S32G274 Debugging CAN Communication After Dual-Core Boot-up
3,759件の閲覧回数
sdx111
I am currently debugging the CAN communication when both the M core and A core are started simultaneously. The CAN pins are PC_11 and PC_12. I need to apply FLEXCAN in the M7 core APP project, so I have disabled the settings of llce_can0 in the BSP35.0 of the A core's Linux (as shown in the figure). However, the phenomenon is that when the A core is in Uboot, the flexcan of the M7 core is communicating normally; but when the A core enters Linux, the flexcan of the M7 core stops working properly. Could you please tell me where else in the A core needs to be changed?
10 返答(返信)
3,408件の閲覧回数
alejandro_e
Hello @sdx111,
Sorry for such the late update, I was out of the office for these past weeks. Are you still seeing the problem? If so, please let me know any update.
I noticed that you created a new post to continue the topic, if your problem was solve by my colleague please also let me know.
Thanks.
3,177件の閲覧回数
sdx111
It's still the same. The problem hasn't been solved.
3,108件の閲覧回数
alejandro_e
Hello @sdx111,
I understand, can you create a new post for this? due to the inactive time the tool we use to track the status of the posts has closed this one. You can create a new post explaining that it is a continuation of this topic and if you prefer you can tag me to continue working with me.
Thanks and sorry for the inconveniences
3,733件の閲覧回数
alejandro_e
Hello @sdx111,
Please apply the following changes to remove the use of the LLCE can0 pins in Linux:
diff --git a/arch/arm64/boot/dts/freescale/s32g.dtsi b/arch/arm64/boot/dts/freescale/s32g.dtsi
index de9caffb3ca1..ff02f046676b 100644
--- a/arch/arm64/boot/dts/freescale/s32g.dtsi
+++ b/arch/arm64/boot/dts/freescale/s32g.dtsi
@@ -379,18 +379,18 @@ llce_can_logger15: llce_can_logger15 {
 				status = "okay";
-			llce_can0: llce_can0 {
-				compatible = "nxp,s32g-llce-can";
-				mboxes = <&llce_mb S32G_LLCE_CAN_CONF_MB 0>,
-					 <&llce_mb S32G_LLCE_CAN_RX_MB 0>,
-					 <&llce_mb S32G_LLCE_CAN_TX_MB 0>;
-				mbox-names = "config", "rx", "tx";
-				clocks = <&clks S32G_SCMI_CLK_LLCE_CAN_PE>;
-				clock-names = "can_pe";
-				pinctrl-names = "default";
-				pinctrl-0 = <&llce_can0_pins>;
-				status = "disabled";
+//			llce_can0: llce_can0 {
+//				compatible = "nxp,s32g-llce-can";
+//				mboxes = <&llce_mb S32G_LLCE_CAN_CONF_MB 0>,
+//					 <&llce_mb S32G_LLCE_CAN_RX_MB 0>,
+//					 <&llce_mb S32G_LLCE_CAN_TX_MB 0>;
+//				mbox-names = "config", "rx", "tx";
+//				clocks = <&clks S32G_SCMI_CLK_LLCE_CAN_PE>;
+//				clock-names = "can_pe";
+//				pinctrl-names = "default";
+//				pinctrl-0 = <&llce_can0_pins>;
+//				status = "disabled";
 			llce_can1: llce_can1 {
@@ -615,23 +615,23 @@ usbotg: usb@44064000 {
 &pinctrl {
-	llce_can0_pins: llce_can0_pins {
-		llce_can0_grp0 {
-			pinmux = <S32CC_PINMUX(43, FUNC0)>;
-			input-enable;
-			slew-rate = <S32CC_SLEW_208MHZ>;
-		llce_can0_grp1 {
-			pinmux = <S32CC_PINMUX(44, FUNC2)>;
-			output-enable;
-		llce_can0_grp2 {
-			pinmux = <S32CC_PINMUX(745, FUNC2)>;
+//	llce_can0_pins: llce_can0_pins {
+//		llce_can0_grp0 {
+//			pinmux = <S32CC_PINMUX(43, FUNC0)>;
+//			input-enable;
+//			slew-rate = <S32CC_SLEW_208MHZ>;
+//		llce_can0_grp1 {
+//			pinmux = <S32CC_PINMUX(44, FUNC2)>;
+//			output-enable;
+//		llce_can0_grp2 {
+//			pinmux = <S32CC_PINMUX(745, FUNC2)>;
 	llce_can1_pins: llce_can1_pins {
 		llce_can1_grp0 {
diff --git a/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts b/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts
index 0247b542f98b..fe93303e8ca9 100644
--- a/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts
+++ b/arch/arm64/boot/dts/freescale/s32g274a-bluebox3.dts
@@ -91,9 +91,9 @@ &llce_boot_status {
 	status = "okay";
-&llce_can0 {
-	status = "okay";
+//&llce_can0 {
+//	status = "okay";
 &llce_can1 {
 	status = "okay";
diff --git a/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi b/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi
index afe8a5cea3e1..ada20f67f2d7 100644
--- a/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi
+++ b/arch/arm64/boot/dts/freescale/s32gxxxa-rdb.dtsi
@@ -168,9 +168,9 @@ &llce_boot_status {
 	status = "okay";
-&llce_can0 {
-	status = "okay";
+//&llce_can0 {
 &llce_can1 {
 	status = "okay";
After that, if you list the llce can0 nodes and pins like below, you should not be able to see llce_can0:
root@s32g274ardb2:~# ls /sys/firmware/devicetree/base/soc/siul2@4009c000/siul2-pinctrl@4009c240/llce_can0_pins
ls: cannot access '/sys/firmware/devicetree/base/soc/siul2@4009c000/siul2-pinctrl@4009c240/llce_can0_pins': No such file or directory
root@s32g274ardb2:~# ls /sys/firmware/devicetree/base/soc/llce@43a00000/llce_can0/
ls: cannot access '/sys/firmware/devicetree/base/soc/llce@43a00000/llce_can0/': No such file or directory
In contrast, when having those nodes, listing as above shows the device tree subnodes.
Let me know if you are able to use the CAN0 in the M7 after that change.
3,724件の閲覧回数
sdx111
I have made the changes as per the above instructions. However, after the A core enters the Linux system, the CAN0 communication of the M core is still abnormal.
s32g274ardb2 login: root
3,708件の閲覧回数
alejandro_e
Hello @sdx111,
I see, let me test some configuration and I will get back to you.
3,702件の閲覧回数
sdx111
After I removed the initialization codes for both can0 of A's BSP35.0 and llcecan0, when the M core was not loading the PFE, the can0 of M core was able to communicate normally. However, if I added "DISTRO_FEATURES_append += 'pfe'" and "NXP_FIRMWARE_LOCAL_DIR = '/home/hhkj/linux3/fsl-auto-yocto-bsp35.0/firmware_bin/'" in /fsl-auto-yocto-bsp35.0/build_s32g274ardb2/conf/local.conf, meaning that after the PFE was loaded in the A core, the M core seemed to have crashed. Since I need to apply PFEMAC0 and pfemca1 in the M core using CAN0 and SGMII mode, and in the A core using RGMII mode for PFEMAC2, I want to know why the loading of PFE's firmware in the M core would affect the CAN0 communication of the A core when only CAN0 communication is running in the M core?
3,669件の閲覧回数
alejandro_e
Hello @sdx111,
I have not seen any behavior like the one you mention, being that the PFE and CAN are interfering with each other. However, I did some change that might solve your issue, in pinctrl-s32g.c#L430 I removed the lines with the problematic pins, in your case it should be the following two:
S32CC_PINCTRL_PIN(S32G_MSCR_PC_11),
S32CC_PINCTRL_PIN(S32G_MSCR_PC_12),
I did this tests with the pins that correspond to the RGB led in the RDB2, when removing the respective pins from the list, the pins stay "floating" and you can see the leds slightly ON, instead of turning off like they normally do once Linux boots.
Can you do that test and let me know if now the CAN0 pins work correctly in the M7 core?
3,642件の閲覧回数
sdx111
I have made the necessary changes to the pinctrl-s32g.c file as per your instructions. However, the issue still persists. Whenever I load the PFE firmware (see the attached image), after the A core enters the Linux system, the CAN0 of the M7 core becomes abnormal. If I do not load the PFE firmware, after the A core enters the Linux system, the CAN0 of the M7 core functions normally. Where should I look for the problem? Or could you please test for me after loading the PFE firmware?
3,622件の閲覧回数
alejandro_e
I investigated internally and did not find any restriction when using LLCE and PFE. Can you check if the following registers change before and after Linux boots?
%3CLINGO-SUB%20id%3D%22lingo-sub-2306579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G274%20%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%B3%E3%82%A2%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%81%AECAN%E9%80%9A%E4%BF%A1%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2306579%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81M%20%E3%82%B3%E3%82%A2%E3%81%A8%20A%20%E3%82%B3%E3%82%A2%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%8C%E5%90%8C%E6%99%82%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%20CAN%20%E9%80%9A%E4%BF%A1%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CAN%20%E3%83%94%E3%83%B3%E3%81%AF%20PC_11%20%E3%81%A8%20PC_12%20%E3%81%A7%E3%81%99%E3%80%82M7%E3%82%B3%E3%82%A2%E3%81%AEAPP%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7FLEXCAN%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81A%E3%82%B3%E3%82%A2%E3%81%AELinux%E3%81%AEBSP35.0%E3%81%A7llce_can0%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E5%9B%B3%E3%82%92%E5%8F%82%E7%85%A7%EF%BC%89%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%8F%BE%E8%B1%A1%E3%81%AF%E3%80%81A%20%E3%82%B3%E3%82%A2%E3%81%8C%20Uboot%20%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%20M7%20%E3%82%B3%E3%82%A2%E3%81%AE%20flexcan%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81A%20%E3%82%B3%E3%82%A2%E3%81%8C%20Linux%20%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%A8%20M7%20%E3%82%B3%E3%82%A2%E3%81%AE%20flexcan%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82A%20%E3%82%B3%E3%82%A2%E3%81%AE%E4%BB%96%E3%81%AB%E3%81%A9%E3%81%93%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_0-1770203152639.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375485i125F395153B45FEC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_0-1770203152639.png%22%20alt%3D%22sdx111_0-1770203152639.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_2-1770203430530.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375488i4D7713F7D23B3CD9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_2-1770203430530.png%22%20alt%3D%22sdx111_2-1770203430530.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_3-1770203435694.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375489iC5E156E25EFACD6D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_3-1770203435694.png%22%20alt%3D%22sdx111_3-1770203435694.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sdx111_4-1770203442267.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375490iA2BC852DA347B851%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sdx111_4-1770203442267.png%22%20alt%3D%22sdx111_4-1770203442267.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81A%20%E3%82%B3%E3%82%A2%E3%81%8C%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%9F%E5%BE%8C%E3%82%82%E3%80%81M%20%E3%82%B3%E3%82%A2%E3%81%AE%20CAN0%20%E9%80%9A%E4%BF%A1%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E7%95%B0%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3Es32g274ardb2%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%3A%20root%3CBR%20%2F%3E%20root%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins%3CBR%20%2F%3E%20ls%3A%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins'%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Eroot%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F%3CBR%20%2F%3E%20ls%3A%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F'%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2311993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2311993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ELinux%20%E3%81%A7%20LLCE%20can0%20%E3%83%94%E3%83%B3%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ediff%20--git%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%0Aindex%20de9caffb3ca1..ff02f046676b%20100644%0A---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%0A%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g.dtsi%0A%40%40%20-379%2C18%20%2B379%2C18%20%40%40%20llce_can_logger15%3A%20llce_can_logger15%20%7B%0A%20%09%09%09%09status%20%3D%20%22okay%22%3B%0A%20%09%09%09%7D%3B%0A%20%0A-%09%09%09llce_can0%3A%20llce_can0%20%7B%0A-%09%09%09%09compatible%20%3D%20%22nxp%2Cs32g-llce-can%22%3B%0A-%09%09%09%09mboxes%20%3D%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_CONF_MB%200%26gt%3B%2C%0A-%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_RX_MB%200%26gt%3B%2C%0A-%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_TX_MB%200%26gt%3B%3B%0A-%09%09%09%09mbox-names%20%3D%20%22config%22%2C%20%22rx%22%2C%20%22tx%22%3B%0A-%09%09%09%09clocks%20%3D%20%26lt%3B%26amp%3Bclks%20S32G_SCMI_CLK_LLCE_CAN_PE%26gt%3B%3B%0A-%09%09%09%09clock-names%20%3D%20%22can_pe%22%3B%0A-%09%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A-%09%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bllce_can0_pins%26gt%3B%3B%0A-%09%09%09%09status%20%3D%20%22disabled%22%3B%0A-%09%09%09%7D%3B%0A%2B%2F%2F%09%09%09llce_can0%3A%20llce_can0%20%7B%0A%2B%2F%2F%09%09%09%09compatible%20%3D%20%22nxp%2Cs32g-llce-can%22%3B%0A%2B%2F%2F%09%09%09%09mboxes%20%3D%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_CONF_MB%200%26gt%3B%2C%0A%2B%2F%2F%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_RX_MB%200%26gt%3B%2C%0A%2B%2F%2F%09%09%09%09%09%20%26lt%3B%26amp%3Bllce_mb%20S32G_LLCE_CAN_TX_MB%200%26gt%3B%3B%0A%2B%2F%2F%09%09%09%09mbox-names%20%3D%20%22config%22%2C%20%22rx%22%2C%20%22tx%22%3B%0A%2B%2F%2F%09%09%09%09clocks%20%3D%20%26lt%3B%26amp%3Bclks%20S32G_SCMI_CLK_LLCE_CAN_PE%26gt%3B%3B%0A%2B%2F%2F%09%09%09%09clock-names%20%3D%20%22can_pe%22%3B%0A%2B%2F%2F%09%09%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%2B%2F%2F%09%09%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bllce_can0_pins%26gt%3B%3B%0A%2B%2F%2F%09%09%09%09status%20%3D%20%22disabled%22%3B%0A%2B%2F%2F%09%09%09%7D%3B%0A%20%0A%20%09%09%09llce_can1%3A%20llce_can1%20%7B%0A%20%09%09%09%09compatible%20%3D%20%22nxp%2Cs32g-llce-can%22%3B%0A%40%40%20-615%2C23%20%2B615%2C23%20%40%40%20usbotg%3A%20usb%4044064000%20%7B%0A%20%7D%3B%0A%20%0A%20%26amp%3Bpinctrl%20%7B%0A-%09llce_can0_pins%3A%20llce_can0_pins%20%7B%0A-%09%09llce_can0_grp0%20%7B%0A-%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A-%09%09%09input-enable%3B%0A-%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A-%09%09%7D%3B%0A-%0A-%09%09llce_can0_grp1%20%7B%0A-%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A-%09%09%09output-enable%3B%0A-%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A-%09%09%7D%3B%0A-%0A-%09%09llce_can0_grp2%20%7B%0A-%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A-%09%09%7D%3B%0A-%09%7D%3B%0A%2B%2F%2F%09llce_can0_pins%3A%20llce_can0_pins%20%7B%0A%2B%2F%2F%09%09llce_can0_grp0%20%7B%0A%2B%2F%2F%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A%2B%2F%2F%09%09%09input-enable%3B%0A%2B%2F%2F%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A%2B%2F%2F%09%09%7D%3B%0A%2B%2F%2F%0A%2B%2F%2F%09%09llce_can0_grp1%20%7B%0A%2B%2F%2F%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A%2B%2F%2F%09%09%09output-enable%3B%0A%2B%2F%2F%09%09%09slew-rate%20%3D%20%3CS32CC_SLEW_208MHZ%3E%3B%0A%2B%2F%2F%09%09%7D%3B%0A%2B%2F%2F%0A%2B%2F%2F%09%09llce_can0_grp2%20%7B%0A%2B%2F%2F%09%09%09pinmux%20%3D%20%3CS32CC_PINMUX%3E%3B%0A%2B%2F%2F%09%09%7D%3B%0A%2B%2F%2F%09%7D%3B%0A%20%0A%20%09llce_can1_pins%3A%20llce_can1_pins%20%7B%0A%20%09%09llce_can1_grp0%20%7B%0Adiff%20--git%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%0Aindex%200247b542f98b..fe93303e8ca9%20100644%0A---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%0A%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32g274a-bluebox3.dts%0A%40%40%20-91%2C9%20%2B91%2C9%20%40%40%20%26amp%3Bllce_boot_status%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0A%20%7D%3B%0A%20%0A-%26amp%3Bllce_can0%20%7B%0A-%09status%20%3D%20%22okay%22%3B%0A-%7D%3B%0A%2B%2F%2F%26amp%3Bllce_can0%20%7B%0A%2B%2F%2F%09status%20%3D%20%22okay%22%3B%0A%2B%2F%2F%7D%3B%0A%20%0A%20%26amp%3Bllce_can1%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0Adiff%20--git%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%0Aindex%20afe8a5cea3e1..ada20f67f2d7%20100644%0A---%20a%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%0A%2B%2B%2B%20b%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fs32gxxxa-rdb.dtsi%0A%40%40%20-168%2C9%20%2B168%2C9%20%40%40%20%26amp%3Bllce_boot_status%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0A%20%7D%3B%0A%20%0A-%26amp%3Bllce_can0%20%7B%0A-%09status%20%3D%20%22okay%22%3B%0A-%7D%3B%0A%2B%2F%2F%26amp%3Bllce_can0%20%7B%0A%2B%2F%2F%09status%20%3D%20%22okay%22%3B%0A%2B%2F%2F%7D%3B%0A%20%0A%20%26amp%3Bllce_can1%20%7B%0A%20%09status%20%3D%20%22okay%22%3B%0A%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FS32CC_SLEW_208MHZ%3E%3C%2FS32CC_PINMUX%3E%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20llce%20can0%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A8%E3%83%94%E3%83%B3%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81llce_can0%20%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eroot%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins%0Als%3A%20cannot%20access%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fsiul2%404009c000%2Fsiul2-pinctrl%404009c240%2Fllce_can0_pins'%3A%20No%20such%20file%20or%20directory%0Aroot%40s32g274ardb2%3A~%23%20ls%20%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F%0Als%3A%20cannot%20access%20'%2Fsys%2Ffirmware%2Fdevicetree%2Fbase%2Fsoc%2Fllce%4043a00000%2Fllce_can0%2F'%3A%20No%20such%20file%20or%20directory%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%AF%BE%E7%85%A7%E7%9A%84%E3%81%AB%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%AA%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%82%B5%E3%83%96%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A4%89%E6%9B%B4%E5%BE%8C%E3%81%AB%20M7%20%E3%81%A7%20CAN0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%80%81%E3%81%BE%E3%81%9F%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AA%E5%8B%95%E4%BD%9C%E3%81%AF%E8%A6%8B%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82PFE%20%E3%81%A8%20CAN%20%E3%81%8C%E7%9B%B8%E4%BA%92%E3%81%AB%E5%B9%B2%E6%B8%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Flinux%2Fblob%2F1594b25154a2db746972517c61cbd0935366391a%2Fdrivers%2Fpinctrl%2Ffreescale%2Fpinctrl-s32g.c%23L430%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Epinctrl-s32g.c%23L430%3C%2FA%3E%E3%81%A7%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E5%A4%89%E6%9B%B4%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%82%E3%82%8B%E3%83%94%E3%83%B3%E3%81%AE%E3%81%82%E3%82%8B%E8%A1%8C%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E6%AC%A1%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E8%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3ES32CC_PINCTRL_PIN(S32G_MSCR_PC_11)%2C%0AS32CC_PINCTRL_PIN(S32G_MSCR_PC_12)%2C%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%20RDB2%20%E3%81%AE%20RGB%20LED%20%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E3%81%A7%E3%81%93%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8B%E3%82%89%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%83%94%E3%83%B3%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%94%E3%83%B3%E3%81%AF%E3%80%8C%E6%B5%AE%E3%81%84%E3%81%9F%E3%80%8D%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81Linux%20%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E9%80%9A%E5%B8%B8%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8B%20LED%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AB%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%20LED%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%80%81M7%20%E3%82%B3%E3%82%A2%E3%81%A7%20CAN0%20%E3%83%94%E3%83%B3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EA%20%E3%81%AE%20BSP35.0%20%E3%81%AE%20can0%20%E3%81%A8%20llcecan0%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81M%20%E3%82%B3%E3%82%A2%E3%81%8C%20PFE%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81M%20%E3%82%B3%E3%82%A2%E3%81%AE%20can0%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%9A%E4%BF%A1%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%2Ffsl-auto-yocto-bsp35.0%2Fbuild_s32g274ardb2%2Fconf%2Flocal.conf%E3%81%AB%E3%80%8CDISTRO_FEATURES_append%20%2B%3D%20'pfe'%E3%80%8D%E3%81%A8%E3%80%8CNXP_FIRMWARE_LOCAL_DIR%20%3D%20'%2Fhome%2Fhhkj%2Flinux3%2Ffsl-auto-yocto-bsp35.0%2Ffirmware_bin%2F'%E3%80%8D%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81PFE%20%E3%81%8C%20A%20%E3%82%B3%E3%82%A2%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%80%81M%20%E3%82%B3%E3%82%A2%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82CAN0%20%E3%81%A8%20SGMII%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20M%20%E3%82%B3%E3%82%A2%E3%81%A7%E3%81%AF%20PFEMAC0%20%E3%81%A8%20pfemca1%20%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%80%81PFEMAC2%20%E3%81%AE%20RGMII%20%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20A%20%E3%82%B3%E3%82%A2%E3%81%A7%E3%81%AF%20PFEMAC2%20%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81M%20%E3%82%B3%E3%82%A2%E3%81%A7%20CAN0%20%E9%80%9A%E4%BF%A1%E3%81%AE%E3%81%BF%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81M%20%E3%82%B3%E3%82%A2%E3%81%AB%20PFE%20%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%20A%20%E3%82%B3%E3%82%A2%E3%81%AE%20CAN0%20%E9%80%9A%E4%BF%A1%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%86%85%E9%83%A8%E7%9A%84%E3%81%AB%E8%AA%BF%E6%9F%BB%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81LLCE%20%E3%81%8A%E3%82%88%E3%81%B3%20PFE%20%E3%81%AE%E4%BD%BF%E7%94%A8%E6%99%82%E3%81%AB%E5%88%B6%E9%99%90%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82Linux%20%E3%81%AE%E8%B5%B7%E5%8B%95%E5%89%8D%E3%81%A8%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E5%A4%89%E5%8C%96%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22alejandro_e_0-1770676601912.png%22%20style%3D%22width%3A%20295px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376212iB17A777B7B8E0DD0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22alejandro_e_0-1770676601912.png%22%20alt%3D%22alejandro_e_0-1770676601912.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Epinctrl-s32g.c%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82PFE%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%20(%E6%B7%BB%E4%BB%98%E7%94%BB%E5%83%8F%E3%82%92%E5%8F%82%E7%85%A7)%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E3%80%81A%20%E3%82%B3%E3%82%A2%E3%81%8C%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%9F%E5%BE%8C%E3%80%81M7%20%E3%82%B3%E3%82%A2%E3%81%AE%20CAN0%20%E3%81%8C%E7%95%B0%E5%B8%B8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82PFE%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81A%20%E3%82%B3%E3%82%A2%E3%81%8C%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%9F%E5%BE%8C%E3%80%81M7%20%E3%82%B3%E3%82%A2%E3%81%AE%20CAN0%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E6%8E%A2%E3%81%9B%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81PFE%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F376000i1C27896A0C0AC284%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375996iE2EBBFCCE552DF6E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2315057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2315057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E1.%E7%A7%81%E3%81%8C%E8%A6%B3%E5%AF%9F%E3%81%97%E3%81%9F%E7%8F%BE%E8%B1%A1%E3%81%AF%E3%80%81A%20%E3%82%B3%E3%82%A2%E3%81%8C%20PFE%20%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81M7%20%E3%81%AE%20flexcan0%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%9A%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%81cantest%20%E4%B8%8A%E4%BD%8D%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20CAN%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%20flexcan0%20%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81M7%20%E3%81%AE%20flexcan0%20%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E5%BF%9C%E7%AD%94%E3%81%9B%E3%81%9A%E3%80%81%E5%A4%96%E9%83%A8%E3%81%AB%E4%BD%95%E3%82%82%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7M7%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%9F%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%202%20%E3%81%A4%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AF%E9%96%93%E9%81%95%E3%81%84%E3%81%AA%E3%81%8F%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E2.%20Linux%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E5%80%A4%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E4%BD%95%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E3.PFE%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E5%86%85%E3%81%AE%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E6%A9%9F%E8%83%BD%E3%81%8C%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%AD%E3%83%BC%E3%83%89%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FHIL1%20%E3%82%92%20HIL0%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%9B%B4%E6%96%B0%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%93%E6%95%B0%E9%80%B1%E9%96%93%E3%81%AF%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%82%92%E9%9B%A2%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%A0%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E6%9C%80%E6%96%B0%E6%83%85%E5%A0%B1%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%90%8C%E5%83%9A%E3%81%8C%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AB%E3%82%82%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2329244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2329244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231473%22%20target%3D%22_blank%22%3E%40sdx111%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E9%9D%9E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E6%99%82%E9%96%93%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E6%8A%95%E7%A8%BF%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E8%BF%BD%E8%B7%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E9%96%89%E3%81%98%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AE%E7%B6%9A%E3%81%8D%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E7%A7%81%E3%81%AB%E3%82%BF%E3%82%B0%E3%82%92%E4%BB%98%E3%81%91%E3%81%A6%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E5%8D%94%E5%8A%9B%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%86%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%94%E4%B8%8D%E4%BE%BF%E3%82%92%E3%81%8A%E3%81%8B%E3%81%91%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G274%20Debugging%20CAN%20Communication%20After%20Dual-Core%20Boot-up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328547%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BB%8A%E3%82%82%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-BODY%3E
