%3A%20Resp%5B0%5D%3A%200x00000000%20%7CResp%5B1%5D%3A0xffffffff%3CBR%20%2F%3E%5B%20423.468236%5D%20mmc0%3A%20sdhci%3A%20Resp%5B2%5D%3A%200x329f5903%20%7C%E5%BF%9C%E7%AD%94%5B3%5D%3A0x00d0ffff%3CBR%20%2F%3E%5B%20423.474657%5D%20mmc0%3A%20sdhci%3A%20%E3%83%9B%E3%82%B9%E3%83%88%20ctl2%3A%200x00000008%3CBR%20%2F%3E%5B%20423.479083%5D%20mmc0%3A%20sdhci%3A%20ADMA%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%200x00000000%20%7CADMA%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A0xad467408%3CBR%20%2F%3E%5B%20423.485508%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20ESDHC%20IMX%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20423.493061%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20CMD%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2120%3CBR%20%2F%3E%5B%20423.498701%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2200%3CBR%20%2F%3E%5B%20423.504429%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2300%3CBR%20%2F%3E%5B%20423.510245%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20DMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2400%3CBR%20%2F%3E%5B%20423.515887%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20ADMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2510%3CBR%20%2F%3E%5B%20423.521615%5D%20MMC0%3A%20SDHCI-ESDHC-IMX%3A%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2680%3CBR%20%2F%3E%5B%20423.527344%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%E9%9D%9E%E5%90%8C%E6%9C%9F%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2750%3CBR%20%2F%3E%5B%20423.533593%5D%20MMC0%3A%20SDHCI%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20423.540075%5D%20mmc0%3A%20CQE%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20501.799092%5D%20MMC0%3A%20CQHCI%3A%20%E3%82%BF%E3%82%B0%2031%E3%80%81QCNT%2024%20%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3CBR%20%2F%3E%5B%20501.803698%5D%20MMC0%3A%20CQHCI%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20501.810106%5D%20mmc0%3A%20cqhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x0000310a%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000510%3CBR%20%2F%3E%5B%20501.816528%5D%20mmc0%3A%20cqhci%3A%20%E8%A8%AD%E5%AE%9A%3A%200x00001001%20%7C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%3A0x00000000%3CBR%20%2F%3E%5B%20501.822948%5D%20mmc0%3A%20cqhci%3A%20%E5%9B%BD%E9%9A%9B%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E5%9B%BD%E9%9A%9B%20enab%3A%200x00000006%3CBR%20%2F%3E%5B%20501.829398%5D%20mmc0%3A%20cqhci%3A%20Int%20sig%3A%200x00000006%20%7CInt%20Coal%3A%200x00000000%3CBR%20%2F%3E%5B%20501.835801%5D%20mmc0%3A%20cqhci%3A%20TDL%20%E3%83%99%E3%83%BC%E3%82%B9%3A%200x823c3000%20%7CTDL%20up32%3A0x00000000%3CBR%20%2F%3E%5B%20501.842221%5D%20mmc0%3A%20cqhci%3A%20%E3%83%89%E3%82%A2%E3%83%99%E3%83%AB%3A%200xe01fffff%20%7CTCN%3A0x00000000%3CBR%20%2F%3E%5B%20501.848666%5D%20mmc0%3A%20cqhci%3A%20%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%A5%E3%83%BC%3A%200x00000000%20%7C%E9%96%8B%E7%99%BA%E3%83%9A%E3%83%B3%E3%83%89%3A0x00008000%3CBR%20%2F%3E%5B%20501.855070%5D%20mmc0%3A%20cqhci%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20clr%3A%200x00000000%20%7CSSC1%3A0x00011000%3CBR%20%2F%3E%5B%20501.861533%5D%20mmc0%3A%20cqhci%3A%20SSC2%3A%200x00000001%20%7CDCMD%20RSP%20%3A%200x00000900%3CBR%20%2F%3E%5B%20501.867916%5D%20mmc0%3Acqhci%3ARED%E3%83%9E%E3%82%B9%E3%82%AF%3A0xfdf9a080%20%7C%E3%83%86%E3%83%AA%E3%83%BC%3A0x00000000%3CBR%20%2F%3E%5B%20501.874333%5D%20mmc0%3A%20cqhci%3A%20Resp%20idx%3A%200x0000000d%20%7C%E5%BF%9C%E7%AD%94%E5%BC%95%E6%95%B0%3A%200x00000000%3CBR%20%2F%3E%5B%20501.880756%5D%20MMC0%3A%20SDHCI%20%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SDHCI%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20501.887180%5D%20mmc0%3A%20sdhci%3A%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%BF%BD%E5%8A%A0%3A%200xa5a15000%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000002%3CBR%20%2F%3E%5B%20501.893600%5D%20mmc0%3A%20sdhci%3A%20%E9%BB%92%E5%AD%97%E3%82%B5%E3%82%A4%E3%82%BA%3A%200x00000200%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AFCNT%3A0x00000020%3CBR%20%2F%3E%5B%20501.900029%5D%20mmc0%3A%20sdhci%3A%20%E5%BC%95%E6%95%B0%3A%200x00018000%20%7CTrn%E3%83%A2%E3%83%BC%E3%83%89%3A0x00000023%3CBR%20%2F%3E%5B%20501.906450%5D%20mmc0%3A%20sdhci%3A%20%E7%8F%BE%E5%9C%A8%3A%200x01fd8008%20%7C%E3%83%9B%E3%82%B9%E3%83%88ctl%3A0x00000030%3CBR%20%2F%3E%5B%20501.912875%5D%20mmc0%3A%20sdhci%3A%20%E9%9B%BB%E6%BA%90%3A%200x00000002%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3A0x00000080%3CBR%20%2F%3E%5B%20501.919301%5D%20mmc0%3A%20sdhci%3A%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%3A%200x00000008%20%7C%E6%99%82%E8%A8%88%3A0x0000000f%3CBR%20%2F%3E%5B%20501.925717%5D%20mmc0%3A%20sdhci%3A%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3A%200x0000008f%20%7CInt%E7%B5%B1%E8%A8%88%3A0x00000000%3CBR%20%2F%3E%5B%20501.932139%5D%20mmc0%3A%20sdhci%3A%20Int%20enab%3A%200x107f4000%20%7C%E7%BD%B2%E5%90%8Denab%3A0x107f4000%3CBR%20%2F%3E%5B%20501.938564%5D%20mmc0%3A%20sdhci%3A%20ACmd%20%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88int%3A0x00000502%3CBR%20%2F%3E%5B%20501.944994%5D%20mmc0%3A%20sdhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x07eb0000%20%7CCaps_1%3A0x0000b407%3CBR%20%2F%3E%5B%20501.951435%5D%20mmc0%3A%20sdhci%3A%20Cmd%3A%200x00000d1a%20%7C%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9%20%E3%82%AB%E3%83%BC%3A0x00ffffff%3CBR%20%2F%3E%5B%20501.957841%5D%20mmc0%3A%20sdhci%3A%20Resp%5B0%5D%3A%200x00000000%20%7CResp%5B1%5D%3A0xffffffff%3CBR%20%2F%3E%5B%20501.964284%5D%20mmc0%3A%20sdhci%3A%20Resp%5B2%5D%3A%200x329f5903%20%7C%E5%BF%9C%E7%AD%94%5B3%5D%3A0x00d0ffff%3CBR%20%2F%3E%5B%20501.970686%5D%20mmc0%3A%20sdhci%3A%20%E3%83%9B%E3%82%B9%E3%83%88%20ctl2%3A%200x00000008%3CBR%20%2F%3E%5B%20501.975106%5D%20mmc0%3A%20sdhci%3A%20ADMA%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%200x00000000%20%7CADMA%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A0xad463808%3CBR%20%2F%3E%5B%20501.981529%5D%20MMC0%3ASDHCI-ESDHC-IMX%3A%3D%3D%3D%3D%3D%3D%3D%3D%3D%20ESDHC%20IMX%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20501.989083%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20CMD%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2120%3CBR%20%2F%3E%5B%20501.994728%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2200%3CBR%20%2F%3E%5B%20502.000451%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20TRANS%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2300%3CBR%20%2F%3E%5B%20502.006266%5D%20MMC0%3ASDHCI-ESDHC-IMX%3ADMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A0x2400%3CBR%20%2F%3E%5B%20502.011909%5D%20MMC0%3ASDHCI-ESDHC-IMX%3AADMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A0x2510%3CBR%20%2F%3E%5B%20502.017636%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2680%3CBR%20%2F%3E%5B%20502.023365%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20ASYNC%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2750%3CBR%20%2F%3E%5B%20502.029650%5D%20MMC0%3A%20SDHCI%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20502.036090%5D%20mmc0%3A%20CQE%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%20607.207068%5D%20mmc0%3A%20CQHCI%3A%20%E3%82%BF%E3%82%B0%2031%E3%80%81QCNT%2021%20%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3CBR%20%2F%3E%5B%20607.211666%5D%20MMC0%3A%20CQHCI%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20607.218083%5D%20mmc0%3A%20cqhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x0000310a%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000510%3CBR%20%2F%3E%5B%20607.224498%5D%20mmc0%3A%20cqhci%3A%20%E8%A8%AD%E5%AE%9A%3A%200x00001001%20%7C%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%3A0x00000000%3CBR%20%2F%3E%5B%20607.230915%5D%20mmc0%3A%20cqhci%3A%20%E5%9B%BD%E9%9A%9B%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E5%9B%BD%E9%9A%9B%20enab%3A%200x00000006%3CBR%20%2F%3E%5B%20607.237344%5D%20mmc0%3A%20cqhci%3A%20Int%20sig%3A%200x00000006%20%7CInt%20Coal%3A%200x00000000%3CBR%20%2F%3E%5B%20607.243803%5D%20mmc0%3A%20cqhci%3A%20TDL%20%E3%83%99%E3%83%BC%E3%82%B9%3A%200x823c3000%20%7CTDL%20up32%3A0x00000000%3CBR%20%2F%3E%5B%20607.250194%5D%20mmc0%3A%20cqhci%3A%20%E3%83%89%E3%82%A2%E3%83%99%E3%83%AB%3A%200x83ffc1fe%20%7CTCN%3A0x00000000%3CBR%20%2F%3E%5B%20607.256635%5D%20mmc0%3A%20cqhci%3A%20%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%A5%E3%83%BC%3A%200x00000000%20%7C%E9%96%8B%E7%99%BA%E3%83%9A%E3%83%B3%E3%83%89%3A0x00000001%3CBR%20%2F%3E%5B%20607.263039%5D%20mmc0%3A%20cqhci%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20clr%3A%200x00000000%20%7CSSC1%3A0x00011000%3CBR%20%2F%3E%5B%20607.269485%5D%20mmc0%3A%20cqhci%3A%20SSC2%3A%200x00000001%20%7CDCMD%20RSP%20%3A%200x00000900%3CBR%20%2F%3E%5B%20607.275915%5D%20mmc0%3A%20cqhci%3A%20RED%20%E3%83%9E%E3%82%B9%E3%82%AF%3A%200xfdf9a080%20%7C%E3%83%86%E3%83%AA%E3%83%BC%3A0x00000000%3CBR%20%2F%3E%5B%20607.282328%5D%20mmc0%3A%20cqhci%3A%20Resp%20idx%3A%200x0000000d%20%7C%E5%BF%9C%E7%AD%94%E5%BC%95%E6%95%B0%3A%200x00000000%3CBR%20%2F%3E%5B%20607.288731%5D%20MMC0%3A%20SDHCI%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20607.295180%5D%20mmc0%3A%20sdhci%3A%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%BF%BD%E5%8A%A0%3A%200x9cefe000%20%7C%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%200x00000002%3CBR%20%2F%3E%5B%20607.301577%5D%20mmc0%3A%20sdhci%3A%20%E9%BB%92%E5%AD%97%E3%82%B5%E3%82%A4%E3%82%BA%3A%200x00000200%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AFCNT%3A0x00000020%3CBR%20%2F%3E%5B%20607.308021%5D%20mmc0%3A%20sdhci%3A%20%E5%BC%95%E6%95%B0%3A%200x00018000%20%7CTrn%E3%83%A2%E3%83%BC%E3%83%89%3A0x00000023%3CBR%20%2F%3E%5B%20607.314425%5D%20mmc0%3A%20sdhci%3A%20%E7%8F%BE%E5%9C%A8%3A%200x01fd8008%20%7C%E3%83%9B%E3%82%B9%E3%83%88ctl%3A0x00000030%3CBR%20%2F%3E%5B%20607.320843%5D%20mmc0%3A%20sdhci%3A%20%E9%9B%BB%E6%BA%90%3A%200x00000002%20%7C%E3%83%96%E3%83%A9%E3%83%83%E3%82%AF%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%3A0x00000080%3CBR%20%2F%3E%5B%20607.327263%5D%20mmc0%3A%20sdhci%3A%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%3A%200x00000008%20%7C%E6%99%82%E8%A8%88%3A0x0000000f%3CBR%20%2F%3E%5B%20607.333725%5D%20mmc0%3A%20sdhci%3A%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%3A%200x0000008f%20%7CInt%E7%B5%B1%E8%A8%88%3A0x00000000%3CBR%20%2F%3E%5B%20607.340117%5D%20mmc0%3A%20sdhci%3A%20Int%20enab%3A%200x107f4000%20%7C%E7%BD%B2%E5%90%8Denab%3A0x107f4000%3CBR%20%2F%3E%5B%20607.346575%5D%20mmc0%3A%20sdhci%3A%20ACmd%20%E7%B5%B1%E8%A8%88%3A%200x00000000%20%7C%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88int%3A0x00000502%3CBR%20%2F%3E%5B%20607.352962%5D%20mmc0%3A%20sdhci%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%200x07eb0000%20%7CCaps_1%3A0x0000b407%3CBR%20%2F%3E%5B%20607.359405%5D%20mmc0%3A%20sdhci%3A%20Cmd%3A%200x00000d1a%20%7C%E6%9C%80%E5%A4%A7%E3%82%AB%E3%83%BC%3A0x00ffffff%3CBR%20%2F%3E%5B%20607.365818%5D%20mmc0%3A%20sdhci%3A%20Resp%5B0%5D%3A%200x00000000%20%7CResp%5B1%5D%3A0xffffffff%3CBR%20%2F%3E%5B%20607.372254%5D%20mmc0%3A%20sdhci%3A%20Resp%5B2%5D%3A%200x329f5903%20%7C%E5%BF%9C%E7%AD%94%5B3%5D%3A0x00d0ffff%3CBR%20%2F%3E%5B%20607.378692%5D%20MMC0%3A%20sdhci%3A%20%E3%83%9B%E3%82%B9%E3%83%88%20ctl2%3A%200x00000008%3CBR%20%2F%3E%5B%20607.383103%5D%20mmc0%3A%20sdhci%3A%20ADMA%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%200x00000000%20%7CADMA%E3%81%AEPtr%3A0xad463408%3CBR%20%2F%3E%5B%20607.389505%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%20ESDHC%20IMX%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%E3%83%80%E3%83%B3%E3%83%97%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20607.397083%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20CMD%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2120%3CBR%20%2F%3E%5B%20607.402704%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2200%3CBR%20%2F%3E%5B%20607.408454%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B9%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2300%3CBR%20%2F%3E%5B%20607.414245%5D%20MMC0%3A%20SDHCI-ESDHC-IMX%3A%20DMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2400%3CBR%20%2F%3E%5B%20607.419880%5D%20MMC0%3ASDHCI-ESDHC-IMX%3AADMA%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A0x2510%3CBR%20%2F%3E%5B%20607.425607%5D%20MMC0%3A%20SDHCI-ESDHC-IMX%3A%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2680%3CBR%20%2F%3E%5B%20607.431335%5D%20mmc0%3A%20SDHCI-ESDHC-IMX%3A%20ASYNC%20FIFO%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200x2750%3CBR%20%2F%3E%5B%20607.437586%5D%20MMC0%3A%20SDHCI%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%20607.444076%5D%20mmc0%3A%20CQE%20%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECMD13%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%80%E3%83%B3%E3%83%97%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8Cemmc%E3%81%8C%E5%BF%9C%E7%AD%94%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8E%9F%E5%9B%A0%E3%82%92%E6%8E%A2%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABdebugfs%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%22cat%20%2Fsys%2Fkernel%2Fdebug%2Fmmc0%2Fmmc0%5C%3A0001%2Fstatus%22%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6CMD13%E3%82%92emmc%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%80%81%E8%BF%94%E3%81%97%E3%81%A6%E7%B5%90%E6%9E%9C%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E7%B4%8410%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AE%E3%81%BF%E3%80%81%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AE%E3%81%BF%E3%80%81%22cat%20%2Fsys%2Fkernel%2Fdebug%2Fmmc0%2Fmmc0%5C%3A0001%2Fstate%22%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%99%E3%81%90%E3%81%AB%E6%88%BB%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%B5%90%E5%B1%80%E3%80%81CQHCI%E3%82%92%E9%96%89%E9%8E%96%E3%81%97%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CQHCI%E3%81%AF%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A1%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A3%BD%E9%80%A0%E3%81%95%E3%82%8C%E3%81%9Femmc%E3%81%A7%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E6%96%B0%E3%81%9F%E3%81%AA%E9%80%B2%E5%B1%95%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1970806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2Cjun13_chen%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1970768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241049%22%20target%3D%22_blank%22%3E%40yan4%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%ABRDB%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%96%E3%81%AENXP%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82CQHCI%20t%3CSPAN%3E%E3%82%92%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%3C%2FSPAN%3E%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220717%22%20target%3D%22_blank%22%3E%40jun13_chen%3C%2FA%3E%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%80%81%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E6%A9%9F%E8%83%BD%E3%82%92%E9%96%89%E3%81%98%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%81%E3%82%A7%E3%83%B3%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1970732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%9F%E3%81%B6%E3%82%93%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Flinux%2Fcommit%2F185b9d9a592ca5eb97e67f9d43616d2c3de34ec8%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Flinux%2Fcommit%2F185b9d9a592ca5eb97e67f9d43616d2c3de34ec8%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CQHCI%E3%81%AF%E5%AE%89%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81NXP%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E9%96%89%E3%81%98%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Flinux%2Fcommit%2Fd856f42b65e5a976a49adfd9e95d1d81a27a9ca9%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Flinux%2Fcommit%2Fd856f42b65e5a976a49adfd9e95d1d81a27a9ca9%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1969720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81chenyin_h%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E5%89%8D%E8%BF%B0%E3%81%AE%E8%88%B9%E4%B8%8A%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%96%9C%E3%82%93%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241049%22%20target%3D%22_blank%22%3E%40yan4%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E8%B2%B4%E9%87%8D%E3%81%AA%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%8F%82%E7%85%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%83%B3%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81chenyin%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%81%E6%AD%A3%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BBSP38%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8BV5.15%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AB%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81link%3A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FThe-issues-on-quot-mmc0-cqhci-timeout-for-tag-0-quot%2Fm-p%2F993779%2Fthread-id%2F147435%2Fpage%2F2%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FThe-issues-on-quot-mmc0-cqhci-timeout-for-tag-0-quot%2Fm-p%2F993779%2Fthread-id%2F147435%2Fpage%2F2%3C%2FA%3E%E3%80%82%3CBR%20%2F%3EI.MX%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81BSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E5%85%AC%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AF%E6%80%9D%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81CQHCI%E3%81%AF%E4%B8%8D%E5%AE%89%E5%AE%9A%E3%81%AA%E6%A9%9F%E8%83%BD%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%80%81Linux%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812022%E5%B9%B4%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%20gogdan-gabriel.roman%40nxp.com%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%B0%8E%E5%85%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E6%80%A7%E3%82%92%E5%86%8D%E8%A9%95%E4%BE%A1%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%AE%E3%83%90%E3%82%B0%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%A4%E3%83%B3%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%AF%E3%81%84%E3%80%81BSP38%20%E3%81%A8%206.1.168%E7%A7%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1962228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3ACQHCI%E3%81%AB%E3%82%88%E3%82%8Bemmc%E3%83%80%E3%83%B3%E3%83%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1962228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241049%22%20target%3D%22_blank%22%3E%40yan4%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF6.1.68%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E4%B8%AD%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81BSP%20%E3%81%AE%E8%A6%B3%E7%82%B9%E3%81%8B%E3%82%89%E3%81%AF%E6%AD%A3%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBSP(%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%815.15.x%E3%81%BE%E3%81%9F%E3%81%AF6.6.x%E3%81%AEBSP41)%E3%81%AE%E4%BD%BF%E7%94%A8%E4%B8%AD%E3%81%AB%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%82%B1%E3%83%8D%E3%83%AB)%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%83%B3%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
