S32G IPCF LLCE examples
3,006 次查看
chansookang
I am using S32G274A rdb2, S32DS 3.5, LLCE 1.0.9, IPCF SW32G_IPCF_4.10.0_D2405
I checked both Can_Llce_DS_Loopback_S32G274A_M7 , IPCF_Example_S32G274A_M7_0  working well.
So I add ipcf module in Can_Llce_DS_Loopback_S32G274A_M7, and configured same as the ipcf example. I also changed the main.c and Linker file as ipcf. (LLCE will not work but my objective is to make ipcf work in CAN LLCE example)
I also defined "MPU_DISABLE".
But the same log below is printing
[ 22.685977] ipc-shm-sample: starting demo...
[ 22.686011] ipc-shm-sample: ch 0 >> 20 bytes: SENDING MESSAGES: 10
[ 22.686024] ipc-shm-sample: send_ctrl_msg(): tx failed on control channel
标记 (1)
2,993 次查看
Joey_z
hi,chansookang
Thank you for cantacting us.
Do you use the multi-core mode for RDB2? Which is the version of BSP are your using?
And do you use the bootloader to boot both M core and A core?
Joey
5 回复数
2,591 次查看
honeybee1881
I am also facing the same issue what is the solution?
2,563 次查看
chansookang
define "D_CACHE_ENABLE_NOT" in preprocessor
2,999 次查看
chansookang
I checked ipcf working by defining "D_CACHE_ENABLE_NOT" but i am not sure what this will change the operation of LLCE example
2,994 次查看
Joey_z
hi,chansookang
Joey
2,906 次查看
chansookang
Sorry for late response. I solved it.
Thank you
%3CLINGO-SUB%20id%3D%22lingo-sub-2150759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G%20IPCF%20LLCE%20%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20S32G274A%20rdb2%E3%80%81S32DS%203.5%20%E5%92%8C%20LLCE%201.0.9%E3%80%81IPCF%20SW32G_IPCF_4.10.0_D2405%3C%2FP%3E%3CP%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20Can_Llce_DS_Loopback_S32G274A_M7%20%2C%20IPCF_Example_S32G274A_M7_0%20%E9%83%BD%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E5%9C%A8%20Can_Llce_DS_Loopback_S32G274A_M7%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%20ipcf%20%E6%A8%A1%E5%9D%97%EF%BC%8C%E5%B9%B6%E6%8C%89%E7%85%A7%20ipcf%20%E7%A4%BA%E4%BE%8B%E8%BF%9B%E8%A1%8C%E4%BA%86%E9%85%8D%E7%BD%AE%E3%80%82%E6%88%91%E8%BF%98%E4%BF%AE%E6%94%B9%E4%BA%86%20main.c%3CSPAN%3E%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%B8%BA%20ipcf%E3%80%82(LLCE%20%E5%B0%86%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E6%98%AF%E8%AE%A9%20ipcf%20%E5%9C%A8%20CAN%20LLCE%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E5%B7%A5%E4%BD%9C%EF%BC%89%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E8%BF%98%E5%AE%9A%E4%B9%89%E4%BA%86%22MPU_DISABLE%22%20%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E4%B8%8B%E9%9D%A2%E6%89%93%E5%8D%B0%E7%9A%84%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%E6%97%A5%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%5B22.685977%5D%20ipc-shm-sample%EF%BC%9A%E5%BC%80%E5%A7%8B%E6%BC%94%E7%A4%BA...%3CBR%20%2F%3E%5B22.686011%5D%20ipc-shm-sample%EF%BC%9Ach%200%20%26gt%3B%20%26gt%3B%2020%20%E5%AD%97%E8%8A%82%EF%BC%9A%E5%8F%91%E9%80%81%E6%B6%88%E6%81%AF%EF%BC%9A10%20%3CBR%20%2F%3E%20%5B22.686024%5D%20ipc-shm-sample%EF%BC%9Asend_ctrl_msg%20()%EF%BC%9A%E6%8E%A7%E5%88%B6%E9%80%9A%E9%81%93%E5%8F%91%E9%80%81%E5%A4%B1%E8%B4%A5%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%E9%A2%84%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%AD%E5%AE%9A%E4%B9%89%22D_CACHE_ENABLE_NOT%22%20%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%9C%89%E4%BB%80%E4%B9%88%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%E6%88%91%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%EF%BC%8Cchansookang%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%8E%E6%88%91%E4%BB%AC%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%20RDB2%20%E7%9A%84%E5%A4%9A%E6%A0%B8%E6%A8%A1%E5%BC%8F%E5%90%97%EF%BC%9F%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%90%8C%E6%97%B6%E5%90%AF%E5%8A%A8%20M%20%E5%86%85%E6%A0%B8%E5%92%8C%20A%20%E5%86%85%E6%A0%B8%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E9%80%9A%E8%BF%87%E5%AE%9A%E4%B9%89%22D_CACHE_ENABLE_NOT%22%20%E6%A3%80%E6%9F%A5%E4%BA%86%20ipcf%20%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%83%85%E5%86%B5%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E8%BF%99%E4%BC%9A%E5%AF%B9%20LLCE%20%E7%A4%BA%E4%BE%8B%E7%9A%84%E8%BF%90%E8%A1%8C%E4%BA%A7%E7%94%9F%E4%BB%80%E4%B9%88%E5%BD%B1%E5%93%8D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
