S32G2 HSE_ImportKey return HSE_SRV_RSP_INVALID_ADDR
Black8Mamba
 Hi NXP:
I encountered some problems when testing the HSE_DEMOAPP_S32G2XX_0_1_0_14 project.
The HSE_SRV_ID_GET_KEY_INFO service returns HSE_SRV_RSP_INVALID_ADDR(0x55A5A26AUL). The HSE_SRV_ID_IMPORT_KEY service returns HSE_SRV_RSP_GENERAL_ERROR(0x33D6D4F1UL).
The steps are as follows:
1. Use APP_HSE_FW_INSTALL_NO_SEC_BOOT macro definition
2. HSE_Config/HSE_InstallNvmKeys/HSE_ImportSymKey/HSE_ImportKe/HSE_GetKeyInfo(return HSE_SRV_RSP_INVALID_ADDR)
Black8Mamba
When I comment out HSE_GetKeyInfo, HSE_ImportKey returns HSE_SRV_RSP_GENERAL_ERROR
Joey_z
hi,Black8Mamba
Sorry for the late reply.
I have tested HSE_DEMOAPP_S32G2XX_0_1_0_14 demo. The picture is my experimental phenomenon, srvResponse = HSE_SRV_RSP_OK. To perform this demo test, you can refer to the HSE_DEMOAPP_S32G2XX_0_1_0_14_ReadMe.pdf document. Also, make sure that you can view the loaded HSE FW version through gHseFwVersion.
Hope it can help you!
Joey
