S32G2 HSE Document Support
2,202件の閲覧回数
imx8dxl-OB
Good day
Would like to check if you can assist or direct us to access/retrieve NXP HSE files for S32G2:
  1. HSE Firmware Security Installer Source Code
  2. The HSE Firmware Reference Manual
We tried to access/search from the nxpDocStore as per the product brief of NXP HSE firmware but unable to do so.
Thank you
2 返答(返信)
2,185件の閲覧回数
Daniel-Aguirre
Below will be some comments on your open points:
1 > HSE Firmware Security Installer Source Code
[DA]: Can you help us elaborate more on regards of the SW you are looking for? Where is it referenced? We do understand that on regards of HSE-FW, no source code is provided. We do apologize.
2 > The HSE Firmware Reference Manual
[DA]: It seems to be that there is a problem at this moment under the S32G2 product page for retrieving the HSE-FW Reference Manual, we do apologize.
If your account is correctly enabled, you should be able to get the HSE-FW RM with the following steps:
  • Under the new page, select the "File" option and search for "HSE-H/M":
  • If available to your account, you should be able to see the HSE-FW RM. If not, then it might be that your account is not correctly enabled to access the HSE documentation. For that, help us contact your local NXP FAE/DFAE/representative.
Please, let us know.
2,160件の閲覧回数
imx8dxl-OB
Hi @Daniel-Aguirre,
For #01, we're designing a module that requires integration of HSM via/using S32G2.
Unable to retrieve the HSE-FW RM from NXP page.
We'll follow-up with our NXP contact for further details/advise.
Thank you
