An error occurs when compiling the IPCF_Example_multi_instance_S32G274_M7_0 project
DRAVE
Hi nxp,
我正在使用 S32 Design Studio for S32 Platform 3.5 编译“IPCF_Example_multi_instance_S32G274_M7_0” 例程,出现报错如下:
14:35:25 **** Incremental Build of configuration Debug_RAM for project IPCF_Example_multi_instance_S32G274_M7_1 ****
make -j20 all
Building file: ../generate/src/OsIf_Cfg.c
Building file: ../src/main.c
Building file: ../board/Siul2_Port_Ip_Cfg.c
Building file: ../src/sample.c
Building file: ../generate/src/Mpu_M7_Ip_Cfg.c
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@src/main.args" -MMD -MP -MF"src/main.d" -MT"src/main.o" -o "src/main.o" "../src/main.c"
arm-none-eabi-gcc "@src/main.args" -MMD -MP -MF"src/sample.d" -MT"src/sample.o" -o "src/sample.o" "../src/sample.c"
arm-none-eabi-gcc "@generate/src/Mpu_M7_Ip_Cfg.args" -MMD -MP -MF"generate/src/OsIf_Cfg.d" -MT"generate/src/OsIf_Cfg.o" -o "generate/src/OsIf_Cfg.o" "../generate/src/OsIf_Cfg.c"
arm-none-eabi-gcc "@board/Siul2_Port_Ip_Cfg.args" -MMD -MP -MF"board/Siul2_Port_Ip_Cfg.d" -MT"board/Siul2_Port_Ip_Cfg.o" -o "board/Siul2_Port_Ip_Cfg.o" "../board/Siul2_Port_Ip_Cfg.c"
arm-none-eabi-gcc "@generate/src/Mpu_M7_Ip_Cfg.args" -MMD -MP -MF"generate/src/Mpu_M7_Ip_Cfg.d" -MT"generate/src/Mpu_M7_Ip_Cfg.o" -o "generate/src/Mpu_M7_Ip_Cfg.o" "../generate/src/Mpu_M7_Ip_Cfg.c"
../src/main.c:20:10: fatal error: Clock_Ip.h: No such file or directory
20 | #include "Clock_Ip.h"
compilation terminated.
In file included from ../generate/src/Mpu_M7_Ip_Cfg.c:46:
D:/nxp/workspaceS32DS.3.5/IPCF_Example_multi_instance_S32G274_M7_1/generate/include/Mpu_M7_Ip_Cfg.h:39:10: fatal error: Mpu_M7_Ip_Types.h: No such file or directory
39 | #include "Mpu_M7_Ip_Types.h"
In file included from ../board/Siul2_Port_Ip_Cfg.c:43:
../board/Siul2_Port_Ip_Cfg.h:47:10: fatal error: Siul2_Port_Ip_Types.h: No such file or directory
47 | #include "Siul2_Port_Ip_Types.h"
../src/sample.c:24:10: fatal error: ipcf_Ip_Cfg.h: No such file or directory
24 | #include "ipcf_Ip_Cfg.h"
In file included from ../generate/src/OsIf_Cfg.c:44:
D:/nxp/S32DS.3.5/S32DS/software/PlatformSDK_S32XX_2022_03/SW32_RTD_4_4_3_0_2_D2203/Base_TS_T40D11M30I2R0/include/OsIf_Cfg_TypesDef.h:87:6: error: #error "Software Version Numbers of OsIf_Cfg_TypesDef.h and OsIf_Cfg.h are different"
87 | #error "Software Version Numbers of OsIf_Cfg_TypesDef.h and OsIf_Cfg.h are different"
../generate/src/OsIf_Cfg.c:93:6: error: #error "Software Version Numbers of OsIf_Cfg.c and OsIf_Cfg_TypesDef.h are different"
93 | #error "Software Version Numbers of OsIf_Cfg.c and OsIf_Cfg_TypesDef.h are different"
make: *** [generate/src/subdir.mk:23: generate/src/Mpu_M7_Ip_Cfg.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [src/subdir.mk:23: src/sample.o] Error 1
make: *** [board/subdir.mk:20: board/Siul2_Port_Ip_Cfg.o] Error 1
make: *** [src/subdir.mk:23: src/main.o] Error 1
make: *** [generate/src/subdir.mk:23: generate/src/OsIf_Cfg.o] Error 1
"make -j20 all" terminated with exit code 2. Build might be incomplete.
14:35:26 Build Failed. 12 errors, 0 warnings. (took 552ms)
打开 Peripherals 配置出现问题显示如下:
已安装软件包如下:
麻烦可以帮忙看看什么原因不?谢谢!
DRAVE
Hi @Celeste_Liu
貌似是我装多一个 RTD 包导致的,我重装软件后就可以了,谢谢!问下,是否有关于 S32G-VNP-RDB3 类似 AN13750.pdf 的文档?就是能在  S32G-VNP-RDB3 上实现 A 核和 M 核同时工作的状态?
Celeste_Liu
Hello @DRAVE ,
感谢你的提问。在编译项目之前,你似乎没有使用配置工具生成代码。请点击标记处的绿色按钮”更新源代码“,它会向项目中添加缺失的模块以使其正常工作。我们建议再次导入示例(删除之前的)并使用配置工具生成代码。
Celeste
DRAVE
Hi @Celeste_Liu
Celeste_Liu
Hello ,
很高兴听到你的问题解决了。目前没有关于 S32G3 的双核启动的类似 AN13750.pdf 的文档,并且也没有发布此类文档的计划。这是因为 S32G3 的 GoldVIP 里面已经有双核启动了。我认为 AN13750 对你仍具有一定的参考价值,因为思路是一致的。以下这个案例可能会对你有所帮助:Solved: S32G399A-RDB3-Multi-core-boot-failed-following-AN13750 。
BR,
Celeste
DRAVE
Hi @Celeste_Liu
好的,我参考一下,谢谢!
DRAVE
Hi nxp,
下面三个例程运行都出现一样的现象
IPCF_Example_multi_instance_S32G274_M7_2
%3CLINGO-SUB%20id%3D%22lingo-sub-1971039%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EAn%20error%20occurs%20when%20compiling%20the%20IPCF_Example_multi_instance_S32G274_M7_0%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971039%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20nxp%2C%3C%2FP%3E%3CP%3EI%20am%20using%20S32%20Design%20Studio%20for%20S32%20Platform%203.5%20to%20compile%20the%20%22IPCF_Example_multi_instance_S32G274_M7_0%22%20routine%20and%20the%20following%20error%20occurs%3A%3C%2FP%3E%3CP%3E14%3A35%3A25%20****%20Incremental%20Build%20of%20configuration%20Debug_RAM%20for%20project%20IPCF_Example_multi_instance_S32G274_M7_1%20****%3CBR%20%2F%3Emake%20-j20%20all%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fgenerate%2Fsrc%2FOsIf_Cfg.c%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fsrc%2Fmain.c%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fboard%2FSiul2_Port_Ip_Cfg.c%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fsrc%2Fsample.c%3CBR%20%2F%3EBuilding%20file%3A%20..%2Fgenerate%2Fsrc%2FMpu_M7_Ip_Cfg.c%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40src%2Fmain.args%22%20-MMD%20-MP%20-MF%22src%2Fmain.d%22%20-MT%22src%2Fmain.o%22%20-o%20%22src%2Fmain.o%22%20%22..%2Fsrc%2Fmain.c%22%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40src%2Fmain.args%22%20-MMD%20-MP%20-MF%22src%2Fsample.d%22%20-MT%22src%2Fsample.o%22%20-o%20%22src%2Fsample.o%22%20%22..%2Fsrc%2Fsample.c%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FMpu_M7_Ip_Cfg.args%22%20-MMD%20-MP%20-MF%22generate%2Fsrc%2FOsIf_Cfg.d%22%20-MT%22generate%2Fsrc%2FOsIf_Cfg.o%22%20-o%20%22generate%2Fsrc%2FOsIf_Cfg.o%22%20%22..%2Fgenerate%2Fsrc%2FOsIf_Cfg.c%22%3CBR%20%2F%3EInvoking%3A%20Standard%20S32DS%20C%20Compiler%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40board%2FSiul2_Port_Ip_Cfg.args%22%20-MMD%20-MP%20-MF%22board%2FSiul2_Port_Ip_Cfg.d%22%20-MT%22board%2FSiul2_Port_Ip_Cfg.o%22%20-o%20%22board%2FSiul2_Port_Ip_Cfg.o%22%20%22..%2Fboard%2FSiul2_Port_Ip_Cfg.c%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FMpu_M7_Ip_Cfg.args%22%20-MMD%20-MP%20-MF%22generate%2Fsrc%2FMpu_M7_Ip_Cfg.d%22%20-MT%22generate%2Fsrc%2FMpu_M7_Ip_Cfg.o%22%20-o%20%22generate%2Fsrc%2FMpu_M7_Ip_Cfg.o%22%20%22..%2Fgenerate%2Fsrc%2FMpu_M7_Ip_Cfg.c%22%3CBR%20%2F%3E..%2Fsrc%2Fmain.c%3A20%3A10%3A%20fatal%20error%3A%20Clock_Ip.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E20%20%7C%20%23include%20%22Clock_Ip.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3EIn%20file%20included%20from%20..%2Fgenerate%2Fsrc%2FMpu_M7_Ip_Cfg.c%3A46%3A%3CBR%20%2F%3ED%3A%2Fnxp%2FworkspaceS32DS.3.5%2FIPCF_Example_multi_instance_S32G274_M7_1%2Fgenerate%2Finclude%2FMpu_M7_Ip_Cfg.h%3A39%3A10%3A%20fatal%20error%3A%20Mpu_M7_Ip_Types.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E39%20%7C%20%23include%20%22Mpu_M7_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3EIn%20file%20included%20from%20..%2Fboard%2FSiul2_Port_Ip_Cfg.c%3A43%3A%3CBR%20%2F%3E..%2Fboard%2FSiul2_Port_Ip_Cfg.h%3A47%3A10%3A%20fatal%20error%3A%20Siul2_Port_Ip_Types.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E47%20%7C%20%23include%20%22Siul2_Port_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3E..%2Fsrc%2Fsample.c%3A24%3A10%3A%20fatal%20error%3A%20ipcf_Ip_Cfg.h%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3E24%20%7C%20%23include%20%22ipcf_Ip_Cfg.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~%3CBR%20%2F%3EIn%20file%20included%20from%20..%2Fgenerate%2Fsrc%2FOsIf_Cfg.c%3A44%3A%3CBR%20%2F%3ED%3A%2Fnxp%2FS32DS.3.5%2FS32DS%2Fsoftware%2FPlatformSDK_S32XX_2022_03%2FSW32_RTD_4_4_3_0_2_D2203%2FBase_TS_T40D11M30I2R0%2Finclude%2FOsIf_Cfg_TypesDef.h%3A87%3A6%3A%20error%3A%20%23error%20%22Software%20Version%20Numbers%20of%20OsIf_Cfg_TypesDef.h%20and%20OsIf_Cfg.h%20are%20different%22%3CBR%20%2F%3E87%20%7C%20%23error%20%22Software%20Version%20Numbers%20of%20OsIf_Cfg_TypesDef.h%20and%20OsIf_Cfg.h%20are%20different%22%3CBR%20%2F%3E%7C%20%5E~~~~%3CBR%20%2F%3Ecompilation%20terminated.%3CBR%20%2F%3E..%2Fgenerate%2Fsrc%2FOsIf_Cfg.c%3A93%3A6%3A%20error%3A%20%23error%20%22Software%20Version%20Numbers%20of%20OsIf_Cfg.c%20and%20OsIf_Cfg_TypesDef.h%20are%20different%22%3CBR%20%2F%3E93%20%7C%20%23error%20%22Software%20Version%20Numbers%20of%20OsIf_Cfg.c%20and%20OsIf_Cfg_TypesDef.h%20are%20different%22%3CBR%20%2F%3E%7C%20%5E~~~~%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A23%3A%20generate%2Fsrc%2FMpu_M7_Ip_Cfg.o%5D%20Error%201%3CBR%20%2F%3Emake%3A%20***%20Waiting%20for%20unfinished%20jobs....%3CBR%20%2F%3Emake%3A%20***%20%5Bsrc%2Fsubdir.mk%3A23%3A%20src%2Fsample.o%5D%20Error%201%3CBR%20%2F%3Emake%3A%20***%20%5Bboard%2Fsubdir.mk%3A20%3A%20board%2FSiul2_Port_Ip_Cfg.o%5D%20Error%201%3CBR%20%2F%3Emake%3A%20***%20%5Bsrc%2Fsubdir.mk%3A23%3A%20src%2Fmain.o%5D%20Error%201%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A23%3A%20generate%2Fsrc%2FOsIf_Cfg.o%5D%20Error%201%3CBR%20%2F%3E%22make%20-j20%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%3C%2FP%3E%3CP%3E14%3A35%3A26%20Build%20Failed.%2012%20errors%2C%200%20warnings.%20(took%20552ms)%3C%2FP%3E%3CP%3EWhen%20opening%20the%20Peripherals%20configuration%2C%20a%20problem%20occurs%20and%20the%20following%20is%20displayed%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_0-1728542282150.png%22%20style%3D%22width%3A%20792px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_0-1728542282150.png%22%20style%3D%22width%3A%20792px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303944i36935ABDCE8FF15A%2Fimage-dimensions%2F792x298%3Fv%3Dv2%22%20width%3D%22792%22%20height%3D%22298%22%20role%3D%22button%22%20title%3D%22DRAVE_0-1728542282150.png%22%20alt%3D%22DRAVE_0-1728542282150.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDRAVE_0-1728542282150.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThe%20installed%20packages%20are%20as%20follows%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DRAVE_2-1728542432284.png%22%20style%3D%22width%3A%20769px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DRAVE_2-1728542432284.png%22%20style%3D%22width%3A%20769px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303946iAE23DAB68D58E1F3%2Fimage-dimensions%2F769x178%3Fv%3Dv2%22%20width%3D%22769%22%20height%3D%22178%22%20role%3D%22button%22%20title%3D%22DRAVE_2-1728542432284.png%22%20alt%3D%22DRAVE_2-1728542432284.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDRAVE_2-1728542432284.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ECould%20you%20please%20help%20me%20find%20out%20the%20reason%3F%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972444%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20An%20error%20occurs%20when%20compiling%20the%20IPCF_Example_multi_instance_S32G274_M7_0%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972444%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EOk%2C%20I'll%20take%20a%20look%20at%20it%2C%20thank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972050%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20An%20error%20occurs%20when%20compiling%20the%20IPCF_Example_multi_instance_S32G274_M7_0%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972050%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EI'm%20glad%20to%20hear%20that%20your%20problem%20has%20been%20solved.%20There%20is%20no%20document%20similar%20to%20AN13750.pdf%20about%20dual-core%20boot%20of%20S32G3%2C%20and%20there%20is%20no%20plan%20to%20release%20such%20a%20document.%20This%20is%20because%20dual-core%20boot%20is%20already%20included%20in%20GoldVIP%20of%20S32G3.%20I%20think%20AN13750%20is%20still%20of%20some%20reference%20value%20to%20you%20because%20the%20ideas%20are%20the%20same.%20The%20following%20case%20may%20help%20you%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32G%2FS32G399A-RDB3-Multi-core-boot-failed-following-AN13750%2Fm-p%2F1753196%22%20target%3D%22_self%22%3ESolved%3A%20S32G399A-RDB3-Multi-core-boot-failed-following-AN13750%3C%2FA%3E%20.%3C%2FP%3E%0A%3CP%3EBR%2C%3C%2FP%3E%0A%3CP%3ECeleste%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1972006%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20An%20error%20occurs%20when%20compiling%20the%20IPCF_Example_multi_instance_S32G274_M7_0%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1972006%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237877%22%20target%3D%22_blank%22%3E%40Celeste_Liu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIt%20seems%20that%20I%20installed%20an%20extra%20RTD%20package.%20I%20reinstalled%20the%20software%20and%20it%20worked.%20Thank%20you!%20Is%20there%20any%20document%20similar%20to%20AN13750.pdf%20about%20S32G-VNP-RDB3%3F%20That%20is%2C%20can%20I%20achieve%20the%20state%20of%20A%20core%20and%20M%20core%20working%20at%20the%20same%20time%20on%20S32G-VNP-RDB3%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971228%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20An%20error%20occurs%20when%20compiling%20the%20IPCF_Example_multi_instance_S32G274_M7_0%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971228%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211314%22%20target%3D%22_blank%22%3E%40DRAVE%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20question.%20%3CSPAN%3EIt%20seems%20that%20you%20did%20not%20generate%20code%20using%20the%20configuration%20tool%20before%20compiling%20the%20project.%3C%2FSPAN%3E%20Please%20click%20the%20green%20button%20%22Update%20Source%20Code%22%20at%20the%20mark%2C%20it%20will%20add%20the%20missing%20modules%20to%20the%20project%20to%20make%20it%20work%20properly.%20We%20recommend%20importing%20the%20example%20again%20(deleting%20the%20previous%20one)%20and%20generating%20code%20using%20the%20configuration%20tool.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1728551462510.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1728551462510.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303983i5FF7FFB15075442B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1728551462510.png%22%20alt%3D%22Celeste_Liu_0-1728551462510.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECeleste_Liu_0-1728551462510.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3ECeleste%3C%2FP%3E%3C%2FLINGO-BODY%3E
