how to seleck the submodue2 of the flexpwm module using sdk for 5744P
1,152 次查看
wyj122793
how to select the submodule[2]of flexpwm module using sdk for 5744P ?
1,054 次查看
PetrS
submodule is not selected within flexpwm component. In this component you just define configuration parameters, those are then reflected in configuration structures (here flexPWM1_ModuleSetup0, flexPWM1_SignalSetup0) and used later in code to setup submodule using function
FLEXPWM_DRV_SetupPwm(INST_FLEXPWM1, 0U, &flexPWM1_ModuleSetup0, &flexPWM1_SignalSetup0);
The second parameter is submodule number.
BR, Petr
1,054 次查看
wyj122793
Thank you very much!
