Adding IPCF functionality to existing S32DS project.
Niranj_369
Hi @Joey_z
We’ve successfully established IPCF communication between the M7 and A53 cores on the S32G3 SoC using the M7 IPCF example provided in the updatesite.
We’ve also developed and tested our own application that currently does not include IPCF functionality. Now, we’re looking to integrate IPCF into this existing program.
We followed the steps shown in the image below, but encountered some "variable not found" errors during integration.
Could you please suggest the correct approach to integrate IPCF functionality into our existing code?
Sarath_Thalacheeru
Hi ,
 May i know how this issue got resolved
I am also facing the same issue once i added the uart module on top of IPCF-FreeRtos i am getting garbage values at A53 and M7 terminal is also not responding
 May i know what all configurations need to modify for ipcf to work along with uart
Joey_z
hi,Niranj_369
Thank you for contacting us.
You can try to add the ipcf Middleware as the following picture, I used the UART demo and added the ipcf module into the application. Then, click the "Update Code" button to add the ipcf code in the project.
Hope this can help you.
Joey
Niranj_369
Thanks @Joey_z
I've integrated IPCF into the LIN code and successfully generated the binary. However, I'm encountering the following issues:
  1. LIN functionality works as expected, but after loading the M7 firmware, the serial terminal displays garbage characters. I'm unable to access the terminal or proceed with booting the A53.
  2. IPCF functionality is not working. I've included the ping-pong logic from the IPCFG example, but it doesn't seem to respond.
Could you please suggest fixes for these issues? I've attached the linker script below for reference.
Note: I have used the correct load address and also verified the lin and IPCF examples seperately.
Joey_z
Hi,Niranj_369
Thank you for your reply.
Do you have only the test for LIN application on multi-core?  is the Lin function normal on multi-core? The clock setting and SetMode in M core may will have the conflict with A core at boot stage.
Joey
Niranj_369
Thanks @Joey_z
1. The lin application runs on one core only. We have parallely booted both the cores and tested the lin functionality successfully.
2.  I have given the IPCF pheripheral configuration below for reference.
Joey_z
hi,Niranj_369
1.You can refer to the IPCF demo for your ipcf setting in your Lin project.
2.Do you have tested the Lin function without IPCF on M + A core boot? You can separately test the two demos on M+A first.
Joey
Niranj_369
Thanks @Joey_z
>>>>> I have tested the IPCF example and lin code seperately with parallel boot(A+M cores) and both them are working fine.
Note: I have used the single instance IPCF example and the corresponding IPCF drivers.
Joey_z
hi,Niranj_369
Could you please share the M core project with me in private ticket? I can help you to check it.
You can post private ticket using this link: https://support.nxp.com
Joey
%3CLINGO-SUB%20id%3D%22lingo-sub-2192960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAdding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192960%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EWe%E2%80%99ve%20successfully%20established%20IPCF%20communication%20between%20the%20M7%20and%20A53%20cores%20on%20the%20S32G3%20SoC%20using%20the%20M7%20IPCF%20example%20provided%20in%20the%20updatesite.%3CBR%20%2F%3EWe%E2%80%99ve%20also%20developed%20and%20tested%20our%20own%20application%20that%20currently%20does%20not%20include%20IPCF%20functionality.%20Now%2C%20we%E2%80%99re%20looking%20to%20integrate%20IPCF%20into%20this%20existing%20program.%3CBR%20%2F%3EWe%20followed%20the%20steps%20shown%20in%20the%20image%20below%2C%20but%20encountered%20some%20%22variable%20not%20found%22%20errors%20during%20integration.%3CBR%20%2F%3ECould%20you%20please%20suggest%20the%20correct%20approach%20to%20integrate%20IPCF%20functionality%20into%20our%20existing%20code%3F%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.jpg%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362567i849C02EC711B9E09%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.jpg%22%20alt%3D%22image.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3CSPAN%3ENiranj_369%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20the%20M%20core%20project%20with%20me%20in%20private%20ticket%3F%20I%20can%20help%20you%20to%20check%20it.%3C%2FP%3E%0A%3CP%3EYou%20can%20post%20private%20ticket%20using%20this%20link%3A%20%3CA%20href%3D%22https%3A%2F%2Fsupport.nxp.com%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsupport.nxp.com%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193959%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EThanks%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EDo%20you%20have%20tested%20the%20Lin%20function%20without%20IPCF%20on%20M%20%2B%20A%20core%20boot%3F%20You%20can%20separately%20test%20the%20two%20demos%20on%20M%2BA%20first%3CBR%20%2F%3E%3C%2FSPAN%3E%26gt%3B%26gt%3B%26gt%3B%26gt%3B%26gt%3B%20I%20have%20tested%20the%20IPCF%20example%20and%20lin%20code%20seperately%20with%20parallel%20boot(A%2BM%20cores)%20and%20both%20them%20are%20working%20fine.%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3ENote%3A%20I%20have%20used%20the%20single%20instance%20IPCF%20example%20and%20the%20corresponding%20IPCF%20drivers.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3CSPAN%3ENiranj_369%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E1.You%20can%20refer%20to%20the%20IPCF%20demo%20for%20your%20ipcf%20setting%20in%20your%20Lin%20project.%3C%2FP%3E%0A%3CP%3E2.Do%20you%20have%20tested%20the%20Lin%20function%20without%20IPCF%20on%20M%20%2B%20A%20core%20boot%3F%20You%20can%20separately%20test%20the%20two%20demos%20on%20M%2BA%20first.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E1.%20The%20lin%20application%20runs%20on%20one%20core%20only.%20We%20have%20parallely%20booted%20both%20the%20cores%20and%20tested%20the%20lin%20functionality%20successfully.%3CBR%20%2F%3E2.%26nbsp%3B%20I%20have%20given%20the%20IPCF%20pheripheral%20configuration%20below%20for%20reference.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Niranj_369_0-1761622815140.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Niranj_369_0-1761622815140.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Niranj_369_0-1761622815140.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362809i565FAF9B5AA36DA5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Niranj_369_0-1761622815140.png%22%20alt%3D%22Niranj_369_0-1761622815140.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ENiranj_369_0-1761622815140.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CSPAN%3ENiranj_369%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EThank%20you%20for%20your%20reply.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EDo%20you%20have%20only%20the%20test%20for%20LIN%20application%20on%20multi-core%3F%26nbsp%3B%20is%20the%20Lin%20function%20normal%20on%20multi-core%3F%20The%20clock%20setting%20and%20SetMode%20in%20M%20core%20may%20will%20have%20the%20conflict%20with%20A%20core%20at%20boot%20stage.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3BBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EJoey%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3C!--%20StartFragment%20%20--%3E%3C%2FP%3E%3CP%3EThanks%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236188%22%20target%3D%22_blank%22%3E%40Joey_z%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EI've%20integrated%20IPCF%20into%20the%20LIN%20code%20and%20successfully%20generated%20the%20binary.%20However%2C%20I'm%20encountering%20the%20following%20issues%3A%3C%2FP%3E%3COL%3E%3CLI%3ELIN%20functionality%20works%20as%20expected%2C%20but%20after%20loading%20the%20M7%20firmware%2C%20the%20serial%20terminal%20displays%20garbage%20characters.%20I'm%20unable%20to%20access%20the%20terminal%20or%20proceed%20with%20booting%20the%20A53.%3C%2FLI%3E%3CLI%3EIPCF%20functionality%20is%20not%20working.%20I've%20included%20the%20ping-pong%20logic%20from%20the%20IPCFG%20example%2C%20but%20it%20doesn't%20seem%20to%20respond.%3C%2FLI%3E%3C%2FOL%3E%3CP%3ECould%20you%20please%20suggest%20fixes%20for%20these%20issues%3F%20I've%20attached%20the%20linker%20script%20below%20for%20reference.%3CBR%20%2F%3ENote%3A%20I%20have%20used%20the%20correct%20load%20address%20and%20also%20verified%20the%20lin%20and%20IPCF%20examples%20seperately.%3C%2FP%3E%3CP%3E%3C!--%20EndFragment%20%20--%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Niranj_369_0-1761588032096.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Niranj_369_0-1761588032096.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Niranj_369_0-1761588032096.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362746iDD577E34673FD970%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Niranj_369_0-1761588032096.png%22%20alt%3D%22Niranj_369_0-1761588032096.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ENiranj_369_0-1761588032096.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3CSPAN%3ENiranj_369%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20us.%3C%2FP%3E%0A%3CP%3EYou%20can%20try%20to%20add%20the%20ipcf%20Middleware%20as%20the%20following%20picture%2C%20I%20used%20the%20UART%20demo%20and%20added%20the%20ipcf%20module%20into%20the%20application.%20Then%2C%20click%20the%20%22Update%20Code%22%20button%20to%20add%20the%20ipcf%20code%20in%20the%20project.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Joey_z_1-1761530408715.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1761530408715.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Joey_z_1-1761530408715.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362582i9051DE31817CA8EF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Joey_z_1-1761530408715.png%22%20alt%3D%22Joey_z_1-1761530408715.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJoey_z_1-1761530408715.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EHope%20this%20can%20help%20you.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EJoey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Adding%20IPCF%20functionality%20to%20existing%20S32DS%20project.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%26nbsp%3BMay%20i%20know%20how%20this%20issue%20got%20resolved%26nbsp%3B%3CBR%20%2F%3EI%20am%20also%20facing%20the%20same%20issue%20once%20i%20added%20the%20uart%20module%20on%20top%20of%20IPCF-FreeRtos%20i%20am%20getting%20garbage%20values%20at%20A53%20and%20M7%20terminal%20is%20also%20not%20responding%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3BMay%20i%20know%20what%20all%20configurations%20need%20to%20modify%20for%20ipcf%20to%20work%20along%20with%20uart%3C%2FP%3E%3C%2FLINGO-BODY%3E
