S32G3 PFE: egress Change via libfci_cli Not Reflected in Linux Network Interface Traffic Path
ソリューションへジャンプ
2,542件の閲覧回数
minJ
[Question Summary]
On the S32G3 board, I attempted to change the egress of emac0 from hif0 to hif1 using the following command:
libfci_cli logif-update -i emac0 --egress hif1
However, the actual traffic path does not behave as expected.
root@s32g399ardb3:~# libfci_cli phyif-print -i emac0
DISCLAIMER: T[ 2243.924784] pfeng 46000000.pfe: emac0: Unable to get MAC address: 2
his[ 2243.931384] pfeng 46000000.pfe: emac0: Unable to get MAC address: 2
is a DEMO application. It is not part of the production code deliverables.
0: emac0
<ENABLED>
<promisc:OFF, mode:DEFAULT, block-state:NORMAL>
<vlan-conf:OFF, ptp-conf:OFF, ptp-promisc:OFF, q-in-q:ON>
<discard-if-ttl-below-2:OFF, fast-forward-all-tcp:ON>
ingress: 151 egress: 54 discarded: 0 malformed: 0
flexible-filter: ---
ptp-mgmt-if: ---
MAC:
00:04:9f:be:ef:00
33:33:00:00:00:01
01:00:5e:00:00:01
33:33:ff:be:ef:00
01:80:c2:00:00:00
01:80:c2:00:00:03
01:80:c2:00:00:0e
mirrors:
rxmirr0: ---
rxmirr1: ---
txmirr0: ---
txmirr1: ---
logical interfaces:
0: emac0
<ENABLED>
<promisc:ON, match-mode:AND, discard-on-match:OFF>
accepted: 151 rejected: 0 discarded: 0 processed: 151
egress: hif1
match-rules: ---
Command successfully executed.
[Detailed Situation]
In the device tree (dts), each Linux network interface (pfe0, pfe1, pfe2, etc.) is statically mapped using the nxp,pfeng-hif-channels and nxp,pfeng-linked-phyif properties as follows:
Example:
  • pfe0: hif0 (0), emac0 (0)
  • pfe1: hif1 (1), emac1 (1)
  • pfe2: hif2 (2), emac2 (2)
After running
to change the egress of emac0 to hif1,
Expectation:
Traffic entering emac0 should be forwarded to hif1 (and thus appear on pfe1).
Reality:
No traffic appears on the pfe1 interface (tested with ping, raw socket, etc.).
Only the originally mapped interfaces (pfe0, pfe2, etc.) work as expected.
[Questions]
  1. Why does changing the egress with libfci_cli logif-update -i emac0 --egress hif1 not result in traffic being delivered to the corresponding Linux network interface (e.g., pfe1)?
  2. Does the egress setting take precedence for the actual traffic path, or is the device tree mapping always prioritized?
  3. What additional configuration or steps are required to dynamically change the traffic path by modifying the egress as intended?
2,477件の閲覧回数
chenyin_h
Hello, @minJ
Thanks for your confirmation.
As far as I know, currently dynamically updating the bindings(emac, hif) during run-time is not supported in Linux PFE drivers.
Chenyin
4 返答(返信)
2,516件の閲覧回数
chenyin_h
Hello, @minJ
Thanks for the post.
I will check it soon, may I know which version BSP you are working with?
Chenyin
2,514件の閲覧回数
minJ
2,478件の閲覧回数
chenyin_h
Hello, @minJ
Chenyin
2,208件の閲覧回数
minJ
Thank you for your response.
%3CLINGO-SUB%20id%3D%22lingo-sub-2322294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G3%20PFE%3A%20libfci_cli%20%E7%B5%8C%E7%94%B1%E3%81%AE%E5%87%BA%E5%8A%9B%E5%A4%89%E6%9B%B4%E3%81%8C%20Linux%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%20%E3%83%91%E3%82%B9%E3%81%AB%E5%8F%8D%E6%98%A0%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%5B%E8%B3%AA%E5%95%8F%E3%81%AE%E8%A6%81%E7%B4%84%5D%3CBR%20%2F%3E%20S32G3%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20emac0%20%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%20hif0%20%E3%81%8B%E3%82%89%20hif1%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20libfci_cli%20logif-update%20-i%20emac0%20--egress%20hif1%3CBR%20%2F%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%20%E3%83%91%E3%82%B9%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eroot%40s32g399ardb3%3A~%23%20libfci_cli%20phyif-print%20-i%20emac0%3CBR%20%2F%3E%E5%85%8D%E8%B2%AC%E4%BA%8B%E9%A0%85%EF%BC%9AT%5B2243.924784%5Dpfeng%2046000000.pfe%3Aemac0%3A%20MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%202%3CBR%20%2F%3E%E5%BD%BC%E3%81%AE%5B%202243.931384%5Dpfeng%2046000000.pfe%3Aemac0%3A%20MAC%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%202%3CBR%20%2F%3E%E3%83%87%E3%83%A2%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E8%A3%BD%E5%93%81%E7%89%88%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%88%90%E6%9E%9C%E7%89%A9%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E0%3A%20%E3%82%A8%E3%83%9E%E3%83%83%E3%82%AF0%3CBR%20%2F%3E%3CENABLED%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%A5%E5%8A%9B%3A%20151%20%E5%87%BA%E5%8A%9B%3A%2054%20%E7%A0%B4%E6%A3%84%3A%200%20%E4%B8%8D%E6%AD%A3%3A%200%3CBR%20%2F%3E%20%E3%83%95%E3%83%AC%E3%82%AD%E3%82%B7%E3%83%96%E3%83%AB%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3A%20---%3CBR%20%2F%3E%20ptp-mgmt-if%3A%20---%20%E3%83%9E%E3%83%83%E3%82%AF%EF%BC%9A%3CBR%20%2F%3E%20%3CBR%20%2F%3E00%3A04%3A9f%3Abe%3Aef%3A00%3CBR%20%2F%3E%2033%3A33%3A00%3A00%3A00%3A01%3CBR%20%2F%3E%2001%3A00%3A5e%3A00%3A00%3A01%3CBR%20%2F%3E%2033%3A33%3Aff%3Abe%3Aef%3A00%3CBR%20%2F%3E%2001%3A80%3Ac2%3A00%3A00%3A00%3CBR%20%2F%3E%2001%3A80%3Ac2%3A00%3A00%3A03%3CBR%20%2F%3E%2001%3A80%3Ac2%3A00%3A00%3A0e%3CBR%20%2F%3E%20%E3%83%9F%E3%83%A9%E3%83%BC%3A%3CBR%20%2F%3E%20rxmirr0%3A%20---%3CBR%20%2F%3E%20rxmirr1%3A%20---%3CBR%20%2F%3E%20txmirr0%3A%20---%3CBR%20%2F%3E%20txmirr1%3A%20---%3CBR%20%2F%3E%20%E8%AB%96%E7%90%86%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%3CBR%20%2F%3E%200%3A%20%E3%82%A8%E3%83%9E%E3%83%83%E3%82%AF0%20%E6%89%BF%E8%AA%8D%3A%20151%20%E6%8B%92%E5%90%A6%3A%200%20%E7%A0%B4%E6%A3%84%3A%3CBR%20%2F%3E%3CENABLED%3E%3CBR%20%2F%3E%20%3CBR%20%2F%3E0%20%E5%87%A6%E7%90%86%E6%B8%88%E3%81%BF%3A%20151%3CBR%20%2F%3E%20%E5%87%BA%E5%8A%9B%3A%20hif1%3CBR%20%2F%3E%20%E3%83%9E%E3%83%83%E3%83%81%E3%83%AB%E3%83%BC%E3%83%AB%3A%20---%3CBR%20%2F%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FENABLED%3E%3C%2FENABLED%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E3%80%90%E8%A9%B3%E7%B4%B0%E3%81%AA%E7%8A%B6%E6%B3%81%E3%80%91%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20(dts)%20%E3%81%A7%E3%81%AF%E3%80%81%E5%90%84%20Linux%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20(pfe0%E3%80%81pfe1%E3%80%81pfe2%20%E3%81%AA%E3%81%A9)%20%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20nxp%2Cpfeng-hif-%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%81%8A%E3%82%88%E3%81%B3%20nxp%2Cpfeng-linked-phyif%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%9D%99%E7%9A%84%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3Epfe0%3A%20hif0%20(0)%2C%20emac0%20(0)%3C%2FLI%3E%3CLI%3Epfe1%3A%20hif1%20(1)%2C%20emac1%20(1)%3C%2FLI%3E%3CLI%3Epfe2%3A%20hif2%20(2)%2C%20emac2%20(2)%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%B5%B0%E3%81%A3%E3%81%9F%E5%BE%8C%3CBR%20%2F%3Elibfci_cli%20logif-update%20-i%20emac0%20--egress%20hif1%3CBR%20%2F%3E%20emac0%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92hif1%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E6%9C%9F%E5%BE%85%EF%BC%9A%3CBR%20%2F%3E%20emac0%20%E3%81%AB%E5%85%A5%E3%82%8B%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AF%20hif1%20%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20(%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%20pfe1%20%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%AE%9F%EF%BC%9A%3CBR%20%2F%3E%20pfe1%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20(ping%E3%80%81raw%20%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%AA%E3%81%A9%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF)%E3%80%82%3CBR%20%2F%3E%E5%85%83%E3%80%85%E3%83%9E%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20(pfe0%E3%80%81pfe2%20%E3%81%AA%E3%81%A9)%20%E3%81%AE%E3%81%BF%E3%81%8C%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%90%E8%B3%AA%E5%95%8F%E3%80%91%3C%2FP%3E%3COL%3E%3CLI%3Elibfci_cli%20logif-update%20-i%20emac0%20--egress%20hif1%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%87%BA%E5%8A%9B%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%20Linux%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20(%E4%BE%8B%3A%20pfe1)%20%E3%81%AB%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%81%8C%E9%85%8D%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%20%E3%83%91%E3%82%B9%E3%81%A7%E3%81%AF%E5%87%BA%E5%8A%9B%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%84%AA%E5%85%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%8C%E5%B8%B8%E3%81%AB%E5%84%AA%E5%85%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3CLI%3E%E6%84%8F%E5%9B%B3%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%AB%E5%87%BA%E5%8A%9B%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%83%88%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%20%E3%83%91%E3%82%B9%E3%82%92%E5%8B%95%E7%9A%84%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%BF%BD%E5%8A%A0%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%BE%E3%81%9F%E3%81%AF%E6%89%8B%E9%A0%86%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2322294%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B4%E3%83%BC%E3%83%AB%E3%83%89VIP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20PFE%3A%20egress%20Change%20via%20libfci_cli%20Not%20Reflected%20in%20Linux%20Network%20Interface%20Traffic%20Path%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBSP46.0%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20PFE%3A%20egress%20Change%20via%20libfci_cli%20Not%20Reflected%20in%20Linux%20Network%20Interface%20Traffic%20Path%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322452%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260071%22%20target%3D%22_blank%22%3E%40minJ%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%99%E3%81%90%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20BSP%20%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2323572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20PFE%3A%20egress%20Change%20via%20libfci_cli%20Not%20Reflected%20in%20Linux%20Network%20Interface%20Traffic%20Path%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2323572%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260071%22%20target%3D%22_blank%22%3E%40minJ%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E7%8F%BE%E5%9C%A8%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%83%90%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20(emac%E3%80%81hif)%20%E3%82%92%E5%8B%95%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81Linux%20PFE%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20PFE%3A%20egress%20Change%20via%20libfci_cli%20Not%20Reflected%20in%20Linux%20Network%20Interface%20Traffic%20Path%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E
