Which Lauterbach Debugger?
6,930 次查看
ankush_s
I've installed the S32 Design Studio for Power Architecture, Version: 1.2.
I've connected S32R274RRUEVB(daughter board only) to PC using USB mini cable.
I am able to build the SPT example projects in SDK but not able to debug those.
I know that for debugging SPT we required Lauterbach Power Debugger but I do not know
Which Lauterbach Power Debugger I have to purchase and from where?
> Power Debug Interface USB 3
> Power Debug PRO
> PowerTrace II LITE
> PowerTrace II
> Power Trace Serial
Please help me with this.
With Regards,
Ankush
6,569 次查看
rweiss
Hi Ankush,
there are several options available depending on your requirements (debug vs. debug and trace).
You can find S32R274 configuration options for debug here and for debug and trace here.
You can purchase tools from our worldwide offices and sales partners.
Reinhard
6,570 次查看
rweiss
Hi Ankush,
Reinhard
6,569 次查看
ankush_s
Thanks for the reply,
Could you please suggest one, which will be helpful for debugging SPT(Signal Processing Toolbox) off S32R274RRU
or is this is the correct one which I can use "LA-3505 PowerDebug PRO Ethernet" for that?
With Regards,
Ankush
6,569 次查看
rweiss
Any of the listed configurations supports debugging the SPT. Your local sales contact will give advice about the best choice for your requirements.
