S32G-VNP-RDB2(s32g274a) board PFE network ping failed
ソリューションへジャンプ
2,207件の閲覧回数
waitewang
Hello
I am using the S32G-VNP-RDB2 board and run the Linux BSP 44.0 from NXP.
The BSP print the version "Auto Linux BSP 44.0 s32g274ardb2 ttyLF0".
Set the pfe0 net interface the IP 192.168.0.12
root@s32g274ardb2:/# ifconfig pfe0
pfe0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.12 netmask 255.255.255.0 broadcast 192.168.0.1
inet6 fe80::204:9fff:febe:ef00 prefixlen 64 scopeid 0x20<link>
ether 00:04:9f:be:ef:00 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 127 bytes 15832 (15.4 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0x46000000-46ffffff
when I used the ping command, it print
root@s32g274ardb2:/# ping 192.168.0.11
PING 192.168.0.11 (192.168.0.11) 56(84) bytes of data.
From 192.168.0.12 icmp_seq=1 Destination Host Unreachable
ping: sendmsg: No route to host
From 192.168.0.12 icmp_seq=2 Destination Host Unreachable
From 192.168.0.12 icmp_seq=3 Destination Host Unreachable
If the PFE is different of GMAC? Can you tell me how to use the PFE network?
タグ(3)
2,183件の閲覧回数
chenyin_h
Hello, @waitewang
Thanks for your post.
I understand that you are running with BSP44 on a RDB2, may I know:
1. You are using a pre-built BSP image to boot the board or built it yourself?
2. Would you mind sharing all log for booting the board? from bootloader to the kernel shell, so that I could help to analyze the issue with details
Chenyin
2 返答(返信)
2,184件の閲覧回数
chenyin_h
Hello, @waitewang
Chenyin
1,548件の閲覧回数
waitewang
hello
(1) I am using the binary image file downloaded from the official NXP website.
(2) I try it according to the manaul as follow, it is successfully.
thanks very much!
%3CLINGO-SUB%20id%3D%22lingo-sub-2268727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G-VNP-RDB2(s32g274a)%E3%83%9C%E3%83%BC%E3%83%89PFE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AFping%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20S32G-VNP-RDB2%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81NXP%20%E3%81%AE%20Linux%20BSP%2044.0%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBSP%20%E3%81%AF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%80%8C%E8%BB%8A%E8%BC%89%20Linux%20BSP%2044.0%20s32g274ardb2%20ttyLF0%E3%80%8D%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Epfe0%E3%83%8D%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92192.168.0.12%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%3CEM%3Eroot%40s32g274ardb2%3A%2F%23%20ifconfig%20pfe0%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20pfe0%3A%20flags%3D4163%3CUP%3E%20mtu%201500%3C%2FUP%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20inet%20192.168.0.12%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%20255.255.255.0%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20192.168.0.1%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20inet6%20fe80%3A%3A204%3A9fff%3Afebe%3Aef00%20%E3%83%97%E3%83%AC%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E9%95%B7%2064%20%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97ID%200x20%3CLINK%20%2F%3E%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20ether%2000%3A04%3A9f%3Abe%3Aef%3A00%20txqueuelen%201000%20(%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20RX%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%200%20%E3%83%90%E3%82%A4%E3%83%88%200%20(0.0%20B)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20RX%E3%82%A8%E3%83%A9%E3%83%BC%200%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%200%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%200%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%200%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20%E9%80%81%E4%BF%A1%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%20127%20%E3%83%90%E3%82%A4%E3%83%88%2015832%20(15.4%20KiB)%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20%E9%80%81%E4%BF%A1%E3%82%A8%E3%83%A9%E3%83%BC%200%20%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%200%20%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%A9%E3%83%B3%200%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%200%20%E8%A1%9D%E7%AA%81%200%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%A1%E3%83%A2%E3%83%AA%200x46000000-46ffffff%3C%2FEM%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eping%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CP%3E%3CEM%3Eroot%40s32g274ardb2%3A%2F%23%20192.168.0.11%20%E3%81%ABping%E3%82%92%E5%AE%9F%E8%A1%8C%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EPING%20192.168.0.11%20(192.168.0.11)%2056(84)%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E192.168.0.12%20icmp_seq%3D1%20%E5%AE%9B%E5%85%88%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3Eping%3A%20sendmsg%3A%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%B8%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E192.168.0.12%20icmp_seq%3D2%20%E5%AE%9B%E5%85%88%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E192.168.0.12%20icmp_seq%3D3%20%E5%AE%9B%E5%85%88%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AB%E5%88%B0%E9%81%94%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FEM%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPFE%20%E3%81%8C%20GMAC%20%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FPFE%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E4%BD%BF%E3%81%84%E6%96%B9%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB2(s32g274a)%20board%20PFE%20network%20ping%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256633%22%20target%3D%22_blank%22%3E%40waitewang%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ERDB2%20%E3%81%A7%20BSP44%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%89%BF%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AC%A1%E3%81%AE%E7%82%B9%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BA%8B%E5%89%8D%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%9F%20BSP%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E8%87%AA%E5%88%86%E3%81%A7%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E2.%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%B7%E3%82%A7%E3%83%AB%E3%81%BE%E3%81%A7%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AA%E5%95%8F%E9%A1%8C%E5%88%86%E6%9E%90%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2294612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G-VNP-RDB2(s32g274a)%20board%20PFE%20network%20ping%20failed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2294612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%EF%BC%88%EF%BC%91%EF%BC%89NXP%E3%81%AE%E5%85%AC%E5%BC%8F%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%EF%BC%92%EF%BC%89%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22waitewang_0-1768525603975.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22waitewang_0-1768525603975.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373068i3003BE384EE4E585%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22waitewang_0-1768525603975.png%22%20alt%3D%22waitewang_0-1768525603975.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%8B%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
