S32G DC electricals
S32G DC electricals
1,289 次查看
yangmingsong
破坏者
破坏者
   The customer has started to design S32G, but some key information is missing in the downloaded materials, please help to support it,. The specific information is as follows:
    In S32G datasheet, Chapter 9 DC electricals only provides the total core voltage power, without detailed power supply values and voltage fluctuation range. Could you please provide more specific data about power supply design?
1,282 次查看
Daniel-Aguirre
For power supply design under the S32G2 platform, there is an Application Note (AN13299: S32G2 Power Estimations Application Note) we recommend looking.
As for "power supply values and voltage fluctuation range", could you please elaborate more on the details? The datasheet shows the voltage needed for the specific power domains and the range they should stay between [Table 4, Page 13, S32G2 Data Sheet, Rev. 6, 12/2022].
Please, let us know.
