Fetcher error while building the image after including pfe pfe-slave in local.conf.
hulk101
I want to build PFE multi-instance driver, For which I have added "DISTRO_FEATURES:append = " pfe"" in the local.conf, and while bitbake I get the below error:
WARNING: pfe-1.0.0-r0 do_fetch: Failed to fetch URL file://./s32g_pfe_class.fw, attempting MIRRORS if available
ERROR: pfe-1.0.0-r0 do_fetch: Fetcher failure: Unable to find file file://./s32g_pfe_class.fw anywhere. The paths that were searched were:
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/fsl-auto
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/fsl-auto
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/fsl-auto
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/s32g274ardb2
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/s32g274ardb2
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/s32g274ardb2
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/s32cc
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/s32cc
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/s32cc
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/armv8a
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/armv8a
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/armv8a
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe-1.0.0/aarch64
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe/aarch64
/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/files/aarch64
/home/teuser/S32G2/fsl-auto-yocto-bsp/downloads
ERROR: pfe-1.0.0-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'file://./s32g_pfe_class.fw')
ERROR: Logfile of failure stored in: /home/teuser/S32G2/fsl-auto-yocto-bsp/build_s32g274ardb2/tmp/work/s32g274ardb2-fsl-linux/pfe/1.0.0-r0/temp/log.do_fetch.122939
ERROR: Task (/home/teuser/S32G2/fsl-auto-yocto-bsp/sources/meta-alb/recipes-kernel/pfe/pfe_1.0.0.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2128 tasks of which 2125 didn't need to be rerun and 1 failed.
chenyin_h
Thanks for the reply, @hulk101
From the log, the PFE FW is not found by the Yocto, have you added it according to the UM?
Chenyin
hulk101
Hi, @chenyin_h
NXP_FIRMWARE_LOCAL_DIR is not added. I have searched for the "s32g_pfe_class.fw" file and was not able to find it. Should I create this file by my own ?
chenyin_h
Hello, @hulk101
Thanks for your reply.
No, the file mentioned is the PFE FW which is provisioned by NXP, you may download it in your account, like this:
Note that this is not the version used for BSP38, you may try downloading the 1.7.1 PFE FW for using with the BSP38.
I hope it will help.
Chenyin
chenyin_h
Hello, @hulk101
Thanks for the post.
May I know which version BSP is used?
Chenyin
hulk101
Hello @chenyin_h
BSP 38.0 version is used for the build.
Thankyou.
%3CLINGO-SUB%20id%3D%22lingo-sub-2171111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20want%20to%26nbsp%3Bbuild%20PFE%20multi-instance%20driver%2C%20For%20which%20I%20have%20added%20%22DISTRO_FEATURES%3Aappend%20%3D%20%22%20pfe%22%22%20in%20the%20local.conf%2C%20and%20while%20bitbake%20I%20get%20the%20below%20error%3A%3C%2FP%3E%3CP%3EWARNING%3A%20pfe-1.0.0-r0%20do_fetch%3A%20Failed%20to%20fetch%20URL%20file%3A%2F%2F.%2Fs32g_pfe_class.fw%2C%20attempting%20MIRRORS%20if%20available%3CBR%20%2F%3EERROR%3A%20pfe-1.0.0-r0%20do_fetch%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20file%20file%3A%2F%2F.%2Fs32g_pfe_class.fw%20anywhere.%20The%20paths%20that%20were%20searched%20were%3A%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Ffsl-auto%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Ffsl-auto%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Ffsl-auto%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Fs32g274ardb2%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Fs32g274ardb2%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32g274ardb2%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Fs32cc%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Fs32cc%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32cc%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Fs32%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Fs32%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Farmv8a%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Farmv8a%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Farmv8a%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Faarch64%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Faarch64%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Faarch64%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Fs32g%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Fs32g%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32g%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Fs32g2%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Fs32g2%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Fs32g2%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2Faarch64%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2Faarch64%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2Faarch64%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe-1.0.0%2F%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe%2F%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Ffiles%2F%3CBR%20%2F%3E%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fdownloads%3CBR%20%2F%3EERROR%3A%20pfe-1.0.0-r0%20do_fetch%3A%20Bitbake%20Fetcher%20Error%3A%20FetchError('Unable%20to%20fetch%20URL%20from%20any%20source.'%2C%20'file%3A%2F%2F.%2Fs32g_pfe_class.fw')%3CBR%20%2F%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fbuild_s32g274ardb2%2Ftmp%2Fwork%2Fs32g274ardb2-fsl-linux%2Fpfe%2F1.0.0-r0%2Ftemp%2Flog.do_fetch.122939%3CBR%20%2F%3EERROR%3A%20Task%20(%2Fhome%2Fteuser%2FS32G2%2Ffsl-auto-yocto-bsp%2Fsources%2Fmeta-alb%2Frecipes-kernel%2Fpfe%2Fpfe_1.0.0.bb%3Ado_fetch)%20failed%20with%20exit%20code%20'1'%3CBR%20%2F%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%202128%20tasks%20of%20which%202125%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2171111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGoldVIP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243266%22%20target%3D%22_blank%22%3E%40hulk101%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%0A%3CP%3ENo%2C%20the%20file%20mentioned%20is%20the%20PFE%20FW%20which%20is%20provisioned%20by%20NXP%2C%20you%20may%20download%20it%20in%20your%20account%2C%20like%20this%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1758188868304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1758188868304.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357509i52BCC0C6D66F472B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1758188868304.png%22%20alt%3D%22chenyin_h_0-1758188868304.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ENote%20that%20this%20is%20not%20the%20version%20used%20for%20BSP38%2C%20you%20may%20try%20downloading%20the%201.7.1%20PFE%20FW%20for%20using%20with%20the%20BSP38.%3C%2FP%3E%0A%3CP%3EI%20hope%20it%20will%20help.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171773%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%2C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3ENXP_FIRMWARE_LOCAL_DIR%20is%20not%20added.%20I%20have%20searched%20for%20the%20%22s32g_pfe_class.fw%22%20file%20and%20was%20not%20able%20to%20find%20it.%20Should%20I%20create%20this%20file%20by%20my%20own%20%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20the%20reply%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243266%22%20target%3D%22_blank%22%3E%40hulk101%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFrom%20the%20log%2C%20the%20PFE%20FW%20is%20not%20found%20by%20the%20Yocto%2C%20have%20you%20added%20it%20according%20to%20the%20UM%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22chenyin_h_0-1758180124137.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22chenyin_h_0-1758180124137.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357463iCD2FCF493AA76D25%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22chenyin_h_0-1758180124137.png%22%20alt%3D%22chenyin_h_0-1758180124137.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171613%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24163%22%20target%3D%22_blank%22%3E%40chenyin_h%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EBSP%2038.0%20version%20is%20used%20for%20the%20build.%3CBR%20%2F%3E%3CBR%20%2F%3EThankyou.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetcher%20error%20while%20building%20the%20image%20after%20including%20pfe%20pfe-slave%20in%20local.conf.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171499%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243266%22%20target%3D%22_blank%22%3E%40hulk101%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20post.%3C%2FP%3E%0A%3CP%3EMay%20I%20know%20which%20version%20BSP%20is%20used%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EChenyin%3C%2FP%3E%3C%2FLINGO-BODY%3E
