S32G2 BSP 44 Ubuntu Build Failure
267件の閲覧回数
sid_rotor
Hello, I am trying to build an ubuntu image for xx as specified by S32G2_LinuxBSP_44.0_User_Manual_updated_D250603.pdf. However, I am running into the following errors. Inspecting the configuration files, it appears that some of the system still expects `kirkstone` even though we are now building with `scarthgap`? And the glib versions that are expected don't seem to match. I have listed the commands run and the error output when I attempt to run the build. Am I missing some configuration?
Commands:
mkdir fsl-auto-yocto-bsp
cd fsl-auto-yocto-bsp
repo init -u https://github.com/nxp-auto-linux/auto_yocto_bsp/ -b release/bsp44.0 -m default.xml
repo sync
sudo apt update
./sources/meta-alb/scripts/host-prepare.sh
source nxp-setup-alb.sh -m s32g274ardb2ubuntu
# Set NXP_FIRMWARE_LOCAL_DIR in local/local.conf
bitbake fsl-image-ubuntu-base
Output:
❯ bitbake fsl-image-ubuntu-base
Loading cache: 100% |#######################################################################################################################################################################################################| Time: 0:00:00
Loaded 1143 entries from dependency cache.
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu.bb: nativeaptinstall.bbclass is incompatible to the current layer set | ETA: 0:00:44
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-ros.bb: nativeaptinstall.bbclass is incompatible to the current layer set | ETA: 0:00:32
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-ros.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-base.bb: nativeaptinstall.bbclass is incompatible to the current layer set | ETA: 0:00:29
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-fsl/images/fsl-image-ubuntu-base.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-extended/ubuntu/ubuntu-base_22.04.1.bb: nativeaptinstall.bbclass is incompatible to the current layer setETA: 0:00:17
ERROR: /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-extended/ubuntu/ubuntu-base_22.04.1.bb: You must check APTGET_YOCTO_TRANSLATION and update the anonymous python() function!
Parsing recipes: 100% |#####################################################################################################################################################################################################| Time: 0:00:55
Parsing of 3692 .bb files complete (766 cached, 2926 parsed). 5803 targets, 617 skipped, 2 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
WARNING: preferred version 2.35 of cross-localedef-native not available (for item cross-localedef-native)
WARNING: versions of cross-localedef-native available: 2.31+git 2.39+git
WARNING: preferred version 2.38 of binutils-cross-aarch64 not available (for item virtual/aarch64-fsl-linux-binutils)
WARNING: versions of binutils-cross-aarch64 available: 2.34 2.42
WARNING: preferred version 2.35 of cross-localedef-native not available (for item cross-localedef-native-dev)
WARNING: preferred version 2.38 of binutils-crosssdk-x86_64-fslbsp-linux not available (for item virtual/x86_64-fslbsp-linux-binutils)
WARNING: versions of binutils-crosssdk-x86_64-fslbsp-linux available: 2.42
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item virtual/nativesdk-libc)
WARNING: versions of nativesdk-glibc available: 2.39+git
WARNING: preferred version 2.35 of glibc not available (for item virtual/libc)
WARNING: versions of glibc available: 2.31+git 2.39+git
WARNING: preferred version 2.38 of binutils-native not available (for item binutils-native)
WARNING: versions of binutils-native available: 2.42
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item virtual/nativesdk-libintl)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item virtual/nativesdk-libiconv)
WARNING: preferred version 2.35 of glibc not available (for item glibc-thread-db)
WARNING: preferred version 2.35 of glibc-locale not available (for item glibc-localedata-i18n)
WARNING: versions of glibc-locale available: 2.31 2.39+git
WARNING: preferred version 2.35 of glibc not available (for item glibc-utils)
WARNING: preferred version 2.35 of glibc not available (for item glibc-dbg)
WARNING: preferred version 2.35 of glibc not available (for item glibc-dev)
WARNING: preferred version 2.38 of binutils-cross-canadian-aarch64 not available (for item binutils-cross-canadian-aarch64)
WARNING: versions of binutils-cross-canadian-aarch64 available: 2.34 2.42
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-ldconfig)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-glibc)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-glibc-utils)
WARNING: preferred version 2.35 of nativesdk-glibc not available (for item nativesdk-glibc-dev)
WARNING: preferred version 2.35 of glibc not available (for item glibc)
WARNING: preferred version 2.35 of glibc not available (for item ldconfig)
WARNING: preferred version 2.35 of glibc-locale not available (for item glibc-locale)
ERROR: Nothing PROVIDES 'virtual/x86_64-fslbsp-linux-gcc-crosssdk' (but /path/reproduce-for-forum/fsl-auto-yocto-bsp/sources/meta-alb/meta-alb-sdk/recipes-devtools/binutils2.34/binutils-cross-canadian_2.34.bb DEPENDS on or otherwise requires it). Close matches:
virtual/x86_64-fslbsp-linux-g++
virtual/x86_64-fslbsp-linux-go
NOTE: Runtime target 'binutils-cross-canadian-aarch64' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['binutils-cross-canadian-aarch64', 'virtual/x86_64-fslbsp-linux-gcc-crosssdk']
NOTE: Runtime target 'packagegroup-cross-canadian-s32g274ardb2' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['packagegroup-cross-canadian-s32g274ardb2', 'binutils-cross-canadian-aarch64', 'virtual/x86_64-fslbsp-linux-gcc-crosssdk']
ERROR: Required build target 'fsl-image-ubuntu-base' has no buildable providers.
Missing or unbuildable dependency chain was: ['fsl-image-ubuntu-base', 'packagegroup-cross-canadian-s32g274ardb2', 'binutils-cross-canadian-aarch64', 'virtual/x86_64-fslbsp-linux-gcc-crosssdk']
Summary: There were 46 WARNING messages.
Summary: There were 10 ERROR messages, returning a non-zero exit code.
206件の閲覧回数
chenyin_h
Hello, @sid_rotor
Thanks for your reply.
As far as I know, the BSP version before 44(43 or earlier) could support the ubuntu build correctly, you may try using these versions for your work.
Chenyin
3 返答(返信)
233件の閲覧回数
chenyin_h
Hello, @sid_rotor
Thanks for your post.
Building Ubuntu images for running on S32G processors is not available in BSP44 release, I feel sorry that the BSP UM is not updated correctly, I suggest ignoring the related chapter in the UM.
Chenyin
213件の閲覧回数
sid_rotor
Thanks for the quick response. Is this also the case for other BSP versions? I will try to port our patches to a different BSP, but would like to make sure they support building an Ubuntu image.
Also, where might I be able to find a changelog/release notes/porting guide to update my BSP version?
207件の閲覧回数
chenyin_h
Hello, @sid_rotor
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2409750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G2%20BSP%2044%20Ubuntu%20%E3%83%93%E3%83%AB%E3%83%89%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82S32G2_LinuxBSP_44.0_User_Manual_updated_D250603.pdf%20%E3%81%A7%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81xx%20%E7%94%A8%E3%81%AE%20Ubuntu%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E7%8F%BE%E5%9C%A8%60scarthgap%60%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%8C%E3%81%BE%E3%81%A0%60kirkstone%60%E3%82%92%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8Bglib%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E9%9A%9B%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A8%E3%80%81%E3%81%9D%E3%81%AE%E9%9A%9B%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%8A%9C%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3Emkdir%20fsl-auto-yocto-bsp%3CBR%20%2F%3Ecd%20fsl-auto-yocto-bsp%3CBR%20%2F%3Erepo%20init%20-u%20https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%2F%20-b%20release%2Fbsp44.0%20-m%20default.xml%3CBR%20%2F%3Erepo%20sync%3CBR%20%2F%3Esudo%20apt%20update%3CBR%20%2F%3E.%2Fsources%2Fmeta-alb%2Fscripts%2Fhost-prepare.sh%3CBR%20%2F%3Esource%20nxp-setup-alb.sh%20-m%20s32g274ardb2ubuntu%3CBR%20%2F%3E%23%20Set%20NXP_FIRMWARE_LOCAL_DIR%20in%20local%2Flocal.conf%3CBR%20%2F%3Ebitbake%20fsl-image-ubuntu-base%3C%2FPRE%3E%3CP%3E%E5%87%BA%E5%8A%9B%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%E2%9D%AF%20bitbake%20fsl-image-ubuntu-base%3CBR%20%2F%3ELoading%20cache%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A00%3CBR%20%2F%3ELoaded%201143%20entries%20from%20dependency%20cache.%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20set%20%7C%20ETA%3A%200%3A00%3A44%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-ros.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20set%20%7C%20ETA%3A%200%3A00%3A32%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-ros.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-base.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20set%20%7C%20ETA%3A%200%3A00%3A29%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-fsl%2Fimages%2Ffsl-image-ubuntu-base.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-extended%2Fubuntu%2Fubuntu-base_22.04.1.bb%3A%20nativeaptinstall.bbclass%20is%20incompatible%20to%20the%20current%20layer%20setETA%3A%200%3A00%3A17%3CBR%20%2F%3EERROR%3A%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-extended%2Fubuntu%2Fubuntu-base_22.04.1.bb%3A%20You%20must%20check%20APTGET_YOCTO_TRANSLATION%20and%20update%20the%20anonymous%20python()%20function!%3CBR%20%2F%3EParsing%20recipes%3A%20100%25%20%7C%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%7C%20Time%3A%200%3A00%3A55%3CBR%20%2F%3EParsing%20of%203692%20.bb%20files%20complete%20(766%20cached%2C%202926%20parsed).%205803%20targets%2C%20617%20skipped%2C%202%20masked%2C%200%20errors.%3CBR%20%2F%3ENOTE%3A%20Resolving%20any%20missing%20task%20queue%20dependencies%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20cross-localedef-native%20not%20available%20(for%20item%20cross-localedef-native)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20cross-localedef-native%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-cross-aarch64%20not%20available%20(for%20item%20virtual%2Faarch64-fsl-linux-binutils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-cross-aarch64%20available%3A%202.34%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20cross-localedef-native%20not%20available%20(for%20item%20cross-localedef-native-dev)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20cross-localedef-native%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20cross-localedef-native%20not%20available%20(for%20item%20cross-localedef-native)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20cross-localedef-native%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-crosssdk-x86_64-fslbsp-linux%20not%20available%20(for%20item%20virtual%2Fx86_64-fslbsp-linux-binutils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-crosssdk-x86_64-fslbsp-linux%20available%3A%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20virtual%2Fnativesdk-libc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20virtual%2Flibc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-native%20not%20available%20(for%20item%20binutils-native)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-native%20available%3A%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20virtual%2Fnativesdk-libintl)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20virtual%2Fnativesdk-libiconv)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-thread-db)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc-locale%20not%20available%20(for%20item%20glibc-localedata-i18n)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc-locale%20available%3A%202.31%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-utils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-dbg)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc-dev)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.38%20of%20binutils-cross-canadian-aarch64%20not%20available%20(for%20item%20binutils-cross-canadian-aarch64)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20binutils-cross-canadian-aarch64%20available%3A%202.34%202.42%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-ldconfig)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-glibc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-glibc-utils)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20nativesdk-glibc%20not%20available%20(for%20item%20nativesdk-glibc-dev)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20nativesdk-glibc%20available%3A%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20glibc)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc%20not%20available%20(for%20item%20ldconfig)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc%20available%3A%202.31%2Bgit%202.39%2Bgit%3CBR%20%2F%3EWARNING%3A%20preferred%20version%202.35%20of%20glibc-locale%20not%20available%20(for%20item%20glibc-locale)%3CBR%20%2F%3EWARNING%3A%20versions%20of%20glibc-locale%20available%3A%202.31%202.39%2Bgit%3CBR%20%2F%3EERROR%3A%20Nothing%20PROVIDES%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%20(but%20%2Fpath%2Freproduce-for-forum%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Fmeta-alb-sdk%2Frecipes-devtools%2Fbinutils2.34%2Fbinutils-cross-canadian_2.34.bb%20DEPENDS%20on%20or%20otherwise%20requires%20it).%20Close%20matches%3A%3CBR%20%2F%3Evirtual%2Fx86_64-fslbsp-linux-g%2B%2B%3CBR%20%2F%3Evirtual%2Fx86_64-fslbsp-linux-gcc%3CBR%20%2F%3Evirtual%2Fx86_64-fslbsp-linux-go%3CBR%20%2F%3ENOTE%3A%20Runtime%20target%20'binutils-cross-canadian-aarch64'%20is%20unbuildable%2C%20removing...%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'binutils-cross-canadian-aarch64'%2C%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%5D%3CBR%20%2F%3ENOTE%3A%20Runtime%20target%20'packagegroup-cross-canadian-s32g274ardb2'%20is%20unbuildable%2C%20removing...%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'packagegroup-cross-canadian-s32g274ardb2'%2C%20'binutils-cross-canadian-aarch64'%2C%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%5D%3CBR%20%2F%3EERROR%3A%20Required%20build%20target%20'fsl-image-ubuntu-base'%20has%20no%20buildable%20providers.%3CBR%20%2F%3EMissing%20or%20unbuildable%20dependency%20chain%20was%3A%20%5B'fsl-image-ubuntu-base'%2C%20'packagegroup-cross-canadian-s32g274ardb2'%2C%20'binutils-cross-canadian-aarch64'%2C%20'virtual%2Fx86_64-fslbsp-linux-gcc-crosssdk'%5D%3CBR%20%2F%3E%3CBR%20%2F%3ESummary%3A%20There%20were%2046%20WARNING%20messages.%3CBR%20%2F%3ESummary%3A%20There%20were%2010%20ERROR%20messages%2C%20returning%20a%20non-zero%20exit%20code.%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%20BSP%2044%20Ubuntu%20Build%20Failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F266082%22%20target%3D%22_blank%22%3E%40sid_rotor%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ES32G%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BUbuntu%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AFBSP44%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AF%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82BSP%E3%81%AEUM%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E6%AE%8B%E5%BF%B5%E3%81%A7%E3%81%99%E3%80%82UM%E3%81%AE%E9%96%A2%E9%80%A3%E7%AB%A0%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%20BSP%2044%20Ubuntu%20Build%20Failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410159%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%BF%85%E9%80%9F%E3%81%AA%E3%81%94%E5%AF%BE%E5%BF%9C%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AEBSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AA%E3%81%93%E3%81%A8%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%88%A5%E3%81%AEBSP%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Ubuntu%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E6%A7%8B%E7%AF%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81BSP%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E5%A4%89%E6%9B%B4%E5%B1%A5%E6%AD%B4%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%80%81%E7%A7%BB%E6%A4%8D%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AA%E3%81%A9%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G2%20BSP%2044%20Ubuntu%20Build%20Failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F266082%22%20target%3D%22_blank%22%3E%40sid_rotor%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%8144%E4%BB%A5%E5%89%8D%E3%81%AEBSP%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3(43%E4%BB%A5%E5%89%8D)%E3%81%AFUbuntu%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BB%95%E4%BA%8B%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%AE%E3%82%82%E8%89%AF%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
