S32G274 Debugging CAN Communication After Dual-Core Boot-up
3,484 次查看
sdx111
I am currently debugging the CAN communication when both the M core and A core are started simultaneously. The CAN pins are PC_11 and PC_12. I need to apply FLEXCAN in the M7 core APP project, so I have disabled the settings of llce_can0 in the BSP35.0 of the A core's Linux (as shown in the figure). However, the phenomenon is that when the A core is in Uboot, the flexcan of the M7 core is communicating normally; but when the A core enters Linux, the flexcan of the M7 core stops working properly. Could you please tell me where else in the A core needs to be changed?
sdx111_2-1770203430530.pngsdx111_2-1770203430530.pngsdx111_3-1770203435694.pngsdx111_3-1770203435694.pngsdx111_4-1770203442267.pngsdx111_4-1770203442267.png
10 回复数
3,133 次查看
alejandro_e
Hello @sdx111,
Sorry for such the late update, I was out of the office for these past weeks. Are you still seeing the problem? If so, please let me know any update.
I noticed that you created a new post to continue the topic, if your problem was solve by my colleague please also let me know.
Thanks.
2,902 次查看
sdx111
It's still the same. The problem hasn't been solved.
2,833 次查看
alejandro_e
Hello @sdx111,
I understand, can you create a new post for this? due to the inactive time the tool we use to track the status of the posts has closed this one. You can create a new post explaining that it is a continuation of this topic and if you prefer you can tag me to continue working with me.
Thanks and sorry for the inconveniences
3,458 次查看
alejandro_e
Hello @sdx111,
Please apply the following changes to remove the use of the LLCE can0 pins in Linux:
diff --git a/arch/arm64/boot/dts/freescale/s32g.dtsi b/arch/arm64/boot/dts/freescale/s32g.dtsi
index de9caffb3ca1..ff02f046676b 100644
--- a/arch/arm64/boot/dts/freescale/s32g.dtsi
+++ b/arch/arm64/boot/dts/freescale/s32g.dtsi
@@ -379,18 +379,18 @@ llce_can_logger15: llce_can_logger15 {
 				status = "okay";
-			llce_can0: llce_can0 {
-				compatible = "nxp,s32g-llce-can";
-				mboxes = <&llce_mb S32G_LLCE_CAN_CONF_MB 0>,
-					 <&llce_mb S32G_LLCE_CAN_RX_MB 0>,
-					 <&llce_mb S32G_LLCE_CAN_TX_MB 0>;
-				mbox-names = "config", "rx", "tx";
-				clocks = <&clks S32G_SCMI_CLK_LLCE_CAN_PE>;
-				clock-names = "can_pe";
-				pinctrl-names = "default";
-				pinctrl-0 = <&llce_can0_pins>;
-				status = "disabled";
+//			llce_can0: llce_can0 {
+//				compatible = "nxp,s32g-llce-can";
+//				mboxes = <&llce_mb S32G_LLCE_CAN_CONF_MB 0>,
+//					 <&llce_mb S32G_LLCE_CAN_RX_MB 0>,
+//					 <&llce_mb S32G_LLCE_CAN_TX_MB 0>;
+//				mbox-names = "config", "rx", "tx";
+//				clocks = <&clks S32G_SCMI_CLK_LLCE_CAN_PE>;
+//				clock-names = "can_pe";
+//				pinctrl-names = "default";
+//				pinctrl-0 = <&llce_can0_pins>;
+//				status = "disabled";
 			llce_can1: llce_can1 {
@@ -615,23 +615,23 @@ usbotg: usb@44064000 {
 &pinctrl {
-	llce_can0_pins: llce_can0_pins {
-		llce_can0_grp0 {
-			pinmux = <S32CC_PINMUX(43, FUNC0)>;
-			input-enable;
-			slew-rate = <S32CC_SLEW_208MHZ>;
-		llce_can0_grp1 {
-			pinmux = <S32CC_PINMUX(44, FUNC2)>;
-			output-enable;
-		llce_can0_grp2 {
-			pinmux = <S32CC_PINMUX(745, FUNC2)>;
+//	llce_can0_pins: llce_can0_pins {
+//		llce_can0_grp0 {
+//			pinmux = <S32CC_PINMUX(43, FUNC0)>;
+//			input-enable;
+//			slew-rate = <S32CC_SLEW_208MHZ>;
+//		llce_can0_grp1 {
+//			pinmux = <S32CC_PINMUX(44, FUNC2)>;
+//			output-enable;
+//		llce_can0_grp2 {
+//			pinmux = <S32CC_PINMUX(745, FUNC2)>;
 	llce_can1_pins: llce_can1_pins {
 		llce_can1_grp0 {
diff --git a/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts b/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts
index 0247b542f98b..fe93303e8ca9 100644
--- a/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts
+++ b/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts
@@ -91,9 +91,9 @@ &llce_boot_status {
 	status = "okay";
-&llce_can0 {
-	status = "okay";
+//&llce_can0 {
+//	status = "okay";
 &llce_can1 {
 	status = "okay";
diff --git a/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi b/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi
index afe8a5cea3e1..ada20f67f2d7 100644
--- a/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi
+++ b/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi
@@ -168,9 +168,9 @@ &llce_boot_status {
 	status = "okay";
-&llce_can0 {
-	status = "okay";
+//&llce_can0 {
 &llce_can1 {
 	status = "okay";
After that, if you list the llce can0 nodes and pins like below, you should not be able to see llce_can0:
root@s32g274ardb2:~# ls /sys/firmware/devicetree/base/soc/siul2@4009c000/siul2-pinctrl@4009c240/llce_can0_pins
ls: cannot access '/sys/firmware/devicetree/base/soc/siul2@4009c000/siul2-pinctrl@4009c240/llce_can0_pins': No such file or directory
root@s32g274ardb2:~# ls /sys/firmware/devicetree/base/soc/llce@43a00000/llce_can0/
ls: cannot access '/sys/firmware/devicetree/base/soc/llce@43a00000/llce_can0/': No such file or directory
In contrast, when having those nodes, listing as above shows the device tree subnodes.
Let me know if you are able to use the CAN0 in the M7 after that change.
3,449 次查看
sdx111
I have made the changes as per the above instructions. However, after the A core enters the Linux system, the CAN0 communication of the M core is still abnormal.
s32g274ardb2 login: root
3,433 次查看
alejandro_e
Hello @sdx111,
I see, let me test some configuration and I will get back to you.
3,427 次查看
sdx111
After I removed the initialization codes for both can0 of A's BSP35.0 and llcecan0, when the M core was not loading the PFE, the can0 of M core was able to communicate normally. However, if I added "DISTRO_FEATURES_append += 'pfe'" and "NXP_FIRMWARE_LOCAL_DIR = '/home/hhkj/linux3/fsl-auto-yocto-bsp35.0/firmware_bin/'" in /fsl-auto-yocto-bsp35.0/build_s32g274ardb2/conf/local.conf, meaning that after the PFE was loaded in the A core, the M core seemed to have crashed. Since I need to apply PFEMAC0 and pfemca1 in the M core using CAN0 and SGMII mode, and in the A core using RGMII mode for PFEMAC2, I want to know why the loading of PFE's firmware in the M core would affect the CAN0 communication of the A core when only CAN0 communication is running in the M core?
3,394 次查看
alejandro_e
Hello @sdx111,
I have not seen any behavior like the one you mention, being that the PFE and CAN are interfering with each other. However, I did some change that might solve your issue, in pinctrl-s32g.c#L430 I removed the lines with the problematic pins, in your case it should be the following two:
S32CC_PINCTRL_PIN(S32G_MSCR_PC_11),
S32CC_PINCTRL_PIN(S32G_MSCR_PC_12),
I did this tests with the pins that correspond to the RGB led in the RDB2, when removing the respective pins from the list, the pins stay "floating" and you can see the leds slightly ON, instead of turning off like they normally do once Linux boots.
Can you do that test and let me know if now the CAN0 pins work correctly in the M7 core?
3,367 次查看
sdx111
I have made the necessary changes to the pinctrl-s32g.c file as per your instructions. However, the issue still persists. Whenever I load the PFE firmware (see the attached image), after the A core enters the Linux system, the CAN0 of the M7 core becomes abnormal. If I do not load the PFE firmware, after the A core enters the Linux system, the CAN0 of the M7 core functions normally. Where should I look for the problem? Or could you please test for me after loading the PFE firmware?
3,347 次查看
alejandro_e
I investigated internally and did not find any restriction when using LLCE and PFE. Can you check if the following registers change before and after Linux boots?
%3CLINGO-SUB%20id%3D%22lingo-sub-2306579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G274%20%E5%9C%A8%E5%8F%8C%E6%A0%B8%E5%90%AF%E5%8A%A8%E5%90%8E%E8%B0%83%E8%AF%95%20CAN%20%E9%80%9A%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2306579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E8%B0%83%E8%AF%95%E5%90%8C%E6%97%B6%E5%90%AF%E5%8A%A8%20M%20%E5%86%85%E6%A0%B8%E5%92%8C%20A%20%E5%86%85%E6%A0%B8%E6%97%B6%E7%9A%84%20CAN%20%E9%80%9A%E4%BF%A1%E3%80%82CAN%20%E5%BC%95%E8%84%9A%E4%B8%BA%20PC_11%20%E5%92%8C%20PC_12%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%20M7%20%E5%86%85%E6%A0%B8%20APP%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%BA%94%E7%94%A8%20FLEXCAN%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%A6%81%E7%94%A8%E4%BA%86%20A%20%E5%86%85%E6%A0%B8%20Linux%20BSP35.0%20%E4%B8%AD%E7%9A%84%20llce_can0%20%E8%AE%BE%E7%BD%AE%EF%BC%88%E5%A6%82%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%89%E3%80%82%E4%BD%86%E7%8E%B0%E8%B1%A1%E6%98%AF%EF%BC%8C%E5%BD%93%20A%20%E6%A0%B8%E5%A4%84%E4%BA%8E%20Uboot%20%E7%8A%B6%E6%80%81%E6%97%B6%EF%BC%8CM7%20%E6%A0%B8%E7%9A%84%20flexcan%20%E9%80%9A%E4%BF%A1%E6%AD%A3%E5%B8%B8%EF%BC%9B%E4%BD%86%E5%BD%93%20A%20%E6%A0%B8%E8%BF%9B%E5%85%A5%20Linux%20%E7%8A%B6%E6%80%81%E6%97%B6%EF%BC%8CM7%20%E6%A0%B8%E7%9A%84%20flexcan%20%E5%81%9C%E6%AD%A2%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%20A%20%E6%A0%B8%E5%BF%83%E8%BF%98%E6%9C%89%E5%93%AA%E4%BA%9B%E5%9C%B0%E6%96%B9%E9%9C%80%E8%A6%81%E6%94%B9%E5%8A%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375485i125F395153B45FEC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_0-1770203152639.png%22%20alt%3D%22sdx111_0-1770203152639.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esdx111_0-1770203152639.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375488i4D7713F7D23B3CD9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_2-1770203430530.png%22%20alt%3D%22sdx111_2-1770203430530.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esdx111_2-1770203430530.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375489iC5E156E25EFACD6D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_3-1770203435694.png%22%20alt%3D%22sdx111_3-1770203435694.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esdx111_3-1770203435694.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375490iA2BC852DA347B851%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_4-1770203442267.png%22%20alt%3D%22sdx111_4-1770203442267.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esdx111_4-1770203442267.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E5%B7%B2%E6%8C%89%E7%85%A7%E4%B8%8A%E8%BF%B0%E8%AF%B4%E6%98%8E%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%9B%B4%E6%94%B9%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%20A%20%E6%A0%B8%E5%BF%83%E8%BF%9B%E5%85%A5%20Linux%20%E7%B3%BB%E7%BB%9F%E5%90%8E%EF%BC%8CM%20%E6%A0%B8%E5%BF%83%E7%9A%84%20CAN0%20%E9%80%9A%E4%BF%A1%E4%BB%8D%E7%84%B6%E5%BC%82%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Es32g274ardb2%20%E7%99%BB%E5%BD%95%EF%BC%9Aroot%3CBR%20%2F%3Eroot%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins%3CBR%20%2F%3Els%EF%BC%9Acannot%20access%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins'%EF%BC%9ANo%20such%20file%20or%20directory%3CBR%20%2F%3Eroot%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F%3CBR%20%2F%3Els%3A%20cannot%20access%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F'%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%AD%A4%E7%B1%BB%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2311993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2311993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E8%BF%9B%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%9B%B4%E6%94%B9%EF%BC%8C%E4%BB%A5%E5%8F%96%E6%B6%88%E5%9C%A8%20Linux%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20LLCE%20can0%20%E5%BC%95%E8%84%9A%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ediff%20--git%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%0Aindex%20de9caffb3ca1..ff02f046676b%20100644%0A---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%0A%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%0A%40%40%20-379%2C18%20%2B379%2C18%20%40%40%20llce_can_logger15%3A%20llce_can_logger15%20%7B%0A%20%09%09%09%09status%20%3D%20%22okay%22%3B%0A%20%09%09%09%7D%3B%0A%20%0A-%09%09%09llce_can0%3A%20llce_can0%20%7B%0A-%09%09%09%09compatible%20%3D%20%22nxp%2Cs32g-llce-can%22%3B%0A-%09%09%09%09mboxes%20%3D%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_CONF_MB%200%26gt%3B%2C%0A-%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_RX_MB%200%26gt%3B%2C%0A-%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_TX_MB%200%26gt%3B%3B%0A-%09%09%09%09mbox-names%20%3D%20%22config%22%2C%20%22rx%22%2C%20%22tx%22%3B%0A-%09%09%09%09clocks%20%3D%20%26lt%3B%26amp%3Bclks%20S32G_SCMI_CLK_LLCE_CAN_PE%26gt%3B%3B%0A-%09%09%09%09clock-names%20%3D%20%22can_pe%22%3B%0A-%09%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A-%09%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bllce_can0_pins%26gt%3B%3B%0A-%09%09%09%09status%20%3D%20%22disabled%22%3B%0A-%09%09%09%7D%3B%0A%2B%2F%2F%09%09%09llce_can0%3A%20llce_can0%20%7B%0A%2B%2F%2F%09%09%09%09compatible%20%3D%20%22nxp%2Cs32g-llce-can%22%3B%0A%2B%2F%2F%09%09%09%09mboxes%20%3D%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_CONF_MB%200%26gt%3B%2C%0A%2B%2F%2F%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_RX_MB%200%26gt%3B%2C%0A%2B%2F%2F%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_TX_MB%200%26gt%3B%3B%0A%2B%2F%2F%09%09%09%09mbox-names%20%3D%20%22config%22%2C%20%22rx%22%2C%20%22tx%22%3B%0A%2B%2F%2F%09%09%09%09clocks%20%3D%20%26lt%3B%26amp%3Bclks%20S32G_SCMI_CLK_LLCE_CAN_PE%26gt%3B%3B%0A%2B%2F%2F%09%09%09%09clock-names%20%3D%20%22can_pe%22%3B%0A%2B%2F%2F%09%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%2B%2F%2F%09%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bllce_can0_pins%26gt%3B%3B%0A%2B%2F%2F%09%09%09%09status%20%3D%20%22disabled%22%3B%0A%2B%2F%2F%09%09%09%7D%3B%0A%20%0A%20%09%09%09llce_can1%3A%20llce_can1%20%7B%0A%20%09%09%09%09compatible%20%3D%20%22nxp%2Cs32g-llce-can%22%3B%0A%40%40%20-615%2C23%20%2B615%2C23%20%40%40%20usbotg%3A%20usb%4044064000%20%7B%0A%20%7D%3B%0A%20%0A%20%26amp%3Bpinctrl%20%7B%0A-%09llce_can0_pins%3A%20llce_can0_pins%20%7B%0A-%09%09llce_can0_grp0%20%7B%0A-%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A-%09%09%09input-enable%3B%0A-%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A-%09%09%7D%3B%0A-%0A-%09%09llce_can0_grp1%20%7B%0A-%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A-%09%09%09output-enable%3B%0A-%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A-%09%09%7D%3B%0A-%0A-%09%09llce_can0_grp2%20%7B%0A-%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A-%09%09%7D%3B%0A-%09%7D%3B%0A%2B%2F%2F%09llce_can0_pins%3A%20llce_can0_pins%20%7B%0A%2B%2F%2F%09%09llce_can0_grp0%20%7B%0A%2B%2F%2F%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A%2B%2F%2F%09%09%09input-enable%3B%0A%2B%2F%2F%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A%2B%2F%2F%09%09%7D%3B%0A%2B%2F%2F%0A%2B%2F%2F%09%09llce_can0_grp1%20%7B%0A%2B%2F%2F%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A%2B%2F%2F%09%09%09output-enable%3B%0A%2B%2F%2F%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A%2B%2F%2F%09%09%7D%3B%0A%2B%2F%2F%0A%2B%2F%2F%09%09llce_can0_grp2%20%7B%0A%2B%2F%2F%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A%2B%2F%2F%09%09%7D%3B%0A%2B%2F%2F%09%7D%3B%0A%20%0A%20%09llce_can1_pins%3A%20llce_can1_pins%20%7B%0A%20%09%09llce_can1_grp0%20%7B%0Adiff%20--git%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%0Aindex%200247b542f98b..fe93303e8ca9%20100644%0A---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%0A%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%0A%40%40%20-91%2C9%20%2B91%2C9%20%40%40%20%26amp%3Bllce_boot_status%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0A%20%7D%3B%0A%20%0A-%26amp%3Bllce_can0%20%7B%0A-%09status%20%3D%20%22okay%22%3B%0A-%7D%3B%0A%2B%2F%2F%26amp%3Bllce_can0%20%7B%0A%2B%2F%2F%09status%20%3D%20%22okay%22%3B%0A%2B%2F%2F%7D%3B%0A%20%0A%20%26amp%3Bllce_can1%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0Adiff%20--git%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%0Aindex%20afe8a5cea3e1..ada20f67f2d7%20100644%0A---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%0A%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%0A%40%40%20-168%2C9%20%2B168%2C9%20%40%40%20%26amp%3Bllce_boot_status%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0A%20%7D%3B%0A%20%0A-%26amp%3Bllce_can0%20%7B%0A-%09status%20%3D%20%22okay%22%3B%0A-%7D%3B%0A%2B%2F%2F%26amp%3Bllce_can0%20%7B%0A%2B%2F%2F%09status%20%3D%20%22okay%22%3B%0A%2B%2F%2F%7D%3B%0A%20%0A%20%26amp%3Bllce_can1%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0A%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%83%8F%E4%B8%8B%E9%9D%A2%E8%BF%99%E6%A0%B7%E5%88%97%E5%87%BA%20llce%20can0%20%E8%8A%82%E7%82%B9%E5%92%8C%E5%BC%95%E8%84%9A%EF%BC%8C%E5%BA%94%E8%AF%A5%E5%B0%B1%E7%9C%8B%E4%B8%8D%E5%88%B0%20llce_can0%E4%BA%86%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins%0Als%3A%20cannot%20access%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins'%3A%20No%20such%20file%20or%20directory%0Aroot%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F%0Als%3A%20cannot%20access%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F'%3A%20No%20such%20file%20or%20directory%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%9B%B8%E6%AF%94%E4%B9%8B%E4%B8%8B%EF%BC%8C%E5%BD%93%E6%8B%A5%E6%9C%89%E8%BF%99%E4%BA%9B%E8%8A%82%E7%82%B9%E6%97%B6%EF%BC%8C%E5%A6%82%E4%B8%8A%E6%89%80%E7%A4%BA%E7%9A%84%E6%B8%85%E5%8D%95%E6%98%BE%E7%A4%BA%E4%BA%86%E8%AE%BE%E5%A4%87%E6%A0%91%E5%AD%90%E8%8A%82%E7%82%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%9B%B4%E6%94%B9%E5%90%8E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%20M7%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20CAN0%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%8C%E8%AE%A9%E6%88%91%E6%B5%8B%E8%AF%95%E4%B8%80%E4%B8%8B%E9%85%8D%E7%BD%AE%EF%BC%8C%E7%84%B6%E5%90%8E%E7%BB%99%E6%82%A8%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%20PFE%20%E5%92%8C%20CAN%20%E7%9B%B8%E4%BA%92%E5%B9%B2%E6%89%B0%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E7%B1%BB%E4%BC%BC%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%E8%A1%8C%E4%B8%BA%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Flinux%2Fblob%2F1594b25154a2db746972517c61cbd0935366391a%2Fdrivers%2Fpinctrl%2Ffreescale%2Fpinctrl-s32g.c%23L430%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Epinctrl-s32g.c%23L430%3C%2FA%3E%E4%B8%AD%E5%81%9A%E4%BA%86%E4%B8%80%E4%BA%9B%E6%9B%B4%E6%94%B9%EF%BC%8C%E6%88%96%E8%AE%B8%E8%83%BD%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%20%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%E6%9C%89%E9%97%AE%E9%A2%98%E5%BC%95%E8%84%9A%E7%9A%84%E9%82%A3%E5%87%A0%E8%A1%8C%EF%BC%8C%E5%9C%A8%E6%82%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%BA%94%E8%AF%A5%E6%98%AF%E4%B8%8B%E9%9D%A2%E4%B8%A4%E8%A1%8C%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ES32CC_PINCTRL_PIN(S32G_MSCR_PC_11)%2C%0AS32CC_PINCTRL_PIN(S32G_MSCR_PC_12)%2C%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%8E%20RDB2%20%E4%B8%AD%E7%9A%84%20RGB%20LED%20%E7%9B%B8%E5%AF%B9%E5%BA%94%E7%9A%84%E5%BC%95%E8%84%9A%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%BD%93%E4%BB%8E%E5%88%97%E8%A1%A8%E4%B8%AD%E5%88%A0%E9%99%A4%E7%9B%B8%E5%BA%94%E7%9A%84%E5%BC%95%E8%84%9A%E6%97%B6%EF%BC%8C%E5%BC%95%E8%84%9A%E4%BF%9D%E6%8C%81%20%22%20%E6%B5%AE%E7%A9%BA%20%22%20%E5%B9%B6%E4%B8%94%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%20LED%20%E7%95%A5%E5%BE%AE%E4%BA%AE%E8%B5%B7%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%83%8F%E5%BE%80%E5%B8%B8%E4%B8%80%E6%A0%B7%20Linux%20%E5%90%AF%E5%8A%A8%E5%90%8E%E5%85%B3%E9%97%AD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E8%BF%9B%E8%A1%8C%E8%AF%A5%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%B9%B6%E5%91%8A%E8%AF%89%E6%88%91%20CAN0%20%E5%BC%95%E8%84%9A%E7%8E%B0%E5%9C%A8%E6%98%AF%E5%90%A6%E8%83%BD%E5%9C%A8%20M7%20%E5%86%85%E6%A0%B8%E4%B8%AD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E5%88%A0%E9%99%A4%E4%BA%86%20A%20%E7%9A%84%20BSP35.0%20can0%20%E5%92%8C%20llcecan0%20%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%A3%E7%A0%81%E5%90%8E%EF%BC%8C%E5%BD%93%20M%20%E5%86%85%E6%A0%B8%E4%B8%8D%E5%8A%A0%E8%BD%BD%20PFE%20%E6%97%B6%EF%BC%8CM%20%E5%86%85%E6%A0%B8%E7%9A%84%20can0%20%E8%83%BD%E5%A4%9F%E6%AD%A3%E5%B8%B8%E9%80%9A%E4%BF%A1%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%20%2Ffsl-auto-yocto-bsp35.0%2Fbuild_s32g274ardb2%2Fconf%2Flocal.conf%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%22DISTRO_FEATURES_append%20%2B%3D%20'pfe'%22%20%E5%92%8C%22NXP_FIRMWARE_LOCAL_DIR%20%3D%20'%2Fhome%2Fhhkj%2Flinux3%2Ffsl-auto-yocto-bsp35.0%2Ffirmware_bin%2F'%22%20%E3%80%81%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E5%9C%A8%20A%20%E6%A0%B8%E5%8A%A0%E8%BD%BD%20PFE%20%E5%90%8E%EF%BC%8CM%20%E6%A0%B8%E4%BC%BC%E4%B9%8E%E5%B4%A9%E6%BA%83%E4%BA%86%E3%80%82%E7%94%B1%E4%BA%8E%E6%88%91%E9%9C%80%E8%A6%81%E5%9C%A8%E4%BD%BF%E7%94%A8%20CAN0%20%E5%92%8C%20SGMII%20%E6%A8%A1%E5%BC%8F%E7%9A%84%20M%20%E5%86%85%E6%A0%B8%E4%B8%AD%E5%BA%94%E7%94%A8%20PFEMAC0%20%E5%92%8C%20pfemca1%EF%BC%8C%E5%B9%B6%E5%9C%A8%E4%BD%BF%E7%94%A8%20RGMII%20%E6%A8%A1%E5%BC%8F%E7%9A%84%20A%20%E5%86%85%E6%A0%B8%E4%B8%AD%E5%BA%94%E7%94%A8%20PFEMAC2%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%20M%20%E5%86%85%E6%A0%B8%E4%B8%AD%E5%8A%A0%E8%BD%BD%20PFE%20%E5%9B%BA%E4%BB%B6%E4%BC%9A%E5%BD%B1%E5%93%8D%20A%20%E5%86%85%E6%A0%B8%E7%9A%84%20CAN0%20%E9%80%9A%E4%BF%A1%EF%BC%8C%E5%9B%A0%E4%B8%BA%20M%20%E5%86%85%E6%A0%B8%E4%B8%AD%E5%8F%AA%E8%BF%90%E8%A1%8C%20CAN0%20%E9%80%9A%E4%BF%A1%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%86%85%E9%83%A8%E8%BF%9B%E8%A1%8C%E4%BA%86%E8%B0%83%E6%9F%A5%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%20LLCE%20%E5%92%8C%20PFE%20%E6%97%B6%E6%9C%89%E4%BB%BB%E4%BD%95%E9%99%90%E5%88%B6%E3%80%82%E4%BD%A0%E8%83%BD%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E4%B8%8B%E5%88%97%E5%AF%84%E5%AD%98%E5%99%A8%E5%9C%A8%20Linux%20%E5%90%AF%E5%8A%A8%E5%89%8D%E5%90%8E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%98%E5%8C%96%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376212iB17A777B7B8E0DD0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1770676601912.png%22%20alt%3D%22alejandro_e_0-1770676601912.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ealejandro_e_0-1770676601912.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%AF%B9%20pinctrl-s32g.c%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%BF%85%E8%A6%81%E7%9A%84%E4%BF%AE%E6%94%B9%E6%96%87%E4%BB%B6%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E6%AF%8F%E5%BD%93%E6%88%91%E5%8A%A0%E8%BD%BD%20PFE%20%E5%9B%BA%E4%BB%B6%EF%BC%88%E8%A7%81%E9%99%84%E5%9B%BE%EF%BC%89%E6%97%B6%EF%BC%8CA%20%E5%86%85%E6%A0%B8%E8%BF%9B%E5%85%A5%20Linux%20%E7%B3%BB%E7%BB%9F%E5%90%8E%EF%BC%8CM7%20%E5%86%85%E6%A0%B8%E7%9A%84%20CAN0%20%E5%B0%B1%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%BC%82%E5%B8%B8%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%8D%E5%8A%A0%E8%BD%BD%20PFE%20%E5%9B%BA%E4%BB%B6%EF%BC%8CA%20%E5%86%85%E6%A0%B8%E8%BF%9B%E5%85%A5%20Linux%20%E7%B3%BB%E7%BB%9F%E5%90%8E%EF%BC%8CM7%20%E5%86%85%E6%A0%B8%E7%9A%84%20CAN0%20%E5%8A%9F%E8%83%BD%E6%AD%A3%E5%B8%B8%E3%80%82%E6%88%91%E5%BA%94%E8%AF%A5%E4%BB%8E%E5%93%AA%E9%87%8C%E6%9F%A5%E6%89%BE%E9%97%AE%E9%A2%98%EF%BC%9F%E6%88%96%E8%80%85%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%9C%A8%E5%8A%A0%E8%BD%BD%20PFE%20%E5%9B%BA%E4%BB%B6%E5%90%8E%E5%B8%AE%E6%88%91%E6%B5%8B%E8%AF%95%E4%B8%80%E4%B8%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376000i1C27896A0C0AC284%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375996iE2EBBFCCE552DF6E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E1.%E6%88%91%E8%A7%82%E5%AF%9F%E5%88%B0%E7%9A%84%E7%8E%B0%E8%B1%A1%E6%98%AF%EF%BC%8C%E5%9C%A8%20A%20core%20%E5%8A%A0%E8%BD%BD%20PFE%20%E5%B9%B6%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8CM7%20%E7%9A%84%20flexcan0%20%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E9%80%9A%E4%BF%A1%E3%80%82%E5%85%B7%E4%BD%93%E6%83%85%E5%86%B5%E6%98%AF%EF%BC%8C%E6%AD%A4%E6%97%B6%EF%BC%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20cantest%20%E4%B8%8A%E4%BD%8D%E6%9C%BA%E5%90%91%20flexcan0%20%E5%8F%91%E9%80%81%20CAN%20%E6%8A%A5%E6%96%87%E6%97%B6%EF%BC%8C%E6%8A%A5%E6%96%87%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E5%8F%91%E9%80%81%EF%BC%8C%E4%BD%86%20M7%20%E7%9A%84%20flexcan0%20%E5%8D%B4%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%93%8D%E5%BA%94%EF%BC%8C%E4%B9%9F%E4%B8%8D%E5%AF%B9%E5%A4%96%E5%8F%91%E9%80%81%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%8E%A8%E6%96%AD%20M7%20%E7%9B%AE%E5%89%8D%E5%B7%B2%E7%BB%8F%E5%B4%A9%E6%BA%83%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E4%B8%A4%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E8%82%AF%E5%AE%9A%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%E3%80%82%3CBR%20%2F%3E2.%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%9C%A8%E5%90%AF%E5%8A%A8%20Linux%20%E5%90%8E%E8%AF%BB%E5%8F%96%E7%9B%B8%E5%85%B3%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%80%BC%E3%80%82%E6%98%AF%E4%BB%80%E4%B9%88%E5%91%BD%E4%BB%A4%EF%BC%9F%3CBR%20%2F%3E3.%E5%90%AF%E7%94%A8%20PFE%20%E5%9B%BA%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%90%8E%EF%BC%8C%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%93%AA%E4%BA%9B%E6%96%87%E4%BB%B6%E5%92%8C%E5%8A%9F%E8%83%BD%E6%98%AF%E5%85%B7%E4%BD%93%E7%9A%84%E5%8A%A0%E8%BD%BD%E8%BF%87%E7%A8%8B%EF%BC%9F%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%E5%B0%86%E5%85%B6%E4%B8%AD%E7%9A%84%20HIL1%20%E6%94%B9%E4%B8%BA%20HIL0%EF%BC%8C%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E6%99%9A%E6%89%8D%E6%9B%B4%E6%96%B0%EF%BC%8C%E8%BF%99%E5%87%A0%E5%91%A8%E6%88%91%E9%83%BD%E4%B8%8D%E5%9C%A8%E5%8A%9E%E5%85%AC%E5%AE%A4%E3%80%82%E4%BD%A0%E8%BF%98%E8%83%BD%E7%9C%8B%E5%88%B0%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%9C%89%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%9C%80%E6%96%B0%E8%BF%9B%E5%B1%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E6%82%A8%E6%96%B0%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%B8%96%E5%AD%90%E6%9D%A5%E7%BB%A7%E7%BB%AD%E8%BF%99%E4%B8%AA%E8%AF%9D%E9%A2%98%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E7%9A%84%E5%90%8C%E4%BA%8B%E8%A7%A3%E5%86%B3%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B9%9F%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2329244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%8C%E6%82%A8%E8%83%BD%E4%B8%BA%E6%AD%A4%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%B8%96%E5%AD%90%E5%90%97%EF%BC%9F%E7%94%B1%E4%BA%8E%E4%B8%8D%E6%B4%BB%E5%8A%A8%E6%97%B6%E9%97%B4%E8%BF%87%E9%95%BF%EF%BC%8C%E6%88%91%E4%BB%AC%E7%94%A8%E6%9D%A5%E8%B7%9F%E8%B8%AA%E5%B8%96%E5%AD%90%E7%8A%B6%E6%80%81%E7%9A%84%E5%B7%A5%E5%85%B7%E5%B7%B2%E5%85%B3%E9%97%AD%E4%BA%86%E8%BF%99%E4%B8%AA%E5%B8%96%E5%AD%90%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E8%AF%B4%E6%98%8E%E8%BF%99%E6%98%AF%E6%9C%AC%E4%B8%BB%E9%A2%98%E7%9A%84%E5%BB%B6%E7%BB%AD%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%84%BF%E6%84%8F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%A0%87%E8%AE%B0%E6%88%91%EF%BC%8C%E7%BB%A7%E7%BB%AD%E4%B8%8E%E6%88%91%E5%90%88%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E5%B9%B6%E5%AF%B9%E9%80%A0%E6%88%90%E7%9A%84%E4%B8%8D%E4%BE%BF%E8%A1%A8%E7%A4%BA%E6%AD%89%E6%84%8F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%BF%98%E6%98%AF%E8%80%81%E6%A0%B7%E5%AD%90%E3%80%82%E9%97%AE%E9%A2%98%E8%BF%98%E6%B2%A1%E6%9C%89%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FLINGO-BODY%3E
