S32g serial RCON
S32g serial RCON
775 次查看
LB666
I am using the S32G-VNP-RDB2 development board and I would like to test the serial boot. Can you tell me how to proceed?
644 次查看
chenyin_h
Hello, @LB666
Thanks for the feedback and clarification.
So you may consider the serial RCON, is it right? What is your exact question regarding to it?
You may reference the  detailed information in “31.3.2.2.2 Boot from serial RCON“ from S32G3 Reference Manual for this topic.
Best Regards
Chenyin
703 次查看
chenyin_h
Hello, @LB666
Thanks for the question and sorry for the delay
Serial Boot mode enables application code to be downloaded to SRAM.
On S32G2, CAN and UART could be used to support serial boot.
  1. Firstly, set the switches:
  1. Secondly, create serial boot images using IVT tools
You may reference the following link:
https://community.nxp.com/t5/S32G/How-to-create-an-image-for-serial-boot/td-p/1716703
  1. At last, transfer the generated image to the board via UART.
The details are shown from the link below:
https://community.nxp.com/t5/S32G/How-to-boot-an-image-from-uart/td-p/1718722
Hope it helps.
Best Regards
Chenyin
663 次查看
LB666
Thank you for your reply. This is not the answer I wanted. Perhaps I did not describe my problem clearly. Now, I am redefining my problem and would like to know how to start it on the S32g vnp rdb2 development board through serial EEPROM (at24c02)
