How zero copy API works in IPCF
1,253件の閲覧回数
AhmedAbd-ElFattah
In Inter-Platform Communication Framework Product Brief document, it's mentioned that zero-copy API used to reduce overhead, I need to know how this implemented, Does the copy is based on DMA transfer or another method ?
1,231件の閲覧回数
Daniel-Aguirre
The following information is available on regards of this topic:
"The IPCF uses share memory as communication channel between two end point.  No memory copy was introduced and there is no actually sort of transmission involved like ethernet."
Please, let us know.
