How to use PWM function on S32R372?
851 次查看
Kidd
I would like to use PWM  (FlexPWM0 submoudle3  A3 & X3 2channel )function to control 2 LEDs via TI Dual-Channel Smart High-Side Power Switch.
Use the internal clock.
Can switch the duty cycle. (25% / 50%)
How to config / init / start PWM on S32R372 ?  Could anyone provide the sample code ?
774 次查看
petervlna
Could you please specify if you are using some drivers, or you are asking for bare metal code example / explanation?
best regards,
Peter
