Sboot FCCU Ncf Tests - Alarm Timeout Enable
Irshad2225
While testing Sboot FCCU NCF tests, one of the tests is getting failed due to alarm timeout disabled. Its not available in Emecm module.
Could you mention where exactly it can be configured?
Irshad
Tags (5)
chenyin_h
Hello, @Irshad2225
Thanks for your confirmation.
The CMU_SAFETY_CORES_ERROR is related to the CMU_FC checking, I have checked the FCCU settings in eMcem, it is related to the fault_28, may I know if you have correctly set it via the eMcem?
Chenyin
chenyin_h
Hello, @Irshad2225
Thanks for your post.
May I know which version SAF is used on your board? which test failed?
Chenyin
Irshad2225
Hi Chenyin,
SAF version: SW32G_SAF_2.0.2_QLP01_D2410
I have enabled only CMU_SAFERY_CORES_ERROR as R3 for test configuration.
%3CLINGO-SUB%20id%3D%22lingo-sub-2138005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESboot%20FCCU%20Ncf%20Tests%20-%20Alarm%20Timeout%20Enable%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EWhile%20testing%20Sboot%20FCCU%20NCF%20tests%2C%20one%20of%20the%20tests%20is%20getting%20failed%20due%20to%20alarm%20timeout%20disabled.%20Its%20not%20available%20in%20Emecm%20module.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3ECould%20you%20mention%20where%20exactly%20it%20can%20be%20configured%3F%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%26nbsp%3B%3CBR%20%2F%3EIrshad%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2138005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGoldVIP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Sboot%20FCCU%20Ncf%20Tests%20-%20Alarm%20Timeout%20Enable%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242290%22%20target%3D%22_blank%22%3E%40Irshad2225%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20confirmation.%3C%2FP%3E%0A%3CP%3EThe%26nbsp%3B%3CSPAN%3ECMU_SAFETY_CORES_ERROR%26nbsp%3Bis%20related%20to%20the%20CMU_FC%20checking%2C%20I%20have%20checked%20the%20FCCU%20settings%20in%20eMcem%2C%20it%20is%20related%20to%20the%20fault_28%2C%20may%20I%20know%20if%20you%20have%20correctly%20set%20it%20via%20the%20eMcem%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EChenyin%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Sboot%20FCCU%20Ncf%20Tests%20-%20Alarm%20Timeout%20Enable%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Chenyin%2C%3CBR%20%2F%3E%3CBR%20%2F%3ESAF%20version%3A%20SW32G_SAF_2.0.2_QLP01_D2410%3CBR%20%2F%3EI%20have%20enabled%20only%20CMU_SAFERY_CORES_ERROR%20as%20R3%20for%20test%20configuration.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Sboot%20FCCU%20Ncf%20Tests%20-%20Alarm%20Timeout%20Enable%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242290%22%20target%3D%22_blank%22%3E%40Irshad2225%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EMay%20I%20know%20which%20version%20SAF%20is%20used%20on%20your%20board%3F%20which%20test%20failed%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
