S32G3: Thermal Shutdown
yellapu_anishkh
Hi Team
Hardware: Based on S32G3.
When reading the zone1 temperature, which is for A-core. When it reaches “64 degrees centigrade” the hardware is getting rebooted.
Below is the Linux message. Temperature is continuously read, for three zones values are as below, when issue happened.
64350(zone 0)
64350(zone 1)
62850(zone 2)
kernel[435]: [ 7919.187233] thermalthermal_zone1: a53_cores: critical temperature reached, shutting down
kernel[435]: [ 7919.187252] reboot: HARDWARE PROTECTION shutdown (Temperature too high)
Alert temperature is 80 and critical temperature is 100 degrees configured in Linux DTS, even though we configured 100, still reboot is observed at 64 degrees.
chenyin_h
Hello, @yellapu_anishkh
Thanks for your reply.
There are several issues regarding to TMU since BSP39, some of them are fixed in BSP40, while some of them are fixed in later release, if possible, I suggest testing it on BSP42
Chenyin
chenyin_h
I have checked the source code, and suggest having a test for your cases under BSP42(or newer) if possible, since there is some bugfix applied since this version, the bug you mentioned is also fixed from the available information.
Chenyin
chenyin_h
Thanks for your post.
I understand that you may test it on your custom S32G3 based board, is it right? May I know which version BSP you are working with? I would check the kernel code first once confirmed.
Chenyin
yellapu_anishkh
It is observed on BSP39, and below issue is mentioned in BSP39 release notes.
I have looked into release notes from BSP39 to BSP44, observed this current bug is not yet fixed. Could you please confirm the same, whether it is fixed ?
Tags (2)
yellapu_anishkh
I have seen one commit (c5697686c8d19ff1edbce015fa5562ba2a2065e6) for the driver. in the comments it is mentioned, but the Jira ID (ALB-10663) is not matching. Could you please confirm once.
%3CLINGO-SUB%20id%3D%22lingo-sub-2137397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G3%3A%20Thermal%20Shutdown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Team%3C%2FP%3E%3CP%3EHardware%3A%20Based%20on%20S32G3.%3C%2FP%3E%3CP%3EWhen%20reading%20the%20zone1%20temperature%2C%20which%20is%20for%20A-core.%20When%20it%20reaches%20%E2%80%9C64%20degrees%20centigrade%E2%80%9D%20the%20hardware%20is%20getting%20rebooted.%3C%2FP%3E%3CP%3EBelow%20is%20the%20Linux%20message.%20Temperature%20is%20continuously%20read%2C%20for%20three%20zones%20values%20are%20as%20below%2C%20when%20issue%20happened.%3C%2FP%3E%3CP%3E64350(zone%200)%3CBR%20%2F%3E64350(zone%201)%3CBR%20%2F%3E62850(zone%202)%3C%2FP%3E%3CP%3Ekernel%5B435%5D%3A%20%5B%207919.187233%5D%20thermalthermal_zone1%3A%20a53_cores%3A%20critical%20temperature%20reached%2C%20shutting%20down%3C%2FP%3E%3CP%3Ekernel%5B435%5D%3A%20%5B%207919.187252%5D%20reboot%3A%20HARDWARE%20PROTECTION%20shutdown%20(Temperature%20too%20high)%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAlert%20temperature%20is%2080%20and%20critical%20temperature%20is%20100%20degrees%20configured%20in%20Linux%20DTS%2C%20even%20though%20we%20configured%20100%2C%20still%20reboot%20is%20observed%20at%2064%20degrees.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%3A%20Thermal%20Shutdown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F99285%22%20target%3D%22_blank%22%3E%40yellapu_anishkh%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EThere%20are%20several%20issues%20regarding%20to%20TMU%20since%20BSP39%2C%20some%20of%20them%20are%20fixed%20in%20BSP40%2C%20while%20some%20of%20them%20are%20fixed%20in%20later%20release%2C%20if%20possible%2C%20I%20suggest%20testing%20it%20on%20BSP42%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%3A%20Thermal%20Shutdown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20have%20seen%20one%20commit%20(c5697686c8d19ff1edbce015fa5562ba2a2065e6)%20for%20the%20driver.%20in%20the%20comments%20it%20is%20mentioned%2C%20but%20the%20Jira%20ID%20(ALB-10663)%20is%20not%20matching.%20Could%20you%20please%20confirm%20once.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%3A%20Thermal%20Shutdown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F99285%22%20target%3D%22_blank%22%3E%40yellapu_anishkh%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EI%20have%20checked%20the%20source%20code%2C%20and%20suggest%20having%20a%20test%20for%20your%20cases%20under%20BSP42(or%20newer)%20if%20possible%2C%20since%20there%20is%20some%20bugfix%20applied%20since%20this%20version%2C%20the%20bug%20you%20mentioned%20is%20also%20fixed%20from%20the%20available%20information.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%3A%20Thermal%20Shutdown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EIt%20is%20observed%20on%20BSP39%2C%20and%20below%20issue%20is%20mentioned%20in%20BSP39%20release%20notes.%3C%2FP%3E%3CP%3EI%20have%20looked%20into%20release%20notes%20from%20BSP39%20to%20BSP44%2C%20observed%20this%20current%20bug%20is%20not%20yet%20fixed.%20Could%20you%20please%20confirm%20the%20same%2C%20whether%20it%20is%20fixed%20%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22yellapu_anishkh_0-1753164457500.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22yellapu_anishkh_0-1753164457500.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348695iCBCE90C1F208C59D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22yellapu_anishkh_0-1753164457500.png%22%20alt%3D%22yellapu_anishkh_0-1753164457500.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%3A%20Thermal%20Shutdown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F99285%22%20target%3D%22_blank%22%3E%40yellapu_anishkh%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EI%20understand%20that%20you%20may%20test%20it%20on%20your%20custom%20S32G3%20based%20board%2C%20is%20it%20right%3F%20May%20I%20know%20which%20version%20BSP%20you%20are%20working%20with%3F%20I%20would%20check%20the%20kernel%20code%20first%20once%20confirmed.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
