Missing ECU Resource Definitions for Crypto Module (HSE plugin – S32G3) in EB Tresos
Sunilap
Hello NXP Team,
I am working on S32G3 Bootloader (Bootloader_S32G3XX_ASR_4.4_M7) using EB Tresos Studio with the Crypto module (HSE integration).
While configuring Crypto.xdm, I see errors related to missing ECU resource properties:
  • Crypto.HseFwTypes.List
  • Crypto.MuInstances.List
  • Crypto.SupportedPrimitives
  • Crypto.HseMaxNumOfKeyGroups.*
Example error:
Invalid XPath-expression: The requested ECU resource property "Crypto.HseFwTypes.List" does not exist
I checked the installed HSE Firmware package (HSE_FW_S32G3XX_0_2_64_0), but I do not see any .list or ARXML files that define these ECU resources.
Could you please confirm:
  1. Which package provides these missing ECU resource definitions?
  2. Should they be part of the HSE plugin for EB Tresos or delivered separately?
  3. Is there a reference Crypto configuration available for S32G3 Bootloader with HSE enabled?
regards,
Sunil
chenyin_h
Hello, @Sunilap
Thanks for your post.
I understand that the HSE 0.2.64 is used
1. What is the version of your bootloader used? is it from any version of GoldVIP?
2. Which version RTD is used?
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2166531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMissing%20ECU%20Resource%20Definitions%20for%20Crypto%20Module%20(HSE%20plugin%20%E2%80%93%20S32G3)%20in%20EB%20Tresos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20NXP%20Team%2C%3C%2FP%3E%3CP%3EI%20am%20working%20on%20%3CFONT%20face%3D%22andale%20mono%2Ctimes%22%3ES32G3%20Bootloader%20(%3CSTRONG%3EBootloader_S32G3XX_ASR_4.4_M7%3C%2FSTRONG%3E)%3C%2FFONT%3E%20using%20%3CSTRONG%3EEB%20Tresos%20Studio%3C%2FSTRONG%3E%20with%20the%20Crypto%20module%20(HSE%20integration).%3C%2FP%3E%3CP%3EWhile%20configuring%20Crypto.xdm%2C%20I%20see%20errors%20related%20to%20missing%20ECU%20resource%20properties%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ECrypto.HseFwTypes.List%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECrypto.MuInstances.List%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECrypto.SupportedPrimitives%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECrypto.HseMaxNumOfKeyGroups.*%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EExample%20error%3A%3CBR%20%2F%3EInvalid%20XPath-expression%3A%20The%20requested%20ECU%20resource%20property%20%22Crypto.HseFwTypes.List%22%20does%20not%20exist%3C%2FP%3E%3CP%3EI%20checked%20the%20installed%20HSE%20Firmware%20package%20(HSE_FW_S32G3XX_0_2_64_0)%2C%20but%20I%20do%20not%20see%20any%20.list%20or%20ARXML%20files%20that%20define%20these%20ECU%20resources.%3C%2FP%3E%3CP%3ECould%20you%20please%20confirm%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3EWhich%20package%20provides%20these%20missing%20ECU%20resource%20definitions%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EShould%20they%20be%20part%20of%20the%20HSE%20plugin%20for%20EB%20Tresos%20or%20delivered%20separately%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EIs%20there%20a%20reference%20Crypto%20configuration%20available%20for%20S32G3%20Bootloader%20with%20HSE%20enabled%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3Eregards%2C%3CBR%20%2F%3E%3CSPAN%3ESunil%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Missing%20ECU%20Resource%20Definitions%20for%20Crypto%20Module%20(HSE%20plugin%20%E2%80%93%20S32G3)%20in%20EB%20Tresos%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254247%22%20target%3D%22_blank%22%3E%40Sunilap%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post.%3C%2FP%3E%0A%3CP%3EI%20understand%20that%20the%20HSE%200.2.64%20is%20used%3C%2FP%3E%0A%3CP%3E1.%20What%20is%20the%20version%20of%20your%20bootloader%20used%3F%20is%20it%20from%20any%20version%20of%20GoldVIP%3F%3C%2FP%3E%0A%3CP%3E2.%20Which%20version%20RTD%20is%20used%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
