S32G399A-RDB3 QNX PFE Driver Problems
6,892件の閲覧回数
Seneca
Greetings,
we try to get PFE running on a S32G399A-RDB3 board with QNX. As far as I can tell, this is a valid combination:
BSP 37.0
PFE-FW_S32G_1.7.0
PFE-DRV-S32G_A53_QNX_1.4.0
It ends with a no carrier error on all network interfaces. Plugging the cable into different ethernet ports changes nothing.
It used to work with gmac0.
Any ideas?
io pkt call:
io-pkt-v6-hc -p tcpip -d pfe-2 pfe0_mac=000a0b0c0d66,pfe1_mac=001a1b1c1d66,pfe2_mac=002a2b2c2d66,class_fw=/proc/boot/s32g_pfe_class.fw,no_reset,mode0=sgmii,phy0=0,mode1=sgmii,phy1=1
Uboot parameters:
Uboot is the same as from the Linux sdcard image with modified parmeters for qnx boot.
setenv hwconfig "pcie0:mode=rc,clock=ext;pcie1:mode=sgmii,clock=ext,fmhz=125,xpcs_mode=2G5"
setenv pfeng_mode 'enable,sgmii,sgmii,rgmii'
setenv s32cc_gmac_mode disable
setenv pfeng enable; s32ccgmac disable; s32ccgmac enable;
setenv boot_qnx_atf 'mmc dev 0; fatload mmc 0:1 0x83e00000 s32g399a-rdb3.dtb; pfeng enable; s32ccgmac disable; s32ccgmac enable; fatload mmc 0:1 0x80080000 ifs-s32g399a-rdb.ui; bootm 0x80080000 - 0x83E00000'
setenv bootcmd 'run boot_qnx_atf'
saveenv
Log:
U-Boot 2020.04+g156b168010 (Jun 09 2023 - 10:14:25 +0000)
CPU:   NXP S32G399A rev. 1.1
Model: NXP S32G399A-RDB3
DRAM:  3.5 GiB
MMC:   FSL_SDHC: 0
Loading Environment from MMC... OK
Configuring PCIe0 as RootComplex
PCIe0: Failed to get link up
PCI: Failed autoconfig bar 1c
In:    serial@401c8000
Out:   serial@401c8000
Err:   serial@401c8000
Board revision: RDB3 Revision F
Net:   EQOS phy: rgmii @ 1
Warning: eth_eqos (eth0) using random MAC address - 26:e4:e6:43:15:ad
eth0: eth_eqosFailed to get speed of XPCS for emac1_xpcs PFE: emac0: sgmii emac1: sgmii emac2: rgmii
, eth1: eth_pfeng
Hit any key to stop autoboot:  3  2  1  0
switch to partitions #0, OK
mmc0 is current device
50640 bytes read in 17 ms (2.8 MiB/s)
11948752 bytes read in 540 ms (21.1 MiB/s)
## Booting kernel from Legacy Image at 80080000 ...
   Image Name:
   Image Type:   AArch64 Linux Kernel Image (uncompressed)
   Data Size:    11948688 Bytes = 11.4 MiB
   Load Address: 80080000
   Entry Point:  80080000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 83e00000
   Booting using the fdt blob at 0x83e00000
   Loading Kernel Image
   Using Device Tree in place at 0000000083e00000, end 0000000083e0f5cf
   fixup: pfe0 set to 00:01:be:be:ef:11
   fixup: pfe1 set to 00:01:be:be:ef:22
   fixup: pfe1: update phy addr to 0x8
   fixup: pfe2 set to 00:01:be:be:ef:33
Starting kernel ...
Reserving RAM region for PFE driver on EVB/RDB
Done.
ClockCycles samples:
 0 43600679
 1 43600679
 2 43600678
 3 43600679
 4 43600678
 5 43600678
 6 43600678
 7 43600679
All ClockCycles offsets within tolerance
Welcome to QNX Neutrino 7.1.0 on the NXP S32G399A RDB Board!!
Starting watchdog...
Starting serial driver ...
Starting Networking driver (/dev/socket)...
Process 4107 (ifconfig) exited status=0.
Process 10 (sh) exited status=0.
Process 9 (dhclient) exited status=0.
cp: Can't open source file.  (/proc/boot/libfci_cli)
Process 20489 (cp) exited status=1.
Starting SPI driver (/dev/spi0,1,2,3,4,5)...
Starting I2C 0/1/2/3/4 driver (/dev/i2c0,1,2,3,4)...
Starting USDHC0 memory card driver...
[00]     SIM="SDMMC" HBA="imx"
[00,0,0] type=00 ver=05 resp=00                       SDMMC:
Process 24596 (chkqnx6fs) exited status=0.
Process 28692 (mount) exited status=0.
Starting QSPI Flash driver...
Starting USB host driver (/dev/usb/*)
Detected QSPI Flash: Macronix MX25UW512, JEDEC 0xC2 - 0x813A, Size: 0x4000000
Launching devb-umass for /dev/usb/* ...
Process 36891 (sleep) exited status=0.
sh: /var/cetitec2/startup.sh: No such file or directory
Process 45081 (sh) terminated signo=0 code=0 by process 0 value=0.
slog2info
Jan 01 00:00:00.023                       random.4                  low*     0  qcrypto: loading configuration file '/etc/qcrypto.conf' [qcrypto_common.c(190)]
Jan 01 00:00:00.024                    random.4..0                 slog*   700  Random is using the Fortuna PRNG
Jan 01 00:00:00.031                       random.4                  low      0  qcrypto: 'openssl' plugin loaded [qcrypto_plugins.c(354)]
Jan 01 00:00:00.031                    random.4..0                 slog    700  Selecting timer as an entropy source
Jan 01 00:00:00.032                    random.4..0                 slog    700  Registered path names
Jan 01 00:00:00.032                    random.4..0                 slog    700  random: starting resmgr
Jan 01 00:00:00.032                    random.4..0                 slog    700  random: Daemonizing the process
Jan 01 00:00:00.042             devc_serlinflexd.7                 slog*     0  serlinflexd_interrupt_attach: Attaching to interrupt 114
Jan 01 00:00:00.047                        iopkt.8          main_buffer*     0  tcpip starting
Jan 01 00:00:00.047                        iopkt.8          main_buffer      0  smmu support is disabled
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0  initializing IPsec...
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0   done
Jan 01 00:00:00.049                        iopkt.8          main_buffer      0  IPsec: Initialized Security Association Processing.
Jan 01 00:00:00.051                        iopkt.8          main_buffer      0  devnp-pfe-2.so pfe0_mac=000a0b0c0d66,pfe1_mac=001a1b1c1d66,pfe2_mac=002a2b2c2d66,class_fw=/proc/boot/s32g_pfe_class.fw,pfe0_mode=sgmii,pfe0_phy=0,pfe1_mode=sgmii,pfe1_phy=1
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog*     0  INF[src/pfe_drv.c:1377]: VERSION INFO
Driver version: 1.4.0
Driver commit hash: 2f3265a49ac18f94ba5e48254c8f870fe7bfc511
PFE_CFG_MULTI_INSTANCE_SUPPORT: 0
PFE_CFG_LOCAL_IF: 6
PFE_CFG_MASTER_IF: 6
PFE_CFG_SC_HIF: 1
PFE_CFG_HIF_RING_LENGTH: 256
PFE_CFG_PFE0_PROMISC: 1
PFE_CFG_PFE1_PROMISC: 1
PFE_CFG_PFE2_PROMISC: 1
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1384]: --- Safe IRQ enabled. No InterrupAttach() or InterruptAttach_r() allowed.
Jan 01 00:00:00.052                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_fw.c:83]: 42792 bytes read
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_fw.c:89]: Loaded firmware file: /proc/boot/s32g_pfe_class.fw
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe0/EMAC0 not found. Using SGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe1/EMAC1 not found. Using SGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1477]: MII mode configuration for pfe2/EMAC2 not found. Using RGMII.
Jan 01 00:00:00.053                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1495]: Issuing PFE peripheral reset...
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1496]: PFE reset OK.
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3519]: PFE CBUS p0x46000000 mapped @ v0x38f2e23000
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3524]: HW version 0x101
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hw_feature.c:95]: Silicon S32G3
Jan 01 00:00:00.274                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:3536]: Fail-Stop mode disabled
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2687]: PFE_ERRORS:Parity instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2702]: PFE_ERRORS:Watchdog instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2718]: PFE_ERRORS:Bus Error instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2731]: PFE_ERRORS:FW Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2744]: PFE_ERRORS:Host Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2757]: PFE_ERRORS:Fail Stop instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2770]: PFE_ERRORS:ECC Err instance created
Jan 01 00:00:00.275                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:1766]: BMU1 buffer base: p0xc0000000
Jan 01 00:00:00.277                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:1810]: BMU2 buffer base: p0x83000000 (0x200000 bytes)
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE BMU IRQ Worker started (IRQ ID: 226)
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2194]: The option 'g2_ordered_class_writes' is disabled.
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_bmu_csr.c:96]: BMU_EMPTY_INT (BMU @ p0x88000). Pool ready.
Jan 01 00:00:00.279                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_bmu_csr.c:96]: BMU_EMPTY_INT (BMU @ p0x8c000). Pool ready.
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2239]: Firmware .elf detected
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2248]: Uploading CLASS firmware
Jan 01 00:00:00.281                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:609]: Selected FW loading OPs to load 8 PEs in parallel
Jan 01 00:00:00.285                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:1945]: pfe_ct.h file version"92367c0e25f21f49217a9b08168ad2c8"
Jan 01 00:00:00.288                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_pe.c:2422]: [FW VERSION] 1.7.0, Build: Jun  2 2023, 13:48:57 (nogitaaa), ID: 0x31454650
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2312]: VLAN ID incorrect or not set. Using default VLAN ID = 0x01.
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  WRN[hw/s32g/pfe_platform_master.c:2318]: VLAN stats size incorrect or not set. Using default VLAN stats size = 20.
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1181]: Software vlan hash table @ p0x20001228
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1286]: Fall-back bridge domain @ 0x20000a7c (class)
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_l2br.c:1287]: Default bridge domain @ 0x20000a74 (class)
Jan 01 00:00:00.406                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:2412]: Routing table created, Hash Table @ p0x80014000, Pool @ p0x8001c000 (65536 bytes)
Jan 01 00:00:00.407                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.408                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.409                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_chnl.c:1997]: Initializing RX buffer pool. Depth: 256; Buffer Size: 2048; Cache Line Size: 64
Jan 01 00:00:00.508                 io_pkt_v6_hc.8                 slog      0  INF[hw/s32g/pfe_platform_master.c:3705]: Feature err051211_workaround: DISABLED
Jan 01 00:00:00.509                        iopkt.8          main_buffer      0  pfe0
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2152]: pfe0: Using PHY mode: MDIO=0, ADDR=0, CLAUSE=0, RESET=0
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF0 IRQ Worker started (IRQ ID: 222)
Jan 01 00:00:00.509                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.511                        iopkt.8          main_buffer      0  pfe1
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe0 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 0, ID: 0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2152]: pfe1: Using PHY mode: MDIO=1, ADDR=0, CLAUSE=0, RESET=0
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF1 IRQ Worker started (IRQ ID: 223)
Jan 01 00:00:00.511                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:1a:1b:1c:1d:66 to pfe1
Jan 01 00:00:00.513                        iopkt.8          main_buffer      0  pfe2
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe1 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 1
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 1, ID: 2
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2145]: pfe2: Using static PHY mode, RESET=0
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/oal_irq_qnx.c:117]: PFE HIF2 IRQ Worker started (IRQ ID: 224)
Jan 01 00:00:00.513                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:1795]: Adding 00:2a:2b:2c:2d:66 to pfe2
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2298]: Speed/duplex configuration for pfe2 not found. Using 1 Gbps/full-duplex.
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:336]: Attempt to register HIF client: 2
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_hif_drv_sc.c:1189]: HIF driver started
Jan 01 00:00:00.515                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2363]: New PFE device: 2, ID: 4
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2702]: Adding 00:0a:0b:0c:0d:66 to pfe0
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2707]: Unable to assign MAC address 00:0a:0b:0c:0d:66 to the pfe0
Jan 01 00:00:00.530                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_mdio.c:427]: pfe0: PHY @ bus 0 addr 0 not found. Switching to static mode.
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.538                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.540                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.540                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2829]: EMAC speed change for SGMII is currently not supported.
Jan 01 00:00:00.542                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 01:00:5e:00:00:01 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:00:00:00:01 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:00:00:00:01 into emac0: 17
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2443]: Adding 33:33:ff:0c:0d:66 to emac0
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  WRN[src/pfe_drv.c:2450]: unable to add 33:33:ff:0c:0d:66 into emac0: 17
Jan 01 00:00:00.544                 io_pkt_v6_hc.8                 slog      0  INF[src/pfe_drv.c:2663]: pfe0: Disabling promiscuous mode
Jan 01 00:00:00.554               spi_master.24585               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.558               spi_master.24587               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.561               spi_master.24588               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.565               spi_master.24589               normal*     0  Starting spi-master resource manager
Jan 01 00:00:00.582          devb_sdmmc_mx8x.24595                 slog*  1800  devb-sdmmc-mx8x 1.00A (Jun 23 2026 09:45:48)
Jan 01 00:00:00.583          devb_sdmmc_mx8x.24595                 slog      0  libcam.so (Jun 22 2020 21:33:15) bver 7010003
Jan 01 00:00:00.594          devb_sdmmc_mx8x.24595                 slog   1800  sdio_cd:  insertion path 0, cd state 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD CID:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    MID 0x27, OID 0x5048, PNM SD32G
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    PRV 0x62, PSN 0x6c62d132, MDT 4-2023
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD CSD:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    CSD_STRUCTURE 1, SPEC_VERS 0, CCC 0x5b5
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    TAAC 14, NSAC 0, TRAN_SPEED 50
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    C_SIZE 59023, C_SIZE_MULT 0
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    READ_BL_LEN 9, WRITE_BL_LEN 9
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    ERASE GRP_SIZE 0, GRP_MULT 0, SIZE 127
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    blksz 512, sectors 60440576, dtr 25000000
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  SD SW CAPS:
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    bus mode 0x3, cmd sys 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    drv type 0x1, curr limit 0x1
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800    dtr 50000000
Jan 01 00:00:00.644          devb_sdmmc_mx8x.24595                 slog   1800  CFG:  Timing HS, DTR 50000000, Bus Width 4 bit
Jan 01 00:00:00.645          devb_sdmmc_mx8x.24595                 slog    100  cam-disk.so (Jun 22 2020 21:33:17)
Jan 01 00:00:00.647          devb_sdmmc_mx8x.24595                 slog      0  scsi_interpret_sense (sdmmc ptl-0:0:0):  cam_status=c4, scsi_status=2, flag=00000040, vuflag=0008, cmd=1a, error=70, sense=5, asc=24, ascq=0
Jan 01 00:00:00.647          devb_sdmmc_mx8x.24595                 slog      0  scsi_interpret_sense (sdmmc ptl-0:0:0):  cam_status=c4, scsi_status=2, flag=00000040, vuflag=0008, cmd=5a, error=70, sense=5, asc=24, ascq=0
Jan 01 00:00:01.827          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: Allocation strategy 0
Jan 01 00:00:01.827          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: Use btree directory 0
Jan 01 00:00:01.828          devb_sdmmc_mx8x.24595                 slog   1000  fs-qnx6: fs-qnx6: trim (0,1048576,2) was not requested, and is NOT supported
Jan 01 00:00:01.833               io_usb_otg.36885                 slog*     0  main(453)[tid:1]: io-usb-otg (Jun 13 2020 20:10:17) args: -d hcd-ehci-mx28 ioport=0x44064100,irq=243,ulpi,no_stream,verbose=5
Jan 01 00:00:01.835           devf_qspi_s32g.36884                 slog*     0  (devf  t1::f3s_qspi_ident:73) Page size: 256
Jan 01 00:00:01.835           devf_qspi_s32g.36884                 slog      0  (devf  t1::f3s_qspi_ident:74) Total chip size: 0x4000000, Unit size: 0x10000
Jan 01 00:00:01.839               io_usb_otg.36885                 slog      0  ehci_init: Initialiaing with sever version: 2
Jan 01 00:00:01.839               io_usb_otg.36885                 slog      0  ehci_controller_init(4303): devu-hcd-ehci-mx28.so (Apr 19 2024 13:44:54):  args ulpi,no_stream,verbose=5
Jan 01 00:00:01.840               io_usb_otg.36885                 slog      8  usb_enum_port(94)[tid:1]: busno 0, parent -1, port 0, High speed
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     12  usb_device_set_address(245)[tid:1]: b:0 devno 0
Jan 01 00:00:01.840               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 1, index 0, length 18)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 9)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  usb_client_descriptor_get(198)[tid:1]: (type 2, index 0, length 25)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog      8  usb_enum_port(141)[tid:1]: vid 0x0000, did 0x0000 enumerated(busno 0, devno 0:0)
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     11  hub_state_inserted(569)[tid:1]: bdentry 0, dentry 0 0
Jan 01 00:00:01.841               io_usb_otg.36885                 slog     13  hub_configuration_enable(263)[tid:1]: 1
Jan 01 00:00:01.943               io_usb_otg.36885                 slog      0  usbh_timeout_init(203)[tid:1]: Complete
Jan 01 00:00:01.954               io_usb_otg.36885                 slog      0  read_vid_pid: ULPI VID 0x0424 PID 0x0009
Jan 01 00:00:01.954               io_usb_otg.36885                 slog      0  s32g_phy_set_vbus: set_vbus off
Jan 01 00:00:01.968               io_usb_otg.36885                 slog      0  s32g_phy_set_vbus: set_vbus on
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      0  ehci_get_port_status(3568 0x44064100): port=0, tpstatus 10100 e_pstatus 8c001000
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      8  usb_enum_port_extract(172)[tid:7]: (busno 0, pdevno 0, portno 1)
Jan 01 00:00:01.979               io_usb_otg.36885                 slog      8  usb_enum_port_extract(192)[tid:7]: status (2)
Jan 01 00:00:01.983               devb_umass.36886                 slog*   900  devb-umass 1.00A (Jun 22 2020 21:33:41)
Jan 01 00:00:01.984               devb_umass.36886                 slog      0  libcam.so (Jun 22 2020 21:33:15) bver 7010003
Jan 01 00:00:01.985               io_usb_otg.36885                 slog      0  usbdi_client_connect(58)[tid:5]: pid 36886 proc=proc/boot/devb-umass usbdi_client 32eebb9a80
Jan 01 00:00:01.986               io_usb_otg.36885                 slog      0  usbdi_resmgr_connect(310)[tid:5]: usbdi_resmgr_connect: pid 36886 usbdi_client 32eebb9a80
Jan 01 00:00:01.986               devb_umass.36886                 slog      0  usbdi debug path /pps/usb/debug/ doesn't exist
Process 49177 (slog2info) exited status=0.
# ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33136
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
pfe0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
capabilities=1f<IP4CSUM,TCP4CSUM,UDP4CSUM,TCP6CSUM,UDP6CSUM>
enabled=0
address: 00:0a:0b:0c:0d:66
media: Ethernet none (1000baseT full-duplex)
status: active
inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255
inet6 fe80::20a:bff:fe0c:d66%pfe0 prefixlen 64 scopeid 0x11
pfe1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
enabled=0
address: 00:1a:1b:1c:1d:66
status: no carrier
pfe2: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
enabled=0
address: 00:2a:2b:2c:2d:66
status: no carrier
Process 57369 (ifconfig) exited status=0.
54 返答(返信)
1,110件の閲覧回数
Seneca
Another thing. Will this uboot line recommended in the integration manual:
hwconfig "serdes0:mode=pcie,clock=ext;pcie0:mode=rc;serdes1:mode=xpcs0&xpcs1,clock=ext,fmhz=125;xpcs1_0:speed=2G5;xpcs1_1:speed=1G"
Really enable gmac0, pfe0 and pfe2 as individual interfaces or only two of them?
1,109件の閲覧回数
chenyin_h
Hello, @Seneca
Thanks for your reply.
1. For the hwconfig you mentioned, when using them on RDB3, the 3 MACs could all be used.
2. For the error log you shared, sorry that we do not commonly support QNX commands directly, form my personal experience, it may caused by the command used itself, I suggest  re-checking syntax of commands based on the QNX document.
3. Under QNX, there are some limitation for the PFE driver, auto-negotiation is not supported, so you may make sure that the two sides are running with the same speed.
Chenyin
1,096件の閲覧回数
Seneca
Greetings,
I recorded the network adapter state of a LInux Laptop that successfully connects to the TC387 media converter (which should be in 100T1 master mode). Can you tell me if pfe2 can drive this mode?
  *-network:1
       description: Ethernet interface
       physical id: e
       bus info: usb@2:4
       logical name: enx00e04c680383
       serial: 00:e0:4c:68:03:83
       capacity: 1Gbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.12.13 duplex=full firmware=rtl8153b-2 v2 04/27/23 ip=192.168.10.102 link=yes multicast=yes port=MII speed=100Mbit/s
       NIC statistics:
     tx_packets: 60
     rx_packets: 3
     tx_errors: 0
     rx_errors: 0
     rx_missed: 0
     align_errors: 0
     tx_single_collisions: 0
     tx_multi_collisions: 0
     rx_unicast: 3
     rx_broadcast: 0
     rx_multicast: 0
     tx_aborted: 0
     tx_underrun: 0
     enx00e04c680383: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.10.102  netmask 255.255.255.0  broadcast 192.168.10.255
        inet6 fe80::9165:ed06:804a:54c0  prefixlen 64  scopeid 0x20<link>
        ether 00:e0:4c:68:03:83  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        Settings for enx00e04c680383:
Supported ports: [ TP MII ]
Supported link modes:   10baseT/Half 10baseT/Full
                        100baseT/Half 100baseT/Full
                        1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes:  10baseT/Half 10baseT/Full
                        1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes:  10baseT/Half 10baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 100Mb/s
Duplex: Full
Auto-negotiation: on
Port: MII
PHYAD: 32
Transceiver: internal
Supports Wake-on: pumbg
Wake-on: g
        Current message level: 0x00007fff (32767)
                               drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol
Link detected: yes
1,092件の閲覧回数
chenyin_h
Hello, @Seneca
Thanks for your post.
1. I can confirm that the PFE2 port on RDB3 could work correctly with connection to 100T1 network via a 100base-TX<->100base-T1 converter under Linux BSP provisioned by NXP.
2. You may try the following command for a test: io-pkt-v6-hc -p tcpip -d pfe2_link=100-1-2
But I am not very sure for these settings on QNX since it is beyond our S32G community supporting scope,  sorry for your inconvenience.
Chenyin
1,102件の閲覧回数
Seneca
Greetings,
I tried setting the correct speed on QNX with something like
ifconfig pfe2 media 100baseTX mediaopt full-duplex
but it wasn't enough. Do I have to do something else, maybe even in uboot parameters?
1,111件の閲覧回数
Seneca
Greetings,
after more research it seem that pfe_mac2 in particular has problems with our 100T1 ethernet adapters. Connecting a Linux Laptop with USB ethernet works fine though.
Do you know if pfe_mac2 can connect to this adapter type correctly and if I have to do something special to make it work?
1,113件の閲覧回数
Seneca
Ok, so I should be able to use, from the three stacked ports, left port as pfe0 and top center as pfe2 I presume. Bottom center for gmac0.
Now, I try to start the interfaces in bridge mode using the following io pkt syntax (note the bridge parameter behind tcp ip):
io-pkt-v6-hc -p tcpip bridge pkt_typed_mem=pfe_ddr -d dwceqos-s32g mac=`genmac-random -m`,ptp_off,verbose=5 -d /proc/boot/devnp-pfe-2.so pfe0_mac=000a0b0c0d66,pfe1_mac=001a1b1c1d66,pfe2_mac=002a2b2c2d66,class_fw=/proc/boot/s32g_pfe_class.fw,util_fw=/proc/boot/s32g_pfe_util.fw
ifconfig dwc0 192.168.10.100 up
ifconfig pfe0 0.0.0.0 up
ifconfig pfe2 0.0.0.0 up
ifconfig bridge0 create
ifconfig bridge0 add dwc0 add pfe0 add pfe2 up
This will result in lots of memory errors in slog2info
Jan 01 00:04:37.485 io_pkt_v6_hc.159753 slog 0 ERR[src/pfe_drv.c:2996]: (DRIVER) event 1 - Driver runtime error: Mbuf addr out of 32bit. Start @ p0x8df239b58 end @ p0x8df239b82
Jan 01 00:04:38.485 io_pkt_v6_hc.159753 slog 0 ERR[src/pfe_drv.c:2996]: (DRIVER) event 1 - Driver runtime error: Mbuf addr out of 32bit. Start @ p0x8df239558 end @ p0x8df239582
Jan 01 00:04:39.451 io_pkt_v6_hc.159753 slog 0 ERR[src/pfe_drv.c:2996]: (DRIVER) event 1 - Driver runtime error: Mbuf addr out of 32bit. Start @ p0x8df239b58 end @ p0x8df239b82
Is bridge parameter correct in io-pkt-v6-hc call?
Also, I use this allocation from the driver integration manual for both gmac0 and pfe as can be seen in the io-pkt-v6-hc call. Is that a problem?
kprintf("Reserving RAM region for PFE driver on EVB/RDB\n");
as_add_containing(0x80000000,0x80000000 + 0x4000000 - 1,AS_ATTR_RAM, "pfe_ddr","ram");
1,169件の閲覧回数
Seneca
Greetings,
when I connect the TC387 to my Linux desktop there are lots of arp/icmp messages produced immediately. The same when I connect my S32G pfe2 port to the Linux desktop. But when I connect the TC387 to the S32G pfe2 port I get not arp or icmp messages at all.
For which error messages should I look?
1,304件の閲覧回数
Seneca
Greetings,
can you tell me if 192.168.0.200 listens to broadcast calls or something like that?
1,260件の閲覧回数
chenyin_h
Hello, @Seneca
This IP could receive the broadcast packets from linked devices.
Chenyin
1,313件の閲覧回数
Seneca
Greetings,
init_serdes();
has been commented out from the s32g399a-rdb main.c.
1,401件の閲覧回数
Seneca
Greetings,
I intend to try the following combination:
BSP 33
PFE Driver 1.2.0
PFE FW 1.3.0
Is this officially supported?
1,321件の閲覧回数
chenyin_h
Hello. @Seneca
1. For the combination, I suggest referencing the documents included in the QNX PFE drivers directly, which included the recommended/tested combination.
Other combination may or may not work, you may test it accordingly if indeed needed.
2. From the available information, for QNX PFE drive 1.2, the supported PFE FW is 1.2 with BSP30 used for test
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2385092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G399A-RDB3%20QNX%20PFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385092%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AFQNX%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FS32G399A-RDB3%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7PFE%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%88%E3%81%86%E3%81%A8%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A7%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CSPAN%3EBSP%2037.0%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3EPFE-FW_S32G_1.7.0%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3EPFE-DRV-S32G_A53_QNX_1.4.0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E3%80%8C%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%97%E3%80%8D%E3%81%A7%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%B7%AE%E3%81%97%E3%81%A6%E3%82%82%E4%BD%95%E3%82%82%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E5%89%8D%E3%81%AFgmac0%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3Eio%20pkt%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%3A%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%20-p%20tcpip%20-d%20pfe-2%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cno_reset%2Cmode0%3Dsgmii%2Cphy0%3D0%2Cmode1%3Dsgmii%2Cphy1%3D1%3C%2FP%3E%3CP%3EU-Boot%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%EF%BC%9A%3C%2FP%3E%3CP%3EUboot%E3%81%AFLinux%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%80%81qnx%E3%83%96%E3%83%BC%E3%83%88%E7%94%A8%E3%81%AB%E3%83%91%E3%83%BC%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20hwconfig%20%22pcie0%3Amode%3Drc%2Cclock%3Dext%3Bpcie1%3Amode%3Dsgmii%2Cclock%3Dext%2Cfmhz%3D125%2Cxpcs_mode%3D2G5%22%3CBR%20%2F%3E%20setenv%20pfeng_mode%20'enable%2Csgmii%2Csgmii%2Crgmii'%3CBR%20%2F%3E%20setenv%20s32cc_gmac_mode%20disable%3CBR%20%2F%3E%20setenv%20pfeng%20enable%3B%20s32ccgmac%20disable%3B%20s32ccgmac%20enable%3B%3CBR%20%2F%3E%20setenv%20boot_qnx_atf%20'mmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3Bpfeng%20%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%3B%20s32ccgmac%20%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%3B%20s32ccgmac%20%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%3B%20fatload%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%3Bbootm%200x80080000%20-%200x83E00000'%3CBR%20%2F%3E%20setenv%20bootcmd%20'run%20boot_qnx_atf'%3CBR%20%2F%3E%20saveenv%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%AD%E3%82%B0%EF%BC%9A%3C%2FP%3E%3CDIV%3EU-Boot%202020.04%2Bg156b168010(2023%E5%B9%B46%E6%9C%889%E6%97%A5%2010%3A14%3A25%20%2B0000)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECPU%3A%20NXP%20S32G399A%20rev.1.1%3C%2FDIV%3E%3CDIV%3E%E3%83%A2%E3%83%87%E3%83%AB%3ANXP%20S32G399A-RDB3%3C%2FDIV%3E%3CDIV%3EDRAM%3A%203.5%20GiB%3C%2FDIV%3E%3CDIV%3EMMC%3A%20FSL_SDHC%3A%200%3C%2FDIV%3E%3CDIV%3EMMC%E3%81%8B%E3%82%89%E7%92%B0%E5%A2%83%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99...%20OK%3C%2FDIV%3E%3CDIV%3EPCIe0%E3%82%92%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3EPCIe0%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3EPCI%3A%20%E8%87%AA%E5%8B%95%E6%A7%8B%E6%88%90%E3%83%90%E3%83%BC%201c%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%E5%85%A5%E5%8A%9B%3A%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E5%87%BA%E5%8A%9B%3A%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E3%83%9C%E3%83%BC%E3%83%89%E6%94%B9%E8%A8%82%EF%BC%9ARDB3%20%E6%94%B9%E8%A8%82F%3C%2FDIV%3E%3CDIV%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3A%20EQOS%20%E7%89%A9%E7%90%86%3A%20rgmii%20%40%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%AD%A6%E5%91%8A%3A%20eth_eqos%20(eth0)%20%E3%81%AF%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%20MAC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20-%2026%3Ae4%3Ae6%3A43%3A15%3Aad%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3Eeth0%3A%20eth_eqos%20emac1_xpcs%20%E3%81%AE%20XPCS%20%E3%81%AE%E9%80%9F%E5%BA%A6%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20PFE%3A%20emac0%3A%20sgmii%20emac1%3A%20sgmii%20emac2%3A%20rgmii%3C%2FDIV%3E%3CDIV%3E%E3%80%81eth1%3A%20eth_pfeng%3C%2FDIV%3E%3CDIV%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%203%202%201%200%3C%2FDIV%3E%3CDIV%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%80%81OK%3C%2FDIV%3E%3CDIV%3Emmc0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FDIV%3E%3CDIV%3E50640%E3%83%90%E3%82%A4%E3%83%88%E3%82%9217%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%882.8%20MiB%2F%E7%A7%92%EF%BC%89%3C%2FDIV%3E%3CDIV%3E11948752%E3%83%90%E3%82%A4%E3%83%88%E3%82%92540%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%8821.1%20MiB%2F%E7%A7%92%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%23%23%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%9280080000%E7%95%AA%E5%9C%B0%E3%81%A7%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%E7%94%BB%E5%83%8F%E5%90%8D%3A%3C%2FDIV%3E%3CDIV%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BF%E3%82%A4%E3%83%97%3AAArch64%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8(%E9%9D%9E%E5%9C%A7%E7%B8%AE)%3C%2FDIV%3E%3CDIV%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%3A%2011948688%E3%83%90%E3%82%A4%E3%83%88%20%3D%2011.4MiB%3C%2FDIV%3E%3CDIV%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2080080000%3C%2FDIV%3E%3CDIV%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A%2080080000%3C%2FDIV%3E%3CDIV%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E6%A4%9C%E8%A8%BC%E4%B8%AD...OK%3C%2FDIV%3E%3CDIV%3E%23%23%20%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%96%E3%83%AD%E3%83%96%20(83e00000)%3C%2FDIV%3E%3CDIV%3E0x83e00000%E3%81%AB%E3%81%82%E3%82%8Bfdt%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3C%2FDIV%3E%3CDIV%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%920000000083e00000%E3%81%A7%E4%BD%BF%E7%94%A8%E3%80%81%E7%B5%82%E4%BA%860000000083e0f5cf%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe0%20%E3%82%92%2000%3A01%3Abe%3Abe%3Aef%3A11%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe1%20%E3%82%92%2000%3A01%3Abe%3Abe%3Aef%3A22%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe1%3A%20phy%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%200x8%20%E3%81%AB%E6%9B%B4%E6%96%B0%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe2%20%E3%82%92%2000%3A01%3Abe%3Abe%3Aef%3A33%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EEVB%2FRDB%E4%B8%8A%E3%81%AEPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E7%94%A8%E3%81%ABRAM%E9%A0%98%E5%9F%9F%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3E%E7%B5%82%E3%82%8F%E3%82%8A%E3%80%82%3C%2FDIV%3E%3CDIV%3EClockCycles%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E0%2043600679%3C%2FDIV%3E%3CDIV%3E1%2043600679%3C%2FDIV%3E%3CDIV%3E2%2043600678%3C%2FDIV%3E%3CDIV%3E3%2043600679%3C%2FDIV%3E%3CDIV%3E4%2043600678%3C%2FDIV%3E%3CDIV%3E5%2043600678%3C%2FDIV%3E%3CDIV%3E6%2043600678%3C%2FDIV%3E%3CDIV%3E7%2043600679%3C%2FDIV%3E%3CDIV%3E%E8%A8%B1%E5%AE%B9%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%3EQNX%20Neutrino%207.1.0%E3%81%B8%E3%82%88%E3%81%86%E3%81%93%E3%81%9DNXP%20S32G399A%20RDB%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7!!%3C%2FDIV%3E%3CDIV%3E%E7%9B%A3%E8%A6%96%E5%BD%B9%E3%82%92%E9%96%8B%E5%A7%8B%E2%80%A6%3C%2FDIV%3E%3CDIV%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fsocket)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B94107%EF%BC%88ifconfig%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B910%EF%BC%88sh%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B99%EF%BC%88dhclient%EF%BC%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3Ecp%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82(%2Fproc%2Fboot%2Flibfci_cli)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B920489%EF%BC%88cp%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B91%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AESPI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5)...%3C%2FDIV%3E%3CDIV%3EI2C%200%2F1%2F2%2F3%2F4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3EUSDHC0%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%5B00%5D%20SIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3C%2FDIV%3E%3CDIV%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%20SDMMC%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B924596%EF%BC%88chkqnx6fs%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B928692%EF%BC%88%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3EQSPI%20Flash%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3EUSB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fusb%2F*)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%3C%2FDIV%3E%3CDIV%3E%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%EF%BC%9AMacronix%20MX25UW512%E3%80%81JEDEC%200xC2%20-%200x813A%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%EF%BC%9A0x4000000%3C%2FDIV%3E%3CDIV%3E%2Fdev%2Fusb%2F*%20%E7%94%A8%E3%81%AB%20devb-umass%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FDIV%3E%3CDIV%3E%23%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B936891%EF%BC%88%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3Esh%3A%20%2Fvar%2Fcetitec2%2Fstartup.sh%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%2045081%20(sh)%20%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%200%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%20signo%3D0%20code%3D0%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3Eslog2info%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.023%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%80%824low*%200%20qcrypto%3A%20%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20'%2Fetc%2Fqcrypto.conf'%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%5Bqcrypto_common.c(190)%5D%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.024random.4..0%20slog*%20700%20Random%20%E3%81%AF%20Fortuna%20PRNG%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%80%824low%200%20qcrypto%3A%20'openssl'%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%5Bqcrypto_plugins.c(354)%5D%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031random.4..0%20slog%20700%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%92%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E6%BA%90%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.032random.4..0%20slog%20700%20%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9F%E3%83%91%E3%82%B9%E5%90%8D%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.032random.4..0%20slog%20700%20random%3A%20resmgr%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.032random.4..0%20slog%20700%20random%3A%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.042devc_serlinflexd.7slog*%200%20serlinflexd_interrupt_attach%3A%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20114%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.047iopkt.8main_buffer*%200%20tcpip%20%E8%B5%B7%E5%8B%95%E4%B8%AD%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.047iopkt.8main_buffer%20SMMU%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.049iopkt.8main_buffer%200%20IPsec%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.049iopkt.8%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200%20%E5%AE%8C%E4%BA%86%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.049iopkt.8main_buffer%200%20IPsec%3A%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E9%96%A2%E9%80%A3%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.051iopkt.8main_buffer%200%20devnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cpfe0_mode%3Dsgmii%2Cpfe0_phy%3D0%2Cpfe1_mode%3Dsgmii%2Cpfe1_phy%3D1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.052io_pkt_v6_hc.8slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E6%83%85%E5%A0%B1%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A1.4.0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3A%202f3265a49ac18f94ba5e48254c8f870fe7bfc511%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_MULTI_INSTANCE_SUPPORT%3A%200%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_LOCAL_IF%3A%206%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_MASTER_IF%3A%206%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_SC_HIF%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_HIF_RING_LENGTH%3A%20256%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE0_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE1_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPFE_CFG_PFE2_PROMISC%3A%201%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.052io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A---%20%E5%AE%89%E5%85%A8%E3%81%AAIRQ%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82InterruptAttach()%20%E3%81%BE%E3%81%9F%E3%81%AF%20InterruptAttach_r()%20%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.052io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A42792%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe0%2FEMAC0%E3%81%AEMII%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe1%2FEMAC1%E3%81%AEMII%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe2%2FEMAC2%20%E7%94%A8%E3%81%AE%20MII%20%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82RGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.053io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3APFE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E7%99%BA%E8%A1%8C%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3APFE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%88%90%E5%8A%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3APFE%20CBUS%20p0x46000000%20%E3%81%8C%20v0x38f2e23000%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%200x101%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3S32G3%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3APFE_ERRORS%3A%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3APFE_ERRORS%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3APFE_ERRORS%3A%E3%83%90%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3APFE_ERRORS%3AFW%20%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3APFE_ERRORS%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E9%9A%9C%E5%AE%B3%E5%81%9C%E6%AD%A2%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3APFE_ERRORS%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%AE%E5%81%9C%E6%AD%A2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3APFE_ERRORS%3A%20ECC%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.275io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3ABMU1%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%99%E3%83%BC%E3%82%B9%3A%20p0xc0000000%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.277io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3ABMU2%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%9Ap0x83000000%EF%BC%880x200000%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20BMU%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88IRQ%20ID%EF%BC%9A226%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8Cg2_ordered_class_writes%E3%80%8D%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000)%E3%80%82%E3%83%97%E3%83%BC%E3%83%AB%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.279io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000)%E3%80%82%E3%83%97%E3%83%BC%E3%83%AB%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.281io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2.elf%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.281io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3ACLASS%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.281io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9FFW%E3%83%AD%E3%83%BC%E3%83%89%E6%93%8D%E4%BD%9C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%818%E3%81%A4%E3%81%AEPE%E3%82%92%E4%B8%A6%E5%88%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.285io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3Apfe_ct.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2292367c0e25f21f49217a9b08168ad2c8%22%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.288io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%5BFW%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%5D%201.7.0%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%3A%202023%E5%B9%B46%E6%9C%882%E6%97%A5%2013%3A48%3A57%20(nogitaaa)%E3%80%81ID%3A%200x31454650%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3AVLAN%20ID%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEVLAN%20ID%20%3D%200x01%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3AVLAN%E7%B5%B1%E8%A8%88%E6%83%85%E5%A0%B1%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEVLAN%E7%B5%B1%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%3D20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2VLAN%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%40%20p0x20001228%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%40%200x20000a7c%20(%E3%82%AF%E3%83%A9%E3%82%B9)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%40%200x20000a74%20(%E3%82%AF%E3%83%A9%E3%82%B9)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AFp0x80014000%E3%80%81%E3%83%97%E3%83%BC%E3%83%AB%E3%81%AFp0x8001c000%E3%81%A7%E3%81%99%EF%BC%8865536%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.407io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.408io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.409io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.508io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%E6%A9%9F%E8%83%BD%20err051211_workaround%3A%20%E7%84%A1%E5%8A%B9%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509iopkt.8%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200%20pfe0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2152%5D%3Apfe0%3A%20PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%3A%20MDIO%3D0%E3%80%81ADDR%3D0%E3%80%81CLAUSE%3D0%E3%80%81RESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20HIF0%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88IRQ%20ID%3A%20222%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe0%E3%81%AB00%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511iopkt.8%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200%20pfe1%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe0%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3A%200%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B00%20INF%5BSRC%2Fpfe_hif_drv_sc.c%3A1189%5D%3AHIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E8%B5%B7%E5%8B%95%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%200%E3%80%81ID%3A%200%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2152%5D%3Apfe1%3A%20PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%3A%20MDIO%3D1%E3%80%81ADDR%3D0%E3%80%81CLAUSE%3D0%E3%80%81RESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20HIF1%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88IRQ%20ID%EF%BC%9A223%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.511io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe1%E3%81%AB00%3A1a%3A1b%3A1c%3A1d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513iopkt.8%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200%20pfe2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe1%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3A%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B00%20INF%5BSRC%2Fpfe_hif_drv_sc.c%3A1189%5D%3AHIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E8%B5%B7%E5%8B%95%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%9A1%E3%80%81ID%EF%BC%9A2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe2%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3APFE%20HIF2%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88IRQ%20ID%3A%20224%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.513io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe2%E3%81%AB00%3A2a%3A2b%3A2c%3A2d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe2%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3A%202%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B00%20INF%5BSRC%2Fpfe_hif_drv_sc.c%3A1189%5D%3AHIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E8%B5%B7%E5%8B%95%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.515io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%9A2%E3%80%81ID%EF%BC%9A4%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.530io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3Apfe0%E3%81%AB00%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.530io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3AMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B900%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92pfe0%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.530io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.538io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_mdio.c%3A427%5D%3Apfe0%3A%20PHY%20%40%20%E3%83%90%E3%82%B9%200%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%9D%99%E7%9A%84%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.538io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3ASGMII%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BEMAC%E9%80%9F%E5%BA%A6%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.538io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.540io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.540io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3ASGMII%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BEMAC%E9%80%9F%E5%BA%A6%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.542io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB01%3A00%3A5e%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.544io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.554spi_master.24585%20%E9%80%9A%E5%B8%B8*%200%20%E3%82%B9%E3%83%91%E3%82%A4%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E8%B5%B7%E5%8B%95%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.558spi_master.24587%20%E9%80%9A%E5%B8%B8*%200%20spi-master%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E8%B5%B7%E5%8B%95%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.561spi_master.24588%20normal*%200%20spi-master%20resource%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%20%E8%B5%B7%E5%8B%95%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.565spi_master.24589%20%E9%80%9A%E5%B8%B8*%200%20%E3%82%B9%E3%83%91%E3%82%A4%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E9%96%8B%E5%A7%8B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.582devb_sdmmc_mx8x.24595%20slog*%201800%20devb-sdmmc-mx8x%201.00A%20(2026%E5%B9%B46%E6%9C%8823%E6%97%A5%2009%3A45%3A48)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.583devb_sdmmc_mx8x.24595%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20libcam.so(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%20%E3%83%90%E3%83%90%E3%83%BC%207010003%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.594devb_sdmmc_mx8x.24595%20slog%201800%20sdio_cd%3A%20%E6%8C%BF%E5%85%A5%E3%83%91%E3%82%B9%200%E3%80%81cd%20%E7%8A%B6%E6%85%8B%200x1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20SD%20CID%3A%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20MID%200x27%E3%80%81OID%200x5048%E3%80%81PNM%20SD32G%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20PRV%200x62%E3%80%81PSN%200x6c62d132%E3%80%81MDT%204-2023%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20SD%20CSD%3A%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20CSD_STRUCTURE%201%E3%80%81SPEC_VERS%200%E3%80%81CCC%200x5b5%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20TAAC%2014%E3%80%81NSAC%200%E3%80%81TRAN_SPEED%2050%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20C_SIZE%2059023%E3%80%81C_SIZE_MULT%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20READ_BL_LEN%209%E3%80%81WRITE_BL_LEN%209%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20ERASE%20GRP_SIZE%200%2C%20GRP_MULT%200%2C%20SIZE%20127%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20blksz%20512%E3%80%81%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%2060440576%E3%80%81dtr%2025000000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20SD%20SW%20CAPS%3A%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20%E3%83%90%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%200x3%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%200x1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20drv%E3%82%BF%E3%82%A4%E3%83%97%200x1%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E5%88%B6%E9%99%90%200x1%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20dtr%2050000000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.644devb_sdmmc_mx8x.24595%20slog%201800%20CFG%3A%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20HS%E3%80%81DTR%2050000000%E3%80%81%E3%83%90%E3%82%B9%E5%B9%85%204%20%E3%83%93%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.645devb_sdmmc_mx8x.24595%20%E3%82%B9%E3%83%AD%E3%82%B0%20100%20cam-disk.so(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A17)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.647devb_sdmmc_mx8x.24595%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%E3%80%81scsi_status%3D2%E3%80%81flag%3D00000040%E3%80%81vuflag%3D0008%E3%80%81cmd%3D1a%E3%80%81error%3D70%E3%80%81sense%3D5%E3%80%81asc%3D24%E3%80%81ascq%3D0%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.647devb_sdmmc_mx8x.24595%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%E3%80%81scsi_status%3D2%E3%80%81flag%3D00000040%E3%80%81vuflag%3D0008%E3%80%81cmd%3D5a%E3%80%81error%3D70%E3%80%81sense%3D5%E3%80%81asc%3D24%E3%80%81ascq%3D0%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.647devb_sdmmc_mx8x.24595%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%E3%80%81scsi_status%3D2%E3%80%81flag%3D00000040%E3%80%81vuflag%3D0008%E3%80%81cmd%3D5a%E3%80%81error%3D70%E3%80%81sense%3D5%E3%80%81asc%3D24%E3%80%81ascq%3D0%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.827devb_sdmmc_mx8x.24595%20slog%201000%20fs-qnx6%3A%20%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E6%88%A6%E7%95%A5%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.827devb_sdmmc_mx8x.24595%20slog%201000%20fs-qnx6%3A%20btree%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%200%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.828devb_sdmmc_mx8x.24595%20slog%201000%20fs-qnx6%3A%20fs-qnx6%3A%20trim%20(0%2C1048576%2C2)%20%E3%81%AF%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.833io_usb_otg.36885%20slog*%200%20main(453)%5Btid%3A1%5D%3A%20io-usb-otg%20(2020%E5%B9%B46%E6%9C%8813%E6%97%A5%2020%3A10%3A17)%20args%3A%20-d%20hcd-ehci-mx28%20ioport%3D0x44064100%2Cirq%3D243%2Culpi%2Cno_stream%2Cverbose%3D5%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.835devf_qspi_s32g.36884%20slog*%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A73)%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%3A%20256%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.835devf_qspi_s32g.36884%20slog%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A74)%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%90%88%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%3A%200x4000000%E3%80%81%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%3A%200x10000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.839io_usb_otg.36885%20slog%200%20ehci_init%3A%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.839io_usb_otg.36885%20slog%200%20ehci_controller_init(4303)%3A%20devu-hcd-ehci-mx28.so%20(2024%E5%B9%B44%E6%9C%8819%E6%97%A5%2013%3A44%3A54)%3A%20args%20ulpi%2Cno_stream%2Cverbose%3D5%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%208%20usb_enum_port(94)%5Btid%3A1%5D%3A%20busno%200%2C%20parent%20-1%2C%20port%200%2C%20High%20speed%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%97%201%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%200%E3%80%81%E9%95%B7%E3%81%95%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%2012%20usb_device_set_address(245)%5Btid%3A1%5D%3A%20b%3A0%20devno%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.840io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%97%201%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%200%E3%80%81%E9%95%B7%E3%81%95%2018)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%97%202%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%200%E3%80%81%E9%95%B7%E3%81%95%209)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%97%202%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%200%E3%80%81%E9%95%B7%E3%81%95%2025)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%208%20usb_enum_port(141)%5Btid%3A1%5D%3A%20vid%200x0000%E3%80%81did%200x0000%20%E3%81%8C%E5%88%97%E6%8C%99%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F(busno%200%E3%80%81devno%200%3A0)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2011%20hub_state_inserted(569)%5Btid%3A1%5D%3A%20bdentry%200%2C%20dentry%200%200%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.841io_usb_otg.36885%20slog%2013%20hub_configuration_enable(263)%5Btid%3A1%5D%3A%201%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.943io_usb_otg.36885%20slog%200%20usbh_timeout_init(203)%5Btid%3A1%5D%3A%20%E5%AE%8C%E4%BA%86%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.954io_usb_otg.36885%20slog%200%20read_vid_pid%3A%20ULPI%20VID%200x0424%20PID%200x0009%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.954io_usb_otg.36885%20slog%200%20s32g_phy_set_vbus%3A%20set_vbus%20off%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.968io_usb_otg.36885%20slog%200%20s32g_phy_set_vbus%3A%20set_vbus%20%E3%82%AA%E3%83%B3%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.979io_usb_otg.36885%20slog%200%20ehci_get_port_status(3568%200x44064100)%3A%20port%3D0%2C%20tpstatus%2010100%20e_pstatus%208c001000%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.979io_usb_otg.36885%20slog%208%20usb_enum_port_extract(172)%5Btid%3A7%5D%3A%20(busno%200%2C%20pdevno%200%2C%20portno%201)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.979io_usb_otg.36885%20slog%208%20usb_enum_port_extract(192)%5Btid%3A7%5D%3A%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20(2)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.983devb_umass.36886%20slog*%20900%20devb-umass%201.00A%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A41)%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.984devb_umass.36886%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20libcam.so(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%E5%AD%A6%E5%A3%AB%207010003%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.985io_usb_otg.36885%20slog%200%20usbdi_client_connect(58)%5Btid%3A5%5D%3A%20pid%2036886%20proc%3Dproc%2Fboot%2Fdevb-umass%20usbdi_client%2032eebb9a80%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.986io_usb_otg.36885%20slog%200%20usbdi_resmgr_connect(310)%5Btid%3A5%5D%3A%20usbdi_resmgr_connect%3A%20pid%2036886%20usbdi_client%2032eebb9a80%3C%2FDIV%3E%3CDIV%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A01.986devb_umass.36886%20slog%200%20usbdi%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%91%E3%82%B9%20%2Fpps%2Fusb%2Fdebug%2F%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B949177%EF%BC%88slog2info%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%3A%20flags%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E9%95%B7%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%3A%20flags%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2000%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xff000000%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BD%8F%E6%89%80%3A%2000%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%3A%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2000%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%3A%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B957369%EF%BC%88ifconfig%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%23%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E3%81%93%E3%81%93%E3%81%A7s32g_pfe_class.fw%E3%81%A8s32g_pfe_util.fw%E3%82%92PFE-FW_S32G_1.6.0.zip%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%3CSPAN%3E%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D14074877%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D14074877%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EU-Boot%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%EF%BC%9A%3C%2FP%3E%3CP%3Esetenv%20boot_qnx_atf%20'mmc%20dev%200%3B%20fatload%20mmc%200%3A1%200x83e00000%20s32g399a-rdb3.dtb%3Batf_fdt_0to3%20%E3%82%92%E5%AE%9F%E8%A1%8C%3B%20atf_fdt_4to7%20%E3%82%92%E5%AE%9F%E8%A1%8C%3B%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%20%E3%82%92%E3%83%95%E3%82%A1%E3%83%83%E3%83%88%E3%83%AD%E3%83%BC%E3%83%89%3Bpfeng%20%E6%9C%89%E5%8A%B9%E5%8C%96%3B%20s32ccgmac%20%E7%84%A1%E5%8A%B9%E5%8C%96%3B%20s32ccgmac%20%E6%9C%89%E5%8A%B9%E5%8C%96%3B%20bootm%200x80080000%20-%200x83E00000'%3CBR%20%2F%3E%20setenv%20atf_fdt_0to3%20'fdt%20addr%200x83e00000%3B%20fdt%20resize%3B%20fdt%20set%20%2Fcpus%2Fcpu%401%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40100%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40101%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B'%3CBR%20%2F%3E%20setenv%20atf_fdt_4to7%20'fdt%20set%20%2Fcpus%2Fcpu%402%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%403%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40102%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%20fdt%20set%20%2Fcpus%2Fcpu%40103%20cpu-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B'%3CBR%20%2F%3E%20setenv%20release_cpus%20'run%20cpu_trap%3B%20mp%201%20release%200xa0000000%3B%20mp%202%20release%200xa0000000%3B%20mp%203%20release%200xa0000000%3B%20mp%204%20release%200xa0000000%3B%20mp%205%20release%200xa0000000%3B%20mp%206%20release%200xa0000000%3B%20mp%207%20release%200xa0000000%3B'%3CBR%20%2F%3E%20setenv%20cpu_trap%20'dcache%20off%3B%20mw.l%200xa0000000%200xd503205f%3B%20mw.l%200xa0000004%200x58000060%3B%20mw.l%200xa0000008%200xb4ffffc0%3B%20mw.l%200xa000000C%200xd61f0000%3B%20mw.q%200xa0000010%200x00000000%3B%20dcache%20on%3B'%3CBR%20%2F%3E%20setenv%20bootcmd%20'run%20boot_qnx_atf'%3CBR%20%2F%3E%20setenv%20hwconfig%20%22pcie0%3Amode%3Drc%2Cclock%3Dext%3Bpcie1%3Amode%3Dsgmii%2Cclock%3Dext%2Cfmhz%3D125%2Cxpcs_mode%3D2G5%22%3CBR%20%2F%3E%20setenv%20pfeng_mode%20'enable%2Csgmii%2Csgmii%2Crgmii'%3CBR%20%2F%3E%20setenv%20s32cc_gmac_mode%20disable%3CBR%20%2F%3E%20saveenv%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20boot_qnx_atf%20%E3%81%8B%E3%82%89%20release_cpus%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81CPU%201%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AB%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E8%89%AF%E3%81%8F%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CDIV%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%EF%BC%9ABL2%EF%BC%9Av2.5%EF%BC%88%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%EF%BC%89%EF%BC%9Absp37.0_rc6-2.5%3C%2FDIV%3E%3CDIV%3E%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%EF%BC%9ABL2%EF%BC%9A%E3%83%93%E3%83%AB%E3%83%89%E6%97%A5%E6%99%82%EF%BC%9A2023%E5%B9%B46%E6%9C%8813%E6%97%A5%2009%3A12%3A21%3C%2FDIV%3E%3CDIV%3E%E9%80%9A%E7%9F%A5%3A%20BL2%3A%20BL31%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EU-Boot%202020.04%2Bg156b168010(2023%E5%B9%B46%E6%9C%889%E6%97%A5%2010%3A14%3A25%20%2B0000)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3ECPU%3A%20NXP%20S32G399A%20rev.1.1%3C%2FDIV%3E%3CDIV%3E%E3%83%A2%E3%83%87%E3%83%AB%3ANXP%20S32G399A-RDB3%3C%2FDIV%3E%3CDIV%3EDRAM%3A%203.5%20GiB%3C%2FDIV%3E%3CDIV%3EMMC%3A%20FSL_SDHC%3A%200%3C%2FDIV%3E%3CDIV%3EMMC%E3%81%8B%E3%82%89%E7%92%B0%E5%A2%83%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99...%20OK%3C%2FDIV%3E%3CDIV%3EPCIe0%E3%82%92%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3EPCIe0%3A%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3EPCI%3A%20%E8%87%AA%E5%8B%95%E6%A7%8B%E6%88%90%E3%83%90%E3%83%BC%201c%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%E5%85%A5%E5%8A%9B%3A%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E5%87%BA%E5%8A%9B%3A%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20serial%40401c8000%3C%2FDIV%3E%3CDIV%3E%E3%83%9C%E3%83%BC%E3%83%89%E6%94%B9%E8%A8%82%EF%BC%9ARDB3%20%E6%94%B9%E8%A8%82F%3C%2FDIV%3E%3CDIV%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3A%20EQOS%20%E7%89%A9%E7%90%86%3A%20rgmii%20%40%201%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%AD%A6%E5%91%8A%3A%20eth_eqos%20(eth0)%20%E3%81%AF%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AA%20MAC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%2016%3Aec%3Aa0%3A4e%3A1d%3A7c%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3Eeth0%3A%20eth_eqos%20emac1_xpcs%20%E3%81%AE%20XPCS%20%E3%81%AE%E9%80%9F%E5%BA%A6%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20PFE%3A%20emac0%3A%20sgmii%20emac1%3A%20sgmii%20emac2%3A%20rgmii%3C%2FDIV%3E%3CDIV%3E%E3%80%81eth1%3A%20eth_pfeng%3C%2FDIV%3E%3CDIV%3E%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%203%202%201%200%3C%2FDIV%3E%3CDIV%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%80%81OK%3C%2FDIV%3E%3CDIV%3Emmc0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3C%2FDIV%3E%3CDIV%3E50640%E3%83%90%E3%82%A4%E3%83%88%E3%82%9217%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%882.8%20MiB%2F%E7%A7%92%EF%BC%89%3C%2FDIV%3E%3CDIV%3E11950600%E3%83%90%E3%82%A4%E3%83%88%E3%82%92534%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%8821.3%20MiB%2F%E7%A7%92%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%23%23%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%9280080000%E7%95%AA%E5%9C%B0%E3%81%A7%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%E7%94%BB%E5%83%8F%E5%90%8D%3A%3C%2FDIV%3E%3CDIV%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%BF%E3%82%A4%E3%83%97%3AAArch64%20Linux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8(%E9%9D%9E%E5%9C%A7%E7%B8%AE)%3C%2FDIV%3E%3CDIV%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B5%E3%82%A4%E3%82%BA%3A%2011950536%E3%83%90%E3%82%A4%E3%83%88%20%3D%2011.4MiB%3C%2FDIV%3E%3CDIV%3E%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2080080000%3C%2FDIV%3E%3CDIV%3E%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3A%2080080000%3C%2FDIV%3E%3CDIV%3E%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E6%A4%9C%E8%A8%BC%E4%B8%AD...OK%3C%2FDIV%3E%3CDIV%3E%23%23%20%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%96%E3%83%AD%E3%83%96%20(83e00000)%3C%2FDIV%3E%3CDIV%3E0x83e00000%E3%81%AB%E3%81%82%E3%82%8Bfdt%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FDIV%3E%3CDIV%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3C%2FDIV%3E%3CDIV%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%920000000083e00000%E3%81%A7%E4%BD%BF%E7%94%A8%E3%80%81%E7%B5%82%E4%BA%860000000083e0ffff%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe0%20%E3%82%92%2000%3A01%3Abe%3Abe%3Aef%3A11%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe1%20%E3%82%92%2000%3A01%3Abe%3Abe%3Aef%3A22%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe1%3A%20phy%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%200x8%20%E3%81%AB%E6%9B%B4%E6%96%B0%3C%2FDIV%3E%3CDIV%3E%E4%BF%AE%E6%AD%A3%3A%20pfe2%20%E3%82%92%2000%3A01%3Abe%3Abe%3Aef%3A33%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EEVB%2FRDB%E4%B8%8A%E3%81%AEPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E7%94%A8%E3%81%ABRAM%E9%A0%98%E5%9F%9F%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3E%E7%B5%82%E3%82%8F%E3%82%8A%E3%80%82%3C%2FDIV%3E%3CDIV%3EClockCycles%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E0%2043642864%3C%2FDIV%3E%3CDIV%3E1%2043642864%3C%2FDIV%3E%3CDIV%3E2%2043642864%3C%2FDIV%3E%3CDIV%3E3%2043642864%3C%2FDIV%3E%3CDIV%3E4%2043642864%3C%2FDIV%3E%3CDIV%3E5%2043642864%3C%2FDIV%3E%3CDIV%3E6%2043642864%3C%2FDIV%3E%3CDIV%3E7%2043642864%3C%2FDIV%3E%3CDIV%3E%E8%A8%B1%E5%AE%B9%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3C%2FDIV%3E%3CDIV%3EQNX%20Neutrino%207.1.0%E3%81%B8%E3%82%88%E3%81%86%E3%81%93%E3%81%9DNXP%20S32G399A%20RDB%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7!!%3C%2FDIV%3E%3CDIV%3E%E7%9B%A3%E8%A6%96%E5%BD%B9%E3%82%92%E9%96%8B%E5%A7%8B%E2%80%A6%3C%2FDIV%3E%3CDIV%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fsocket)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B94107%EF%BC%88ifconfig%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B910%EF%BC%88sh%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B99%EF%BC%88dhclient%EF%BC%89%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AF0%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3Ecp%3A%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82(%2Fproc%2Fboot%2Flibfci_cli)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B920489%EF%BC%88cp%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B91%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AESPI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5)...%3C%2FDIV%3E%3CDIV%3EI2C%200%2F1%2F2%2F3%2F4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3EUSDHC0%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3E%5B00%5D%20SIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3C%2FDIV%3E%3CDIV%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%20SDMMC%3A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B924596%EF%BC%88chkqnx6fs%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B928692%EF%BC%88%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3EQSPI%20Flash%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3C%2FDIV%3E%3CDIV%3EUSB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC(%2Fdev%2Fusb%2F*)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%3C%2FDIV%3E%3CDIV%3E%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9FQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%EF%BC%9AMacronix%20MX25UW512%E3%80%81JEDEC%200xC2%20-%200x813A%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%EF%BC%9A0x4000000%3C%2FDIV%3E%3CDIV%3E%2Fdev%2Fusb%2F*%20%E7%94%A8%E3%81%AB%20devb-umass%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%3A%20flags%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E9%95%B7%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%3A%20flags%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2000%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xff000000%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BD%8F%E6%89%80%3A%2000%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%3A%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2000%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%3A%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B940985%EF%BC%88ifconfig%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%23%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B936891%EF%BC%88%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3Esh%3A%20%2Fvar%2Fcetitec2%2Fstartup.sh%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%2053273%20(sh)%20%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%200%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%20signo%3D0%20code%3D0%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23%20ifconfig%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Elo0%3A%20flags%3D8049%3CUP%3E%20mtu%2033136%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%20127.0.0.1%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xff000000%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20%3A%3A1%20%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E9%95%B7%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe0%3A%20flags%3D8843%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2000%3A0a%3A0b%3A0c%3A0d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet%200.0.0.0%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xff000000%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20255.255.255.255%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einet6%20fe80%3A%3A20a%3Abff%3Afe0c%3Ad66%25pfe0%20prefixlen%2064%20scopeid%200x11%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe1%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BD%8F%E6%89%80%3A%2000%3A1a%3A1b%3A1c%3A1d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%3A%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3Epfe2%3A%20flags%3D8802%3CBROADCAST%3E%20mtu%201500%3C%2FBROADCAST%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecapabilities%3D1f%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%8A%B9%3D0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3A%2000%3A2a%3A2b%3A2c%3A2d%3A66%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AA%E3%81%97(1000baseT%E5%85%A8%E4%BA%8C%E9%87%8D)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8A%B6%E6%85%8B%3A%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%81%AA%E3%81%97%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CP%3E%23%20slog2info%20%7C%20grep%20pfe%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.051%20iopkt.8main_buffer%200%20devnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E6%83%85%E5%A0%B1%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A---%20%E5%AE%89%E5%85%A8%E3%81%AAIRQ%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82InterruptAttach()%20%E3%81%BE%E3%81%9F%E3%81%AF%20InterruptAttach_r()%20%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A49480%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe0%2FEMAC0%E3%81%AEMII%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe1%2FEMAC1%E3%81%AEMII%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe2%2FEMAC2%20%E7%94%A8%E3%81%AE%20MII%20%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82RGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3APFE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E7%99%BA%E8%A1%8C%E4%B8%AD...%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3APFE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3APFE%20CBUS%20p0x46000000%20%E3%81%8C%20v0x1abef95000%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%200x101%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3S32G3%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3APFE_ERRORS%3A%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3APFE_ERRORS%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3APFE_ERRORS%3A%E3%83%90%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3APFE_ERRORS%3AFW%20%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3APFE_ERRORS%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E9%9A%9C%E5%AE%B3%E5%81%9C%E6%AD%A2%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3APFE_ERRORS%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%AE%E5%81%9C%E6%AD%A2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3APFE_ERRORS%3A%20ECC%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3ABMU1%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%99%E3%83%BC%E3%82%B9%3A%20p0xc0000000%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.277%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3ABMU2%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%9Ap0x83000000%EF%BC%880x200000%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8Cg2_ordered_class_writes%E3%80%8D%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000)%E3%80%82%E3%83%97%E3%83%BC%E3%83%AB%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000)%E3%80%82%E3%83%97%E3%83%BC%E3%83%AB%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2.elf%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3ACLASS%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9FFW%E3%83%AD%E3%83%BC%E3%83%89%E6%93%8D%E4%BD%9C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%818%E3%81%A4%E3%81%AEPE%E3%82%92%E4%B8%A6%E5%88%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%201%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.285%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3Apfe_ct.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2292367c0e25f21f49217a9b08168ad2c8%22%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.288%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%5BFW%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%5D%201.6.0%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%3A%202023%E5%B9%B43%E6%9C%8815%E6%97%A5%2012%3A37%3A54%20()%E3%80%81ID%3A%200x31454650%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3AVLAN%20ID%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEVLAN%20ID%20%3D%200x01%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3AVLAN%E7%B5%B1%E8%A8%88%E6%83%85%E5%A0%B1%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEVLAN%E7%B5%B1%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%3D20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2VLAN%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%40%20p0x20001208%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%40%200x20000a44%20(%E3%82%AF%E3%83%A9%E3%82%B9)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%40%200x20000a3c%20(%E3%82%AF%E3%83%A9%E3%82%B9)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AFp0x80014000%E3%80%81%E3%83%97%E3%83%BC%E3%83%AB%E3%81%AFp0x8001c000%E3%81%A7%E3%81%99%EF%BC%8865536%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%E3%80%82%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.407%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.408%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.409%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.508%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%E6%A9%9F%E8%83%BD%20err051211_workaround%3A%20%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.509%20iopkt.8%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200%20pfe0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.509%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe0%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.510%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe0%E3%81%AB00%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.512%20iopkt.8%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200%20pfe1%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe0%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3A%200%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B00%20INF%5BSRC%2Fpfe_hif_drv_sc.c%3A1189%5D%3AHIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%200%E3%80%81ID%3A%200%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe1%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe1%E3%81%AB00%3A1a%3A1b%3A1c%3A1d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.514%20iopkt.8%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%200%20pfe2%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe1%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3A%201%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B00%20INF%5BSRC%2Fpfe_hif_drv_sc.c%3A1189%5D%3AHIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%9A1%E3%80%81ID%EF%BC%9A2%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe2%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe2%E3%81%AB00%3A2a%3A2b%3A2c%3A2d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe2%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3A%202%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%9A2%E3%80%81ID%EF%BC%9A4%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3Apfe0%E3%81%AB00%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3AMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B900%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92pfe0%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3ASGMII%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BEMAC%E9%80%9F%E5%BA%A6%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.532%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3ASGMII%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BEMAC%E9%80%9F%E5%BA%A6%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB01%3A00%3A5e%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%23slog2info%20%7C%20grep%20io_pkt_v6_hc%3C%2FP%3E%3CP%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog*%200%20INF%5Bsrc%2Fpfe_drv.c%3A1377%5D%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E6%83%85%E5%A0%B1%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1384%5D%3A---%20%E5%AE%89%E5%85%A8%E3%81%AAIRQ%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82InterruptAttach()%20%E3%81%BE%E3%81%9F%E3%81%AF%20InterruptAttach_r()%20%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A83%5D%3A49480%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.052%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_fw.c%3A89%5D%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20%2Fproc%2Fboot%2Fs32g_pfe_class.fw%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe0%2FEMAC0%E3%81%AEMII%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe1%2FEMAC1%E3%81%AEMII%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1477%5D%3Apfe2%2FEMAC2%20%E7%94%A8%E3%81%AE%20MII%20%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82RGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.053%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1495%5D%3APFE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E7%99%BA%E8%A1%8C%E4%B8%AD...%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1496%5D%3APFE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3519%5D%3APFE%20CBUS%20p0x46000000%20%E3%81%8C%20v0x1abef95000%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3524%5D%3A%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%200x101%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hw_feature.c%3A95%5D%3A%20%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3S32G3%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.274%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3536%5D%3A%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2687%5D%3APFE_ERRORS%3A%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2702%5D%3APFE_ERRORS%3A%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2718%5D%3APFE_ERRORS%3A%E3%83%90%E3%82%B9%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2731%5D%3APFE_ERRORS%3AFW%20%E3%83%95%E3%82%A7%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2744%5D%3APFE_ERRORS%3A%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E9%9A%9C%E5%AE%B3%E5%81%9C%E6%AD%A2%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2757%5D%3APFE_ERRORS%3A%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%AE%E5%81%9C%E6%AD%A2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2770%5D%3APFE_ERRORS%3A%20ECC%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.275%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1766%5D%3ABMU1%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%99%E3%83%BC%E3%82%B9%3A%20p0xc0000000%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.277%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A1810%5D%3ABMU2%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%9Ap0x83000000%EF%BC%880x200000%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2194%5D%3A%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8Cg2_ordered_class_writes%E3%80%8D%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20BMU%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(IRQ%20ID%3A%20226)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x88000)%E3%80%82%E3%83%97%E3%83%BC%E3%83%AB%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.279%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_bmu_csr.c%3A96%5D%3A%20BMU_EMPTY_INT%20(BMU%20%40%20p0x8c000)%E3%80%82%E3%83%97%E3%83%BC%E3%83%AB%E6%BA%96%E5%82%99%E5%AE%8C%E4%BA%86%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2239%5D%3A%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2.elf%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2248%5D%3ACLASS%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.281%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A609%5D%3A%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9FFW%E3%83%AD%E3%83%BC%E3%83%89%E6%93%8D%E4%BD%9C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%818%E3%81%A4%E3%81%AEPE%E3%82%92%E4%B8%A6%E5%88%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%201%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.285%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A1945%5D%3Apfe_ct.h%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%2292367c0e25f21f49217a9b08168ad2c8%22%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.288%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_pe.c%3A2422%5D%3A%5BFW%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%5D%201.6.0%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%3A%202023%E5%B9%B43%E6%9C%8815%E6%97%A5%2012%3A37%3A54%20()%E3%80%81ID%3A%200x31454650%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2312%5D%3AVLAN%20ID%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEVLAN%20ID%20%3D%200x01%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20WRN%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2318%5D%3AVLAN%E7%B5%B1%E8%A8%88%E6%83%85%E5%A0%B1%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEVLAN%E7%B5%B1%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%3D20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1181%5D%3A%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2VLAN%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%20%40%20p0x20001208%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1286%5D%3A%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%40%200x20000a44%20(%E3%82%AF%E3%83%A9%E3%82%B9)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_l2br.c%3A1287%5D%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%20%40%200x20000a3c%20(%E3%82%AF%E3%83%A9%E3%82%B9)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.406%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A2412%5D%3A%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AFp0x80014000%E3%80%81%E3%83%97%E3%83%BC%E3%83%AB%E3%81%AFp0x8001c000%E3%81%A7%E3%81%99%EF%BC%8865536%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%E3%80%82%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.407%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.408%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.409%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_chnl.c%3A1997%5D%3A%20RX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%97%E3%83%BC%E3%83%AB%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%B7%B1%E5%BA%A6%3A%20256%3B%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%B5%E3%82%A4%E3%82%BA%3A%202048%3B%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%B5%E3%82%A4%E3%82%BA%3A%2064%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.508%20io_pkt_v6_hc.8slog%200%20INF%5Bhw%2Fs32g%2Fpfe_platform_master.c%3A3705%5D%3A%E6%A9%9F%E8%83%BD%20err051211_workaround%3A%20%E7%84%A1%E5%8A%B9%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.509%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe0%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.509%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF0%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(IRQ%20ID%3A%20222)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.510%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe0%E3%81%AB00%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe0%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3A%200%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B00%20INF%5BSRC%2Fpfe_hif_drv_sc.c%3A1189%5D%3AHIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%200%E3%80%81ID%3A%200%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe1%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF1%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(IRQ%20ID%3A%20223)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.512%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe1%E3%81%AB00%3A1a%3A1b%3A1c%3A1d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe1%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%99%3A%201%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8%E3%82%B9%E3%83%AD%E3%82%B00%20INF%5BSRC%2Fpfe_hif_drv_sc.c%3A1189%5D%3AHIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%B5%B7%E5%8B%95%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%9A1%E3%80%81ID%EF%BC%9A2%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2145%5D%3Apfe2%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Foal_irq_qnx.c%3A117%5D%3A%20PFE%20HIF2%20IRQ%E3%83%AF%E3%83%BC%E3%82%AB%E3%83%BC%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20(IRQ%20ID%3A%20224)%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.514%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A1795%5D%3Apfe2%E3%81%AB00%3A2a%3A2b%3A2c%3A2d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2298%5D%3Apfe2%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A336%5D%3A%20HIF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AE%E7%99%BB%E9%8C%B2%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3A%202%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_hif_drv_sc.c%3A1189%5D%3A%20HIF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20started%3CBR%20%2F%3EJan%2001%2000%3A00%3A00.516%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2363%5D%3A%E6%96%B0%E3%81%97%E3%81%84PFE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%9A2%E3%80%81ID%EF%BC%9A4%3CBR%20%2F%3E%201%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2702%5D%3Apfe0%E3%81%AB00%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2707%5D%3AMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B900%3A0a%3A0b%3A0c%3A0d%3A66%E3%82%92pfe0%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.531%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3ASGMII%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BEMAC%E9%80%9F%E5%BA%A6%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.532%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.534%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2829%5D%3ASGMII%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BEMAC%E9%80%9F%E5%BA%A6%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A00.536%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB01%3A00%3A5e%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A00.538%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9172057%EF%BC%88slog2info%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3A00%3A00%3A00%3A01%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2443%5D%3Aemac0%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20WRN%5Bsrc%2Fpfe_drv.c%3A2450%5D%3Aemac0%3A17%E3%81%AB33%3A33%3Aff%3A0c%3A0d%3A66%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A01%3A01.630%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2495%5D%3Aemac0%E3%81%8B%E3%82%8901%3A00%3A5e%3A00%3A00%3A01%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A01%3A01.632%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_phy_if.c%3A2716%5D%3A%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%2001%3A00%3A5e%3A00%3A00%3A01%20%E3%81%8C%20emac0%20%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A01%3A01.632%20io_pkt_v6_hc.8slog%200%20INF%5Bsrc%2Fpfe_drv.c%3A2663%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2385407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2385407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%3CSPAN%3ES32G%20PFE%20QNX%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.4.0%E3%81%AFS32G%20PFE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E6%A8%99%E6%BA%96%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.6.0%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AEPFE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EBSP_nxp-s32g-evb_br-710_be-710_SVN984052_JBN51%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%80%81.build%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%3C%2FP%3E%3CP%3Ekprintf(%22EVB%2FRDB%5Cn%E3%81%A7PFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E7%94%A8%E3%81%ABRAM%E9%A0%98%E5%9F%9F%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%22)%3B%3CBR%20%2F%3Eas_add_containing(0x80000000%2C0x80000000%20%2B%200x4000000%20-%201%2CAS_ATTR_RAM%E3%80%81%E3%80%8Cpfe_ddr%E3%80%8D%E3%80%8Cram%E3%80%8D)%3B%3C%2FP%3E%3CP%3E%EF%BD%9E%3C%2FP%3E%3CP%3Esrc%2Fhardware%2Fstartup%2Fboards%2Fs32g%2Fs32g399a-rdb%2Fs32g_init_raminfo.c%20%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81ifs%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20ifs-s32g399a-rdb.ui%20%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AEpfe_ddr%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81uboot%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%A9%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2386663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2386663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%B5%B1%E5%90%88%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E5%8E%B3%E5%AF%86%E3%81%AB%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E9%83%A8%E5%88%86%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82QNX%20BSP%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%83%A8%E5%88%86%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782443542271.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390231i1339D06D28BE6C6B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782443542271.png%22%20alt%3D%22chenyin_h_0-1782443542271.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ENXP%E3%81%AF%E3%80%81board_cleanup_before_linux%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81PFE%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AAuboot%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E6%97%A2%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3Ebinaries_auto_linux_bsp37.0_s32g3_pfe%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E4%BD%95%E3%82%92%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40%E3%82%BB%E3%83%8D%E3%82%AB%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81QNX%20PFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E6%8E%A8%E5%A5%A8%E3%83%BB%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E7%9B%B4%E6%8E%A5%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%96%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8C%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81QNX%20PFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%961.2%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8BPFE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF1.2%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AFBSP30%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9FPFE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3EJBN51%E3%81%AB%E3%81%AFNXP%20BSP39%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AFPFE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A21.8.0%E3%81%8C%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Pfe%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC1.7.0%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B32.1.3%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%AFPFW%20FW%201.10.0%E3%81%AE%E3%81%BF%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Seneca_0-1782903766239.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390945iAC23A6EE62F0B101%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Seneca_0-1782903766239.png%22%20alt%3D%22Seneca_0-1782903766239.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%B5%B1%E5%90%88%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7U-Boot%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82PFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC1.7.0%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B32.10.2%E3%81%8B%E3%82%89%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E7%B5%B1%E5%90%88%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%80%82%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eboard_cleanup_before_linux%3A%20QNX%20PFE%20%E3%82%B3%E3%83%BC%E3%83%89%E3%80%82%3CBR%20%2F%3Eethernet%404033c000%20PHY%E3%81%AE%E8%87%AA%E5%8B%95%E4%BA%A4%E6%B8%89%E5%AE%8C%E4%BA%86%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B.........%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88!%3CBR%20%2F%3Ephy_startup()%E5%A4%B1%E6%95%97%3A-110%20%E5%A4%B1%E6%95%97%3A-110%3CBR%20%2F%3EPFE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30x0101(S32G3)%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EPFE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30x0101(S32G3)%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Epfe2%20PHY%E8%87%AA%E5%8B%95%E4%BA%A4%E6%B8%89%E5%AE%8C%E4%BA%86%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B.........%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88!%3CBR%20%2F%3Epfe1%20pfeng_netif%3APFE1%E3%81%A7XPCS%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%99%AE%E9%80%9A%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%88%E3%81%86%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBSP%2033%3C%2FP%3E%3CP%3EPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%201.2.0%3C%2FP%3E%3CP%3EPFE%20FW%201.3.0%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%85%AC%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%88%E3%81%86%E3%81%A8%E6%80%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBSP%2033%3C%2FP%3E%3CP%3EPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%201.2.0%3C%2FP%3E%3CP%3EPFE%20FW%201.3.0%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%85%AC%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%9FBSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AFBSP39%E3%81%A7%E3%80%81QNX%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B31.7.0%E3%81%8A%E3%82%88%E3%81%B3QNX%20SDP%207.1%20BSP%20JBN51%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E9%99%B3%E9%9F%B3%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3EPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC1.7.0%E3%82%92QNXJBN51%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%8C%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9FNXP%20BSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2388736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2388736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%94%BB%E5%83%8F%E3%81%AF%E4%B8%80%E8%88%AC%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%80%8C%20%3CSPAN%3Ebinaries_auto_linux_bsp37.0_s32g3_pfe%3C%2FSPAN%3E%20%E3%80%8D%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AEtgz%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782879234963.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F390855iCCB52D1818442408%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782879234963.png%22%20alt%3D%22chenyin_h_0-1782879234963.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81NXP%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9FLinux%20BSP%E3%81%AE%E4%BA%8B%E5%89%8D%E3%83%93%E3%83%AB%E3%83%89%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81QNX%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%BF%E6%9F%BB%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81U-Boot%E7%92%B0%E5%A2%83%E6%83%85%E5%A0%B1%E3%82%92%E5%90%AB%E3%82%80%E5%AE%8C%E5%85%A8%E3%81%AA%E8%B5%B7%E5%8B%95%E3%83%AD%E3%82%B0%E3%82%92%E3%81%94%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B3%A8%EF%BC%9Apfe0%E3%81%A8pfe2%E3%81%AF%E5%90%8C%E6%99%82%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E5%A4%96%E9%83%A8%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8B%E3%82%89ping%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81pfe0%E3%81%AB%E5%A5%87%E5%A6%99%E3%81%AAMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Earp%20-a%20%7C%20grep%20192%3CBR%20%2F%3E%20%EF%BC%9F(192.168.0.200)%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20on%20enx00e04c680383%3CBR%20%2F%3E%20%EF%BC%9F(192.168.0.202)%20enx00e04c680383%20%E4%B8%8A%E3%81%AE%20%3CINCOMPLETE%3E%3C%2FINCOMPLETE%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFqnx%20slog2info%E3%81%8B%E3%82%89%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A58.251%20iopkt.4121%20main_buffer%200%20%E9%87%8D%E8%A4%87IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20192.168.0.200%20%E3%81%8C%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%2022%3A33%3A44%3A55%3A66%3A77%20%E3%81%8B%E3%82%89%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B5%B7%E5%8B%95%E6%AE%B5%E9%9A%8E%E3%81%A7serdes%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E5%AE%9F%E6%96%BD%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F(init_serdes()%20%E9%96%A2%E6%95%B0%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B)%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1782977121730.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391062i0603F69D828AD2F3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1782977121730.png%22%20alt%3D%22chenyin_h_0-1782977121730.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%B3%A8%EF%BC%9Aio%20pkt%E3%81%AF%E7%8F%BE%E5%9C%A8%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B6%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EU-Boot%202022.04%20(2026%E5%B9%B47%E6%9C%881%E6%97%A5%2016%3A53%3A39%20%2B0200)%3C%2FP%3E%3CP%3ESoC%3A%20NXP%20S32G399A%20rev.1.1%3CBR%20%2F%3ECPU%3AARM%20Cortex-A53%20r0p4%20%40%20max%201300%20MHz%3CBR%20%2F%3E%E3%83%A2%E3%83%87%E3%83%AB%3ANXP%20S32G399A-RDB3%3CBR%20%2F%3EDRAM%3A3.5%20GiB%3CBR%20%2F%3E%E3%82%B3%E3%82%A2%3A306%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8125%20u%E3%82%AF%E3%83%A9%E3%82%B9%E3%80%81devicetree%3A%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3EMMC%3A%20FSL_SDHC%3A%200%3CBR%20%2F%3EMMC%E3%81%8B%E3%82%89%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E7%92%B0%E5%A2%83...%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%9F%3CBR%20%2F%3E%E5%8F%8E%E9%8C%B2%3Aserial%40401c8000%3CBR%20%2F%3E%E3%82%A2%E3%82%A6%E3%83%88%3Aserial%40401c8000%3CBR%20%2F%3E%E3%81%88%E3%81%A3%E3%81%A8%3Aserial%40401c8000%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%E6%94%B9%E8%A8%82%3ARDB3%20%E6%94%B9%E8%A8%82%20F%3CBR%20%2F%3EPCIe%3A%20BusDevFun%20VendorId%20DeviceId%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%AF%E3%83%A9%E3%82%B9%E3%82%B5%E3%83%96%E3%82%AF%E3%83%A9%E3%82%B9%3CBR%20%2F%3E__________________________________________________________________________%3CBR%20%2F%3Epcie%4040400000%20%E3%83%AB%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%3CBR%20%2F%3E%7C%E3%80%8C--%2001%3A00%200x1957%200x4300%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E8%A3%85%E7%BD%AE0x04%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%3Aeth0%3A%20ethernet%404033c000%3CBR%20%2F%3EPFE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30x0101(S32G3)%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%80%81eth1%3A%20PFE0%E3%80%81eth2%3A%20PFE1%E3%80%81eth3%3A%20PFE2%3CBR%20%2F%3EHit%20any%20key%20to%20stop%20autoboot%3A%202%20%26%238%3B%26%238%3B%26%238%3B%201%20%26%238%3B%26%238%3B%26%238%3B%200%3CBR%20%2F%3E%3D%26gt%3B%20printenv%3CBR%20%2F%3Eatf_fdt_0to3%3DFDT%20addr%200x83e00000%3BFDT%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%3BFDT%20%E3%82%BB%E3%83%83%E3%83%88%20%2FCPUS%2Fcpu%401%20CPU-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3BFDT%20set%20%2FCPUS%2Fcpu%40100%20CPU-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3BFDT%20%E3%82%BB%E3%83%83%E3%83%88%20%2FCPUS%2Fcpu%40101%20CPU-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%3CBR%20%2F%3Eatf_fdt_4to7%3DFDT%20set%20%2Fcpus%2Fcpu%402%20CPU-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3BFDT%20%E3%82%BB%E3%83%83%E3%83%88%20%2FCPUS%2Fcpu%403%20CPU-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3BFDT%20%E3%82%BB%E3%83%83%E3%83%88%20%2FCPUS%2Fcpu%40102%20CPU-release-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3BFDT%20%E3%82%BB%E3%83%83%E3%83%88%20%2FCPUS%2Fcpu%40103%20CPU-%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9-addr%20%26lt%3B0x0%200xa0000010%26gt%3B%3B%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%3D115200%3CBR%20%2F%3Eboard_rev%3DF%3CBR%20%2F%3Eboot_mtd%3Dbooti%3CBR%20%2F%3Eboot_qnx_atf%3DMMC%20dev%200%3B%E3%83%95%E3%82%A1%E3%83%83%E3%83%88%E3%83%AD%E3%83%BC%E3%83%89%20MMC%200%3A1%200x83e00000%20S32G399A-RDB3.dtb%3Batf_fdt_0to3%20%E3%82%92%E5%AE%9F%E8%A1%8C%3B%20atf_fdt_4to7%20%E3%82%92%E5%AE%9F%E8%A1%8C%3B%20mmc%200%3A1%200x80080000%20ifs-s32g399a-rdb.ui%20%E3%82%92%E3%83%95%E3%82%A1%E3%83%83%E3%83%88%E3%83%AD%E3%83%BC%E3%83%89%3B%E3%83%96%E3%83%BC%E3%83%84%E3%83%A00x80080000%20-%200x83E00000%3CBR%20%2F%3Ebootargs%3Droot%3D%2Fdev%2Fram%20RW%20EarlyCon%20loglevel%3D7%3CBR%20%2F%3Ebootcmd%3Drun%20boot_qnx_atf%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88%E9%81%85%E5%BB%B6%3D2%3CBR%20%2F%3Econsole%3DttyLF0%3CBR%20%2F%3Ecpu_trap%3Ddcache%20off%3BMW.L%200xa0000000%200xd503205f%3BMW.L%200xa0000004%200x58000060%3BMW.L%200xa0000008%200xb4ffffc0%3BMW.L%200xa000000C%200xd61f0000%3BMW.Q%200xa0000010%200x00000000%3Bdcache%20on%3B%3CBR%20%2F%3Eeth1addr%3D00%3A04%3A9f%3Abe%3Aef%3A00%3CBR%20%2F%3Eeth2addr%3D00%3A04%3A9f%3Abe%3Aef%3A01%3CBR%20%2F%3Eeth3addr%3D00%3A04%3A9f%3Abe%3Aef%3A02%3CBR%20%2F%3EEthaddr%3D0E%3A46%3A58%3A92%3A0B%3A68%3CBR%20%2F%3Efdt_addr%3D0x83000000%3CBR%20%2F%3Efdt_enable_hs400es%3DFDT%20%E5%8A%A0%E7%AE%97%20%24%7Bfdt_addr%7D%3BFDT%20RM%20%2FSOC%2FMMC%20No-1-8-V%3BFDT%E3%83%AA%E3%82%B5%E3%82%A4%E3%82%BA%3B%3CBR%20%2F%3Efdt_file%3DS32G399a-rdb3.dtb%3CBR%20%2F%3Efdt_high%3D0xffffffffffffffff%3CBR%20%2F%3Efdt_override%3D%3B%3CBR%20%2F%3EFDTcontroladdr%3Dffa96000%3CBR%20%2F%3Eflashboot%3Decho%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E4%B8%AD...%3Bflashbootargs%E3%82%92%E5%AE%9F%E8%A1%8C%3Bmtd%E3%81%AFKernel%20%24%7Bloadaddr%7D%E3%82%92%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3Bmtd%E3%81%AFDTB%E3%82%92%E8%AA%AD%E3%81%BF%20%24%7Bfdt_addr%7D%3Bmtd%E3%81%AFRootfs%20%24%7Bramdisk_addr%7D%E3%81%A8%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3B%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20%24%7Bramdisk_addr%7D%20%24%7Bfdt_addr%7D%3B%3CBR%20%2F%3EFlashBootArgs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fram%20RW%20earlycon%20%3BSetenv%20Flashsize%200x04000000%3B%3CBR%20%2F%3Ehwconfig%3Dserdes0%3Amode%3Dpcie%2Cclock%3Dext%3BPCIe0%3Amode%3Drc%3BSerdes1%3Amode%3DXPCs0%26amp%3BXPCs1%2Cclock%3Dext%2CFMHZ%3D125%3Bxpcs1_0%3A%E9%80%9F%E5%BA%A6%3D2G5%3Bxpcs1_1%3A%E9%80%9F%E5%BA%A6%3D1G%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%3D%E7%94%BB%E5%83%8F%3CBR%20%2F%3Einitrd_high%3D0xffffffffffffffff%3CBR%20%2F%3Eipaddr%3D10.0.0.100%3CBR%20%2F%3Eloadaddr%3D0x80000000%3CBR%20%2F%3ELoadFDT%3DFatload%20MMC%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%24%7Bfdt_addr%7D%20span%20translate%3D%E3%80%8C%E3%81%84%E3%81%84%E3%81%88%E3%80%8D%26gt%3B13%20%24%7Bfdt_file%7D%3Bfdt_override%E8%B5%B0%E3%82%8B%3B%3CBR%20%2F%3Eloadimage%3Dfatload%20mmc%20%24%7Bmmcdev%7D%3A%24%7Bmmcpart%7D%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3CBR%20%2F%3Eloadtftpfdt%3Dtftp%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%3B%3CBR%20%2F%3Eloadtftpimage%3Dtftp%20%24%7Bloadaddr%7D%20%24%7Bimage%7D%3B%3CBR%20%2F%3Emmcargs%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%24%7Bmmcroot%7D%20earlycon%3CBR%20%2F%3Emmcboot%3Decho%20mmc%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E4%B8%AD%20...%3Bmmcargs%E3%82%92%E9%81%8B%E5%96%B6%E3%81%97%E3%80%81loadFDT%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6fdt_fixups%E8%B5%B0%E3%82%8B%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%3B%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%82%A8%E3%82%B3%E3%83%BCWARN%3ADT%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3Bfi%3B%3CBR%20%2F%3EMMCDEV%3D0%3CBR%20%2F%3EMMCPART%3D1%3CBR%20%2F%3EMMCroot%3D%2Fdev%2Fmmcblk0p2%20rootwait%20RW%3CBR%20%2F%3ENetARGS%3Dsetenv%20bootargs%20console%3D%24%7Bconsole%7D%2C%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20ip%3Ddhcp%20nfsroot%3D%24%7Bserverip%7D%3A%24%7Bnfsroot%7D%2Cv3%2CTCP%20earlycon%3CBR%20%2F%3Enetboot%3Decho%20%E3%83%8D%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E4%B8%AD...%3BNetARGS%E3%82%92%E9%81%8B%E5%96%B6%3B%E3%82%82%E3%81%97%E6%A4%9C%E5%AE%9A%20%24%7Bip_dyn%7D%20%3D%20%E3%81%AF%E3%81%84%E3%81%AA%E3%82%89%E3%81%B0%E3%80%81%E6%AC%A1%E3%81%ABSetenv%20get_cmd%20DHCP%E3%80%81else%20setenv%20get_cmd%20TFTP%3Bfi%3B%20%24%7Bget_cmd%7D%20%24%7Bimage%7D%3B%E3%82%82%E3%81%97%E6%A4%9C%E5%AE%9A%20%24%7Bboot_fdt%7D%20%3D%20%E3%81%AF%E3%81%84%20%7C%7C%E3%83%86%E3%82%B9%E3%83%88%20%24%7Bboot_fdt%7D%20%3D%E3%83%88%E3%83%A9%E3%82%A4%3B%E3%82%82%E3%81%97%20%24%7Bget_cmd%7D%20%24%7Bfdt_addr%7D%20%24%7Bfdt_file%7D%E3%81%AA%E3%82%89%E3%81%B0%3B%E3%81%9D%E3%82%8C%E3%81%AA%E3%82%89%20%24%7Bboot_mtd%7D%24%7Bloadaddr%7D%20span%20translate%3D%E3%80%8Cno%E3%80%8D%26gt%3B42%20-%20%24%7Bfdt_addr%7D%3B%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%20test%20%24%7Bboot_fdt%7D%20%3D%20try%20%E3%81%AE%E5%A0%B4%E5%90%88%3B%E6%AC%A1%E3%81%AB%24%7Bboot_mtd%7D%3B%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%82%A8%E3%82%B3%E3%83%BCWARN%3ADT%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3Bfi%3Bfi%3B%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%24%7Bboot_mtd%7D%3Bfi%3B%3CBR%20%2F%3Enetmask%3D255.255.255.0%3CBR%20%2F%3Enfsboot%3Decho%20tftp%E3%81%A8nfs%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%8D%E3%83%83%E3%83%88%E3%81%8B%E3%82%89%E3%83%96%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3B%20run%20nfsbootargs%3Brun%20loadtftpimage%3B%20run%20loadtftpfdt%3B%20%24%7Bboot_mtd%7D%20%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr%7D%20%3B%3CBR%20%2F%3E%20nfsbootargs%3Dsetenv%20bootargs%20console%3D%20%24%7Bconsole%7D%20%2C%20%24%7Bbaudrate%7D%20root%3D%2Fdev%2Fnfs%20rw%20ip%3D%20%24%7Bipaddr%7D%20%3A%20%24%7Bserverip%7D%20%3A%3A%20%24%7Bnetmask%7D%20%3A%3Aeth0%3Aoff%20nfsroot%3D%20%24%7Bserverip%7D%20%3A%2Ftftpboot%2Frfs%2Cnolock%2Cv3%2Ctcp%20earlycon%3CBR%20%2F%3E%20pfe1_phy_addr%3D8%3CBR%20%2F%3E%20pfeng_mode%3Denable%2Csgmii%2Csgmii%2Crgmii%3CBR%20%2F%3E%20ramdisk_addr%3D0x90000000%3CBR%20%2F%3E%20release_cpus%3Drun%20cpu_trap%3B%20mp%201%20release%200xa0000000%3B%20mp%202%20release%200xa0000000%3B%20mp%203%20release%200xa0000000%3B%20mp%204%20release%200xa0000000%3B%20mp%205%20release%200xa0000000%3B%20mp%206%20release%200xa0000000%3B%20mp%207%20release%200xa0000000%3B%3CBR%20%2F%3E%20script%3Dboot.scr%3CBR%20%2F%3Eserverip%3D10.0.0.1%3CBR%20%2F%3E%20skip_scmi_reset_agent%3D1%3CBR%20%2F%3E%20stderr%3Dserial%40401c8000%3CBR%20%2F%3E%20stdin%3Dserial%40401c8000%3CBR%20%2F%3E%20stdout%3Dserial%40401c8000%3C%2FP%3E%3CP%3E%E7%92%B0%E5%A2%83%E3%82%B5%E3%82%A4%E3%82%BA%3A3581%2F8188%E3%83%90%E3%82%A4%E3%83%88%3CBR%20%2F%3E%3D%26gt%3B%E3%83%96%E3%83%BC%E3%83%84%3CBR%20%2F%3E%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%230%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%80%81OK%3CBR%20%2F%3EMMC0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%99%3CBR%20%2F%3E59970%E3%83%90%E3%82%A4%E3%83%88%E3%82%927ms(8.2%20MiB%2Fs)%E3%81%A7%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3CBR%20%2F%3E9362112%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%80%9F%E5%BA%A6%E3%81%AF394ms(22.7%20MiB%2Fs)%3CBR%20%2F%3E%23%23%20Booting%20kernel%20from%20Legacy%20Image%20at%2080080000%20...%3CBR%20%2F%3EImage%20Name%3A%3CBR%20%2F%3EImage%20Type%3A%20AArch64%20Linux%20Kernel%20Image%20(uncompressed)%3CBR%20%2F%3EData%20Size%3A%209362048%20Bytes%20%3D%208.9%20MiB%3CBR%20%2F%3ELoad%20Address%3A%2080080000%3CBR%20%2F%3EEntry%20Point%3A%2080080000%3CBR%20%2F%3EVerifying%20Checksum%20...%20OK%3CBR%20%2F%3E%23%23%2083e00000%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%83%88%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%96%E3%83%AD%E3%83%96%3CBR%20%2F%3E0x83e00000%E3%81%AEFDT%E3%83%96%E3%83%AD%E3%83%96%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%9200000000083e00000%E3%81%AB%E8%A8%AD%E7%BD%AE%E3%81%97%E3%81%A6%E3%80%81%E7%B5%82%E4%BA%86%E6%99%82%E3%81%AE0000000083e11fff%3CBR%20%2F%3E%E4%BF%AE%E6%AD%A3%3APFE1%3APHY%20ADR%E3%82%920x8%E3%81%AB%E6%9B%B4%E6%96%B0%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3Eboard_cleanup_before_linux%3A%20QNX%20PFE%20%E3%82%B3%E3%83%BC%E3%83%89%E3%80%82%3CBR%20%2F%3Eethernet%404033c000%20PHY%E3%81%AE%E8%87%AA%E5%8B%95%E4%BA%A4%E6%B8%89%E5%AE%8C%E4%BA%86%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B.........%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88!%3CBR%20%2F%3Ephy_startup()%E5%A4%B1%E6%95%97%3A-110%20%E5%A4%B1%E6%95%97%3A-110%3CBR%20%2F%3EPFE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30x0101(S32G3)%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EPFE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B30x0101(S32G3)%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Epfe2%20PHY%E8%87%AA%E5%8B%95%E4%BA%A4%E6%B8%89%E5%AE%8C%E4%BA%86%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B.........%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88!%3CBR%20%2F%3Epfe1%20pfeng_netif%3APFE1%E3%81%A7XPCS%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%23%23%20Setting%20pfe_ts%20clock%20...%3CBR%20%2F%3E%23%23%20%E6%99%82%E8%A8%88ftm0_sys%E3%82%BB%E3%83%83%E3%83%88...%3CBR%20%2F%3E%23%23%20Setting%20ftm0_ext%20clock%20...%3CBR%20%2F%3E%23%23%20%E6%99%82%E8%A8%88ftm1_sys%E3%82%BB%E3%83%83%E3%83%88...%3CBR%20%2F%3E%23%23%20%E6%99%82%E8%A8%88ftm1_ext%E3%82%BB%E3%83%83%E3%83%88%20...%3CBR%20%2F%3EEVB%2FRDB%E4%B8%8A%E3%81%AEPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E7%94%A8%E3%81%ABRAM%E9%A0%98%E5%9F%9F%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%3CBR%20%2F%3EClockCycles%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%3A%3CBR%20%2F%3E0%20166386615%3CBR%20%2F%3E1%20166386614%3CBR%20%2F%3E2%20166386615%3CBR%20%2F%3E3%20166386615%3CBR%20%2F%3E4%20166386615%3CBR%20%2F%3E5%20166386615%3CBR%20%2F%3E6%20166386616%3CBR%20%2F%3E7%20166386615%3CBR%20%2F%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEClockCycles%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%E8%A8%B1%E5%AE%B9%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%A7%E3%81%99%3CBR%20%2F%3EQNX%20%E3%83%8B%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%83%8E%207.1.0%E3%81%B8%E3%82%88%E3%81%86%E3%81%93%E3%81%9DNXP%20S32G399A%20RDB%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A6!!%3CBR%20%2F%3E%E8%A6%8B%E5%BC%B5%E3%82%8A%E3%82%92%E5%A7%8B%E3%82%81%E3%82%8B...%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90(%2Fdev%2Fsocket)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3EUtarting%20SPI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90(%2Fdev%2Fspi0%2C1%2C2%2C3%2C4%2C5)...%3CBR%20%2F%3EI2C%200%2F1%2F2%2F3%2F4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90(%2Fdev%2Fi2c0%2C1%2C2%2C3%2C4)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3EUSDHC0%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3E%5B00%5D%20QSPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD...%3CBR%20%2F%3ESIM%3D%22SDMMC%22%20HBA%3D%22imx%22%3CBR%20%2F%3E%5B00%2C0%2C0%5D%20type%3D00%20ver%3D05%20resp%3D00%20SDMMC%3A%3CBR%20%2F%3EUSB%E3%83%9B%E3%82%B9%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90(%2Fdev%2Fusb%2F*)%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%3CBR%20%2F%3EQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%A4%9C%E5%87%BA%3AMacronix%20MX25UW512%E3%80%81JEDEC%200xC2%20-%200x813A%E3%80%81%E3%82%B5%E3%82%A4%E3%82%BA%3A0x4000000%3CBR%20%2F%3E%2Fdev%2Fusb%2F*%20%E3%81%AEdevb-umass%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99...%3CBR%20%2F%3EU%23%20slogi%26%238%3B%20%26%238%3B2info%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.022%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0.4low*%200%20qcrypto%3A%20%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20'%2Fetc%2Fqcrypto.conf'%20%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%5Bqcrypto_common.c(190)%5D%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.023%20random.4..0%20slog*%20700%20Random%E3%81%AFFortuna%20PRNG%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0.4low%200%20qcrypto%3A%20'openssl'%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%20%5Bqcrypto_plugins.c(354)%5D%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random..0%20%E3%82%B9%E3%83%AD%E3%82%B0700%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AD%E3%83%94%E3%83%BC%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random..0%20slog%20700%20%E7%99%BB%E9%8C%B2%E6%B8%88%E3%81%BF%E3%83%91%E3%82%B9%E5%90%8D%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random..0%20%E3%82%B9%E3%83%AD%E3%82%B0700%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3A%E3%83%AC%E3%82%B9%E3%83%9F%E3%83%A5%E3%83%A9%E3%83%BC%E9%96%8B%E5%A7%8B%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.031%20random..0%20%E3%82%B9%E3%83%AD%E3%82%B0%20700%20%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%3A%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E3%83%87%E3%83%BC%E3%83%A2%E3%83%8B%E3%82%BA%E3%83%A0%E5%8C%96%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A00.041%20devc_serlinflexd.7%20%E3%82%B9%E3%83%AD%E3%83%BC*%200%20serlinflexd_interrupt_attach%3A%E4%B8%AD%E6%96%AD114%E3%81%AB%E6%8E%A5%E7%B6%9A%E4%B8%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.146%20spi_master.8%20%E9%80%9A%E5%B8%B8*%200%20%E3%82%B9%E3%83%91%E3%82%A4%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E8%B5%B7%E5%8B%95%E4%B8%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.149%20spi_master.9%20%E9%80%9A%E5%B8%B8*%200%20spi-master%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E8%B5%B7%E5%8B%95%E4%B8%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.152%20spi_master.10%20%E9%80%9A%E5%B8%B8*%200%20%E3%82%B9%E3%83%91%E3%82%A4%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E9%96%8B%E5%A7%8B%E4%B8%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.155%20spi_master.11%20%E9%80%9A%E5%B8%B8*%200%20%E3%82%B9%E3%83%91%E3%82%A4%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E9%96%8B%E5%A7%8B%E4%B8%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.158%20spi_master.12%20%E9%80%9A%E5%B8%B8*%200%20%E3%82%B9%E3%83%91%E3%82%A4%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E9%96%8B%E5%A7%8B%E4%B8%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.161%20spi_master.13%20%E9%80%9A%E5%B8%B8*%200%20%E3%82%B9%E3%83%91%E3%82%A4%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E9%96%8B%E5%A7%8B%E4%B8%AD%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.177%20devb_sdmmc_mx8x.19%20slog*%201800%20devb-sdmmc-mx8x%201.00A%20(2026%E5%B9%B47%E6%9C%881%E6%97%A5%2014%3A10%3A37)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.178%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20libcam.so(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%20bver%207010003%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.189%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20sdio_cd%3A%E6%8C%BF%E5%85%A5%E3%83%91%E3%82%B90%E3%80%81CD%20%E7%8A%B6%E6%85%8B0x1%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20SD%20CID%3A%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20%E3%83%9F%E3%83%83%E3%83%890x27%E3%80%81OID%200x5048%E3%80%81PNM%20SD32G%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B01800%20PRV%200x62%E3%80%81PSN%200x6c62d196%E3%80%81MDT%204-2023%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20SD%E3%81%AECSD%3A%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20CSD_STRUCTURE%201%2C%20SPEC_VERS%200%2C%20CCC%200x5b5%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20TAAC%2014%2C%20NSAC%200%2C%20TRAN_SPEED%2050%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20C_SIZE%2059023%2C%20C_SIZE_MULT%200%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20READ_BL_LEN%209%2C%20WRITE_BL_LEN%209%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%83%BC%E3%82%B0%201800%20%E6%B6%88%E5%8E%BB%20GRP_SIZE%200%2C%20GRP_MULT%200%2C%20%E3%82%B5%E3%82%A4%E3%82%BA%20127%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20blksz%20512%2C%20sectors%2060440576%2C%20dtr%2025000000%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20SD%20SW%E3%82%AD%E3%83%A3%E3%83%83%E3%83%97%3A%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20slog%201800%20%E3%83%90%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%890x3%E3%80%81cmd%20sys%200x1%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B01800%20drv%20%E3%82%BF%E3%82%A4%E3%83%970x1%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E9%99%90%E7%95%8C0x1%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20dtr%2050000000%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.239%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0%201800%20CFG%3A%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0HS%E3%80%81DTR%2050000000%E3%80%81%E3%83%90%E3%82%B9%E5%B9%854%E3%83%93%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.240%20devb_sdmmc_mx8x.19%20%E3%82%B9%E3%83%AD%E3%82%B0100%20cam-disk.so(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A17)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D1a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.242%20devb_sdmmc_mx8x.19%20slog%200%20scsi_interpret_sense%20(sdmmc%20ptl-0%3A0%3A0)%3A%20cam_status%3Dc4%2C%20scsi_status%3D2%2C%20flag%3D00000040%2C%20vuflag%3D0008%2C%20cmd%3D5a%2C%20error%3D70%2C%20sense%3D5%2C%20asc%3D24%2C%20ascq%3D0%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.248%20io_usb_otg.21%20slog*%200%20main(453)%5Btid%3A1%5D%3A%20io-usb-otg%20(2020%E5%B9%B46%E6%9C%8813%E6%97%A5%2020%3A10%3A17)%20args%3A%20-d%20hcd-ehci-mx28%20ioport%3D0x44064100%2Cirq%3D243%2Culpi%2Cno_stream%2Cverbose%3D5%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.250%20devf_qspi_s32g.20%20%E3%82%B9%E3%83%AD%E3%83%BC%E3%82%B0*%200%20(devf%20t1%3A%3Af3s_qspi_ident%3A73)%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA%3A256%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.250%20devf_qspi_s32g.20%20%E3%82%B9%E3%83%AD%E3%82%B00(devf%20t1%3A%3Af3s_qspi_ident%3A74)%20%E3%83%81%E3%83%83%E3%83%97%E3%82%B5%E3%82%A4%E3%82%BA%3A0x4000000%E3%80%81%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%3A0x10000%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.254%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20ehci_init%3A%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.254%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20ehci_controller_init(4292)%3A%20devu-hcd-ehci-mx28.so%20(2023%E5%B9%B48%E6%9C%8815%E6%97%A5%2016%3A44%3A48)%3A%20args%20ulpi%2Cno_stream%2Cverbose%3D5%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.254%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%208%20usb_enum_port(94)%5Btid%3A1%5D%3A%20%E3%83%90%E3%82%B9%E3%83%8E0%E3%80%81%E8%A6%AA%E8%88%B9-1%E3%80%81%E3%83%9D%E3%83%BC%E3%83%880%E3%80%81%E9%AB%98%E9%80%9F%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%971%2C%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B90%E3%80%81%E9%95%B7%E3%81%95%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%2012%20usb_device_set_address(245)%5Btid%3A1%5D%3A%20b%3A0%20devno%200%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%971%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B90%E3%80%81%E9%95%B7%E3%81%9518)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%972%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B90%E3%80%81%E9%95%B7%E3%81%959)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.255%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%2011%20usb_client_descriptor_get(198)%5Btid%3A1%5D%3A%20(%E3%82%BF%E3%82%A4%E3%83%972%E3%80%81%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B90%E3%80%81%E9%95%B7%E3%81%9525)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.256%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%208%20usb_enum_port(141)%5Btid%3A1%5D%3A%20vid%200x0000%E3%80%81%E5%88%97%E6%8C%990x0000%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B(busno%200%2C%20devno%200%3A0)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.256%20io_usb_otg.21%20slog%2011%20hub_state_inserted(569)%5Btid%3A1%5D%3A%20bdentry%200%2C%20dentry%200%200%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.256%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%2013%20hub_configuration_enable(263)%5Btid%3A1%5D%3A%201%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.358%20io_usb_otg.21%20%E8%8B%A6%E5%8A%B4%200%20usbh_timeout_init(203)%5Btid%3A1%5D%3A%20%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.369%20io_usb_otg.21%20%E8%8B%A6%E5%8A%B4%200%20read_vid_pid%3AULPI%20VID%200x0424%20PID%200x0009%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.369%20io_usb_otg.21%20%E8%8B%A6%E5%8A%B4%200%20s32g_phy_set_vbus%3A%20set_vbus%20off%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.383%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%83%BC%E3%82%B0%200%20s32g_phy_set_vbus%3A%20%E3%81%A7set_vbus%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.394%20io_usb_otg.21%20slog%200%20ehci_get_port_status(3557%200x44064100)%3A%20port%3D0%2C%20tpstatus%2010100%20e_pstatus%208c001000%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.394%20io_usb_otg.21%20slog%208%20usb_enum_port_extract(172)%5Btid%3A7%5D%3A%20(busno%200%2C%20pdevno%200%2C%20portno%201)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.394%20io_usb_otg.21%20%E3%82%B9%E3%83%AD%E3%82%B0%208%20usb_enum_port_extract(192)%5Btid%3A7%5D%3A%20status(2)%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.398%20devb_umass.22%20%E3%82%B9%E3%83%AD%E3%82%B0*%20900%20devb-umass%201.00A%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A41))%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.399%20devb_umass.22%20%E3%82%B9%E3%83%AD%E3%83%BC%E3%82%B0%200%20libcam.so%20(2020%E5%B9%B46%E6%9C%8822%E6%97%A5%2021%3A33%3A15)%20bver%207010003%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.400%20io_usb_otg.21%20slog%200%20usbdi_client_connect(58)%5Btid%3A5%5D%3A%20pid%2022%20proc%3Dproc%2Fboot%2Fdevb-umass%20usbdi_client%2051ba29fa80%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.400%20io_usb_otg.21%20%E8%8B%A6%E5%8A%B4%200%20usbdi_resmgr_connect(310)%5Btid%3A5%5D%3A%20usbdi_resmgr_connect%3A%20pid%2022%20usbdi_client%2051ba29fa80%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A10.400%20devb_umass.22%20slog%200%20usbdi%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%91%E3%82%B9%20%2Fpps%2Fusb%2Fdebug%2F%20%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A14.507%20qconn.24%20slog*%200%20%E3%83%AA%E3%82%B9%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3Atcp(%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AF%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%82%92%E3%81%8A%E4%BC%9D%E3%81%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%3C%2FP%3E%3CP%3EIO-pkt-v6-HC%20-p%20tcpip%20pkt_typed_mem%3Dpfe_ddr%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3C%2FP%3E%3CP%3Epfe0%E3%81%AB%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20192.168.0.200%20netmask%20255.255.255.0%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20down%3C%2FP%3E%3CP%3Eifconfig%20pfe0%20up%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E5%A4%96%E9%83%A8%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%B8%E3%81%AEping%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%80%81ifconfig%E3%81%AEpfe0%E3%81%A7%E3%81%AF%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%8C%E5%85%A8%E3%81%8F%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E9%80%9F%E5%BA%A6%E3%81%AE%E4%BA%A4%E6%B8%89%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%80%9D%E3%81%88%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%23%20slog2info%20%7C%20grep%20pfe0%3C%2FP%3E%3CP%3EJan%2001%2000%3A00%3A25.515%20iopkt.4121%20main_buffer%200%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A25.517%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A1460%5D%3Apfe0%2FEMAC0%E3%81%AEMII%E3%83%A2%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82SGMII%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1%E6%9C%881%E6%97%A5%2000%3A00%3A25.647%20iopkt.4121%20main_buffer%200%20pfe0%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B998332%EF%BC%88slog2info%EF%BC%89%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B90%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A25.647%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A2124%5D%3Apfe0%3A%20%E9%9D%99%E7%9A%84PHY%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%81RESET%3D0%3CBR%20%2F%3E%201%20%E6%9C%88%2001%20%E6%97%A5%2000%3A00%3A25.647%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A2286%5D%3Apfe0%E3%81%AE%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%821Gbps%2F%E5%85%A8%E4%BA%8C%E9%87%8D%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A00%3A58.251%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E1%20%E6%9C%88%2001%20%E6%97%A5%2000%3A01%3A05.966%20io_pkt_v6_hc.4121%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20INF%5Bsrc%2Fpfe_drv.c%3A2606%5D%3Apfe0%3A%20%E3%83%97%E3%83%AD%E3%83%9F%E3%82%B9%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPfe2%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81uboot%E3%81%AEboard_cleanup_before_linux%E3%81%A7%E6%97%A2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Epfe2%20PHY%E8%87%AA%E5%8B%95%E4%BA%A4%E6%B8%89%E5%AE%8C%E4%BA%86%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B.........%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88!%3C%2FP%3E%3CP%3E%E8%BF%BD%E8%A8%98%3Apfe2%E3%81%8B%E3%82%89%E3%82%82ping%E3%81%AF%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E9%80%9F%E5%BA%A6%E3%81%AE%E4%BA%A4%E6%B8%89%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%80%A4%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2389519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2389519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Einit_serdes()%3B%3C%2FP%3E%3CP%3Es32g399a-rdb%20%E3%81%AE%20main.c%20%E3%81%8B%E3%82%89%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390139%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%82%B4%E3%83%BC%E3%83%AB%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%8F%E3%81%9F%E3%82%81%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%A8%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20pfe0%E3%81%A8pfe2%E3%81%AEMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9Fio%20pkt%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E8%A9%A6%E3%81%BF%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIO-pkt-v6-HC%20-p%20tcpip%20pkt_typed_mem%3Dpfe_ddr%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%A4%96%E9%83%A8%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8B%E3%82%89pfe0%E3%81%ABping%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%9D%E3%81%AE%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AEARP%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%81%AF%E5%81%BD%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3F%20(192.168.0.200)%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20on%20enx00e04c680383%3C%2FP%3E%3CP%3E%E5%A4%96%E9%83%A8%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81tcpdump%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%81192.168.0.200%E3%82%92%E6%8C%81%E3%81%A4pfe0%E3%81%8B%E3%82%89%E3%81%AEARP%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E08%3A53%3A11.208021%20IP6%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC-Precision-7510%20%26gt%3B%20ff02%3A%3A16%3A%20HBH%20ICMP6%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88v2%E3%80%81%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%892%E4%BB%B6%E3%80%81%E9%95%B7%E3%81%9548%3CBR%20%2F%3E08%3A53%3A11.394038%20IP6%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC-Precision-7510%20%26gt%3B%20ff02%3A%3A16%3A%20HBH%20ICMP6%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88v2%E3%80%81%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%892%E4%BB%B6%E3%80%81%E9%95%B7%E3%81%9548%3CBR%20%2F%3E08%3A53%3A25.750284%20ARP%E3%80%81%E8%AA%B0%E3%81%8B%E3%82%92%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%20192.168.0.200%20%E3%83%86%E3%82%A4%E3%83%AB%20192.168.0.200%E3%80%81%E9%95%B7%E3%81%9546%3CBR%20%2F%3E08%3A53%3A26.641915%20IP6%20%3A%3A%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20HBH%20ICMP6%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E5%A0%B1%E5%91%8A%20%E6%9C%80%E5%A4%A7%E5%BF%9C%E7%AD%94%E9%81%85%E5%BB%B6%3A0%20addr%3A%20ff02%3A%3A1%3Aff0c%3Ad66%E3%80%81%E9%95%B7%E3%81%9524%3CBR%20%2F%3E08%3A53%3A26.692011%20IP6%20%3A%3A%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20ICMP6%E3%80%81%E9%9A%A3%E4%BA%BA%E3%81%AE%E5%8B%A7%E8%AA%98%E3%80%81%E8%AA%B0%E3%81%8Cfe80%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%3A%3A20a%3Abff%3Afe0c%3Ad66%E3%80%81%E9%95%B7%E3%81%9524%3CBR%20%2F%3E08%3A53%3A32.742005%20IP6%20fe80%3A%3A20a%3ABFF%3Afe0c%3Ad66%20%26gt%3B%20ff02%3A%3A1%3Aff0c%3Ad66%3A%20HBH%20ICMP6%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%82%B9%E3%83%8A%E3%83%BC%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%20%E6%9C%80%E5%A4%A7%E8%A7%A3%E5%83%8F%E5%BA%A6%E9%81%85%E5%BB%B6%3A0%20addr%3A%20ff02%3A%3A1%3Aff0c%3Ad66%E3%80%81%E9%95%B7%E3%81%9524%3C%2FP%3E%3CP%3E%E5%A4%96%E9%83%A8%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8B%E3%82%89%E5%86%8D%E5%BA%A6ping%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E5%BF%9C%E7%AD%94%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E08%3A59%3A22.118282%20ARP%E3%80%81192.168.0.200%20%E3%82%92%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC-Precision-7510%E3%82%92%E4%BC%9D%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E9%95%B7%E3%81%9528%3CBR%20%2F%3E08%3A59%3A22.118553%20ARP%E3%80%81%E5%BF%9C%E7%AD%94%20192.168.0.200%20is-at%2022%3A33%3A44%3A55%3A66%3A77%20(oui%20%E4%B8%8D%E6%98%8E)%E3%80%81%E9%95%B7%E3%81%9546%3CBR%20%2F%3E08%3A59%3A22.118569%20IP%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC-Precision-7510%20%26gt%3B%20192.168.0.200%3AICMP%E3%82%A8%E3%82%B3%E3%83%BC%E8%A6%81%E6%B1%82%E3%80%81ID%201%E3%80%81%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E7%95%AA%E5%8F%B7%201%E3%80%81%E9%95%B7%E3%81%95%2064%3CBR%20%2F%3E%2008%3A59%3A22.118554%20ARP%E3%80%81%E5%BF%9C%E7%AD%94%20192.168.0.200%20is-at%2000%3A0a%3A0b%3A0c%3A0d%3A66%20(oui%20%E4%B8%8D%E6%98%8E)%E3%80%81%E9%95%B7%E3%81%95%2046%3C%2FP%3E%3CP%3E00%3A0a%3A0b%3A0c%3A0d%3A66%20%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%20MAC%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E5%A4%96%E9%83%A8%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AEARP%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E5%81%BD%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3Earp%20-a%3C%2FP%3E%3CP%3E%3F%20(192.168.0.200)%2022%3A33%3A44%3A55%3A66%3A77%20%5Bether%5D%20on%20enx00e04c680383%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E6%8E%A8%E6%B8%AC%E3%81%A7%E3%81%AF%E3%80%81uboot%E3%81%A7%E6%89%8B%E5%8B%95%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%86%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%B5%B1%E5%90%88%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E6%8E%A8%E5%A5%A8%E3%81%99%E3%82%8B%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-%20%E3%80%8C%E5%9B%BA%E5%AE%9A%E3%83%AA%E3%83%B3%E3%82%AF%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%82%3C%2FP%3E%3CP%3Eethaddr%E3%80%81eth1addr%E3%80%81eth2addr%E3%80%81eth3addr%E3%81%AF%E7%A7%81%E3%81%AEuboot%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81pfe0%E3%81%AE%E5%A5%87%E5%A6%99%E3%81%AAMAC%E3%82%92%E9%98%B2%E3%81%90%E3%81%AB%E3%81%AF%E5%8D%81%E5%88%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390229%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3CSPAN%20class%3D%22fontstyle0%22%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%8Cio-pkt-v6-hc%20-p%20tcpip%20-d%20%3CDRIVER%3E%20%5C%20pfe1_mac%3D000a0b0c0d0e%2Cpfe2_mac%3D001a1b1c1d1e%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDRIVER%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%20RDB3%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81PFE0%E3%81%AFsja1110%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81192.168.0.200%E3%81%AFSJA1110%20SDK%E5%86%85%E3%81%A7%E5%86%85%E9%83%A8%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%81%AEIP%E3%81%AFPFE0%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E4%BD%BF%E3%82%8F%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82PFE0%E3%81%AB%E3%81%AF192.168.1.X%E3%81%AA%E3%81%A9%E4%BB%96%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%20u-boot%E3%81%A7%E3%81%AF%E3%80%81%E5%90%84MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%8Csetenv%20ethaddr%2Feth1addr%2Feth2addr%20xxxx%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390300%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%BE%E3%81%9F%E3%81%BE192.168.0.200%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%88%A5%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81192.168.1.200%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88pfe0%E3%81%AA%E3%82%89%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EPFE%E3%81%8C%E5%A4%96%E9%83%A8%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A8%E6%AD%A3%E3%81%97%E3%81%8Fping%E3%81%A7%E3%81%8D%E3%81%A6%E3%82%88%E3%81%8B%E3%81%A3%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EQNX%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E3%81%AF%E5%88%B6%E9%99%90%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1783044213433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391145i0C1C82024E1B820A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1783044213433.png%22%20alt%3D%22chenyin_h_0-1783044213433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81AN%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%E9%80%9F%E5%BA%A6%E5%A4%89%E6%9B%B4%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E9%96%93%E3%80%81%E5%9B%BA%E5%AE%9A%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20%E3%81%AF%E3%81%84%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AF%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A7%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%81%A3%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%AB%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81chenyin%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AEGMac0%E3%80%81pfe0%E3%80%81pfe2%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A4%E3%82%82%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.qnx.com%2Fdevelopers%2Fdocs%2F7.0.0%2Findex.html%23com.qnx.doc.neutrino.utilities%2Ftopic%2Fb%2Fbrconfig.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.qnx.com%2Fdevelopers%2Fdocs%2F7.0.0%2Findex.html%23com.qnx.doc.neutrino.utilities%2Ftopic%2Fb%2Fbrconfig.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AF%E3%82%B5%E3%83%96%E3%83%8D%E3%83%83%E3%83%88192.168.0.X(%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF255.255.255.0)%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF192.168.0.200%E3%82%84%E4%BB%96%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A8%E7%AB%B6%E5%90%88%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%82%E3%81%97192.168.0.x%E3%82%B5%E3%83%96%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81PFE0%E3%81%A8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A4%96%E9%83%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB192.168.0.200%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%A4%96%E9%83%A8%E3%81%8B%E3%82%89PFE0%E3%81%B8%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%E9%9A%9B%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E6%8E%A5%E7%B6%9A%E3%81%AB%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E192.168.0.200%E3%81%8C%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E9%80%9A%E8%A9%B1%E3%82%92%E8%81%9E%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A4%BE%E5%86%85%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F192.168.0.200%E3%81%8C%E3%82%B5%E3%83%96%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E5%8D%98%E7%8B%AC%E3%81%A7%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AA%E5%8B%95%E4%BD%9C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%81192.168.0.200%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E7%AB%B6%E5%90%88%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%88%A5%E3%81%AE%E3%82%B5%E3%83%96%E3%83%8D%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391371%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AEIP%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%81%AE%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81chenyin%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%9F%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ETC387%20%2F%20FreeRTOS%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92pfe_mac2%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ARP%E3%83%8F%E3%83%B3%E3%83%89%E3%82%B7%E3%82%A7%E3%82%A4%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%81%AELinux%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFpfe2%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AE%E3%81%BF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82TC387%E3%82%92pfe0%E3%81%BE%E3%81%9F%E3%81%AFgmac0%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EPFE2%E3%81%AFLinux%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81S32G%E5%81%B4%E3%81%AB%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%84%E4%B8%A1%E5%81%B4%E9%96%93%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E5%88%86%E6%9E%90%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81Infineon%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392719%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%90%8C%E3%81%98%E6%A7%8B%E6%88%90%E3%81%8CLinux%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AFMAC%E5%81%B4%E3%82%88%E3%82%8A%E3%82%82TC387%E5%81%B4(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%80%81TCP%2FIP%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E6%A7%8B%E6%88%90%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%A2%E9%80%A3%E5%AE%9F%E8%A3%85)%E3%81%AB%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E3%81%AE%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E5%88%86%E6%9E%90%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%AA%E3%82%8B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ETC387%E3%82%92Linux%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E5%A4%9A%E3%81%8F%E3%81%AEARP%2FICMP%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82S32G%20pfe2%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92Linux%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%82%82%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81TC387%E3%82%92S32G%E3%81%AEpfe2%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81ARP%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%82ICMP%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%82%E5%85%A8%E3%81%8F%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81chenyin%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8CS32G399Ardb3%E3%81%AEPFE0%E3%81%A8PFE2%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Epfe0%E3%81%AF3%E3%81%A4%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9F%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%81%86%E3%81%A1%E5%B7%A6%E5%81%B4%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%80%81pfe2%E3%81%AF%E4%B8%8A%E9%83%A8%E4%B8%AD%E5%A4%AE%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3Epfe%E3%81%A8gmac%E3%82%92%E6%B7%B7%E5%9C%A8%E3%81%95%E3%81%9B%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E4%BD%95%E3%81%8B%E6%97%A2%E7%9F%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%A8%E6%8B%B6%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%A8%E3%80%81%E7%89%B9%E3%81%ABpfe_mac2%E3%81%AF100T1%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%81%A7%E5%95%8F%E9%A1%8C%E3%82%92%E6%8A%B1%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82Linux%E3%83%8E%E3%83%BC%E3%83%88PC%E3%82%92USB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%BF%E3%82%A4%E3%83%97pfe_mac2%E6%AD%A3%E3%81%97%E3%81%8F%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E7%89%B9%E5%88%A5%E3%81%AA%E3%81%93%E3%81%A8%E3%82%92%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784081687384.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392313iB58AFA9F989B7423%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1784081687384.png%22%20alt%3D%22chenyin_h_0-1784081687384.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPFE0%E3%81%AFSJA1110%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81P1%2F2%2F3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AFPFE0%E3%81%AB%E6%8E%A5%E7%B6%9A%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3EGMAC%E3%81%AFPFE%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E4%BD%BF%E3%81%86%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9Fhwconfig%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81RDB3%E3%81%A7%E4%BD%BF%E3%81%86%E5%A0%B4%E5%90%88%E3%80%813%E3%81%A4%E3%81%AEMAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E4%BD%BF%E3%81%88%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%BD%93%E5%BA%97%E3%81%A7%E3%81%AFQNX%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E7%9B%B4%E6%8E%A5%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AA%E7%B5%8C%E9%A8%93%E3%81%8B%E3%82%89%E8%A8%80%E3%81%86%E3%81%A8%E3%80%81%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E8%87%AA%E4%BD%93%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82QNX%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E6%A7%8B%E6%96%87%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E3.%20QNX%E3%81%A7%E3%81%AFPFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%88%B6%E9%99%90%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%AA%E3%83%BC%E3%83%88%E3%83%8D%E3%82%B4%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%B8%A1%E5%81%B4%E3%81%8C%E5%90%8C%E3%81%98%E9%80%9F%E5%BA%A6%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1784104171784.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392340i9DFDF7D21F4AC640%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1784104171784.png%22%20alt%3D%22chenyin_h_0-1784104171784.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E3%80%82%E7%B5%B1%E5%90%88%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%A7%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Buboot%E3%81%AE%E8%A1%8C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3Ehwconfig%20%22serdes0%3Amode%3Dpcie%2Cclock%3Dext%3Bpcie0%3Amode%3Drc%3Bserdes1%3Amode%3Dxpcs0%26amp%3Bxpcs1%2Cclock%3Dext%2Cfmhz%3D125%3Bxpcs1_0%3Aspeed%3D2G5%3Bxpcs1_1%3Aspeed%3D1G%22%3C%2FP%3E%3CP%3Egmac0%E3%80%81pfe0%E3%80%81pfe2%E3%82%92%E5%80%8B%E5%88%A5%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E6%9C%AC%E5%BD%93%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%822%E3%81%A4%E3%81%A0%E3%81%91%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%813%E3%81%A4%E3%81%AE%E9%87%8D%E3%81%AD%E3%82%89%E3%82%8C%E3%81%9F%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E4%BD%BF%E3%81%88%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E5%B7%A6%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AFpfe0%E3%80%81%E4%B8%8A%E4%B8%AD%E5%A4%AE%E3%81%AFpfe2%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82gmac0%E3%81%AF%E4%B8%8B%E4%B8%AD%E5%A4%AE%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AEio%20pkt%E6%A7%8B%E6%96%87(tcp%20ip%E3%81%AE%E5%BE%8C%E3%82%8D%E3%81%AB%E3%81%82%E3%82%8B%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E6%B3%A8%E7%9B%AE)%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIO-pkt-v6-hc%20-p%20tcpip%20bridge%20pkt_typed_mem%3Dpfe_ddr%20-d%20DWCEQOS-s32g%20MAC%3D'GenMac-Random%20-M'%2Cptp_off%2Cverbose%3D5%20-d%20%2Fproc%2Fboot%2Fdevnp-pfe-2.so%20pfe0_mac%3D000a0b0c0d66%2Cpfe1_mac%3D001a1b1c1d66%2Cpfe2_mac%3D002a2b2c2d66%2Cclass_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_class.fw%2Cutil_fw%3D%2Fproc%2Fboot%2Fs32g_pfe_util.fw%3CBR%20%2F%3Eifconfig%20dwc0%20192.168.10.100%20up%3CBR%20%2F%3E%20ifconfig%20pfe0%200.0.0.0%20up%3CBR%20%2F%3E%20ifconfig%20pfe2%200.0.0.0%20up%3CBR%20%2F%3E%20ifconfig%20bridge0%20create%3CBR%20%2F%3E%20ifconfig%20bridge0%20add%20dwc0%20add%20pfe0%20add%20pfe2%20up%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81slog2info%E3%81%A7%E5%A4%9A%E6%95%B0%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A04%3A37.485%20io_pkt_v6_hc.159753%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A(DRIVER)%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%881%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%AE%9F%E8%A1%8C%E6%99%82%E3%82%A8%E3%83%A9%E3%83%BC%3A32bit%E3%81%AEMbuf%20addr%E3%80%82%E9%96%8B%E5%A7%8B%E4%BD%8D%E7%BD%AE%EF%BC%9Ap0x8df239b58%20%E7%B5%82%E4%BA%86%E4%BD%8D%E7%BD%AE%EF%BC%9Ap0x8df239b82%3C%2FP%3E%3CP%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A04%3A38.485%20io_pkt_v6_hc.159753%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A(DRIVER)%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%881%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%AE%9F%E8%A1%8C%E6%99%82%E3%82%A8%E3%83%A9%E3%83%BC%3A32bit%E3%81%AEMbuf%20addr%E3%80%82%E9%96%8B%E5%A7%8B%EF%BC%9Ap0x8df239558%E3%80%80%E7%B5%82%E4%BA%86%EF%BC%9Ap0x8df239582%3C%2FP%3E%3CP%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A04%3A38.485%20io_pkt_v6_hc.159753%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A(DRIVER)%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%881%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%AE%9F%E8%A1%8C%E6%99%82%E3%82%A8%E3%83%A9%E3%83%BC%3A32bit%E3%81%AEMbuf%20addr%E3%80%82%E9%96%8B%E5%A7%8B%EF%BC%9Ap0x8df239558%E3%80%80%E7%B5%82%E4%BA%86%EF%BC%9Ap0x8df239582%3C%2FP%3E%3CP%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A04%3A39.451%20io_pkt_v6_hc.159753%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A(DRIVER)%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%881%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%AE%9F%E8%A1%8C%E6%99%82%E3%82%A8%E3%83%A9%E3%83%BC%3A32bit%E3%81%AEMbuf%20addr%E3%80%82%E9%96%8B%E5%A7%8B%E4%BD%8D%E7%BD%AE%EF%BC%9Ap0x8df239b58%20%E7%B5%82%E4%BA%86%E4%BD%8D%E7%BD%AE%EF%BC%9Ap0x8df239b82%3C%2FP%3E%3CP%3E1%20%E6%9C%88%201%20%E6%97%A5%2000%3A04%3A39.451%20io_pkt_v6_hc.159753%20%E3%82%B9%E3%83%AD%E3%82%B0%200%20ERR%5Bsrc%2Fpfe_drv.c%3A2996%5D%3A(DRIVER)%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%881%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%AE%9F%E8%A1%8C%E6%99%82%E3%82%A8%E3%83%A9%E3%83%BC%3A32bit%E3%81%AEMbuf%20addr%E3%80%82%E9%96%8B%E5%A7%8B%E4%BD%8D%E7%BD%AE%EF%BC%9Ap0x8df239b58%20%E7%B5%82%E4%BA%86%E4%BD%8D%E7%BD%AE%EF%BC%9Ap0x8df239b82%3C%2FP%3E%3CP%3Eio-pkt-v6-hc%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E7%B5%B1%E5%90%88%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AE%E3%81%93%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%92gmac0%E3%81%A8pfe%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81io-pkt-v6-hc%E3%82%B3%E3%83%BC%E3%83%AB%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3Ekprintf(%22EVB%2FRDB%5Cn%E3%81%A7PFE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E7%94%A8%E3%81%ABRAM%E9%A0%98%E5%9F%9F%E3%82%92%E4%BA%88%E7%B4%84%E3%81%99%E3%82%8B%22)%3B%3CBR%20%2F%3Eas_add_containing(0x80000000%2C0x80000000%20%2B%200x4000000%20-%201%2CAS_ATTR_RAM%E3%80%81%E3%80%8Cpfe_ddr%E3%80%8D%E3%80%8Cram%E3%80%8D)%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G399A-RDB3%20QNX%20PFE%20Driver%20Problems%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395825%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F264042%22%20target%3D%22_blank%22%3E%40Seneca%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.RDB3%E3%81%AEPFE2%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81NXP%E3%81%8C%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%97%E3%81%9FLinux%20BSP%E3%81%AE%E4%B8%8B%E3%81%A7100base-TX%26lt%3B-%26gt%3B100base-T1%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E7%B5%8C%E7%94%B1%E3%81%A7100T1%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8C%E3%81%B0%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82io%20%3CSPAN%20class%3D%22fontstyle0%22%3E-pkt-v6-hc%20-p%20tcpip%20-d%20pfe2_link%3D100-1-2%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81QNX%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81S32G%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E7%AF%84%E5%9B%B2%E5%A4%96%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%88%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%94%E8%BF%B7%E6%83%91%E3%82%92%E3%81%8A%E3%81%8B%E3%81%91%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
