Using the UCANS32K146 as a UAVCAN Node with PX4
1,948 次查看
maxe
I'm considering to buy a couple of UCANS32K146 to use them as UAVCAN Nodes with PX4. However, before buying them I would like to make sure that everything works as expected and is easy to set up.
I saw this video of Peter van der Perk using the UCANS32K146 with PX4 as a UAVCAN Node for a GPS. The only problem is that the video seems to be completely outdated. I tried following the instructions given in the video and it didn't work at all. I checked out the pr-uavcan-v1_bms_minimal branch and tried building the firmware using `make nxp_rddrone-uavcan146`, but make reports that the build target does not exist. In the video there is also a link to gitbook that - apparently - is supposed to provide details on how to build the software, but the link is broken: https://nxp.gitbook.io/ucans32k146/px-and-uavcan/building-the-px4-firmware. Is there any updated version of that video or gitbook available? Or is there any other ressource that properly explains how to use UCANS32K146 together with PX4?
1,926 次查看
danielmartynek
I believe all the information can be found here:
UCANS32K146: CAN FD development system for Drones, Rovers, and Mobile Robotics
https://www.nxp.com/design/development-boards/automotive-development-platforms/s32k-mcu-platforms/ca...
Get Started with the UCANS32K146
https://www.nxp.com/document/guide/get-started-with-the-ucans32k146:GS-UCANS32K146
gitbook
BR, Daniel
1,927 次查看
danielmartynek
gitbook
BR, Daniel
