LLCE RXOUT FIFO USE
LLCE RXOUT FIFO USE
LeeHua
HI NXP:
     What does the statement "  The host can configure filters with the receive interface set to one of these 6 FIFOs, which can be shared across all of the channels." mean about RXOUT FIFO in LLCE_firemware_user_guide doucment? How to use the rest of FIFOs(16-21)?
Daniel-Aguirre
Can you let us know which LLCE version are you using? For us to provide information under the same documentation version.
Please, let us know.
LeeHua
 Hello, @Daniel-Aguirre ,
        The LLCE version is " S32G_LLCE_1_0_5_QLP1".
Daniel-Aguirre
For the available information, we understand that these 6 FIFO's are meant for internal functionality of the LLCE. The following is told under the LLCE FW User Guide [Page 21, v1.0.5QLP1]:
"The logging interface transfers RX descriptors from LLCE to Host (RXOUT(17)) and from Host to LLCE (RXOUT(16))."
Which are 2 of the RXOUT FIFO locations you are mentioning. On regards of the other 4, we are not seeing much information, but we assume they are also being used for internal features.
