VR5510 Safety Manual ?
2,518 次查看
bookar
Hi ,
I need the "VR5510 Safety Manual", where can i get this document. Is NDA required?
2,508 次查看
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
You are correct. Usually, these documents require an active NDA.
Once you provide your NDA number, you can download the document from your Secure Files.
I do recommend to submit a new ticket in case you do not have an NDA number.
I hope this information helps.
David
2,509 次查看
diazmarin09
David
