Lost Connection when debug S32G Cortex M7.
2,629件の閲覧回数
chengpei
Hello, I got ccs: Bus error when debug S32G274 cortex m7.
Environment: S32G-VNP-RDB2, gcc compiler, S32DebugProbe & PLS UDE debugger.
Problem description:
Cpu fail when execute ldr.w lr, [sp], #4; with S32DebugProbe:
SP and LR before execution:
[sp]=[0x34063770] memory:
With the same elf file, load into PLS debugger, this instruction executes successfully, but it failed later when executed an branch instruction:
lost connection after execution:
The branch destination address is valid:
タグ(3)
4 返答(返信)
2,611件の閲覧回数
Daniel-Aguirre
What example are you using? If not, under any NXP provided example, can you reproduce this behavior?
Please, let us know.
2,586件の閲覧回数
chengpei
Hi, Daniel,
It's not NXP provided example, but I can give you the elf file. Thank you for your help!
2,577件の閲覧回数
Daniel-Aguirre
Thanks for your feedback.
We recommend opening a ticket under the NXP online services for reviewing your project. Since this is a public channel, we recommend a private channel for this manner.
2,565件の閲覧回数
chengpei
Thank you for your suggestion!
