Fetch source code error
1,666件の閲覧回数
sinjhe
Hello NXP,
I want to build the image for S32G with version BSP33, I use the follow command to fetch the source:
repo init -u https://github.com/nxp-auto-linux/auto_yocto_bsp -b release/bsp33.0
repo sync
I get the error message:
curl: (6) Could not resolve host: source.codeaurora.org\n'
Syncing: 88% (8/9), done in 1m28.689s
Syncing: 133% (12/9) 2:09 | 1 job | 0:35 meta-linaro @ sources/meta-linaroThe following projects failed and could not be synced:
- sources/meta-alb
- sources/meta-linaro
- sources/meta-qoriq
error: Unable to fully sync the tree
error: Downloading network changes failed.
Failing repos (network):
sources/meta-alb
sources/meta-alb
sources/meta-linaro
sources/meta-linaro
sources/meta-qoriq
sources/meta-qoriq
error: Checking out local projects failed.
Failing repos (checkout):
sources/meta-alb
sources/meta-linaro
sources/meta-qoriq
Try re-running with "-j1 --fail-fast" to exit at the first error.
I think the reason is source.codeaurora.org no longer to access now.
So how do I modify the default.xml in .repo/manifests to download the source code for BSP33?
1,658件の閲覧回数
chenyin_h
Hello, @sinjhe
Thanks for your post.
Since the source.codeaurora.org cannot provide service for building the old version BSP, I suggest referencing the following document for building it with updated repo settings
https://community.nxp.com/t5/S32G-Knowledge-Base/Supplement-for-Building-Older-AUTO-Linux-BSPs/ta-p/...
Sorry for your inconvenience.
Chenyin
3 返答(返信)
1,631件の閲覧回数
chenyin_h
Hello, @sinjhe
You are welcome, if any other issues, welcome raising new posts, we are happy to support.
Chenyin
1,644件の閲覧回数
sinjhe
Hello chenyin,
It works, thank you.
1,659件の閲覧回数
chenyin_h
Hello, @sinjhe
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2150849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E5%8F%96%E5%BE%97%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20BSP33%20%E3%81%AE%20S32G%20%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%3C%2FA%3E-b%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%2Fbsp33.0%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E5%90%8C%E6%9C%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3Ecurl%3A%20(6)%20%E3%83%9B%E3%82%B9%E3%83%88%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20source.codeaurora.org%5Cn'%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%90%8C%E6%9C%9F%3A%2088%25%20(8%2F9)%E3%80%811%E5%88%8628%E7%A7%92689%E3%81%A7%E5%AE%8C%E4%BA%86%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%90%8C%E6%9C%9F%E4%B8%AD%3A%20133%25%20(12%2F9)%202%3A09%20%7C%201%20%E3%82%B8%E3%83%A7%E3%83%96%20%7C%200%3A35%20meta-linaro%20%40%20sources%2Fmeta-linaro%E6%AC%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E5%90%8C%E6%9C%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20color%3D%22%23FF0000%22%3E-%20%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%AB%E3%83%96%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E-%20%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%83%AA%E3%83%8A%E3%83%AD%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E-%20%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF-qoriq%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%90%8C%E6%9C%9F%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%EF%BC%88%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%EF%BC%89%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%AB%E3%83%96%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%AB%E3%83%96%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%83%AA%E3%83%8A%E3%83%AD%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%83%AA%E3%83%8A%E3%83%AD%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BFqoriq%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BFqoriq%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%EF%BC%88%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%EF%BC%89%3A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%82%A2%E3%83%AB%E3%83%96%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BF%E3%83%AA%E3%83%8A%E3%83%AD%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%2F%E3%83%A1%E3%82%BFqoriq%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C-j1%20--fail-fast%E3%80%8D%E3%81%A7%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%90%86%E7%94%B1%E3%81%AF%E3%80%81source.codeaurora.org%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESO%E3%80%81BSP33%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81.repo%2Fmanifests%20%E3%81%AE%20default.xml%20%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetch%20source%20code%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F127852%22%20target%3D%22_blank%22%3E%40sinjhe%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%86%E3%81%9E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E5%96%9C%E3%82%93%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetch%20source%20code%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81chenyin%E3%81%95%E3%82%93%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetch%20source%20code%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F127852%22%20target%3D%22_blank%22%3E%40sinjhe%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Esource.codeaurora.org%E3%81%AF%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AEBSP%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G-Knowledge-Base%2FSupplement-for-Building-Older-AUTO-Linux-BSPs%2Fta-p%2F2105913%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G-Knowledge-Base%2FSupplement-for-Building-Older-AUTO-Linux-BSPs%2Fta-p%2F2105913%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E4%B8%8D%E4%BE%BF%E3%82%92%E3%81%8A%E3%81%8B%E3%81%91%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%81%E3%82%A7%E3%82%A4%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
