How to clean DDR in a specific range on ATF?
1,155 次查看
Jeff-CF-Huang
Hi Sir,
We want to clean DDR in ATF, but there is only a ddr_init function available in arm-trusted-firmware/drivers/nxp/s32/ddr.
Jeff Huang
5 回复数
1,090 次查看
chenyin_h
Hello, @Jeff-CF-Huang
Thanks for pointing it out.
There is indeed TFA level libc functions implemented,  I have checked the code in TFA and it seems included in the S32 support.
Yes, you may try using memset directly. I do not see other specific APIs implemented from our BSP perspective.
Chenyin
1,096 次查看
chenyin_h
Thanks for your reply.
I do not find related description from BSP related document, from my experience, there is mmio_write_32 APIs existed in TF-A, you may try using it to modify the DDR range per your request.
Chenyin
1,093 次查看
Jeff-CF-Huang
Hi Chenyin,
Are you suggesting using mmio_write to achieve the same effect as memset(dest, 0, size)?
I don’t believe that’s an efficient approach.
Is there any NXP-specific method for handling the memory controller instead?
Jeff Huang
1,133 次查看
chenyin_h
Thanks for your post.
May I know what is your meaning of "clean"? to set it to all zeros?
Chenyin
1,125 次查看
Jeff-CF-Huang
Hi Chenyin,
Yes.
Jeff Huang
