change IP address failed
lixu
I am using S32DS working on MPC5748G. And I used LWIP instance in example.
Now I want to use an another IP address. I modified it in PE, generate PE code.  Then I can ping successful but cannot transmit data.
How should I do to solve the problem?
Thanks and best regard,
lixu
