Fetch source code error
1,702 次查看
sinjhe
Hello NXP,
I want to build the image for S32G with version BSP33, I use the follow command to fetch the source:
repo init -u https://github.com/nxp-auto-linux/auto_yocto_bsp -b release/bsp33.0
repo sync
I get the error message:
curl: (6) Could not resolve host: source.codeaurora.org\n'
Syncing: 88% (8/9), done in 1m28.689s
Syncing: 133% (12/9) 2:09 | 1 job | 0:35 meta-linaro @ sources/meta-linaroThe following projects failed and could not be synced:
- sources/meta-alb
- sources/meta-linaro
- sources/meta-qoriq
error: Unable to fully sync the tree
error: Downloading network changes failed.
Failing repos (network):
sources/meta-alb
sources/meta-alb
sources/meta-linaro
sources/meta-linaro
sources/meta-qoriq
sources/meta-qoriq
error: Checking out local projects failed.
Failing repos (checkout):
sources/meta-alb
sources/meta-linaro
sources/meta-qoriq
Try re-running with "-j1 --fail-fast" to exit at the first error.
I think the reason is source.codeaurora.org no longer to access now.
So how do I modify the default.xml in .repo/manifests to download the source code for BSP33?
1,694 次查看
chenyin_h
Hello, @sinjhe
Thanks for your post.
Since the source.codeaurora.org cannot provide service for building the old version BSP, I suggest referencing the following document for building it with updated repo settings
https://community.nxp.com/t5/S32G-Knowledge-Base/Supplement-for-Building-Older-AUTO-Linux-BSPs/ta-p/...
Sorry for your inconvenience.
Chenyin
1,667 次查看
chenyin_h
Hello, @sinjhe
You are welcome, if any other issues, welcome raising new posts, we are happy to support.
Chenyin
1,680 次查看
sinjhe
Hello chenyin,
It works, thank you.
1,695 次查看
chenyin_h
Hello, @sinjhe
Chenyin
%3CLINGO-SUB%20id%3D%22lingo-sub-2150849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%8E%B7%E5%8F%96%E6%BA%90%E4%BB%A3%E7%A0%81%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150849%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%20BSP33%20%E7%89%88%E6%9C%AC%E4%B8%BA%20S32G%20%E6%9E%84%E5%BB%BA%E9%95%9C%E5%83%8F%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%9D%A5%E8%8E%B7%E5%8F%96%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BB%93%E5%BA%93%20init-u%20https%3A%2F%2Fgithub.com%2Fnxp-auto-linux%2Fauto_yocto_bsp%3C%2FA%3E-b%20%E7%89%88%E6%9C%AC%2Fbsp33.0%3C%2FP%3E%3CP%3E%E4%BB%93%E5%BA%93%E5%90%8C%E6%AD%A5%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23FF0000%22%3Ecurl%3A%20(6)%20%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%E4%B8%BB%E6%9C%BA%EF%BC%9Asource.codeaurora.org%2Fn'%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%90%8C%E6%AD%A5%EF%BC%9A88%25%20(8%2F9)%EF%BC%8C%E7%94%A8%E6%97%B6%201m28.689s%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%90%8C%E6%AD%A5%EF%BC%9A133%25%20(12%2F9)%202%3A09%20%7C%201%20job%20%7C%200%3A35%20meta-linaro%20%40%20sources%2Fmeta-linaro%E4%BB%A5%E4%B8%8B%E9%A1%B9%E7%9B%AE%E5%A4%B1%E8%B4%A5%EF%BC%8C%E6%97%A0%E6%B3%95%E5%90%8C%E6%AD%A5%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E-%20sources%2Fmeta-alb%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E-%20sources%2Fmeta-linaro%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E-%20sources%2Fmeta-qoriq%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%AE%8C%E5%85%A8%E5%90%8C%E6%AD%A5%E9%A1%B9%E7%9B%AE%E6%A0%91%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%8B%E8%BD%BD%E7%BD%91%E7%BB%9C%E6%9B%B4%E6%94%B9%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%9B%9E%E8%B4%AD%E5%A4%B1%E8%B4%A5%EF%BC%88%E7%BD%91%E7%BB%9C%EF%BC%89%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%E6%9D%A5%E6%BA%90%2Fmeta-alb%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%E6%9D%A5%E6%BA%90%2Fmeta-alb%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%E6%BA%90%E4%BB%A3%E7%A0%81%2Fmeta-linaro%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%E6%BA%90%E4%BB%A3%E7%A0%81%2Fmeta-linaro%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%E6%BA%90%E4%BB%A3%E7%A0%81%2Fmeta-q%20oriq%20%E6%9D%A5%E6%BA%90%2Fmeta-qoriq%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20sources%2Fmeta-qori%20q%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20%E9%94%99%E8%AF%AF%20%EF%BC%9A%E6%9F%A5%E7%9C%8B%E6%9C%AC%E5%9C%B0%E9%A1%B9%E7%9B%AE%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%A4%B1%E8%B4%A5%E7%9A%84%E4%BB%93%E5%BA%93%EF%BC%88%E7%AD%BE%E5%87%BA%EF%BC%89%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3Esources%2Fmeta-alb%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3Esources%2Fmeta-linaro%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3Esources%2Fmeta-qoriq%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20%22-j1%20--fail-fast%22%20%E9%87%8D%E6%96%B0%E8%BF%90%E8%A1%8C%E4%BB%A5%E5%9C%A8%E7%AC%AC%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E6%97%B6%E9%80%80%E5%87%BA%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%8E%9F%E5%9B%A0%E6%98%AF%20source.codeaurora.org%20%E7%8E%B0%E5%9C%A8%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%E5%A6%82%E4%BD%95%E4%BF%AE%E6%94%B9%20.%E4%BB%93%E5%BA%93%2F%E6%B8%85%E5%8D%95%20%E4%B8%AD%E7%9A%84%20default.xml%20%E6%9D%A5%E4%B8%8B%E8%BD%BD%20BSP33%20%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E5%91%A2%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetch%20source%20code%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F127852%22%20target%3D%22_blank%22%3E%40sinjhe%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%8C%E6%AC%A2%E8%BF%8E%E6%8F%90%E5%87%BA%E6%96%B0%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BE%88%E4%B9%90%E6%84%8F%E6%8F%90%E4%BE%9B%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetch%20source%20code%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151565%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8Cchenyin%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BE%88%E5%A5%BD%E7%94%A8%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fetch%20source%20code%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F127852%22%20target%3D%22_blank%22%3E%40sinjhe%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%20%3CSPAN%3Esource.codeaurora.org%20%E6%97%A0%E6%B3%95%E4%B8%BA%E6%9E%84%E5%BB%BA%E6%97%A7%E7%89%88%E6%9C%AC%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E6%8F%90%E4%BE%9B%E6%9C%8D%E5%8A%A1%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E5%BB%BA%E8%AE%AE%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%3C%2FSPAN%3E%E6%96%87%E6%A1%A3%E4%BD%BF%E7%94%A8%E6%9B%B4%E6%96%B0%E7%9A%84%E4%BB%93%E5%BA%93%E8%AE%BE%E7%BD%AE%E8%BF%9B%E8%A1%8C%E6%9E%84%E5%BB%BA%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G-Knowledge-Base%2FSupplement-for-Building-Older-AUTO-Linux-BSPs%2Fta-p%2F2105913%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G-Knowledge-Base%2FSupplement-for-Building-Older-AUTO-Linux-BSPs%2Fta-p%2F2105913%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E7%BB%99%E6%82%A8%E5%B8%A6%E6%9D%A5%E4%B8%8D%E4%BE%BF%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%88%87%E5%AE%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
