PTP using RTD GMAC Driver
yanis-waabi
I'm trying to setup the S32G GMAC0 as a ptp master on the M7 cores.
I'm using RTD driver for GMAC. I could find the function to enable timestamping and correcting the clock but I couldn't find any function related to enabling PTP offloading.
Is there an RTD driver that allows that, or do I have to manually setup the various registers.
If so can you give me the list of register to set to make it act as a ptp master ?
Tags (3)
rizwan_at_disruptdotcom
@yanis-waabi @carlos_o Is there an update on this thread? Do we have a GMAC port for S32G3 gPTP stack? If not then can you please provide details on what changes will be required to reliably port gPTP stack to GMAC for S32G3?
yanis-waabi
Thank you for your quick response.
It seems the doc you shared is for using the PFE with PTP. But I want to use instead the GMAC which provide functions to offload the PTP messaging, controlled by GMAC_MAC_PTO_CONTROL register for instance.
Is there somewhere a high level API that I could use for that ?
carlos_o
Hi @yanis-waabi
You could use the PTP functionality with the linux BSP distributions to run it with GMAC
please refer to the Linux BSP 42.0 User Manual for S32G3 platforms (or the BSP Version you use) at chapter 8
Otherwise, you need to do your own implementation if you want to do it with the RTDs.
carlos_o
Hi @yanis-waabi,
Thanks for your question.
You could find a Reference Software of the Automotive SW - S32G - gPTP Stack at Flexera, the package you have an example that has a function to initialize the PTP Stack
Also refers to the gPTP S32G User Manual that is included when you download the package, there you could see the prerequisites to run the example.
Let me know if you have more questions about this topic.
%3CLINGO-SUB%20id%3D%22lingo-sub-2085944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPTP%20using%20RTD%20GMAC%20Driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2085944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI'm%20trying%20to%20setup%20the%20S32G%20GMAC0%20as%20a%20ptp%20master%20on%20the%20M7%20cores.%3CBR%20%2F%3EI'm%20using%20RTD%20driver%20for%20GMAC.%20I%20could%20find%20the%20function%20to%20enable%20timestamping%20and%20correcting%20the%20clock%20but%20I%20couldn't%20find%20any%20function%20related%20to%20enabling%20PTP%20offloading.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20an%20RTD%20driver%20that%20allows%20that%2C%20or%20do%20I%20have%20to%20manually%20setup%20the%20various%20registers.%3CBR%20%2F%3EIf%20so%20can%20you%20give%20me%20the%20list%20of%20register%20to%20set%20to%20make%20it%20act%20as%20a%20ptp%20master%20%3F%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2306032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PTP%20using%20RTD%20GMAC%20Driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2306032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245960%22%20target%3D%22_blank%22%3E%40yanis-waabi%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%26nbsp%3BIs%20there%20an%20update%20on%20this%20thread%3F%20Do%20we%20have%20a%20GMAC%20port%20for%20S32G3%20gPTP%20stack%3F%20If%20not%20then%20can%20you%20please%20provide%20details%20on%20what%20changes%20will%20be%20required%20to%20reliably%20port%20gPTP%20stack%20to%20GMAC%20for%20S32G3%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2086880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PTP%20using%20RTD%20GMAC%20Driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2086880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245960%22%20target%3D%22_blank%22%3E%40yanis-waabi%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYou%20could%20use%20the%20PTP%20functionality%20with%20the%20linux%20BSP%20distributions%20to%20run%20it%20with%20GMAC%3C%2FP%3E%0A%3CP%3Eplease%20refer%20to%20the%3CSTRONG%3E%26nbsp%3BLinux%20BSP%2042.0%20User%20Manual%20for%20S32G3%20platforms%20(or%20the%20BSP%20Version%20you%20use)%26nbsp%3B%3C%2FSTRONG%3Eat%20chapter%208%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carlos_o_0-1745527441967.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_0-1745527441967.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334809i02D908CCA5E62230%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22carlos_o_0-1745527441967.png%22%20alt%3D%22carlos_o_0-1745527441967.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_0-1745527441967.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EOtherwise%2C%20you%20need%20to%20do%20your%20own%20implementation%20if%20you%20want%20to%20do%20it%20with%20the%20RTDs.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2086045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PTP%20using%20RTD%20GMAC%20Driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2086045%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20quick%20response.%3CBR%20%2F%3EIt%20seems%20the%20doc%20you%20shared%20is%20for%20using%20the%20PFE%20with%20PTP.%20But%20I%20want%20to%20use%20instead%20the%20GMAC%20which%20provide%20functions%20to%20offload%20the%20PTP%20messaging%2C%20controlled%20by%26nbsp%3BGMAC_MAC_PTO_CONTROL%20register%20for%20instance.%3CBR%20%2F%3EIs%20there%20somewhere%20a%20high%20level%20API%20that%20I%20could%20use%20for%20that%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2086039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PTP%20using%20RTD%20GMAC%20Driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2086039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F245960%22%20target%3D%22_blank%22%3E%40yanis-waabi%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20question.%3C%2FP%3E%0A%3CP%3EYou%20could%20find%20a%20Reference%20Software%20of%20the%26nbsp%3B%3CSTRONG%3EAutomotive%20SW%20-%20S32G%20-%20gPTP%20Stack%26nbsp%3B%3C%2FSTRONG%3Eat%20Flexera%2C%20the%20package%20you%20have%20an%20example%20that%20has%20a%20function%20to%20initialize%20the%20PTP%20Stack%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22carlos_o_0-1745449144476.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22carlos_o_0-1745449144476.png%22%20style%3D%22width%3A%20332px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F334562i3E3F1FA5A9E96C7A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22carlos_o_0-1745449144476.png%22%20alt%3D%22carlos_o_0-1745449144476.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecarlos_o_0-1745449144476.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAlso%20refers%20to%20the%26nbsp%3B%3CSTRONG%3EgPTP%20S32G%20User%20Manual%26nbsp%3B%3C%2FSTRONG%3Ethat%20is%20included%20when%20you%20download%20the%20package%2C%20there%20you%20could%20see%20the%20prerequisites%20to%20run%20the%20example.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELet%20me%20know%20if%20you%20have%20more%20questions%20about%20this%20topic.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
