How do I know fip.bin programming into flash or sd card ?
fengxianeric
Hello, I can build fip.bin by using arm-trusted-firmware source tree (branch: bsp35.0-2.5), but not clear that it should be fittable for flash partition or sd card ?
Bio_TICFSL
Firmware Image Package (FIP) is a packaging format used by TF-A to package firmware images is going to Flash devices.
