LLce clock
LLce clock
LB666
In the uboot environment variable, enter clk dump to display the LLce CAN module related clock as follows:
llce_can_pe     0
llce_sys      200000000
llce_per    80000000
I want to know what clock llce_per represents, and why is this clock not present in versions before BSP39? Is llce_can_pe the clock value representing CAN-PE-CLK? Why is the value of llce_can_pe 0?
Daniel-Aguirre
Can you let us know which BSP version are you using?
As for the LLCE CAN PE Clock being 0, the following community thread provides information on this regard:
S32G399 CAN_PE_CLK config - NXP Community
Please, let us know.
