LLCE Firmware load fail
jiajun
    When I am porting the LLCE CAN example, it will jump to HardFault_Handler when running "Llce_Firmware_Load_GetBootStatus", but the official nxp example is fine, please help me to analyse what may be the reasons for the failure of LLCE firmware initialisation.Snipaste_2024-07-24_21-21-47.pngSnipaste_2024-07-24_21-21-59.png
Daniel-Aguirre
Thanks for your feedback.
Have you set the same preprocessor options under your project as the LLCE example? You should be able to find this information under Properties > C/C++ Build > Settings > Standard S32DS C Compiler >  Preprocessor.
Also, have verified that both linkers (the one under your project and the one under the LLCE example) are the same?
Overall, if you are trying to implement a custom application on top of the LLCE example, we can recommend using the LLCE example as a base and not a new project, since it has all the required links and configurations to be able to run.
Please, let us know.
Daniel-Aguirre
For the following comment:
"When I am porting the LLCE CAN example, it will jump to HardFault_Handler"
We understand that this is a custom application. Can you let us know how are you porting it? Is it to a different IDE or microprocessor?
Overall, a HardFault refers to different things, one of which might be related to accessing unavailable or uninitialized memory, which this might be related to.
jiajun
Hi, @Daniel-Aguirre
Thank you for your reply.
The environment used is S32DS 3.5 & S32G-VNP-RDB3 development board & SW32G_RTD_4.4_4.0.2 & S32G_LLCE_1_0_8.
The following are my porting steps.
1. Add new "S32DS Application Project"
2. Adding components against the configuration of "Can_Llce_DS_Can2Can_S32G399A_M7",and generate code
3. Adding LLCE bin file and C code to the projectSnipaste_2024-07-25_16-34-24.png
4. settle error
5. Debugging
Another,during debugging, I found that by placing the mouse over "Llce_Mgr_Status", its value can't be seen, but it can be seen in the official routine, as shown in the following two pictures, the first one is the official routine and the second one is my own routine
So,please also tell me why the "Llce_Mgr_Status" variable cannot be loaded.(ps: my link file is a direct port of the official routine.)
Daniel-Aguirre
Can you confirm in which optimization is your project at?
You should be able to find it under Properties > C/C++ Build > Settings > Standard S32DS C Compiler >  Optimization
jiajun
 Properties > C/C++ Build > Settings > Standard S32DS C Compiler >  Optimization > Optimize for size (-OS)Snipaste_2024-07-26_10-23-02.png
Daniel-Aguirre
%3CLINGO-SUB%20id%3D%22lingo-sub-1916202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELLCE%20Firmware%20load%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3BWhen%20I%20am%20porting%20the%20LLCE%20CAN%20example%2C%20it%20will%20jump%20to%20HardFault_Handler%20when%20running%20%22Llce_Firmware_Load_GetBootStatus%22%2C%20but%20the%20official%20nxp%20example%20is%20fine%2C%20please%20help%20me%20to%20analyse%20what%20may%20be%20the%20reasons%20for%20the%20failure%20of%20LLCE%20firmware%20initialisation.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-24_21-21-47.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-24_21-21-47.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290132i6A8AA201337C3AF4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-24_21-21-47.png%22%20alt%3D%22Snipaste_2024-07-24_21-21-47.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-24_21-21-59.png%22%20style%3D%22width%3A%20934px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-24_21-21-59.png%22%20style%3D%22width%3A%20934px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290133i440DF175F5EE8116%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-24_21-21-59.png%22%20alt%3D%22Snipaste_2024-07-24_21-21-59.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1918197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LLCE%20Firmware%20load%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1918197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20feedback.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHave%20you%20set%20the%20same%20preprocessor%20options%20under%20your%20project%20as%20the%20LLCE%20example%3F%20You%20should%20be%20able%20to%20find%20this%20information%20under%26nbsp%3B%3CEM%3EProperties%20%26gt%3B%20C%2FC%2B%2B%20Build%20%26gt%3B%20Settings%20%26gt%3B%20Standard%20S32DS%20C%20Compiler%20%26gt%3B%26nbsp%3B%20Preprocessor.%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EAlso%2C%20have%20verified%20that%20both%20linkers%20(the%20one%20under%20your%20project%20and%20the%20one%20under%20the%20LLCE%20example)%20are%20the%20same%3F%3C%2FP%3E%0A%3CP%3EOverall%2C%20if%20you%20are%20trying%20to%20implement%20a%20custom%20application%20on%20top%20of%20the%20LLCE%20example%2C%20we%20can%20recommend%20using%20the%20LLCE%20example%20as%20a%20base%20and%20not%20a%20new%20project%2C%20since%20it%20has%20all%20the%20required%20links%20and%20configurations%20to%20be%20able%20to%20run.%3C%2FP%3E%0A%3CP%3EPlease%2C%20let%20us%20know.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1917686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LLCE%20Firmware%20load%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1917686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3EProperties%20%26gt%3B%20C%2FC%2B%2B%20Build%20%26gt%3B%20Settings%20%26gt%3B%20Standard%20S32DS%20C%20Compiler%20%26gt%3B%26nbsp%3B%20Optimization%20%26gt%3B%20Optimize%20for%20size%20(-OS)%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-26_10-23-02.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-26_10-23-02.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290451iBE8ABE267FBDF142%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-26_10-23-02.png%22%20alt%3D%22Snipaste_2024-07-26_10-23-02.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1917324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LLCE%20Firmware%20load%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1917324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20feedback.%3C%2FP%3E%0A%3CP%3ECan%20you%20confirm%20in%20which%20optimization%20is%20your%20project%20at%3F%3C%2FP%3E%0A%3CP%3EYou%20should%20be%20able%20to%20find%20it%20under%26nbsp%3B%3CEM%3EProperties%20%26gt%3B%20C%2FC%2B%2B%20Build%20%26gt%3B%20Settings%20%26gt%3B%20Standard%20S32DS%20C%20Compiler%20%26gt%3B%26nbsp%3B%20Optimization%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EPlease%2C%20let%20us%20know.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1917016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LLCE%20Firmware%20load%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1917016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205137%22%20target%3D%22_blank%22%3E%40Daniel-Aguirre%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20reply.%3C%2FP%3E%3CP%3EThe%20environment%20used%20is%20S32DS%203.5%20%26amp%3B%20S32G-VNP-RDB3%20development%20board%20%26amp%3B%20SW32G_RTD_4.4_4.0.2%20%26amp%3B%20S32G_LLCE_1_0_8.%3C%2FP%3E%3CP%3EThe%20following%20are%20my%20porting%20steps.%3C%2FP%3E%3CP%3E1.%20Add%20new%20%22S32DS%20Application%20Project%22%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-25_16-24-15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-25_16-24-15.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290293i1588F872AD49C1A4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-25_16-24-15.png%22%20alt%3D%22Snipaste_2024-07-25_16-24-15.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2.%26nbsp%3BAdding%20components%20against%20the%20configuration%20of%20%22Can_Llce_DS_Can2Can_S32G399A_M7%22%2Cand%26nbsp%3Bgenerate%20code%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-25_16-30-48.png%22%20style%3D%22width%3A%20729px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-25_16-30-48.png%22%20style%3D%22width%3A%20729px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290294i352268319171798C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-25_16-30-48.png%22%20alt%3D%22Snipaste_2024-07-25_16-30-48.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E3.%26nbsp%3BAdding%20LLCE%20bin%20file%20and%20C%20code%20to%20the%20project%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-25_16-34-24.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-25_16-34-24.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290295i5403EA7F14C406A8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-25_16-34-24.png%22%20alt%3D%22Snipaste_2024-07-25_16-34-24.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E4.%26nbsp%3Bsettle%20error%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-25_16-35-53.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-25_16-35-53.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290296i113FCDE5257887AE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-25_16-35-53.png%22%20alt%3D%22Snipaste_2024-07-25_16-35-53.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E5.%20Debugging%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAnother%2Cduring%20debugging%2C%20I%20found%20that%20by%20placing%20the%20mouse%20over%20%22Llce_Mgr_Status%22%2C%20its%20value%20can't%20be%20seen%2C%20but%20it%20can%20be%20seen%20in%20the%20official%20routine%2C%20as%20shown%20in%20the%20following%20two%20pictures%2C%20the%20first%20one%20is%20the%20official%20routine%20and%20the%20second%20one%20is%20my%20own%20routine%3C%2FP%3E%3CP%3ESo%2Cplease%20also%20tell%20me%20why%20the%20%22Llce_Mgr_Status%22%20variable%20cannot%20be%20loaded.(ps%3A%26nbsp%3Bmy%20link%20file%20is%20a%20direct%20port%20of%20the%20official%20routine.)%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-25_16-42-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-25_16-42-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290297i1E5A3E71A2E0F464%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-25_16-42-19.png%22%20alt%3D%22Snipaste_2024-07-25_16-42-19.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2024-07-25_16-40-09.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2024-07-25_16-40-09.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290298i42AFDCCE06CA9BCC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snipaste_2024-07-25_16-40-09.png%22%20alt%3D%22Snipaste_2024-07-25_16-40-09.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1916339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LLCE%20Firmware%20load%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1916339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EFor%20the%20following%20comment%3A%3C%2FP%3E%0A%3CP%3E%22%3CSPAN%3EWhen%20I%20am%20porting%20the%20LLCE%20CAN%20example%2C%20it%20will%20jump%20to%20HardFault_Handler%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3EWe%20understand%20that%20this%20is%20a%20custom%20application.%20Can%20you%20let%20us%20know%20how%20are%20you%20porting%20it%3F%20Is%20it%20to%20a%20different%20IDE%20or%20microprocessor%3F%3C%2FP%3E%0A%3CP%3EOverall%2C%20a%20HardFault%20refers%20to%20different%20things%2C%20one%20of%20which%20might%20be%20related%20to%20accessing%20unavailable%20or%20uninitialized%20memory%2C%20which%20this%20might%20be%20related%20to.%3C%2FP%3E%0A%3CP%3EPlease%2C%20let%20us%20know.%3C%2FP%3E%3C%2FLINGO-BODY%3E
