StandardTypes.h not find
Arbabmir
I used the SW32G_RTD_4.4_4.0.2 and added it in Design Studio. After compiling the application I got this error:
fatal error: StandardTypes.h: No such file or directory
So, could you please help me to find the solution?
Note: this header file will call by Siul2_Dio_Ip.h
I installed these packages:
S32 Configuration Tools Package
S32 Design Studio Platform package
S32 Trace Package
S32G development package
S32G2 AUTOSAR 4.4 RTD 4.0.2 D2306
Daniel-Aguirre
Thanks for your feedback. For the following comment:
No, for the examples how can I do the setting tools?
We understand that you did not generate the required code under the example. For that, you right-click under the project itself then select the following option:
Then, under configuration tools, click the following button:
It should be green prior to the generation of code and gray (as shown above) once the code has been correctly generated. From our side, we have generated the example you have provided the logs for no problem:
Please, let us know.
Daniel-Aguirre
Can you let us know which S32 Design Studio version are you using?
Are you using any NXP examples? If so, which one? Can you provide a capture of the error being printed under S32 Design Studio?
Have you generated the required code prior to compiling the example?
Arbabmir
S32DS.3.5   version I am using.
I have run two applications one from example and another from my own.
I got this error for building the Adc_example_S32G274A_M7 example:
fatal error: PlatformTypes.h: No such file or directory 55 | #include "PlatformTypes.h"
and for my own application I got this error:
Daniel-Aguirre
Have you generated the required code under Config Tools prior to compiling the example?
Arbabmir
This the error that I paste here:
10:29:02 **** Build of configuration Debug_RAM for project Clock_Ip_Example_S32G274A_M7 ****
make -j8 all
Building file: ../src/main.c
Building file: ../Project_Settings/Startup_Code/Vector_Table.s
Building file: ../Project_Settings/Startup_Code/exceptions.c
Building file: ../Project_Settings/Startup_Code/nvic.c
Building file: ../Project_Settings/Startup_Code/startup.c
Invoking: Standard S32DS C Compiler
Building file: ../Project_Settings/Startup_Code/startup_cm7.s
Invoking: Standard S32DS Assembler
Building file: ../Project_Settings/Startup_Code/system.c
arm-none-eabi-gcc "@Project_Settings/Startup_Code/exceptions.args" -MMD -MP -MF"Project_Settings/Startup_Code/startup.d" -MT"Project_Settings/Startup_Code/startup.o" -o "Project_Settings/Startup_Code/startup.o" "../Project_Settings/Startup_Code/startup.c"
arm-none-eabi-gcc "@Project_Settings/Startup_Code/Vector_Table.args" -o "Project_Settings/Startup_Code/Vector_Table.o" "../Project_Settings/Startup_Code/Vector_Table.s"
arm-none-eabi-gcc "@Project_Settings/Startup_Code/exceptions.args" -MMD -MP -MF"Project_Settings/Startup_Code/exceptions.d" -MT"Project_Settings/Startup_Code/exceptions.o" -o "Project_Settings/Startup_Code/exceptions.o" "../Project_Settings/Startup_Code/exceptions.c"
arm-none-eabi-gcc "@src/main.args" -MMD -MP -MF"src/main.d" -MT"src/main.o" -o "src/main.o" "../src/main.c"
arm-none-eabi-gcc "@Project_Settings/Startup_Code/Vector_Table.args" -o "Project_Settings/Startup_Code/startup_cm7.o" "../Project_Settings/Startup_Code/startup_cm7.s"
arm-none-eabi-gcc "@Project_Settings/Startup_Code/exceptions.args" -MMD -MP -MF"Project_Settings/Startup_Code/nvic.d" -MT"Project_Settings/Startup_Code/nvic.o" -o "Project_Settings/Startup_Code/nvic.o" "../Project_Settings/Startup_Code/nvic.c"
In file included from C:/NXP/S32DS.3.5/S32DS/software/PlatformSDK_S32XX_4_0_0/RTD/BaseNXP_TS_T40D11M40I2R0/include/StandardTypes.h:50,
arm-none-eabi-gcc "@Project_Settings/Startup_Code/exceptions.args" -MMD -MP -MF"Project_Settings/Startup_Code/system.d" -MT"Project_Settings/Startup_Code/system.o" -o "Project_Settings/Startup_Code/system.o" "../Project_Settings/Startup_Code/system.c"
from C:/NXP/S32DS.3.5/S32DS/software/PlatformSDK_S32XX_4_0_0/RTD/BaseNXP_TS_T40D11M40I2R0/include/Std_Types.h:49,
from ../Project_Settings/Startup_Code/startup.c:27:
C:/NXP/S32DS.3.5/S32DS/software/PlatformSDK_S32XX_4_0_0/RTD/BaseNXP_TS_T40D11M40I2R0/include/Platform_Types.h:55:10: fatal error: PlatformTypes.h: No such file or directory
compilation terminated.
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/startup.o] Error 1
make: *** Waiting for unfinished jobs....
Finished building: ../Project_Settings/Startup_Code/Vector_Table.s
from C:/NXP/S32DS.3.5/S32DS/software/PlatformSDK_S32XX_4_0_0/RTD/BaseNXP_TS_T40D11M40I2R0/include/Mcal.h:59,
from ../src/main.c:23:
In file included from ../Project_Settings/Startup_Code/exceptions.c:36:
from ../Project_Settings/Startup_Code/nvic.c:32:
Finished building: ../Project_Settings/Startup_Code/startup_cm7.s
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/exceptions.o] Error 1
make: *** [src/subdir.mk:20: src/main.o] Error 1
In file included from ../Project_Settings/Startup_Code/system.c:42:
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/nvic.o] Error 1
make: *** [Project_Settings/Startup_Code/subdir.mk:42: Project_Settings/Startup_Code/system.o] Error 1
"make -j8 all" terminated with exit code 2. Build might be incomplete.
10:29:02 Build Failed. 11 errors, 0 warnings. (took 454ms)
Daniel-Aguirre
%3CLINGO-SUB%20id%3D%22lingo-sub-1916089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EStandardTypes.h%20not%20find%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20used%20the%20SW32G_RTD_4.4_4.0.2%20and%20added%20it%20in%20Design%20Studio.%20After%20compiling%20the%20application%20I%20got%20this%20error%3A%3C%2FP%3E%3CP%3Efatal%20error%3A%20StandardTypes.h%3A%20No%20such%20file%20or%20directory%3C%2FP%3E%3CP%3ESo%2C%20could%20you%20please%20help%20me%20to%20find%20the%20solution%3F%3C%2FP%3E%3CP%3ENote%3A%20this%20header%20file%20will%20call%20by%26nbsp%3BSiul2_Dio_Ip.h%3C%2FP%3E%3CP%3EI%20installed%20these%20packages%3A%26nbsp%3B%3C%2FP%3E%3CP%3ES32%20Configuration%20Tools%20Package%3CBR%20%2F%3ES32%20Design%20Studio%20Platform%20package%3CBR%20%2F%3ES32%20Trace%20Package%3CBR%20%2F%3ES32G%20development%20package%3CBR%20%2F%3ES32G2%20AUTOSAR%204.4%20RTD%204.0.2%20D2306%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1919530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20StandardTypes.h%20not%20find%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1919530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20feedback.%20For%20the%20following%20comment%3A%3C%2FP%3E%0A%3CP%3E%3CEM%3E%3CSPAN%3ENo%2C%20for%20the%20examples%20how%20can%20I%20do%20the%20setting%20tools%3F%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EWe%20understand%20that%20you%20did%20not%20generate%20the%20required%20code%20under%20the%20example.%20For%20that%2C%20you%20right-click%20under%20the%20project%20itself%20then%20select%20the%20following%20option%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielAguirre_0-1722264688360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielAguirre_0-1722264688360.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290802iB2E7D329B4AB5A2A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DanielAguirre_0-1722264688360.png%22%20alt%3D%22DanielAguirre_0-1722264688360.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielAguirre_0-1722264688360.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%2C%20under%20configuration%20tools%2C%20click%20the%20following%20button%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielAguirre_1-1722264721209.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielAguirre_1-1722264721209.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290804iC4DD078B626BE359%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DanielAguirre_1-1722264721209.png%22%20alt%3D%22DanielAguirre_1-1722264721209.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielAguirre_1-1722264721209.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIt%20should%20be%20green%20prior%20to%20the%20generation%20of%20code%20and%20gray%20(as%20shown%20above)%20once%20the%20code%20has%20been%20correctly%20generated.%20From%20our%20side%2C%20we%20have%20generated%20the%20example%20you%20have%20provided%20the%20logs%20for%20no%20problem%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DanielAguirre_2-1722264792413.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DanielAguirre_2-1722264792413.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290805iE306C8CC7AE9C6D9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22DanielAguirre_2-1722264792413.png%22%20alt%3D%22DanielAguirre_2-1722264792413.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDanielAguirre_2-1722264792413.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPlease%2C%20let%20us%20know.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1919273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20StandardTypes.h%20not%20find%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1919273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%2C%20for%20the%20examples%20how%20can%20I%20do%20the%20setting%20tools%3F%3C%2FP%3E%3CP%3EThis%20the%20error%20that%20I%20paste%20here%3A%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E10%3A29%3A02%20****%20Build%20of%20configuration%20Debug_RAM%20for%20project%20Clock_Ip_Example_S32G274A_M7%20****%3CBR%20%2F%3Emake%20-j8%20all%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fsrc%2Fmain.c%3CBR%20%2F%3EBuilding%20file%3A%20..%2FProject_Settings%2FStartup_Code%2FVector_Table.s%3CBR%20%2F%3EBuilding%20file%3A%20..%2FProject_Settings%2FStartup_Code%2Fexceptions.c%3CBR%20%2F%3EBuilding%20file%3A%20..%2FProject_Settings%2FStartup_Code%2Fnvic.c%3CBR%20%2F%3EBuilding%20file%3A%20..%2FProject_Settings%2FStartup_Code%2Fstartup.c%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3EBuilding%20file%3A%20..%2FProject_Settings%2FStartup_Code%2Fstartup_cm7.s%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20Assembler%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3EBuilding%20file%3A%20..%2FProject_Settings%2FStartup_Code%2Fsystem.c%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2Fexceptions.args%22%20-MMD%20-MP%20-MF%22Project_Settings%2FStartup_Code%2Fstartup.d%22%20-MT%22Project_Settings%2FStartup_Code%2Fstartup.o%22%20-o%20%22Project_Settings%2FStartup_Code%2Fstartup.o%22%20%22..%2FProject_Settings%2FStartup_Code%2Fstartup.c%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2FVector_Table.args%22%20-o%20%22Project_Settings%2FStartup_Code%2FVector_Table.o%22%20%22..%2FProject_Settings%2FStartup_Code%2FVector_Table.s%22%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20Assembler%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2Fexceptions.args%22%20-MMD%20-MP%20-MF%22Project_Settings%2FStartup_Code%2Fexceptions.d%22%20-MT%22Project_Settings%2FStartup_Code%2Fexceptions.o%22%20-o%20%22Project_Settings%2FStartup_Code%2Fexceptions.o%22%20%22..%2FProject_Settings%2FStartup_Code%2Fexceptions.c%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40src%2Fmain.args%22%20-MMD%20-MP%20-MF%22src%2Fmain.d%22%20-MT%22src%2Fmain.o%22%20-o%20%22src%2Fmain.o%22%20%22..%2Fsrc%2Fmain.c%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2FVector_Table.args%22%20-o%20%22Project_Settings%2FStartup_Code%2Fstartup_cm7.o%22%20%22..%2FProject_Settings%2FStartup_Code%2Fstartup_cm7.s%22%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2Fexceptions.args%22%20-MMD%20-MP%20-MF%22Project_Settings%2FStartup_Code%2Fnvic.d%22%20-MT%22Project_Settings%2FStartup_Code%2Fnvic.o%22%20-o%20%22Project_Settings%2FStartup_Code%2Fnvic.o%22%20%22..%2FProject_Settings%2FStartup_Code%2Fnvic.c%22%3CBR%20%2F%3EIn%20file%20included%20from%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FStandardTypes.h%3A50%2C%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2Fexceptions.args%22%20-MMD%20-MP%20-MF%22Project_Settings%2FStartup_Code%2Fsystem.d%22%20-MT%22Project_Settings%2FStartup_Code%2Fsystem.o%22%20-o%20%22Project_Settings%2FStartup_Code%2Fsystem.o%22%20%22..%2FProject_Settings%2FStartup_Code%2Fsystem.c%22%3CBR%20%2F%3Efrom%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FStd_Types.h%3A49%2C%3CBR%20%2F%3Efrom%20..%2FProject_Settings%2FStartup_Code%2Fstartup.c%3A27%3A%3CBR%20%2F%3EC%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FPlatform_Types.h%3A55%3A10%3A%20fatal%20error%3A%20PlatformTypes.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E55%20%7C%20%23include%20%22PlatformTypes.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3A%20Project_Settings%2FStartup_Code%2Fstartup.o%5D%20Error%201%3CBR%20%2F%3Emake%3A%20***%20Waiting%20for%20unfinished%20jobs....%3CBR%20%2F%3EIn%20file%20included%20from%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FStandardTypes.h%3A50%2C%3CBR%20%2F%3EFinished%20building%3A%20..%2FProject_Settings%2FStartup_Code%2FVector_Table.s%3CBR%20%2F%3Efrom%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FMcal.h%3A59%2C%3CBR%20%2F%3Efrom%20..%2Fsrc%2Fmain.c%3A23%3A%3CBR%20%2F%3EC%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FPlatform_Types.h%3A55%3A10%3A%20fatal%20error%3A%20PlatformTypes.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E55%20%7C%20%23include%20%22PlatformTypes.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3EIn%20file%20included%20from%20..%2FProject_Settings%2FStartup_Code%2Fexceptions.c%3A36%3A%3CBR%20%2F%3EC%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FPlatform_Types.h%3A55%3A10%3A%20fatal%20error%3A%20PlatformTypes.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E%3CBR%20%2F%3E55%20%7C%20%23include%20%22PlatformTypes.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3EIn%20file%20included%20from%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FStandardTypes.h%3A50%2C%3CBR%20%2F%3Efrom%20C%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FStd_Types.h%3A49%2C%3CBR%20%2F%3Efrom%20..%2FProject_Settings%2FStartup_Code%2Fnvic.c%3A32%3A%3CBR%20%2F%3EC%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FPlatform_Types.h%3A55%3A10%3A%20fatal%20error%3A%20PlatformTypes.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3EFinished%20building%3A%20..%2FProject_Settings%2FStartup_Code%2Fstartup_cm7.s%3CBR%20%2F%3E55%20%7C%20%23include%20%22PlatformTypes.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3A%20Project_Settings%2FStartup_Code%2Fexceptions.o%5D%20Error%201%3CBR%20%2F%3Emake%3A%20***%20%5Bsrc%2Fsubdir.mk%3A20%3A%20src%2Fmain.o%5D%20Error%201%3CBR%20%2F%3EIn%20file%20included%20from%20..%2FProject_Settings%2FStartup_Code%2Fsystem.c%3A42%3A%3CBR%20%2F%3EC%3A%2FNXP%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_4_0_0%2FRTD%2FBaseNXP_TS_T40D11M40I2R0%2Finclude%2FPlatform_Types.h%3A55%3A10%3A%20fatal%20error%3A%20PlatformTypes.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E55%20%7C%20%23include%20%22PlatformTypes.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3A%20Project_Settings%2FStartup_Code%2Fnvic.o%5D%20Error%201%3CBR%20%2F%3E%3CBR%20%2F%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A42%3A%20Project_Settings%2FStartup_Code%2Fsystem.o%5D%20Error%201%3CBR%20%2F%3E%22make%20-j8%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%3C%2FP%3E%3CP%3E10%3A29%3A02%20Build%20Failed.%2011%20errors%2C%200%20warnings.%20(took%20454ms)%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20StandardTypes.h%20not%20find%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20feedback.%3C%2FP%3E%0A%3CP%3ECan%20you%20provide%20a%20capture%20of%20the%20error%20being%20printed%20under%20S32%20Design%20Studio%3F%3C%2FP%3E%0A%3CP%3EHave%20you%20generated%20the%20required%20code%20under%20Config%20Tools%20prior%20to%20compiling%20the%20example%3F%3C%2FP%3E%0A%3CP%3EPlease%2C%20let%20us%20know.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20StandardTypes.h%20not%20find%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32DS.3.5%26nbsp%3B%20%26nbsp%3Bversion%20I%20am%20using.%3C%2FP%3E%3CP%3EI%20have%20run%20two%20applications%20one%20from%20example%20and%20another%20from%20my%20own.%3C%2FP%3E%3CP%3EI%20got%20this%20error%20for%20building%20the%26nbsp%3BAdc_example_S32G274A_M7%20example%3A%3C%2FP%3E%3CP%3Efatal%20error%3A%20PlatformTypes.h%3A%20No%20such%20file%20or%20directory%26nbsp%3B55%20%7C%20%23include%20%22PlatformTypes.h%22%3C%2FP%3E%3CP%3Eand%20for%20my%20own%20application%20I%20got%20this%20error%3A%3C%2FP%3E%3CP%3E%3CSPAN%3Efatal%20error%3A%20StandardTypes.h%3A%20No%20such%20file%20or%20directory%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20StandardTypes.h%20not%20find%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3ECan%20you%20let%20us%20know%20which%20S32%20Design%20Studio%20version%20are%20you%20using%3F%3C%2FP%3E%0A%3CP%3EAre%20you%20using%20any%20NXP%20examples%3F%20If%20so%2C%20which%20one%3F%20Can%20you%20provide%20a%20capture%20of%20the%20error%20being%20printed%20under%20S32%20Design%20Studio%3F%3C%2FP%3E%0A%3CP%3EHave%20you%20generated%20the%20required%20code%20prior%20to%20compiling%20the%20example%3F%3C%2FP%3E%0A%3CP%3EPlease%2C%20let%20us%20know.%3C%2FP%3E%3C%2FLINGO-BODY%3E
