PFE Master/Slave - Set up M7 Master Network
4,458 次查看
GuilhermeS32G
Dear NXP fellows,
This question is a sequel to my previous topic:
Questions regarding multi-core networking in S32G399A
Right now, I have enabled PFE Master/Slave on our custom board based on S32G399A-RDB3 by appending pfe-slave to the Yocto distro-features:
DISTRO_FEATURES:append = " pfe pfe-slave"
This enables the PFE Slave to run on the A53 cores (Linux BSP).
On the slave side, it seems to be working as expected, I can assign IP addresses to the three PFE interfaces and the ping is working from both sides.
For your reference, the command libfci_cli phyif-print returns:
DISCLAIMER: This is a DEMO application. It is not part of the production code deliverables.
 0: emac0
      <ENABLED>
      <promisc:OFF, mode:DEFAULT, block-state:NORMAL>
      <vlan-conf:OFF, ptp-conf:OFF, ptp-promisc:OFF, q-in-q:ON>
      <discard-if-ttl-below-2:OFF, fast-forward-all-tcp:ON>
      ingress: 57 egress: 45 discarded: 0 malformed: 0
      flexible-filter: ---
      ptp-mgmt-if: ---
      MAC:
          00:04:9f:be:ef:00
          33:33:00:00:00:01
          01:00:5e:00:00:01
          33:33:ff:be:ef:00
          01:80:c2:00:00:00
          01:80:c2:00:00:03
          01:80:c2:00:00:0e
          33:33:00:01:00:03
          01:00:5e:00:00:fc
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       0: emac0
            <ENABLED>
            <promisc:ON, match-mode:AND, discard-on-match:OFF>
            accepted: 57 rejected: 0 discarded: 0 processed: 57
            egress: hif0
            match-rules: ---
 1: emac1
      <ENABLED>
      ingress: 75 egress: 53 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC:
          00:04:9f:be:ef:01
          33:33:00:00:00:01
          01:00:5e:00:00:01
          33:33:ff:be:ef:01
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       1: emac1
            <ENABLED>
            accepted: 75 rejected: 0 discarded: 0 processed: 75
            egress: hif1
            match-rules: ---
 2: emac2
      <ENABLED>
      ingress: 13 egress: 37 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC:
          00:04:9f:be:ef:02
          33:33:00:00:00:01
          01:00:5e:00:00:01
          33:33:ff:be:ef:02
          01:80:c2:00:00:00
          01:80:c2:00:00:03
          01:80:c2:00:00:0e
          01:00:5e:00:00:fc
          33:33:00:01:00:03
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       2: emac2
            <ENABLED>
            accepted: 13 rejected: 0 discarded: 0 processed: 13
            egress: hif2
            match-rules: ---
 5: util
      <DISABLED>
      ingress: 0 egress: 0 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces: ---
 6: hif0
      <ENABLED>
      ingress: 105 egress: 57 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       3: hif0
            <ENABLED>
            accepted: 29 rejected: 0 discarded: 0 processed: 29
            egress: ---
            match-rules: ---
 7: hif1
      <ENABLED>
      ingress: 53 egress: 75 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       4: hif1
            <ENABLED>
            accepted: 0 rejected: 0 discarded: 0 processed: 0
            egress: ---
            match-rules: ---
 8: hif2
      <ENABLED>
      ingress: 37 egress: 13 discarded: 0 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       5: hif2
            <ENABLED>
            egress: ---
            match-rules: ---
 9: hif3
      <DISABLED>
      ingress: 0 egress: 0 discarded: 31 malformed: 0
      ptp-mgmt-if: ---
      MAC: ---
      mirrors:
          rxmirr0: ---
          rxmirr1: ---
          txmirr0: ---
          txmirr1: ---
      logical interfaces:
       6: hif3
            <ENABLED>
            egress: ---
            match-rules: ---
Command successfully executed.
 and the command libfci_cli logif-print returns:
 0: emac0
      <ENABLED>
      parent: emac0
      egress: hif0
      match-rules: ---
 1: emac1
      <ENABLED>
      parent: emac1
      egress: hif1
      match-rules: ---
 2: emac2
      <ENABLED>
      parent: emac2
      egress: hif2
      match-rules: ---
 3: hif0
      <ENABLED>
      parent: hif0
      egress: ---
      match-rules: ---
 4: hif1
      <ENABLED>
      parent: hif1
      egress: ---
      match-rules: ---
 5: hif2
      <ENABLED>
      parent: hif2
      egress: ---
      match-rules: ---
 6: hif3
      <ENABLED>
      parent: hif3
      egress: ---
      match-rules: ---
However, I would like to configure the M7 core PFE-master now.
My questions are:
  • Can I assign an IP address to the PFE Master from the PFE Slave (BSP)?
  • Do I need to use the EB Tresos PFE-DRV_S32G_M7_MCAL sample application for configuring the M7 core networking?
  • Does it require to connect the S32G Debug Probe to the board in order to access the M7 core?
Thank you for your support!
Guilherme
4,420 次查看
Joey_z
hi,GuilhermeS32G
To configure PFE-master for M7 core, you can refer to the PFE-DRV_S32G_M7_MCAL package MasterProject_RDB3 project. In the meantime, you can refer to the readme for more details to complete the setup. You can set IP_ADDRESS_CTRL_0 to set the IP address . RTD drivers must be installed, copy the installed RTD driver plugins and PFE driver plugin to Tresos plugins directory. Also, Run and debug the application with Lauterbach TRACE32.
Joey
6 回复数
4,421 次查看
Joey_z
hi,GuilhermeS32G
Joey
4,416 次查看
GuilhermeS32G
Hello @Joey_z ,
Thank you for your reply.
I see, so that means I require the Lauterbach Trace32 debugger and the EB Tresos Studio IDE for successfully running this example.
Do you know if there is any movement inside NXP to migrate the PFE-DRV_S32G_M7_MCAL software to the S32 Design Studio IDE and supporting the S32 Debug Probe instead?
Guilherme
4,407 次查看
Joey_z
hi,GuilhermeS32G
It is recommended that you debug using Lauterbach Trace32 according to readme.txt requirements. The S32 Debug Probe can be debuggable by loading .elf files, but this is  unstable and does not ensure that you can debug successfully, you can see the following way.
If the following problems occur, try loading the main.c file.
Joey
4,402 次查看
GuilhermeS32G
Hello @Joey_z ,
Thank you for your explanation.
I can see that the latest releases of the S32G Real-Time Driver AUTOSAR 4.4 for Cortex-M7 can be configured, built, and debugged using the S32 Design Studio. However, the S32G PFE MCAL 4.4 driver still requires EB Tresos Studio.
Is there any work in progress to make the future releases of the S32G PFE MCAL driver compatible with the S32 Design Studio?
Thanks again.
Guilherme
4,400 次查看
Joey_z
hi,GuilhermeS32G
PFE MCAL driver does not have this function, thank you for your suggestion, I will report this problem.
Joey
4,395 次查看
GuilhermeS32G
Hello @Joey_z ,
Ok, thank you very much.
Guilherme
%3CLINGO-SUB%20id%3D%22lingo-sub-1986630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPFE%20%E4%B8%BB%2F%E4%BB%8E%20-%20%E8%AE%BE%E7%BD%AE%20M7%20%E4%B8%BB%E7%BD%91%E7%BB%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1986630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%8A%E6%95%AC%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E5%90%84%E4%BD%8D%E5%90%8C%E4%BB%81%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%E6%88%91%E4%B8%8A%E4%B8%80%E4%B8%AA%E4%B8%BB%E9%A2%98%E7%9A%84%E5%90%8E%E7%BB%AD%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2FQuestions-regarding-multi-core-networking-in-S32G399A%2Fm-p%2F1973875%2Fhighlight%2Ftrue%23M11229%22%20target%3D%22_self%22%3E%E5%85%B3%E4%BA%8ES32G399A%E5%A4%9A%E6%A0%B8%E7%BD%91%E7%BB%9C%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E9%80%9A%E8%BF%87%E5%B0%86%20pfe-slave%20%E9%99%84%E5%8A%A0%E5%88%B0%20Yocto%20%E5%8F%91%E8%A1%8C%E7%89%88%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%9C%A8%E5%9F%BA%E4%BA%8E%20S32G399A-RDB3%20%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%E5%90%AF%E7%94%A8%E4%BA%86%20PFE%20Master%2FSlave%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EDISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe%20pfe-slave%22%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E8%BF%99%E4%BD%BF%E5%BE%97%20PFE%20Slave%20%E8%83%BD%E5%A4%9F%E5%9C%A8%20A53%20%E5%86%85%E6%A0%B8%EF%BC%88Linux%20BSP%EF%BC%89%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%BB%8E%E5%B1%9E%E7%AB%AF%EF%BC%8C%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%8C%89%E9%A2%84%E6%9C%9F%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%B8%BA%E4%B8%89%E4%B8%AA%20PFE%20%E6%8E%A5%E5%8F%A3%E5%88%86%E9%85%8D%20IP%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%B9%B6%E4%B8%94%20ping%20%E4%BB%8E%E4%B8%A4%E4%BE%A7%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%EF%BC%8C%E5%91%BD%E4%BB%A4%3CEM%3Elibfci_cli%20phyif-print%3C%2FEM%3E%E8%BF%94%E5%9B%9E%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EDISCLAIMER%3A%20This%20is%20a%20DEMO%20application.%20It%20is%20not%20part%20of%20the%20production%20code%20deliverables.%0A%200%3A%20emac0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2057%20egress%3A%2045%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%0A%20%20%20%20%20%20%20%20%20%2000%3A04%3A9f%3Abe%3Aef%3A00%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3Aff%3Abe%3Aef%3A00%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A00%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A03%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A0e%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A01%3A00%3A03%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3Afc%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%200%3A%20emac0%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2057%20rejected%3A%200%20discarded%3A%200%20processed%3A%2057%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20hif0%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%201%3A%20emac1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2075%20egress%3A%2053%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%0A%20%20%20%20%20%20%20%20%20%2000%3A04%3A9f%3Abe%3Aef%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3Aff%3Abe%3Aef%3A01%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%201%3A%20emac1%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2075%20rejected%3A%200%20discarded%3A%200%20processed%3A%2075%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20hif1%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%202%3A%20emac2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2013%20egress%3A%2037%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%0A%20%20%20%20%20%20%20%20%20%2000%3A04%3A9f%3Abe%3Aef%3A02%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3A01%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3Aff%3Abe%3Aef%3A02%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A00%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A03%0A%20%20%20%20%20%20%20%20%20%2001%3A80%3Ac2%3A00%3A00%3A0e%0A%20%20%20%20%20%20%20%20%20%2001%3A00%3A5e%3A00%3A00%3Afc%0A%20%20%20%20%20%20%20%20%20%2033%3A33%3A00%3A01%3A00%3A03%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%202%3A%20emac2%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2013%20rejected%3A%200%20discarded%3A%200%20processed%3A%2013%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20hif2%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%205%3A%20util%0A%20%20%20%20%20%20%3CDISABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%200%20egress%3A%200%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%20---%0A%206%3A%20hif0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%20105%20egress%3A%2057%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%203%3A%20hif0%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%2029%20rejected%3A%200%20discarded%3A%200%20processed%3A%2029%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%207%3A%20hif1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2053%20egress%3A%2075%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%204%3A%20hif1%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%208%3A%20hif2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%2037%20egress%3A%2013%20discarded%3A%200%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%205%3A%20hif2%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0A%209%3A%20hif3%0A%20%20%20%20%20%20%3CDISABLED%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20%3COFF%3E%0A%20%20%20%20%20%20ingress%3A%200%20egress%3A%200%20discarded%3A%2031%20malformed%3A%200%0A%20%20%20%20%20%20flexible-filter%3A%20---%0A%20%20%20%20%20%20ptp-mgmt-if%3A%20---%0A%20%20%20%20%20%20MAC%3A%20---%0A%20%20%20%20%20%20mirrors%3A%0A%20%20%20%20%20%20%20%20%20%20rxmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20rxmirr1%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr0%3A%20---%0A%20%20%20%20%20%20%20%20%20%20txmirr1%3A%20---%0A%20%20%20%20%20%20logical%20interfaces%3A%0A%20%20%20%20%20%20%206%3A%20hif3%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20%20%20%20%20%20%20match-rules%3A%20---%0ACommand%20successfully%20executed.%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FDISABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FDISABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FOFF%3E%3C%2FENABLED%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E5%91%BD%E4%BB%A4%3CEM%3Elibfci_cli%20logif-print%3C%2FEM%3E%E8%BF%94%E5%9B%9E%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EDISCLAIMER%3A%20This%20is%20a%20DEMO%20application.%20It%20is%20not%20part%20of%20the%20production%20code%20deliverables.%0A%200%3A%20emac0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2057%20rejected%3A%200%20discarded%3A%200%20processed%3A%2057%0A%20%20%20%20%20%20parent%3A%20emac0%0A%20%20%20%20%20%20egress%3A%20hif0%0A%20%20%20%20%20%20match-rules%3A%20---%0A%201%3A%20emac1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2075%20rejected%3A%200%20discarded%3A%200%20processed%3A%2075%0A%20%20%20%20%20%20parent%3A%20emac1%0A%20%20%20%20%20%20egress%3A%20hif1%0A%20%20%20%20%20%20match-rules%3A%20---%0A%202%3A%20emac2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2013%20rejected%3A%200%20discarded%3A%200%20processed%3A%2013%0A%20%20%20%20%20%20parent%3A%20emac2%0A%20%20%20%20%20%20egress%3A%20hif2%0A%20%20%20%20%20%20match-rules%3A%20---%0A%203%3A%20hif0%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%2029%20rejected%3A%200%20discarded%3A%200%20processed%3A%2029%0A%20%20%20%20%20%20parent%3A%20hif0%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0A%204%3A%20hif1%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20parent%3A%20hif1%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0A%205%3A%20hif2%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20parent%3A%20hif2%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0A%206%3A%20hif3%0A%20%20%20%20%20%20%3CENABLED%3E%0A%20%20%20%20%20%20%3CON%3E%0A%20%20%20%20%20%20accepted%3A%200%20rejected%3A%200%20discarded%3A%200%20processed%3A%200%0A%20%20%20%20%20%20parent%3A%20hif3%0A%20%20%20%20%20%20egress%3A%20---%0A%20%20%20%20%20%20match-rules%3A%20---%0ACommand%20successfully%20executed.%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FON%3E%3C%2FENABLED%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E6%83%B3%E9%85%8D%E7%BD%AE%20M7%20%E6%A0%B8%E5%BF%83%20PFE-master%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BB%8E%20PFE%20%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%EF%BC%88BSP%EF%BC%89%E4%B8%BA%20PFE%20%E4%B8%BB%E8%AE%BE%E5%A4%87%E5%88%86%E9%85%8D%20IP%20%E5%9C%B0%E5%9D%80%E5%90%97%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20EB%20Tresos%20PFE-DRV_S32G_M7_MCAL%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%9D%A5%E9%85%8D%E7%BD%AE%20M7%20%E6%A0%B8%E5%BF%83%E7%BD%91%E7%BB%9C%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%B0%86%20S32G%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%BC%80%E5%8F%91%E6%9D%BF%E6%89%8D%E8%83%BD%E8%AE%BF%E9%97%AE%20M7%20%E6%A0%B8%E5%BF%83%EF%BC%9F%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E4%B8%BB%2F%E4%BB%8E%20-%20%E8%AE%BE%E7%BD%AE%20M7%20%E4%B8%BB%E7%BD%91%E7%BB%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E4%B8%BB%2F%E4%BB%8E%20-%20%E8%AE%BE%E7%BD%AE%20M7%20%E4%B8%BB%E7%BD%91%E7%BB%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3CSPAN%3EGuilhermeS32G%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3CBR%20%2F%3EPFE%20MCAL%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%B2%A1%E6%9C%89%E6%AD%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E4%BC%9A%E6%8A%A5%E5%91%8A%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E4%B8%BB%2F%E4%BB%8E%20-%20%E8%AE%BE%E7%BD%AE%20M7%20%E4%B8%BB%E7%BD%91%E7%BB%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E8%A7%A3%E9%87%8A%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20S32%20Design%20Studio%20%E9%85%8D%E7%BD%AE%E3%80%81%E6%9E%84%E5%BB%BA%E5%92%8C%E8%B0%83%E8%AF%95%E9%80%82%E7%94%A8%E4%BA%8E%20Cortex-M7%20%E7%9A%84%20S32G%20%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20AUTOSAR%204.4%20%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8CS32G%20PFE%20MCAL%204.4%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%8D%E7%84%B6%E9%9C%80%E8%A6%81%20EB%20Tresos%20Studio%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E7%9A%84%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BB%A5%E4%BD%BF%20S32G%20PFE%20MCAL%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%9C%AA%E6%9D%A5%E7%89%88%E6%9C%AC%E4%B8%8E%20S32%20Design%20Studio%20%E5%85%BC%E5%AE%B9%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1989886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E4%B8%BB%2F%E4%BB%8E%20-%20%E8%AE%BE%E7%BD%AE%20M7%20%E4%B8%BB%E7%BD%91%E7%BB%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1989886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%3Ehi%2C%3CSPAN%3EGuilhermeS32G%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%8C%89%E7%85%A7readme.txt%E7%9A%84%E8%A6%81%E6%B1%82%E4%BD%BF%E7%94%A8Lauterbach%20Trace32%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E3%80%82S32%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%8A%A0%E8%BD%BD%20.elf%20%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%98%AF%E8%BF%99%E4%B8%AA%E4%B8%8D%E7%A8%B3%E5%AE%9A%EF%BC%8C%E4%B8%8D%E4%BF%9D%E8%AF%81%E4%BD%A0%E8%83%BD%E8%B0%83%E8%AF%95%E6%88%90%E5%8A%9F%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9C%8B%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1730964157981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1730964157981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309135i23D5919FEEFD2389%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1730964157981.png%22%20alt%3D%22Joey_z_0-1730964157981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1730964169114.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1730964169114.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309137i23FA1A2B4DFB64EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1730964169114.png%22%20alt%3D%22Joey_z_1-1730964169114.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%8A%A0%E8%BD%BDmain.c%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_2-1730964191889.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_2-1730964191889.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309138i7F0C974F8AE0AC4C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_2-1730964191889.png%22%20alt%3D%22Joey_z_2-1730964191889.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1988628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E4%B8%BB%2F%E4%BB%8E%20-%20%E8%AE%BE%E7%BD%AE%20M7%20%E4%B8%BB%E7%BD%91%E7%BB%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988628%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%20%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%88%91%E9%9C%80%E8%A6%81%20Lauterbach%20Trace32%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%92%8C%20EB%20Tresos%20Studio%20IDE%20%E6%89%8D%E8%83%BD%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E6%AD%A4%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E7%9F%A5%E9%81%93%20NXP%20%E5%86%85%E9%83%A8%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8A%A8%E5%90%91%EF%BC%8C%E5%B0%86%20PFE-DRV_S32G_M7_MCAL%20%E8%BD%AF%E4%BB%B6%E8%BF%81%E7%A7%BB%E5%88%B0%20S32%20Design%20Studio%20IDE%20%E5%B9%B6%E6%94%AF%E6%8C%81%20S32%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EGuilherme%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1988593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APFE%20%E4%B8%BB%2F%E4%BB%8E%20-%20%E8%AE%BE%E7%BD%AE%20M7%20%E4%B8%BB%E7%BD%91%E7%BB%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1988593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3CSPAN%3EGuilhermeS32G%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E4%B8%BA%20M7%20%E6%A0%B8%E5%BF%83%E9%85%8D%E7%BD%AE%20PFE-master%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%20PFE-DRV_S32G_M7_MCAL%20%E5%8C%85%20MasterProject_RDB3%20%E9%A1%B9%E7%9B%AE%E3%80%82%E5%90%8C%E6%97%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E8%87%AA%E8%BF%B0%E6%96%87%E4%BB%B6%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E6%9D%A5%E5%AE%8C%E6%88%90%E8%AE%BE%E7%BD%AE%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AEIP_ADDRESS_CTRL_0%E6%9D%A5%E8%AE%BE%E7%BD%AEIP%E5%9C%B0%E5%9D%80%E3%80%82%E5%BF%85%E9%A1%BB%E5%AE%89%E8%A3%85%20RTD%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%B0%86%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%20RTD%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8F%92%E4%BB%B6%E5%92%8C%20PFE%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8F%92%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%20Tresos%20%E6%8F%92%E4%BB%B6%E7%9B%AE%E5%BD%95%E3%80%82%E5%8F%A6%E5%A4%96%EF%BC%8C%E4%BD%BF%E7%94%A8%20Lauterbach%20TRACE32%20%E8%BF%90%E8%A1%8C%E5%92%8C%E8%B0%83%E8%AF%95%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_0-1730879600804.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_0-1730879600804.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308870i8963C4831AB8EA96%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_0-1730879600804.png%22%20alt%3D%22Joey_z_0-1730879600804.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1730879608076.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1730879608076.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F308871iB28DDC1286F2372D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1730879608076.png%22%20alt%3D%22Joey_z_1-1730879608076.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E4%B9%94%E4%BC%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E
