已解决! 转到解答。
Hi @zyz,
Are you using a custom board? if not is it an RDB or EVB?
If you are using a custom board, which model of QSPI are you using?
The problem is when you are doing the bypass of the FEE driver and using directly the FLS? or this is a workaround?
