Yacto project for S32G3 GoldVIP error
812 次查看
Wzlinux
Hi deai NXP
I follow UM12007 do the yaoto project for goldvip.
in the 25.2.2 there is a  source nxp-setup-alb.sh -D fsl-goldvip \
-m s32g399ardb3goldvip \
-e "meta-aws meta-java" command.
there is a error after this command . Please help to take a look at this issue. thank you.
标记 (1)
774 次查看
chenyin_h
Hello, @Wzlinux
Thanks for your post.
May I know which version Goldvip you were working with?
I have tested with 1.12, and seems there are no issue.
"source nxp-setup-alb.sh -D fsl-goldvip-hv \-m s32g399ardb3goldvip \-e "meta-aws meta-java"
Configuring for s32g399ardb3goldvip and distro fsl-goldvip-hv...
Proprietary and third party software is subject to agreement and compliance
with, NXP's End User License Agreement. To have the right to use these
binaries in your images, you must read and accept the following terms. If
there are conflicting terms embedded in the software, the terms embedded in
the Software will control.
I  suggest trying it the following way:
Chenyin
