S32G3 EthCtrlConfigShaper
1,957件の閲覧回数
disrupt-user01
I have s32g3 gold box, and I have this project lwip_FreeRTOS_S32G399A_M7_rtd402. I am adding a EthCtrlConfigShaper to Fifo_1, and setting max value to EthCtrlConfigShaperIdleSlope which is 750000000. I don't see these values generated in Gmac_Ip_Sa_PBcfg.c
what I am getting is:
/*.weight = */0U,
/*.idleSlopeCredit = */0U,
/*.sendSlopeCredit = */0U,
/*.hiCredit = */0U,
/*.loCredit = */0,
/*.ringDesc = */GMAC_0_TxRing_1_DescBuffer,
/*.callback = */Eth_TxIrqCallback,
/*.buffer = */GMAC_0_TxRing_1_DataBuffer,
/*.interrupts = */(uint32)GMAC_CH_INTERRUPT_TI,
/*.bufferLen = */1536U,
/*.ringSize = */4U,
/*.priorityMask = */(uint8)GMAC_VLAN_PRIORITY_4 | (uint8)GMAC_VLAN_PRIORITY_5 | (uint8)GMAC_VLAN_PRIORITY_6 | (uint8)GMAC_VLAN_PRIORITY_7,
/*.dmaBurstLength = */64U,
/*.queueOpMode = */GMAC_OP_MODE_DCB_GEN
I would want the idlescopecredit, sendslopecredit and queueopmode be updated accordingly but its not happening.
1,909件の閲覧回数
disrupt-user01
The problem is solved, in the EthCtrlConfigSchedulerPredecessorRef destination we had to set the shaper instead of fifo.
3 返答(返信)
1,910件の閲覧回数
disrupt-user01
1,920件の閲覧回数
Joey_z
Thank you for contacting us.
Do you have changed these values of ( idlescopecredit, sendslopecredit and queueopmode) in Config Tool? But do you not find these values be modified in the code?
Joey
1,912件の閲覧回数
disrupt-user01
Hi Joey,
Thank you for the reply. Yes I did change the values in the config tool. The config tool only provides idleslopecredit, locredit and hicredit values to be modified. But these changes are not reflected when code is generated.
%3CLINGO-SUB%20id%3D%22lingo-sub-2331243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G3%20EthCtrlConfigShaper%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2331243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFs32g3%E3%82%B4%E3%83%BC%E3%83%AB%E3%83%89%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81lwip_FreeRTOS_S32G399A_M7_rtd402%E3%81%A8%E3%81%84%E3%81%86%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Fifo_1%E3%81%ABEthCtrlConfigShaper%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81EthCtrlConfigShaperIdleSlope%E3%81%AE%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92750000000%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Gmac_Ip_Sa_PBcfg.c%20%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%81%8C%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%8C%E5%BE%97%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%7B%3CBR%20%2F%3E%20%2F*.weight%20%3D%20*%2F0U%E3%80%81%3CBR%20%2F%3E%20%2F*.idleSlopeCredit%20%3D%20*%2F0U%2C%3CBR%20%2F%3E%20%2F*.sendSlopeCredit%20%3D%20*%2F0U%2C%3CBR%20%2F%3E%20%2F*.hiCredit%20%3D%20*%2F0U%2C%3CBR%20%2F%3E%20%2F*.loCredit%20%3D%20*%2F0%2C%3CBR%20%2F%3E%20%2F*.ringDesc%20%3D%20*%2FGMAC_0_TxRing_1_DescBuffer%E3%80%81%3CBR%20%2F%3E%20%2F*.callback%20%3D%20*%2FEth_TxIrqCallback%E3%80%81%3CBR%20%2F%3E%20%2F*.buffer%20%3D%20*%2FGMAC_0_TxRing_1_DataBuffer%E3%80%81%3CBR%20%2F%3E%20%2F*.interrupts%20%3D%20*%2F(uint32)GMAC_CH_INTERRUPT_TI%2C%3CBR%20%2F%3E%20%2F*.bufferLen%20%3D%20*%2F1536U%E3%80%81%3CBR%20%2F%3E%20%2F*.ringSize%20%3D%20*%2F4U%E3%80%81%3CBR%20%2F%3E%20%2F*.priorityMask%20%3D%20*%2F(uint8)GMAC_VLAN_PRIORITY_4%20%7C%20(uint8)GMAC_VLAN_PRIORITY_5%20%7C%20(uint8)GMAC_VLAN_PRIORITY_6%20%7C%20(uint8)GMAC_VLAN_PRIORITY_7%2C%3CBR%20%2F%3E%20%2F*.dmaBurstLength%20%3D%20*%2F64U%E3%80%81%3CBR%20%2F%3E%20%2F*.queueOpMode%20%3D%20*%2FGMAC_OP_MODE_DCB_GEN%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3Eidlescopecredit%E3%80%81sendslopecredit%E3%80%81queueopmode%E3%81%8C%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%9C%9B%E3%82%93%E3%81%A7%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%86%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20EthCtrlConfigShaper%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%AF%E3%81%84%E3%80%81%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E5%80%A4%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81idleslopecredit%E3%80%81locredit%E3%80%81hicredit%E3%81%AE%E5%80%A4%E3%81%AE%E3%81%BF%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E6%99%82%E3%81%AB%E3%81%AF%E5%8F%8D%E6%98%A0%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20EthCtrlConfigShaper%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EConfig%20Tool%E3%81%A7%EF%BC%88idlescopecredit%E3%80%81sendslopecredit%E3%80%81queueopmode%EF%BC%89%E3%81%AE%E5%80%A4%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%A7%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B8%E3%83%A7%E3%83%BC%E3%82%A4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2332395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G3%20EthCtrlConfigShaper%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2332395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82EthCtrlConfigSchedulerPredecessorRef%3CSPAN%3E%E3%81%AE%E5%AE%9B%E5%85%88%E3%81%A7%E3%80%81fifo%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20shaper%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
