Error while running assembler
Bannai30
Hello I am currently trying to perform few tests and when I integrated the files in my project (tool used-IAR) it shows an error as below the path and the directory are correct and there is no mismatch. Can you tell me what is the possible reason for this error?
Thank you.
Bio_TICFSL
Hello Bannai30,
You should contact IAR, since it works on our side.
RachelGomez123
This fatal error is reported when a constant assembler expression performs a division by zero. These fatal error is reported when a constant assembler expression is too big to be evaluated by the constant parser. Try reducing the number of terms.
Rachel Gomez
Bio_TICFSL
Hello Bannai30,
