S32G2 BSP 44 Ubuntu Build Failure
sid_rotor
Hello, I am trying to build an ubuntu image for xx as specified by S32G2_LinuxBSP_44.0_User_Manual_updated_D250603.pdf. However, I am running into the following errors. Inspecting the configuration files, it appears that some of the system still expects `kirkstone` even though we are now building with `scarthgap`? And the glib versions that are expected don't seem to match. I have listed the commands run and the error output when I attempt to run the build. Am I missing some configuration?
Commands:
mkdir fsl-auto-yocto-bsp
cd fsl-auto-yocto-bsp
repo init -u https://github.com/nxp-auto-linux/auto_yocto_bsp/ -b release/bsp44.0 -m default.xml
repo sync
sudo apt update
./sources/meta-alb/scripts/host-prepare.sh
source nxp-setup-alb.sh -m s32g274ardb2ubuntu
# Set NXP_FIRMWARE_LOCAL_DIR in local/local.conf
bitbake fsl-image-ubuntu-base
Output:
❯ bitbake fsl-image-ubuntu-base
Loading cache: 100% |#######################################################################################################################################################################################################| Time: 0:00:00
Loaded 1143 entries from dependency cache.
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu.bb: nativeaptinstall.bbclass is incompatible to the current layer set | ETA: 0:00:44
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-ros.bb: nativeaptinstall.bbclass is incompatible to the current layer set | ETA: 0:00:32
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-ros.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-base.bb: nativeaptinstall.bbclass is incompatible to the current layer set | ETA: 0:00:29
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-base.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-extended/ubuntu/ubuntu-base_22.04.1.bb: nativeaptinstall.bbclass is incompatible to the current layer setETA: 0:00:17
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-extended/ubuntu/ubuntu-base_22.04.1.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
Parsing recipes: 100% |#####################################################################################################################################################################################################| Time: 0:00:55
Parsing of 3692 .bb files complete (766 cached, 2926 parsed). 5803 targets, 617 skipped, 2 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
WARNING: preferred version 2.35 of cross-localedef-native not available (for item cross-localedef-native)
WARNING: versions of cross-localedef-native available: 2.31+git 2.39+git
WARNING: preferred version 2.38 of binutils-cross-aarch64 not available (for item virtual/aarch64-fsl-linux-binutils)
WARNING: versions of binutils-cross-aarch64 available: 2.34 2.42
WARNING: preferred version 2.35 of cross-localedef-native not available (for item cross-localedef-native-dev)
WARNING: preferred version 2.38 of binutils-crosssdk-x86_64-fslbsp-linux not available (for item virtual/x86_64-fslbsp-linux-binutils)
WARNING: versions of binutils-crosssdk-x86_64-fslbsp-linux available: 2.42
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item virtual/nativesdk-libc)
WARNING: versions of nativesdk-glibc available: 2.39+git
WARNING: preferred version 2.35 of glibc not available (for item virtual/libc)
WARNING: versions of glibc available: 2.31+git 2.39+git
WARNING: preferred version 2.38 of binutils-native not available (for item binutils-native)
WARNING: versions of binutils-native available: 2.42
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item virtual/nativesdk-libintl)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item virtual/nativesdk-libiconv)
WARNING: preferred version 2.35 of glibc not available (for item glibc-thread-db)
WARNING: preferred version 2.35 of glibc-locale not available (for item glibc-localedata-i18n)
WARNING: versions of glibc-locale available: 2.31 2.39+git
WARNING: preferred version 2.35 of glibc not available (for item glibc-utils)
WARNING: preferred version 2.35 of glibc not available (for item glibc-dbg)
WARNING: preferred version 2.35 of glibc not available (for item glibc-dev)
WARNING: preferred version 2.38 of binutils-cross-canadian-aarch64 not available (for item binutils-cross-canadian-aarch64)
WARNING: versions of binutils-cross-canadian-aarch64 available: 2.34 2.42
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-ldconfig)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-glibc)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-glibc-utils)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-glibc-dev)
WARNING: preferred version 2.35 of glibc not available (for item glibc)
WARNING: preferred version 2.35 of glibc not available (for item ldconfig)
WARNING: preferred version 2.35 of glibc-locale not available (for item glibc-locale)
ERROR: Nothing PROVIDES 'virtual/x86_64-fslbsp-linux-gcc-crosssdk' (but /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-devtools/binutils2.34/binutils-cross-canadian_2.34.bb DEPENDS on or otherwise requires it). Close matches:
virtual/x86_64-fslbsp-linux-g++
virtual/x86_64-fslbsp-linux-go
NOTE: Runtime target 'binutils-cross-canadian-aarch64' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['binutils-cross-canadian-aarch64', 'virtual/x86_64-fslbsp-linux-gcc-crosssdk']
NOTE: Runtime target 'packagegroup-cross-canadian-s32g274ardb2' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['packagegroup-cross-canadian-s32g274ardb2', 'binutils-cross-canadian-aarch64', 'virtual/x86_64-fslbsp-linux-gcc-crosssdk']
ERROR: Required build target 'fsl-image-ubuntu-base' has no buildable providers.
Missing or unbuildable dependency chain was: ['fsl-image-ubuntu-base', 'packagegroup-cross-canadian-s32g274ardb2', 'binutils-cross-canadian-aarch64', 'virtual/x86_64-fslbsp-linux-gcc-crosssdk']
Summary: There were 46 WARNING messages.
Summary: There were 10 ERROR messages, returning a non-zero exit code.
chenyin_h
Hello, @sid_rotor
Thanks for your reply.
As far as I know, the BSP version before 44(43 or earlier) could support the ubuntu build correctly, you may try using these versions for your work.
Chenyin
chenyin_h
Hello, @sid_rotor
Thanks for your post.
Building Ubuntu images for running on S32G processors is not available in BSP44 release, I feel sorry that the BSP UM is not updated correctly, I suggest ignoring the related chapter in the UM.
Chenyin
sid_rotor
Thanks for the quick response. Is this also the case for other BSP versions? I will try to port our patches to a different BSP, but would like to make sure they support building an Ubuntu image.
Also, where might I be able to find a changelog/release notes/porting guide to update my BSP version?
chenyin_h
Hello, @sid_rotor
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2409750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G2%20BSP%2044%20Ubuntu%20Build%20Failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20am%20trying%20to%20build%20an%20ubuntu%20image%20for%20xx%20as%20specified%20by%26nbsp%3BS32G2_LinuxBSP_44.0_User_Manual_updated_D250603.pdf.%20However%2C%20I%20am%20running%20into%20the%20following%20errors.%20Inspecting%20the%20configuration%20files%2C%20it%20appears%20that%20some%20of%20the%20system%20still%20expects%20%60kirkstone%60%20even%20though%20we%20are%20now%20building%20with%20%60scarthgap%60%3F%20And%20the%20glib%20versions%20that%20are%20expected%20don't%20seem%20to%20match.%20I%20have%20listed%20the%20commands%20run%20and%20the%20error%20output%20when%20I%20attempt%20to%20run%20the%20build.%20Am%20I%20missing%20some%20configuration%3F%3C%2FP%3E%3CP%3ECommands%3A%3C%2FP%3E%3CPRE%3Emkdir%20fsl-auto-yocto-bsp%3CBR%20%2F%3Ecd%20fsl-auto-yocto-bsp%3CBR%20%2F%3Erepo%20init%20-u%20https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%2F%20-b%20release%2Fbsp44.0%20-m%20default.xml%3CBR%20%2F%3Erepo%20sync%3CBR%20%2F%3Esudo%20apt%20update%3CBR%20%2F%3E.%2Fsources%2Fmeta-alb%2Fscripts%2Fhost-prepare.sh%3CBR%20%2F%3Esource%20nxp-setup-alb.sh%20-m%20s32g274ardb2ubuntu%3CBR%20%2F%3E%23%20Set%20NXP_FIRMWARE_LOCAL_DIR%20in%20local%2Flocal.conf%3CBR%20%2F%3Ebitbake%20fsl-image-ubuntu-base%3C%2FPRE%3E%3CP%3EOutput%3A%3C%2FP%3E%3CPRE%3E%E2%9D%AF%20bitbake%20fsl-image-ubuntu-base%3CBR%20%2F%3ELoading%20cache%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A00%3CBR%20%2F%3ELoaded%201143%20entries%20from%20dependency%20cache.%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20set%20%7C%20ETA%3A%200%3A00%3A44%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-ros.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20set%20%7C%20ETA%3A%200%3A00%3A32%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-ros.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-base.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20set%20%7C%20ETA%3A%200%3A00%3A29%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-base.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-extended%2Fubuntu%2Fubuntu-base_22.04.1.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20setETA%3A%200%3A00%3A17%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-extended%2Fubuntu%2Fubuntu-base_22.04.1.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EParsing%20recipes%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A55%3CBR%20%2F%3EParsing%20of%203692%20.bb%20files%20complete%20(766%20cached%2C%202926%20parsed).%205803%20targets%2C%20617%20skipped%2C%202%20masked%2C%200%20errors.%3CBR%20%2F%3ENOTE%3A%20Resolving%20any%20missing%20task%20queue%20dependencies%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20cross-localedef-native%20not%20available%20(for%20item%20cross-localedef-native)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20cross-localedef-native%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-cross-aarch64%20not%20available%20(for%20item%20virtual%2Faarch64-fsl-linux-binutils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-cross-aarch64%20available%3A%202.34%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20cross-localedef-native%20not%20available%20(for%20item%20cross-localedef-native-dev)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20cross-localedef-native%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20cross-localedef-native%20not%20available%20(for%20item%20cross-localedef-native)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20cross-localedef-native%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-crosssdk-x86_64-fslbsp-linux%20not%20available%20(for%20item%20virtual%2Fx86_64-fslbsp-linux-binutils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-crosssdk-x86_64-fslbsp-linux%20available%3A%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20virtual%2Fnativesdk-libc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20virtual%2Flibc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-native%20not%20available%20(for%20item%20binutils-native)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-native%20available%3A%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20virtual%2Fnativesdk-libintl)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20virtual%2Fnativesdk-libiconv)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-thread-db)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc-locale%20not%20available%20(for%20item%20glibc-localedata-i18n)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc-locale%20available%3A%202.31%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-utils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-dbg)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-dev)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-cross-canadian-aarch64%20not%20available%20(for%20item%20binutils-cross-canadian-aarch64)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-cross-canadian-aarch64%20available%3A%202.34%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-ldconfig)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-glibc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-glibc-utils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-glibc-dev)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20ldconfig)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc-locale%20not%20available%20(for%20item%20glibc-locale)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc-locale%20available%3A%202.31%202.39%2Bgit%3CBR%20%2F%3EERROR%3A%20Nothing%20PROVIDES%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%20(but%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-devtools%2Fbinutils2.34%2Fbinutils-cross-canadian_2.34.bb%20DEPENDS%20on%20or%20otherwise%20requires%20it).%20Close%20matches%3A%3CBR%20%2F%3Evirtual%2Fx86_64-fslbsp-linux-g%2B%2B%3CBR%20%2F%3Evirtual%2Fx86_64-fslbsp-linux-gcc%3CBR%20%2F%3Evirtual%2Fx86_64-fslbsp-linux-go%3CBR%20%2F%3ENOTE%3A%20Runtime%20target%20'binutils-cross-canadian-aarch64'%20is%20unbuildable%2C%20removing...%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'binutils-cross-canadian-aarch64'%2C%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%5D%3CBR%20%2F%3ENOTE%3A%20Runtime%20target%20'packagegroup-cross-canadian-s32g274ardb2'%20is%20unbuildable%2C%20removing...%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'packagegroup-cross-canadian-s32g274ardb2'%2C%20'binutils-cross-canadian-aarch64'%2C%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%5D%3CBR%20%2F%3EERROR%3A%20Required%20build%20target%20'fsl-image-ubuntu-base'%20has%20no%20buildable%20providers.%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'fsl-image-ubuntu-base'%2C%20'packagegroup-cross-canadian-s32g274ardb2'%2C%20'binutils-cross-canadian-aarch64'%2C%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%5D%3CBR%20%2F%3E%3CBR%20%2F%3ESummary%3A%20There%20were%2046%20WARNING%20messages.%3CBR%20%2F%3ESummary%3A%20There%20were%2010%20ERROR%20messages%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%20BSP%2044%20Ubuntu%20Build%20Failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F266082%22%20target%3D%22_blank%22%3E%40sid_rotor%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EBuilding%20Ubuntu%20images%20for%20running%20on%20S32G%20processors%20is%20not%20available%20in%20BSP44%20release%2C%20I%20feel%20sorry%20that%20the%20BSP%20UM%20is%20not%20updated%20correctly%2C%20I%20suggest%20ignoring%20the%20related%20chapter%20in%20the%20UM.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%20BSP%2044%20Ubuntu%20Build%20Failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20for%20the%20quick%20response.%20Is%20this%20also%20the%20case%20for%20other%20BSP%20versions%3F%20I%20will%20try%20to%20port%20our%20patches%20to%20a%20different%20BSP%2C%20but%20would%20like%20to%20make%20sure%20they%20support%20building%20an%20Ubuntu%20image.%3CBR%20%2F%3E%3CBR%20%2F%3EAlso%2C%20where%20might%20I%20be%20able%20to%20find%20a%20changelog%2Frelease%20notes%2Fporting%20guide%20to%20update%20my%20BSP%20version%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%20BSP%2044%20Ubuntu%20Build%20Failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F266082%22%20target%3D%22_blank%22%3E%40sid_rotor%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3EAs%20far%20as%20I%20know%2C%20the%20BSP%20version%20before%2044(43%20or%20earlier)%20could%20support%20the%20ubuntu%20build%20correctly%2C%20you%20may%20try%20using%20these%20versions%20for%20your%20work.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
