arm-trusted-firmware not build successfully
917 次查看
Jeyaseelan_Kirubaharan
Hi All,
I am trying to build the arm-trusted-firmware for S32G. But the build is not successful
git clone https://github.com/nxp-auto-linux/arm-trusted-firmware.git
cd arm-trusted-firmware && git checkout release/bsp37.0-2.5
make CROSS_COMPILE=aarch64-none-linux-gnu- ARCH=aarch64 PLAT=s32g3xxaevb3 \
BL33=../u-boot/u-boot-nodtb.bin S32_HAS_HV=1 S32_USE_LINFLEX_IN_BL31=1 LOG_LEVEL=40
Getting the below error
user:~/Audi_ADAS/arm-trusted-firmware$ make CROSS_COMPILE=../compiler/arm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu- ARCH=aarch64 PLAT=s32g3xxaevb3 BL33=../u-boot/u-boot-nodtb.bin S32_HAS_HV=1 S32_USE_LINFLEX_IN_BL31=1 LOG_LEVEL=40
HOSTCC fiptool.c
HOSTCC tbbr_config.c
HOSTLD fiptool
Built fiptool successfully
FIP /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/dummy_fip
MKIMAGE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/dummy_fip.s32
MKIMAGE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/ivt_location
MKIMAGE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_offset
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_mmc_offset_flag
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_qspi_offset_flag
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_mem_offset_flag
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/fip_hdr_size
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/dtb_size
CREATE /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/boot_info.c
CC /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/boot_info.c
LD /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/bl31SRAM/bl31SRAM.elf
../compiler/arm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-ld: warning: /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/bl31SRAM/bl31SRAM.elf has a LOAD segment with RWX permissions
make: *** [plat/nxp/s32/s32g/bl31_sram/bl31_sram.mk:28: /home/user/Audi_ADAS/arm-trusted-firmware/build/s32g3xxaevb3/release/bl31SRAM/bl31SRAM.elf] Error 1
It will be useful if someone provide the suggestion to get over this error.
With regards,
Jeyaseelan
标记 (1)
899 次查看
alejandro_e
Hello @Jeyaseelan_Kirubaharan,
Thanks for reaching out to us and thanks for the detailed description of your problem. Checking your logs I see you are using  arm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu while the BSP37 user manual indicates to use arm-gnu-toolchain-11.3.rel1-x86_64-aarch64-none-linux-gnu, I verified myself and I was able to compile ATF + u-boot without problems.
Can you try using the recommended ARM GCC version and let me know if the behavior is different?
Thanks in advance
4 回复数
913 次查看
Please find attached the complete log.
900 次查看
alejandro_e
Thanks in advance
893 次查看
Hi Alejandro,
As mentioned from you , after changing the compiler version we can able to build the ATF successfully.
Thanks for the support..
With regards,
Jeyaseelan
标记 (1)
890 次查看
alejandro_e
I'm glad to know you were able to solve your problem! If possible please select my previous answer as an accepted solution.
Thanks in advance
%3CLINGO-SUB%20id%3D%22lingo-sub-2143610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EArm-trusted-%E5%9B%BA%E4%BB%B6%E6%97%A0%E6%B3%95%E6%88%90%E5%8A%9F%E7%89%88%E6%9C%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B8%BA%20S32G%20%E7%89%88%E6%9C%AC%E5%8F%AF%E9%9D%A0%20Arm%20%E7%9A%84%E5%9B%BA%E4%BB%B6%E3%80%82%E4%BD%86%E6%98%AF%E7%89%88%E6%9C%AC%E4%B8%8D%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3Egit%20clone%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Farm-trusted-firmware.git%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Farm-trusted-firmware.git%3C%2FA%3E%3CBR%20%2F%3E%3CSTRONG%3Ecd%20Arm-trusted-firmware%20%26amp%3B%20%26amp%3B%20git%20checkout%20%E7%89%88%E6%9C%AC%2F%20bsp37.0-2.5%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Emake%20cross_compile%3Daarch64-none-linux-GNU-arch%3Daarch64%20plat%3Ds32g3xxaevb3%5C%20BL33%3D...%20%3CBR%20%2F%3E%2Fu-boot%2Fu-boot-nodtb.bin%20S32_HAS_HV%3D1%20S32_USE_LINFLEX_IN_BL31%3D1%20LOG_LEVEL%3D40%3C%2FP%3E%3CP%3E%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E%E7%94%A8%E6%88%B7%EF%BC%9A~%2Faudi_adas%2FARM-Trusted-firmware%24%20make%20CROSS_COMPILE%3D..%2Fcompiler%2Farm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu%2Fbin%2Faarch64-none-aarch64-none-linux-gnu%2FbinARCH%3Daarch64%20PLAT%3Ds32g3xxaevb3%20BL33%3D..%2Fu-boot%2Fu-boot-nodtb.bin%20S32_HAS_HV%3D1%20S32_USE_LINFLEX_IN_BL31%3D1%20LOG_LEVEL%3D40%3CBR%20%2F%3EHOSTCC%20fiptool.c%3CBR%20%2F%3EHOSTCC%20tbbr_config.c%3CBR%20%2F%3EHOSTLD%20fiptool%3C%2FP%3E%3CP%3E%E6%88%90%E5%8A%9F%E7%89%88%E6%9C%AC%20fiptool%3C%2FP%3E%3CP%3EFIP%20%2FHOME%2FUser%2Faudi_adas%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fdummy_FIP%20MKIMAGE%20%2FHOME%2Fuser%2Faudi_adas%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fdummy_%20%3CBR%20%2F%3E%20fip.s32%20%3CBR%20%2F%3EMKIMAGE%20%2FHOME%2FUser%2Faudi_adas%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fivt_Location%20MKIMAGE%20%2Fhome%2Fuser%2Faudi_adas%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frusted-firmware%2Fbuild%2Fs32g3xxaevbb3%2Frusted-firmware%2Fbuild%2Fs32g3xxaevbb3%2Frusted-firmware%2Fbuild%2F3%2Frelease%2Ffip_mmc_offset_FLAG%20%E5%88%9B%E5%BB%BA%20%2FHOME%2Fuser%2Faudi_ADAS%2FARM-Trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Ffip_qspi_offset_FLAG%20%E5%88%9B%E5%BB%BA%20%2FHOME_ADAS%2FARM%20%E5%8F%AF%E4%BF%A1%E5%9B%BA%E4%BB%B6%2Fbuild%2Fs32g3xxaevb3%2Frelease%2FFIP_QSPI_Offset_FLAG%20%E5%88%9B%E5%BB%BA%20%2FHOME_ADAS%2FARM-Trusted_FLAG%20%2FBUILD%2FS32G3XXAEVB3%2FRelease%2F%E4%B8%BB%E9%A1%B5%2F%E7%94%A8%E6%88%B7%2FAudi_adas%2FARM-Trusted-Firm%20%3CBR%20%2F%3E%20ware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2F%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Efip_hdr_size%20%E5%88%9B%E5%BB%BA%20%2FHOME%2Fuser%2Faudi_adas%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fdtb_size%20%E5%88%9B%E5%BB%BA%20%2FHOME%2FUser%2Faudi_adas%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fdtb_size%20%E5%88%9B%E5%BB%BA%20%2FHOME%2FAUD%20%3CBR%20%2F%3E%20_ADAS%2FARM-%3CBR%20%2F%3E%20%3CBR%20%2F%3ECC%20%2FHOME%2Fuser%2Faudi_adas%2FArm-trusted-firmware%2F%E7%89%88%E6%9C%AC%2Fs32g3xxaevb3%2F%E7%89%88%E6%9C%AC%2Fboot_info.c%20%3CBR%20%2F%3ECC%20%2FHOME%2Fuser%2Faudi_adas%2FArm-trusted-firmware%2F%E7%89%88%E6%9C%AC%2Fs32g3xxaevb3%2F%E7%89%88%E6%9C%AC%2Fboot_info.c%20%3CBR%20%2F%3ELD%20%2Fhome%2Fuser%2Faudi_adas%2Farm-trusted-firmware%2Fbuild%2Fs32g3xxaevb3%2Frelease%2Fbl31%20%3CBR%20%2F%3E%20sram%2Fbl31sram%2Fbl31sram.elf%E3%80%82%2Fcompiler%2Farm-gnu-toolchain-14.3.rel1-x86_64-aarch64-none-linux-gnu%2Fbin%2Faarch64-none-aarch64-none-aarch64-none-ld%EF%BC%9A%E8%AD%A6%E5%91%8A%EF%BC%9A%2FHOME%2Fuser%2Faudi_adas%2FArm-trusted-firmware%2F%E7%89%88%E6%9C%AC%2Fs32g3xxaevb3%2F%E7%89%88%E6%9C%AC%2Fbl31sram%2Fbl31sram.elf%20%E6%9C%89%E4%B8%80%E4%B8%AA%E5%85%B7%E6%9C%89%20RWX%20%E6%9D%83%E9%99%90%E7%9A%84%20LOAD%20%E5%88%86%E6%AE%B5%20make%EF%BC%9A***%20%5Bplat%2Fnxp%2Fs32%2Fs32g%2Fbl31_sram%2Fbl31_sram.mk%3A%2028%3A%20%3CBR%20%2F%3E%2F%E4%B8%BB%E9%A1%B5%2F%E7%94%A8%E6%88%B7%2Faudi_adas%2FArm-trusted-firmware%2F%E7%89%88%E6%9C%AC%2Fs32g3xxaevb3%2F%E7%89%88%E6%9C%AC%2Fbl31sram%2Fbl31sram%2Fbl31sram.elf%5D%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E4%BA%BA%E8%83%BD%E6%8F%90%E4%BE%9B%E5%85%8B%E6%9C%8D%E8%BF%99%E4%B8%80%E9%94%99%E8%AF%AF%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%3CP%3EJeyaseelan%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144654%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202483%22%20target%3D%22_blank%22%3E%40Jeyaseelan_Kirubaharan%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E7%9F%A5%E9%81%93%E4%BD%A0%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%81%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%EF%BC%8C%E8%AF%B7%E9%80%89%E6%8B%A9%E6%88%91%E4%B9%8B%E5%89%8D%E7%9A%84%E7%AD%94%E6%A1%88%E4%BD%9C%E4%B8%BA%E6%8E%A5%E5%8F%97%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A2%84%E5%85%88%E8%87%B4%E8%B0%A2%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%BA%9A%E5%8E%86%E6%9D%AD%E5%BE%B7%E7%BD%97%E3%80%81%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%82%A8%E6%89%80%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E6%9B%B4%E6%94%B9%E7%BC%96%E8%AF%91%E5%99%A8%E7%89%88%E6%9C%AC%E5%90%8E%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E6%9E%84%E5%BB%BA%20ATF%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%3CP%3EJeyaseelan%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143905%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202483%22%20target%3D%22_blank%22%3E%40Jeyaseelan_Kirubaharan%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E8%81%94%E7%B3%BB%E6%88%91%E4%BB%AC%E5%B9%B6%E8%AF%A6%E7%BB%86%E6%8F%8F%E8%BF%B0%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%9F%A5%E7%9C%8B%E4%BD%A0%E7%9A%84%E6%97%A5%E5%BF%97%E6%88%91%E7%9C%8B%E8%A7%81%E4%BD%A0%E5%9C%A8%E4%BD%BF%E7%94%A8%3CEM%3E%20arm-gnu-toolchain-%3CSTRONG%3E%2014.3.rel1-x86_64-aarch64-none-linux-gnu%3C%2FSTRONG%3E%20%3C%2FEM%3E%E8%80%8C%20BSP37%20%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E5%88%99%E8%A1%A8%E7%A4%BA%E8%A6%81%E4%BD%BF%E7%94%A8%3CEM%3E%20%3CSTRONG%3Earm-gnu-toolchain-11.3.rel1%3C%2FSTRONG%3E%20-x86_64-aarch64-%20none-linux-gnu%EF%BC%8C%3C%2FEM%3E%E6%88%91%E9%AA%8C%E8%AF%81%E4%BA%86%E8%87%AA%E5%B7%B1%EF%BC%8C%E8%83%BD%E5%A4%9F%E6%AF%AB%E6%97%A0%E9%97%AE%E9%A2%98%E5%9C%B0%E7%BC%96%E8%AF%91%20ATF%20%2B%20%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%8E%A8%E8%8D%90%E7%9A%84%20ARM%20GCC%20%E7%89%88%E6%9C%AC%EF%BC%8C%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E8%A1%8C%E4%B8%BA%E6%98%AF%E5%90%A6%E4%B8%8D%E5%90%8C%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A2%84%E5%85%88%E8%87%B4%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-trusted-firmware%20not%20build%20successfully%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9A%8F%E5%87%BD%E9%99%84%E4%B8%8A%E5%AE%8C%E6%95%B4%E7%9A%84%E6%97%A5%E5%BF%97%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
