Unable to generate code from Processor Expert
3,473 次查看
sushma
I'm facing this issue of unable to generate the Processor expert Code, as project isn't been activated in the Project Panel. Is there any means to activate the project or any means that will solve this issue?
Thank you
5 回复数
3,280 次查看
jiri_kral
Thanks for sharing screenshots. Processor Expert is part of SDK and your project (example) is not based on SDK.
You can use SDK ADC example insdead:
Jiri
3,280 次查看
sushma
 I don't have the following example(attached screenshot) and my purpose is to generate using processor expert. Have to integrate it with other auto generate code. Can you suggest me any solution.
Thank you
3,280 次查看
jiri_kral
Did you update your S32DS installation? https://community.nxp.com/docs/DOC-341068
Even with non-updated S32DS installation you can use ADC example with Older SDK (just scroll more down in example list). The example which you are using is non-SDK example.
Jiri
3,280 次查看
jiri_kral
your screenshots are no more available. Can you please share it again?
Jiri
3,280 次查看
sushma
