S32G2/G3 DDR Initialization on Cortex - M7
8,324 次查看
arun_belamge
Hello All.
I want to place a part of my code in the external DDR RAM i.e., ORIGIN = 0x80000000, LENGTH = 0x40000000 (1GB).
I am running a Baremetal application on the Cortex - M7 core.
I am unable to figure out how to ddr_init() and how to use the DDR Config Tool provided in the S32DS 3.6.
There is no in detail documentation / training on the same.
Please guide me on how to enable the DDR memory for Cortex - M7 and the initialization for the same.
Thanks in advance.
Arun
20 回复数
8,296 次查看
Joey_z
hi,arun_belamge
Thank you for contacting us.
Could you share more information with us?
Do you use the S32G2 or S32G3? Which version of RTD are you using?
Joey
8,288 次查看
arun_belamge
Hi Joey.
Thank you for the response.
Following are the details,
1. Board: S32G-VNP-RDB3 (S32G399A-RDB) (Primarily working on this)
2. Board: S32G-PROCEVB3-S (S32G274A-EVB) (Will try on this as well)
3. S32DS v3.6.0
4. RTD: S32_RTD_5_0_0_QLP03_D2505_ASR_REL_4_4_REV_0000_20250530
Arun
8,260 次查看
Joey_z
Hi, arun_belamge
Thank you for your reply.
We have supported the similar question before; you can try to refer to this link:
Solved: Initialization LPDDR on M7_0 core of S32G2 - NXP Community
You can tell me if it has help with you. If you still need to help for this question, you can contact me any time.
Joey
8,207 次查看
arun_belamge
Hello Joey.
Is there anything similar for the S32G399A-RDB3 board?
Currently, I have to work on the G3 board and using the above Diagnostic package, I am only able to build S32G2 tests and not G3 tests.
If i try to copy the DDR APIs to my existing project, I am having issues with conflicting header files such as StandardTypes.h and StdTypes.h.
Is there any simple straight forward way to initialize DDR memory controller and place my code on it?
Thank you.
Arun
8,178 次查看
Joey_z
hi,arun_belamge
Sorry for that we do not have the direct guide for S32G3.
You also can try to refer to s32g2 reference to create DDR code for using S32G3.
Also, you can refer to the AN12848 to find more DDR information. About how to use the DDR Tool.
AN12848: DDR Initialization and calibration on the S32G2 Vehicle Network Processor Application Note
Hope this can help you.
Joey
7,242 次查看
arun_belamge
Hi Joey.
After switching to S32DS 3.5 and RTD 5.0, I was able to use the DDR Tool and generate the DDR board files.
After I update the code, I use ddr_init() in my baremetal application, but when I run the program, it hangs / stops at the point where I have called ddr_init().
Defined ddr memory as, DDR0 (RWIX) : ORIGIN = 0x80000000 LENGTH = 0x40000000 (1gb), in linker.
Please help.
P.S. I do not have any debugger at the moment.
Thank you.
Arun
7,204 次查看
Joey_z
hi,arun_belamge
Could you share your project with me in the internal system? It is helpful for your issue.
You can post the new case following this link: https://support.nxp.com
Joey
7,080 次查看
arun_belamge
Hi Joey.
In the document AN12848 I can see the following NOTE.
Can you tell me how to enable DDR partition and set the DDR_CLK?
Thank you.
Arun
6,903 次查看
Joey_z
hi,arun_belamge
Please try to set the DDR clock/partition in the below picture showing.
Joey
6,899 次查看
arun_belamge
Hello Joey.
I have done the same config using the Clock Tool
But i am not using any MCAL, the app is baremetal, and ddr_init() in app doesn't work even after the ddr clock enabled.
Thank you.
Arun
6,842 次查看
Joey_z
hi,arun_belamge
I will help you to check this question.
Joey
7,200 次查看
arun_belamge
Hi Joey.
Thanks for the response.
I have already created one, below are the details:
*Project: SoC Benchmarking
*Case: 00748732
*Subject: DDR Memory Initialization from Cortex - M7
8,054 次查看
arun_belamge
Hello Joey.
Sorry for the late response.
I compiled and built the Diagnostics CM7 test for S32G2 with the Linflexd_UART and LPDDR4 Tests enabled, disabling other tests.
After successfully building and creating the blob.bin for the SD card and flashing it, I am not able to see any logs/print on the console.
Can you please help?
Thanks.
Arun
8,037 次查看
Joey_z
hi,arun_belamge
Could you share more information with me about apply the blob.bin?
How do you create the blob.bin and set the load adderss?
Also, do you have any debugger for this application? you can try to use the debugger to debug it and observe the UART output informaiton.
Joey
8,028 次查看
arun_belamge
Hi Joey.
I followed the document, S32G-VNP-EVBx Diagnostics (Document identifier: S32GVNPEVBXDGUG).
Using this, I created the blob.bin as follows:
Set both RAM start pointer and RAM entry pointer to 0x34000000. This value comes from the value set in the linker file.
Set the Code length to 0x300000 and the Start address to 0x2000.
And, No I do not have any debugger currently at my disposal.
Thanks.
Arun
8,014 次查看
Joey_z
hi,arun_belamge
Could you try to use only the UART demo for the SD boot? It is the better way to check the issue if cause by boot step.
Joey
8,003 次查看
arun_belamge
Hi Joey.
The UART demo also seems to not work on the G2 board.
I suspect, its the default Linflexd_UART_1 channel which is not present on the S32G-PROCEVB-S processor board ONLY. I do not have the evaluation board.
Please clarify, the UART present on the board is J58 and not J1 which is given in the example project.
If thats the case, how do I initialize the UART0, J58 and print on the console?
Thanks.
7,983 次查看
Joey_z
hi,arun_belamge
The demo of Linflexd_Uart_Ip_Example_S32G274A_M7 uses the RDB2 board.
And it uses the J1 for UART1 as the following picture.
Joey
7,971 次查看
arun_belamge
Hi Joey.
Thanks for pointing it out.
But, in the diagnostic test project, LinflexD_UART_0 i.e., J58 is being used to print on the console.
So, it should have worked...
Is the Baud rate:9600 or 27210884bps as given in the diagram?
Can i flash the app to QSPI flash instead of SD card?
Thank you.
Arun
7,805 次查看
Joey_z
hi,arun_belamge
The diagnostic of your showing if for EVB board, and the RTD demo is for RBD board, so it has the different hardware setting.
Yes, you can try to flash the app to QSPI flash instead of SD card. You can try to refer to this link:
Getting Started with the S32G Reference Design Board 2 for Vehicle Network Processing | NXP Semicond...
Getting Started with the S32G Evaluation Board for Vehicle Network Processing | NXP Semiconductors
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2192254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G2%2FG3%20DDR%20%E5%9C%A8%20Cortex%20-%20M7%20%E4%B8%8A%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192254%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%B0%86%E9%83%A8%E5%88%86%E4%BB%A3%E7%A0%81%E6%94%BE%E5%9C%A8%E5%A4%96%E9%83%A8%20DDR%20RAM%20%E4%B8%AD%EF%BC%8C%E5%8D%B3%3CSPAN%3EORIGIN%20%3D%200x80000000%EF%BC%8CLENGTH%20%3D%200x40000000%EF%BC%881GB%EF%BC%89%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%20Cortex%20-%20M7%20%E5%86%85%E6%A0%B8%E4%B8%8A%E8%BF%90%E8%A1%8C%E4%B8%80%E4%B8%AA%20Baremetal%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20ddr_init()%EF%BC%8C%E4%B9%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20S32DS%203.6%20%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%20DDR%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%E8%AF%A6%E7%BB%86%E7%9A%84%E7%9B%B8%E5%85%B3%E6%96%87%E4%BB%B6%2F%E5%9F%B9%E8%AE%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%95%99%E6%88%91%E5%A6%82%E4%BD%95%E5%90%AF%E7%94%A8%20Cortex%20-%20M7%20%E7%9A%84%20DDR%20%E5%86%85%E5%AD%98%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E8%BF%9B%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E9%98%BF%E4%BC%A6%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%EF%BC%8CArun_Belamge%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E7%9A%84%E8%AF%8A%E6%96%AD%E6%98%BE%E7%A4%BA%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%E4%BA%8E%20EVB%20%E6%9D%BF%EF%BC%8C%E8%80%8C%20RTD%20%E6%BC%94%E7%A4%BA%E9%80%82%E7%94%A8%E4%BA%8E%20RBD%20%E6%9D%BF%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%AE%BE%E7%BD%AE%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%B0%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%97%AA%E5%AD%98%E5%88%B0%20QSPI%20%E9%97%AA%E5%AD%98%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20SD%20%E5%8D%A1%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%8F%82%E8%80%83%E6%AD%A4%E9%93%BE%E6%8E%A5%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-s32g-reference-design-board-2-for-vehicle-network-processing%3AGS-S32G-VNP-RDB2%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E7%94%A8%E4%BA%8E%E8%BD%A6%E8%BE%86%E7%BD%91%E7%BB%9C%E5%A4%84%E7%90%86%E7%9A%84S32G%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%E6%9D%BF2%E5%85%A5%E9%97%A8%7C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-s32g-evaluation-board-for-vehicle-network-processing%3AGS-S32G-VNP-EVB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%94%A8%E4%BA%8E%E8%BD%A6%E8%BE%86%E7%BD%91%E7%BB%9C%E5%A4%84%E7%90%86%E7%9A%84S32G%E8%AF%84%E4%BC%B0%E6%9D%BF%E5%85%A5%E9%97%A8%7C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1762481696975.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1762481696975.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364349iE7058F9F40DA64F4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1762481696975.png%22%20alt%3D%22Joey_z_0-1762481696975.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199698%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E6%8C%87%E5%87%BA%E6%9D%A5%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E8%AF%8A%E6%96%AD%E6%B5%8B%E8%AF%95%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8CLinflexD_UART_0%20%E5%8D%B3%20J58%20%E8%A2%AB%E7%94%A8%E6%9D%A5%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%8A%E6%89%93%E5%8D%B0%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22arun_belamge_0-1762400898045.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22arun_belamge_0-1762400898045.png%22%20style%3D%22width%3A%20397px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364213i7DC6B57F6BF37EBF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22arun_belamge_0-1762400898045.png%22%20alt%3D%22arun_belamge_0-1762400898045.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E8%B5%B7%E4%BD%9C%E7%94%A8%E4%BA%86......%3C%2FP%3E%3CP%3E%E6%B3%A2%E7%89%B9%E7%8E%87%E6%98%AF%E5%9B%BE%E4%B8%AD%E7%BB%99%E5%87%BA%E7%9A%84%209600%20%E8%BF%98%E6%98%AF%2027210884bps%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E8%83%BD%E5%90%A6%E5%B0%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%97%AA%E5%AD%98%E5%88%B0%20QSPI%20%E9%97%AA%E5%AD%98%E4%B8%AD%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20SD%20%E5%8D%A1%E4%B8%AD%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EArun%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2199652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2199652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%EF%BC%8CArun_Belamge%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3ELinflexd_Uart_Ip_Example_S32G274A_M7%20%E7%9A%84%E6%BC%94%E7%A4%BA%E4%BD%BF%E7%94%A8%20RDB2%20%E6%9D%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1762396404671.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1762396404671.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364197i614DA83E4CD03EE8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1762396404671.png%22%20alt%3D%22Joey_z_0-1762396404671.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%8C%E5%AE%83%E4%BD%BF%E7%94%A8%20J1%20%E8%BF%9E%E6%8E%A5%20UART1%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1762396422450.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1762396422450.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364198i0566162C569D579F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1762396422450.png%22%20alt%3D%22Joey_z_1-1762396422450.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_2-1762396434316.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1762396434316.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364199i4665AB57E7EA9AC9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_2-1762396434316.png%22%20alt%3D%22Joey_z_2-1762396434316.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%82%3C%2FP%3E%3CP%3EUART%E6%BC%94%E7%A4%BA%E4%BC%BC%E4%B9%8E%E4%B9%9F%E6%97%A0%E6%B3%95%E5%9C%A8G2%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E6%80%80%E7%96%91%EF%BC%8C%E8%BF%99%E6%98%AF%E9%BB%98%E8%AE%A4%E7%9A%84%20Linflexd_UART_1%20%E9%80%9A%E9%81%93%EF%BC%8C%E4%BB%85%E5%9C%A8%20S32G-PROCEVB-S%20%E5%A4%84%E7%90%86%E5%99%A8%E6%9D%BF%E4%B8%8A%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FSTRONG%3E%E6%88%91%E6%B2%A1%E6%9C%89%E8%AF%84%E4%BC%B0%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%BE%84%E6%B8%85%EF%BC%8C%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E7%9A%84%20UART%20%E6%98%AF%20%3CSTRONG%3EJ58%3C%2FSTRONG%3E%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%BB%99%E5%87%BA%E7%9A%84%20J1%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E5%A6%82%E4%BD%95%E5%88%9D%E5%A7%8B%E5%8C%96%20UART0%E3%80%81J58%20%E5%B9%B6%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%8A%E6%89%93%E5%8D%B0%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ehi%EF%BC%8Carun_belamge%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E8%AF%95%E7%9D%80%E5%8F%AA%E4%BD%BF%E7%94%A8%20UART%20%E6%BC%94%E7%A4%BA%E6%9D%A5%E5%90%AF%E5%8A%A8%20SD%20%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E9%97%AE%E9%A2%98%E6%98%AF%E7%94%B1%E5%90%AF%E5%8A%A8%E6%AD%A5%E9%AA%A4%E5%BC%95%E8%B5%B7%E7%9A%84%EF%BC%8C%E8%BF%99%E6%98%AF%E6%A3%80%E6%9F%A5%E9%97%AE%E9%A2%98%E7%9A%84%E6%9B%B4%E5%A5%BD%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E6%96%87%E4%BB%B6%20S32G-VNP-EVBx%20%E8%AF%8A%E6%96%AD%E7%A8%8B%E5%BA%8F%EF%BC%88%E6%96%87%E4%BB%B6%E6%A0%87%E8%AF%86%E7%AC%A6%EF%BC%9AS32GVNPEVBXDGUG%EF%BC%89%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%A9%E7%94%A8%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%20blob.bin%20%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22arun_belamge_0-1762314941982.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22arun_belamge_0-1762314941982.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F364015i4128E1DDE3AD3592%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22arun_belamge_0-1762314941982.png%22%20alt%3D%22arun_belamge_0-1762314941982.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E5%B0%86%20RAM%20%E8%B5%B7%E5%A7%8B%E6%8C%87%E9%92%88%E5%92%8C%20RAM%20%E5%85%A5%E5%8F%A3%E6%8C%87%E9%92%88%E9%83%BD%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x34000000%E3%80%82%E8%AF%A5%E5%80%BC%E6%9D%A5%E8%87%AA%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%9A%84%E5%80%BC%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%E5%B0%86%E4%BB%A3%E7%A0%81%E9%95%BF%E5%BA%A6%E8%AE%BE%E4%B8%BA%200x300000%EF%BC%8C%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%E8%AE%BE%E4%B8%BA%200x2000%E3%80%82%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E8%80%8C%E4%B8%94%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3EArun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198617%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ehi%EF%BC%8Carun_belamge%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E6%9B%B4%E5%A4%9A%E6%9C%89%E5%85%B3%E5%BA%94%E7%94%A8%20blob.bin%20%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9F%20%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E4%BD%95%E5%88%9B%E5%BB%BA%20blob.bin%20%E5%B9%B6%E8%AE%BE%E7%BD%AE%E5%8A%A0%E8%BD%BD%E5%99%A8%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E6%9C%89%E8%AF%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E5%90%97%EF%BC%9F%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E8%A7%82%E5%AF%9F%20UART%20%E8%BE%93%E5%87%BA%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2198018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2198018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%82%3C%2FP%3E%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E6%99%9A%E6%89%8D%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%90%AF%E7%94%A8%20Linflexd_UART%20%E5%92%8C%20LPDDR4%20%E6%B5%8B%E8%AF%95%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E4%B8%BA%20S32G2%20%E7%BC%96%E8%AF%91%E5%B9%B6%E7%89%88%E6%9C%AC%E4%BA%86%20Diagnostics%20CM7%20%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%A6%81%E7%94%A8%E4%BA%86%E5%85%B6%E4%BB%96%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%90%E5%8A%9F%E4%B8%BA%20SD%20%E5%8D%A1%E6%9E%84%E5%BB%BA%E5%92%8C%E5%88%9B%E5%BB%BA%20blob.bin%20%E5%B9%B6%E8%BF%9B%E8%A1%8C%E9%97%AA%E5%AD%98%E5%90%8E%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E6%97%A5%E5%BF%97%2F%E6%89%93%E5%8D%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3EBR%3C%2FP%3E%3CP%3EArun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195412%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ehi%EF%BC%8Carun_belamge%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%20S32G3%20%E7%9A%84%E7%9B%B4%E6%8E%A5%E6%8C%87%E5%8D%97%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%8F%82%E8%80%83%20s32g2%20%E5%8F%82%E8%80%83%E6%9D%A5%E5%88%9B%E5%BB%BA%E4%BD%BF%E7%94%A8%20S32G3%20%E7%9A%84%20DDR%20%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%20AN12848%20%E6%9F%A5%E6%89%BE%E6%9B%B4%E5%A4%9A%20DDR%20%E4%BF%A1%E6%81%AF%E3%80%82%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20DDR%20%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1761793736240.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1761793736240.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363154iB0C2DB63D9AA372E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1761793736240.png%22%20alt%3D%22Joey_z_0-1761793736240.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com.cn%2Fwebapp%2Fsps%2Fdownload%2FpreDownload.jsp%3Frender%3Dtrue%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN12848%EF%BC%9AS32G2%20%E6%B1%BD%E8%BD%A6%E7%BD%91%E7%BB%9C%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%8A%E7%9A%84%20DDR%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%92%8C%E6%A0%A1%E5%87%86%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194770%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%82%3C%2FP%3E%3CP%3ES32G399A-RDB3%20%E6%9D%BF%E6%9C%89%E7%B1%BB%E4%BC%BC%E7%9A%84%E4%B8%9C%E8%A5%BF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E5%BF%85%E9%A1%BB%E5%9C%A8%20G3%20%E6%9D%BF%E4%B8%8A%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%BF%E7%94%A8%E4%B8%8A%E9%9D%A2%E7%9A%84%E8%AF%8A%E6%96%AD%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E6%88%91%E5%8F%AA%E8%83%BD%E6%9E%84%E5%BB%BA%20S32G2%20%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%B8%8D%E8%83%BD%E6%9E%84%E5%BB%BA%20G3%20%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%9D%E8%AF%95%E5%B0%86%20DDR%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%E5%A4%8D%E5%88%B6%E5%88%B0%E7%8E%B0%E6%9C%89%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E5%B0%B1%E4%BC%9A%E9%81%87%E5%88%B0%20StandardTypes.h%20%E5%92%8C%20StdTypes.h%20%E7%AD%89%E5%A4%B4%E6%96%87%E4%BB%B6%E7%9B%B8%E4%BA%92%E5%86%B2%E7%AA%81%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E7%AE%80%E5%8D%95%E7%9B%B4%E6%8E%A5%E7%9A%84%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%88%9D%E5%A7%8B%E5%8C%96%20DDR%20%E5%86%85%E5%AD%98%E6%8E%A7%E5%88%B6%E5%99%A8%E5%B9%B6%E5%B0%86%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E6%94%BE%E5%9C%A8%E4%B8%8A%E9%9D%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3EArun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CSPAN%3EArun_Belamge%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%9B%BE%E7%BB%8F%E6%94%AF%E6%8C%81%E8%BF%87%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9B%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%8F%82%E8%80%83%E6%AD%A4%E9%93%BE%E6%8E%A5%EF%BC%9A%20%20%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2FInitialization-LPDDR-on-M7-0-core-of-S32G2%2Ftd-p%2F1976037%22%20target%3D%22_blank%22%3E%E5%B7%B2%E8%A7%A3%E5%86%B3%EF%BC%9A%E5%9C%A8%20S32G2%20%E7%9A%84%20M7_0%20%E5%86%85%E6%A0%B8%E4%B8%8A%E5%88%9D%E5%A7%8B%E5%8C%96%20LPDDR%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%AE%83%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8A%E8%BF%98%E9%9C%80%E8%A6%81%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%9A%8F%E6%97%B6%E8%81%94%E7%B3%BB%E6%88%91%E3%80%82%20%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E4%B9%94%E4%BC%8A%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A6%E6%83%85%E5%A6%82%E4%B8%8B%E3%80%81%3C%2FP%3E%3CP%3E1%E3%80%82%E6%9D%BF%EF%BC%9AS32G-VNP-RDB3%20(S32G399A-RDB)%EF%BC%88%E4%B8%BB%E8%A6%81%E7%A0%94%E7%A9%B6%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%89%3C%2FP%3E%3CP%3E2%E3%80%82%E6%9D%BF%EF%BC%9AS32G-PROCEVB3-S%20(S32G274A-EVB)%EF%BC%88%E4%B9%9F%E4%BC%9A%E8%AF%95%E8%AF%95%E8%BF%99%E4%B8%AA%EF%BC%89%3C%2FP%3E%3CP%3E3.S32DS%20v3.6.0%3C%2FP%3E%3CP%3E4.RTD%3A%3CSPAN%3ES32_RTD_5_0_0_QLP03_D2505_ASR_REL_4_4_REV_0000_20250530%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3CP%3EArun%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%2FG3%20DDR%20Initialization%20on%20Cortex%20-%20M7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%EF%BC%8CArun_Belamge%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E4%B8%8E%E6%88%91%E4%BB%AC%E5%88%86%E4%BA%AB%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20S32G2%20%E8%BF%98%E6%98%AF%20S32G3%EF%BC%9F%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20RTD%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
