S32G IPCF LLCE examples
chansookang
I am using S32G274A rdb2, S32DS 3.5, LLCE 1.0.9, IPCF SW32G_IPCF_4.10.0_D2405
I checked both Can_Llce_DS_Loopback_S32G274A_M7 , IPCF_Example_S32G274A_M7_0  working well.
So I add ipcf module in Can_Llce_DS_Loopback_S32G274A_M7, and configured same as the ipcf example. I also changed the main.c and Linker file as ipcf. (LLCE will not work but my objective is to make ipcf work in CAN LLCE example)
I also defined "MPU_DISABLE".
But the same log below is printing
[ 22.685977] ipc-shm-sample: starting demo...
[ 22.686011] ipc-shm-sample: ch 0 >> 20 bytes: SENDING MESSAGES: 10
[ 22.686024] ipc-shm-sample: send_ctrl_msg(): tx failed on control channel
Joey_z
hi,chansookang
Thank you for cantacting us.
Do you use the multi-core mode for RDB2? Which is the version of BSP are your using?
And do you use the bootloader to boot both M core and A core?
Joey
honeybee1881
I am also facing the same issue what is the solution?
chansookang
define "D_CACHE_ENABLE_NOT" in preprocessor
chansookang
I checked ipcf working by defining "D_CACHE_ENABLE_NOT" but i am not sure what this will change the operation of LLCE example
Joey_z
hi,chansookang
Joey
chansookang
Sorry for late response. I solved it.
Thank you
%3CLINGO-SUB%20id%3D%22lingo-sub-2150759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20using%20S32G274A%20rdb2%2C%20S32DS%203.5%2C%20LLCE%201.0.9%2C%20IPCF%26nbsp%3BSW32G_IPCF_4.10.0_D2405%3C%2FP%3E%3CP%3EI%20checked%20both%20Can_Llce_DS_Loopback_S32G274A_M7%20%2C%20IPCF_Example_S32G274A_M7_0%26nbsp%3B%20working%20well.%3C%2FP%3E%3CP%3ESo%20I%20add%20ipcf%20module%20in%26nbsp%3BCan_Llce_DS_Loopback_S32G274A_M7%2C%20and%20configured%20same%20as%20the%20ipcf%20example.%20I%20also%20changed%20the%20main.c%20and%26nbsp%3B%3CSPAN%3ELinker%20file%20as%20ipcf.%20(LLCE%20will%20not%20work%20but%20my%20objective%20is%20to%20make%20ipcf%20work%20in%20CAN%20LLCE%20example)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20also%20defined%20%22MPU_DISABLE%22.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBut%20the%20same%20log%20below%20is%20printing%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%5B%2022.685977%5D%20ipc-shm-sample%3A%20starting%20demo...%3CBR%20%2F%3E%5B%2022.686011%5D%20ipc-shm-sample%3A%20ch%200%20%26gt%3B%26gt%3B%2020%20bytes%3A%20SENDING%20MESSAGES%3A%2010%3CBR%20%2F%3E%5B%2022.686024%5D%20ipc-shm-sample%3A%20send_ctrl_msg()%3A%20tx%20failed%20on%20control%20channel%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Edefine%20%22D_CACHE_ENABLE_NOT%22%20in%20preprocessor%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161465%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20also%20facing%20the%20same%20issue%20what%20is%20the%20solution%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESorry%20for%20late%20response.%20I%20solved%20it.%3CBR%20%2F%3EThank%20you%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%EF%BC%8C%3CSPAN%3Echansookang%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20cantacting%20us.%3C%2FP%3E%0A%3CP%3EDo%20you%20use%20the%20multi-core%20mode%20for%20RDB2%3F%20Which%20is%20the%20version%20of%20BSP%20are%20your%20using%3F%3C%2FP%3E%0A%3CP%3EAnd%20do%20you%20use%20the%20bootloader%20to%20boot%20both%20M%20core%20and%20A%20core%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32G%20IPCF%20LLCE%20examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20checked%20ipcf%20working%20by%20defining%20%22D_CACHE_ENABLE_NOT%22%20but%20i%20am%20not%20sure%20what%20this%20will%20change%20the%20operation%20of%20LLCE%20example%3C%2FP%3E%3C%2FLINGO-BODY%3E
