U-Boot for M7_0 Initsram command not valid
695 次查看
SriramVenkat
We're tried using the initsram command for initializing the SRAM region for the M7 core via the U-Boot.
Getting a message as "Unknown command initsram Try - help".
Also, we tried mw.q 0x34000000 0x0 0x100000 for zero-set SRAM. But this leads to memory crash.
Could you pls provide the alternate command used in the U-Boot for M7 S32g399A.
0 回复数
